SYN470R
SYN470R
    SYNOXO
    SOP-16
    SYN470R是一款单芯片ASK/OOK(开关键控)射频接收器IC。该器件是一款真正的“天线输入到数据输出”的单片器件。所有射频和中频调谐均在IC内部自动完成,无需手动调谐,降低了生产成本。其结果是提...
SYN470R 数据手册
SYN470R Datasheet (300-450MHz ASK Receiver) Version 1.0 Contents 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. General Description ................................................................................................................ 1 Features .................................................................................................................................... 1 Applications ............................................................................................................................. 1 Typical Application ................................................................................................................. 2 Ordering Information ............................................................................................................. 2 Pin Configuration .................................................................................................................... 3 8-Pin Options ........................................................................................................................... 3 Pin Description ........................................................................................................................ 4 Absolute Maximum Ratings (Note 1) .................................................................................... 5 Operating Ratings (Note 2) .................................................................................................... 5 Electrical Characteristics ....................................................................................................... 5 Functional Diagram ................................................................................................................ 7 Applications Information and Functional Description ........................................................ 8 13.1. Design Steps .............................................................................................................. 8 13.1.1. Step 1: Selecting the Operating Mode ............................................................... 8 13.1.2. Step 2: Selecting the Reference Oscillator ........................................................ 9 13.1.3. Step 3: Selecting the CTH Capacitor ................................................................ 10 13.1.4. Step 4: Selecting the CAGC Capacitor .............................................................. 11 13.1.5. Step 5: Selecting the Demod Filter Bandwidth ............................................... 12 14. Additional Applications Information .................................................................................. 13 14.1. Antenna Impedance Matching ................................................................................ 13 14.2. Shutdown Function ................................................................................................. 15 14.3. Power Supply Bypass Capacitors ............................................................................ 16 14.4. Increasing Selectivity with an Optional BandPass Filter ........................................ 16 14.5. Data Squelching ...................................................................................................... 16 14.6. Wake-Up Function .................................................................................................. 16 15. Applications Example ........................................................................................................... 18 15.1. 315MHz Receiver/Decoder Application ................................................................. 18 16. Package Information............................................................................................................. 