SS510B
SS510B
    PINGWEI(平伟)
    SMB(DO-214AA)
SS510B 数据手册
SS510B S . SCHOTTKY BARRIER RECTIFIERS 5 .0AMP .0AMPS FEATURE A) DO-214A B(DO-214A DO-214AA SMB SM .For surface mounted application .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge current capability .High temperature soldering guaranteed: 260℃/10 seconds at terminals. .0 8 3 (2 .1 1 ) .0 7 5 (1 .9 1 ) .1 5 5 (3 .9 4 ) .1 3 0 (3 .3 0 ) .1 8 5 (4 .7 0 ) .1 6 0 (4 .0 6 ) .0 1 2 (0 .3 0 5 ) .0 0 6 (0 .1 5 2 ) .1 0 3 (2 .6 0 ) .0 7 8 (1 .9 8 ) MECHANICAL DATA .0 6 0 ((1 .5 2 ) .0 3 2 (0 .8 0 ) .Terminal: Solder plated .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy (Halogen free) .Polarity: color band denotes cathode .Packaging:12mm tape per EIA STD RS-481 .0 0 8 (0 .2 0 3 ) .0 0 2 (0 .0 5 1 ) .2 1 7 (5 .5 0 ) .1 9 3 (4 .9 ) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TL =90°C SYM BOL SS510B units VRRM VRMS VDC 100 V 70 V 100 V IF(AV) 5.0 A IFSM 120.0 A VF 0.85 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 5.0A DC Maximum DC Reverse Current @TA =25°C at rated DC blocking voltage @TA =100°C Typical Junction Capacitance (Note1) Typical Thermal Resistance (Note2) Storage Temperature Operating Junction Temperature IR CJ R(J A) (JA TSTG TJ Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas. 0.1 10.0 mA 500 pF 55 °C /W -55 to +150 °C -55 to +150 °C RATING AND CHARACTERISTIC CURVES ( SS510B ) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 100 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 5.0 2.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 10 1 .1 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle .2 0.8 .5 1.1 1.4 INSTANEOUS FORWARD VOLTAGE,(V) LEAD TEMPERTURE,(℃) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 1.0 8.3ms Single Half Sine-Wave (JEDEC Method) 120 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 160 80 40 0 1 10 NUMBER OF CYCLES AT 60Hz 100 0.1 TJ=25℃ .01 .001 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) 140 Marking and packaging illustration Marking 1、Marking SYMBOL SS510B A B C B C A XXX Explanation Color Band Denotes Cathode Product Name Date Code Packaging 2、Packaging d Top cover tape thickness 0.10mm(0.004") max.thick W1 Embossed carrier tape °MAX A °MAX Embossed cavity SPECIFICATIONS mm(inch) SYMBOL ITEM PACKAGE A) B(DO-214A (DO-214AA SMB SM Carrier width A 3.81(0.150)Max Carrier length B 5.41(0.213)Max Sprocket hole d ø1.55(0.061)Typ Reel outer diameter D 330.0(13.0)Typ Reel inner diameter D1 50.0(1.969)Min Feed hole diameter D2 13.0(0.512)Typ Sprocket hole position J 1.75(0.069)Typ Punch hole position H 5.55(0.219)Typ Carrier depth K 2.45(0.965)Typ Punch hole pitch P 8.00(0.315)Typ Sprocket hole pitch P0 4.00(0.157)Typ Embossment center P1 2.00(0.079)Typ Overall tape thickness T 0.30(0.012)Typ Tape width W 12.0(0.472)Typ Reel width W1 12.4(0.488)Min
SS510B 价格&库存
很抱歉,暂时无法提供与“SS510B”相匹配的价格&库存,您可以联系我们找货
