DSS22 THRU DSS210
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 100 Volts
Forward Current - 2.0 Ampere
SOD-123FL
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.8± 0.2
1.0±0.2
Cathode Band
Top View
1.3± 0.15
0.10-0.30
2.8±0.2
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS DSS22 DSS23 DSS24 DSS25 DSS26 DSS27 DSS28 DSS29 DSS210
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
D22
D23
D24
D25
D26
D27
D28
D29
D210
21
30
40
28
40
50
35
50
60
42
60
70
49
70
80
56
80
90
63
90
100
70
100
UNITS
I(AV)
2.0
VOLTS
VOLTS
VOLTS
Amp
IFSM
40.0
Amps
VRRM
VRMS
VDC
VF
TJ
TSTG
0.85
Volts
0.5
IR
CJ
RθJA
0.70
0.55
mA
5.0
10.0
180
220
pF
K/W
180
-55 to +125
-55 to +150
C
-55 to +150
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.PCB mounted on 0.2*0.2" (5.0*5.0mm) coppeer pad area.
STAR SEA
1.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.8
DSS22-DSS26
DSS27-DSS210
0.4
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
2.0
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
40
32
24
16
8
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
LEAD TEMPERATURE, C
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
0.1
DSS22-DSS24
DSS25-DSS26
DSS27-DSS210
0.01
0.2
0.4
0.6
0.8
1.0
10
100
NUMBER OF CYCLES AT 60 Hz
1.1
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
CURRENT,AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES DSS22 THRU DSS210
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=100 C
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
DSS22-DSS24
DSS25-DSS210
100
TJ=25 C
10
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
STAR SEA
很抱歉,暂时无法提供与“DSS24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23210
- 200+0.15070
- 1500+0.13090
- 3000+0.11550
- 国内价格
- 20+0.25348
- 200+0.19959
- 600+0.16967
- 3000+0.15174
- 9000+0.13619
- 21000+0.12777