19 SYN470R/SYN480R 1. General Description The SYN470R is a single chip ASK/OOK (ON-OFF Keyed) RF receiver IC. This device is a true “antenna-in to data-out” monolithic device. All RF and IF tuning are accomplished automatically within the IC which eliminates manual tuning and reduces production costs. The result is a highly reliable yet low cost solution. The SYN470R is a fully featured part in 16-pin packaging, the SYN480R is the same part packaged in 8-pin packaging with a reduced feature set. The SYN470R provides two additional functions, (1) a Shutdown pin, which may be used to turn the device off for duty-cycled operation, and (2) a “Wake-up” output, which provides an output flag indicating when an RF signal is present. These features make the SYN470R ideal for low and ultra-low power applications, such as RKE and remote controls. All IF filtering and post-detection (demodulator) data filtering is provided within the SYN470R, so no external filters are necessary. One of four demodulator filter bandwidths may be selected externally by the user. The SYN470R offer two modes of operation; fixed-mode (FIX) and sweep-mode (SWP). In fixed mode the SYN470R functions as a conventional super-heterodyne receiver. In sweep mode the SYN470R sweeps a wider RF spectrum. Fixed-mode provides better selectivity and sensitivity performance and sweep mode enables the SYN470R to be used with low cost, imprecise transmitters. 2. Features        300MHz to 440MHz frequency range High receiver sensitivity: -106dBm (315MHz), -107dBm (433MHz) Data-rate up to 10kbps (fixed-mode) Low Power Consumption  2.5mA fully operational (315MHz)  0.9µA in shutdown  250µA in polled operation (10:1 duty-cycle) Wake-up output flag to enable decoders and microprocessors Very low RF re-radiation at the antenna Highly integrated with extremely low external part count 3. Applications     Automotive Remote Keyless Entry (RKE) Remote controls Remote fan and light control Garage door and gate openers *This specification is subject to change without notification. -1- SYN470R/SYN480R 4. Typical Application 315MHz 800bps On-Off Keyed Receiver 5. Ordering Information Part Number Demodulator Bandwidth Operating Mode Shut Down WAKEB Output Flag Package SYN470R User Programmable Fixed or Sweep Yes Yes 16-Pin SOP SYN480R-SW48 5000Hz Sweep No Yes 8-Pin SOP SYN480R-FS12 1250Hz Fixed Yes No 8-Pin SOP SYN480R-FS24 2500Hz Fixed Yes No 8-Pin SOP SYN480R-FS48 5000Hz Fixed Yes No 8-Pin SOP *This specification is subject to change without notification. -2- SYN470R/SYN480R 6. Pin Configuration SEL0 SWEN VSSRF REFOSC VSSRF SEL1 ANT VSSRF CAGC VDDRF WAKEB VDDBB SHUT CTH REFOSC CAGC ANT VDDRF SHUT/WAKEB CTH DO DO NC VSSBB Standard 16-Pin or 8-Pin SOP (M) Packages 7. 8-Pin Options The standard 16-pin package allows complete control of all configurable features. Some reduced function 8-pin versions are also available. For high-volume applications additional customized 8-pin devices can be produced. SWEN, SEL0 and SEL1 pins are internally bonded to reduce the pin count. Pin 6 may be configured as either SHUT or WAKEB. SEL0 SEL1 1 Demodulator Bandwidth Sweep Mode Fixed Mode 1 5000 Hz 10000Hz 0 1 2500 Hz 5000Hz 1 0 1250 Hz 2500 Hz 0 0 625 Hz 1250 Hz Table 1. Nominal Demodulator Filter Bandwidth vs. SEL0, SEL1 and Operating Mode *This specification is subject to change without notification. -3- SYN470R/SYN480R 8. Pin Description Pin Number 16-Pin Pkg. Pin Number 8-Pin Pkg. 1 Pin Name Pin Function SEL0 Bandwidth Selection Bit 0 (Digital Input): Used in conjunction with SEL1 to set the desired demodulator filter bandwidth. See Table 1. Internally pulled-up to VDDRF 2, 3 1 VSSRF 4 2 ANT 5 3 VDDRF 6 7 4 RF Power Supply: Ground return to the RF section power supply. Antenna (Analog Input): For optimal performance the ANT pin should be impedance matched to the antenna. See “Applications Information” for information on input impedance and matching techniques RF Power Supply: Positive supply input for the RF section of the IC VDDBB Base-Band Power Supply: Positive supply input for the baseband section (digital section) of the IC CTH Data Slicing Threshold Capacitor (Analog I/O): Capacitor connected to this pin extracts the dc average value from the demodulated waveform which becomes the reference for the internal data slicing comparator 8 NC 9 VSSBB Not internally connected Base-Band Power Supply: Ground return to the baseband section power supply 10 5 DO 11 6 SHUT Shutdown (Digital Input): Shutdown-mode logic-level control input. Pull low to enable the receiver. Internally pulled-up to VDDRF WAKEB Wakeup (Digital Output): Active-low output that indicates detection of an incoming RF signal CAGC Automatic Gain Control (Analog I/O): Connect an external capacitor to set the attack/decay rate of the on-chip automatic gain control SEL1 Bandwidth Selection Bit 1 (Digital Input): Used in conjunction with SEL0 to set the desired demodulator filter bandwidth. See Table 1. Internally pulled-up to VDDRF 12 13 7 14 15 16 8 REFOSC SWEN Data Output (Digital Output) Reference Oscillator: Timing reference, sets the RF receive frequency. Sweep-Mode Enable (Digital Input): Sweep- or Fixed-mode operation control input. SWEN high = sweep mode; SWEN low = conventional superheterodyne receiver. Internally pulled-up to VDDRF *This specification is subject to change without notification. -4- SYN470R/SYN480R 9. Absolute Maximum Ratings (Note 1) +7V Supply Voltage (VDDRF, VDDBB) Input/Output Voltage (VI/O) VSS–0.3 to VDD+0.3 Junction Temperature (TJ) +150°C Storage Temperature Range (TS) –65°C to +150°C Lead Temperature (soldering, 10 sec.) +260°C ESD Rating Note 3 10. Operating Ratings (Note 2) 300MHz to 440MHz RF Frequency Range Supply Voltage (VDDRF, VDDBB, 300~370MHz) +3.0V to +5.5V Supply Voltage (VDDRF, VDDBB, 370~440MHz) +3.3V to +5.5V 20% to 80% Data Duty-Cycle Reference Oscillator Input Range 0.1VPP to 1.5VPP Ambient Temperature (TA) –30°C to +85°C 11. Electrical Characteristics VDDRF = VDDBB = VDD where +4.75V ≤ VDD ≤ 5.5V, VSS = 0V; CAGC = 4.7µF, CTH = 100nF; SEL0 = SEL1 = VSS; fixed mode (SWEN = VSS); fREFOSC = 4.8970MHz (equivalent to fRF = 315MHz); data-rate = 1kbps (Manchester encoded). TA = 25°C, bold values indicate –40°C ≤ TA ≤ +85°C; current flow into device pins is positive; unless noted. Symbol IOP ISTBY Parameter Operating Current Standby Current Condition Min Typ Max Units continuous operation, fRF = 315MHz 2.5 polled with 10:1 duty cycle, fRF = 315MHz 250 continuous operation, fRF = 433.92MHz 3.9 polled with 10:1 duty cycle, fRF = 433.92MHz 390 µA VSHUT = VDD 0.9 µA *This specification is subject to change without notification. 3 mA µA 4.5 mA -5- SYN470R/SYN480R RF Section, IF Section Receiver Sensitivity (Note 4) fRF = 315MHz –106 dBm fRF = 433.92MHz –107 dBm fIF IF Center Frequency Note 6 0.86 MHz fBW IF Bandwidth Note 6 0.43 MHz Maximum Receiver Input RSC = 50Ω –20 dBm Spurious Reverse Isolation ANT pin, RSC = 50Ω, Note 5 30 µVrms AGC Attack to Decay Ratio tATTACK ÷ tDECAY 0.1 AGC Leakage Current TA = +85°C ±100 nA Note 8 290 kΩ 5.2 uA Reference Oscillator ZREFOSC Reference Oscillator Input Impedance Reference Oscillator Source Current Demodulator ZCTH IZCTH(leak) CTH Source Impedance Note 7 145 kΩ CTH Leakage Current TA = +85°C ±100 nA Demodulator Filter Bandwidth VSEL0 = VDD. VSEL1= VDD 4000 Hz Sweep Mode VSEL0 = VSS. VSEL1= VDD 2000 Hz (SWEN = VDD or OPEN) VSEL0 = VDD. VSEL1= VSS 1000 Hz Note 6 VSEL0 = VSS. VSEL1= VSS 500 Hz VSEL0 = VDD. VSEL1= VDD 8000 Hz VSEL0 = VSS. VSEL1= VDD 4000 Hz VSEL0 = VDD. VSEL1= VSS 2000 Hz VSEL0 = VSS. VSEL1= VSS 1000 Hz Demodulator Filter Bandwidth Fixed Mode (SWEN = VSS ) Note 6 Digital/Control Section VIN(high) Input-High Voltage SEL0, SEL1, SWEN VIN(low) Input-Low Voltage SEL0, SEL1, SWEN Output Current DO, WAKEB pins, push-pull VOUT(high) Output High Voltage DO, WAKEB pins, IOUT = –1µA VOUT(low) Output Low Voltage DO, WAKEB pins, IOUT = +1µA IOUT tR, tF Output Rise and Fall Times DO, WAKEB pins, CLOAD = 15pF 0.8 0.2 VDD VDD 10 µA 0.9 VDD 0.1 10 VDD µs Note 1: Exceeding the absolute maximum rating may damage the device. Note 2: The device is not guaranteed to function outside its operating rating. Note 3: Devices are ESD sensitive, use appropriate ESD precautions. Meets class 1 ESD test *This specification is subject to change without notification. -6- SYN470R/SYN480R Note Note Note Note Note requirements, (human body model HBM), in accordance with MIL-STD-883C, method 3015. Do not operate or store near strong electrostatic fields. 4: Sensitivity is defined as the average signal level measured at the input necessary to achieve 10-2 BER (bit error rate). The RF input is assumed to be matched to 50Ω. 5: Spurious reverse isolation represents the spurious components which appear on the RF input pin (ANT) measured into 50Ω with an input RF matching network. 6: Parameter scales linearly with reference oscillator frequency fT. For any reference oscillator frequency other than 4.8970MHz, compute new parameter value as the ratio: fREFOSCMHz × (parameter value at 4.8970MHz) 4.8970MHz 7: Parameter scales inversely with reference oscillator frequency fT. For any reference oscillator frequency other than 4.8970MHz, compute new parameter value as the ratio: 4.8970MHz × (parameter value at 4.8970MHz) fREFOSCMHz 8: Series resistance of the resonator (ceramic resonator or crystal) should be minimized to the extent possible. In cases where the resonator series resistance is too great, the oscillator may oscillate at a diminished peak-to-peak level, or may fail to oscillate entirely. Synoxo recommends that series resistances for ceramic resonators and crystals not exceed 50Ohms and 100Ohms respectively. 12. Functional Diagram Figure 1. SYN470R Block Diagram *This specification is subject to change without notification. -7- SYN470R/SYN480R 13. Applications Information and Functional Description Refer to figure 1 “SYN470R Block Diagram”. Identified in the block diagram are the four sections of the IC: UHF Downconverter, OOK Demodulator, Reference and Control, and Wakeup. Also shown in the figure are two capacitors (CTH, CAGC) and one timing component, usually a crystal or ceramic resonator. With the exception of a supply decoupling capacitor, and antenna impedance matching network, these are the only external components needed by the SYN470R to assemble a complete UHF receiver. For optimal performance is highly recommended that the SYN470R is impedance matched to the antenna, the matching network will add an additional two or three components. Four control inputs are shown in the block diagram: SEL0, SEL1, SWEN, and SHUT. Using these logic inputs, the user can control the operating mode and selectable features of the IC. These inputs are CMOS compatible, and are internally pulled-up. IF Bandpass Filter Roll-off response of the IF Filter is 5th order, while the demodulator data filter exhibits a 2nd order response. 13.1. Design Steps The following steps are the basic design steps for using the SYN470R receiver: 1) Select the operating mode (sweep or fixed) 2) Select the reference oscillator 3) Select the CTH capacitor 4) Select the CAGC capacitor 5) Select the demodulator filter bandwidth 13.1.1. Step 1: Selecting the Operating Mode 13.1.1.1. Fixed-Mode Operation For applications where the transmit frequency is accurately set (that is, applications where a SAW or crystal-based transmitter is used) the SYN470R may be configured as a standard superheterodyne receiver (fixed mode). In fixed-mode operation the RF bandwidth is narrower making the receiver less susceptible to interfering signals. Fixed mode is selected by connecting SWEN to ground. 13.1.1.2. Sweep-Mode Operation When used in conjunction with low-cost L-C transmitters the SYN470R should be configured in sweep-mode. In sweep-mode, while the topology is still superheterodyne, the LO (local oscillator) is swept over a range of frequencies at rates greater than the data rate. This technique effectively increases the RF bandwidth of the SYN470R, allowing the device to operate in applications where significant transmitter-receiver frequency misalignment may exist. The transmit frequency may vary up to ±0.5% over initial tolerance, aging, and temperature. In sweep-mode a band approximately 1.5% around the nominal transmit frequency is captured. The transmitter may drift *This specification is subject to change without notification. -8- SYN470R/SYN480R up to ±0.5% without the need to retune the receiver and without impacting system performance. The swept-LO technique does not affect the IF bandwidth, therefore noise performance is not degraded relative to fixed mode. The IF bandwidth is 430kHz whether the device is operating in fixed or sweep-mode. Due to limitations imposed by the LO sweeping process, the upper limit on data rate in sweep mode is approximately 5.0kbps. Similar performance is not currently available with crystal-based superheterodyne receivers which can operate only with SAW- or crystal-based transmitters. In sweep-mode, a range reduction will occur in installations where there is a strong interferer in the swept RF band. This is because the process indiscriminately includes all signals within the sweep range. An SYN470R may be used in place of a superregenerative receiver in most applications. 13.1.2. Step 2: Selecting the Reference Oscillator All timing and tuning operations on the SYN470R are derived from the internal Colpitts reference oscillator. Timing and tuning is controlled through the REFOSC pin in one of three ways: 1) Connect a ceramic resonator 2) Connect a crystal 3) Drive this pin with an external timing signal The specific reference frequency required is related to the system transmit frequency and to the operating mode of the receiver as set by the SWEN pin. 13.1.1.3. Crystal or Ceramic Resonator Selection Do not use resonators with integral capacitors since capacitors are included in the IC, also care should be taken to ensure low ESR capacitors are selected. If operating in fixed-mode, a crystal is recommended. In sweep-mode either a crystal or ceramic resonator may be used. When a crystal of ceramic resonator is used the minimum voltage is 300mVPP. If using an externally applied signal it should be AC-coupled and limited to the operating range of 0.1VPP to 1.5VPP. 13.1.1.4. Selecting Reference Oscillator Frequency fT (Fixed Mode) As with any superheterodyne receiver, the mixing between the internal LO (local oscillator) frequency fLO and the incoming transmit frequency fTX ideally must equal the IF center frequency. Equation 1 may be used to compute the appropriate fLO for a given fTX: (1) fLO =fTX ±(0.86 fTX ) 315 Frequencies fTX and fLO are in MHz. Note that two values of fLO exist for any given fTX, distinguished as “high-side mixing” and “low-side mixing.” High-side mixing results in an image frequency above the frequency of interest and low-side mixing results in a frequency below. *This specification is subject to change without notification. -9- SYN470R/SYN480R After choosing one of the two acceptable values of fLO, use Equation 2 to compute the reference oscillator frequency fT: FLO (2) fT = 64.5 Frequency fT is in MHz. Connect a crystal of frequency fT to REFOSC on the SYN470R. Four-decimal-place accuracy on the frequency is generally adequate. The following table identifies fT for some common transmit frequencies when the SYN470R is operated in fixed mode. Transmit Frequency (fTX) Reference Oscillator Frequency (fT) 315MHz 4.8970 MHz 390 MHz 6.0630 MHz 418 MHz 6.4983 MHz 433.92 MHz 6.7458 MHz Table 2. Fixed Mode Recommended Reference Oscillator Values For Typical Transmit Frequencies (high-side mixing) 13.1.1.5. Selecting REFOSC Frequency fT (Sweep Mode) Selection of the reference oscillator frequency fT in sweep mode is much simpler than in fixed mode due to the LO sweeping process. Also, accuracy requirements of the frequency reference component are significantly relaxed. In sweep mode, fT is given by Equation 3: (3) fT = FLO 64.25 In SWEEP mode a reference oscillator with frequency accurate to two-decimal-places is generally adequate. A crystal may be used and may be necessary in some cases if the transmit frequency is particularly imprecise. Transmit Frequency (fTX) Reference Oscillator Frequency (fT) 315MHz 4.88 MHz 390 MHz 6.05 MHz 418 MHz 6.48 MHz 433.92 MHz 6.73 MHz Table 3. Recommended Reference Oscillator Values For Typical Transmit Frequencies (sweep-mode) 13.1.3. Step 3: Selecting the CTH Capacitor Extraction of the dc value of the demodulated signal for purposes of logic-level data slicing is accomplished using the external threshold capacitor CTH and the on-chip switched-capacitor “resistor” RSC, shown in the block diagram. Slicing level time constant values vary somewhat with decoder type, data pattern, and data rate, *This specification is subject to change without notification. - 10 - SYN470R/SYN480R but typically values range from 5ms to 50ms. Optimization of the value of CTH is required to maximize range. 13.1.1.6. Selecting Capacitor CTH The first step in the process is selection of a data-slicing-level time constant. This selection is strongly dependent on system issues including system decode response time and data code structure (that is, existence of data preamble, etc.). This issue is covered in more detail in Application Note 22. The effective resistance of RSC is listed in the electrical characteristics table as 145kΩ at 315MHz, this value scales linearly with frequency. Source impedance of the CTH pin at other frequencies is given by equation (4), where fT is in MHz: (4) RSC =145kΩ 4.8970 fT τ of 5x the bit-rate is recommended. Assuming that a slicing level time constant τ has been established, capacitor CTH may be computed using equation (5) CTH = τ RSC A standard ±20% X7R ceramic capacitor is generally sufficient. 13.1.4. Step 4: Selecting the CAGC Capacitor The signal path has AGC (automatic gain control) to increase input dynamic range. The attack time constant of the AGC is set externally by the value of the CAGC capacitor connected to the CAGC pin of the device. To maximize system range, it is important to keep the AGC control voltage ripple low, preferably under 10mVpp once the control voltage has attained its quiescent value. For this reason capacitor values of at least 0.47µF are recommended. The AGC control voltage is carefully managed on-chip to allow duty-cycle operation of the SYN470R. When the device is placed into shutdown mode (SHUT pin pulled high), the AGC capacitor floats to retain the voltage. When operation is resumed, only the voltage droop due to capacitor leakage must be replenished. A relatively low-leakage capacitor is recommended when the devices are used in duty-cycled operation. To further enhance duty-cycled operation, the AGC push and pull currents are boosted for approximately 10ms immediately after the device is taken out of shutdown. This compensates for AGC capacitor voltage droop and reduces the time to restore the correct AGC voltage. The current is boosted by a factor of 45. 13.1.1.7. Selecting CAGC Capacitor in Continuous Mode A CAGC capacitor in the range of 0.47µF to 4.7µF is typically recommended. The value of the CAGC should be selected to minimize the ripple on the AGC control voltage by using a sufficiently *This specification is subject to change without notification. - 11 - SYN470R/SYN480R large capacitor. However if the capacitor is too large the AGC may react too slowly to incoming signals. AGC settling time from a completely discharged (zero-volt) state is given approximately by Equation 6: (6) ∆t = 1.333CAGC − 0.44 Where: CAGC is in µF, and ∆t is in seconds. 13.1.1.8. Selecting CAGC Capacitor in Duty-Cycle Mode Voltage droop across the CAGC capacitor during shutdown should be replenished as quickly as possible after the IC is enabled. As mentioned above, the SYN470R boosts the push-pull current by a factor of 45 immediately after start-up. This fixed time period is based on the reference oscillator frequency fT. The time is 10.9ms for fT = 6.00MHz, and varies inversely with fT. The value of CAGC capacitor and the duration of the shutdown time period should be selected such that the droop can be replenished within this 10ms period. Polarity of the droop is unknown, meaning the AGC voltage could droop up or down. Worst-case from a recovery standpoint is downward droop, since the AGC pull-up current is 1/10th magnitude of the pulldown current. The downward droop is replenished according to the Equation 7: (7) I CAGC = ∆V ∆t Where: I = AGC pullup current for the initial 10ms (67.5µA) CAGC = AGC capacitor value ∆t = droop recovery time ∆V = droop voltage For example, if user desires ∆t = 10ms and chooses a 4.7µF CAGC, then the allowable droop is about 144mV. Using the same equation with 200nA worst case pin leakage and assuming 1µA of capacitor leakage in the same direction, the maximum allowable ∆t (shutdown time) is about 0.56s for droop recovery in 10ms. The ratio of decay-to-attack time-constant is fixed at 10:1 (that is, the attack time constant is 1/10th of the decay time constant). Generally the design value of 10:1 is adequate for the vast majority of applications. If adjustment is required the constant may be varied by adding a resistor in parallel with the CAGC capacitor. The value of the resistor must be determined on a case by case basis. 13.1.5. Step 5: Selecting the Demod Filter Bandwidth The inputs SEL0 and SEL1 control the demodulator filter bandwidth in four binary steps (625Hz to 5000Hz in sweep, 1250Hz to 10000Hz in fixed mode), see Table 1. Bandwidth must be selected according to the application. The demodulator bandwidth should be set according to equation 8. (8) Demodulator bandwidth = 0.65 / Shortest pulse-width It should be noted that the values indicated in table 1 are nominal values. The filter bandwidth *This specification is subject to change without notification. - 12 - SYN470R/SYN480R scales linearly with frequency so the exact value will depend on the operating frequency. Refer to the “Electrical Characteristics” for the exact filter bandwidth at a chosen frequency. SEL0 SEL1 1 Demodulator Bandwidth Sweep Mode Fixed Mode 1 5000Hz 10000 Hz 0 1 2500 Hz 5000 Hz 1 0 1250 Hz 2500 Hz 0 0 625 Hz 1250 Hz Table 1. Nominal Demodulator Filter Bandwidth vs. SEL0, SEL1 and Operating Mode 14. Additional Applications Information In addition to the basic operation of the SYN470R the following enhancements can be made. In particular it is strongly recommended that the antenna impedance is matched to the input of the IC. 14.1. Antenna Impedance Matching As shown in table 4 the antenna pin input impedance is frequency dependant. The ANT pin can be matched to 50 Ohms with an L-type circuit. That is, a shunt inductor from the RF input to ground and another in series from the RF input to the antenna pin. Inductor values may be different from table depending on PCB material, PCB thickness, ground configuration, and how long the traces are in the layout. Values shown were characterized for a 0.031 thickness, FR4 board, solid ground plane on bottom layer, and very short traces. MuRata *This specification is subject to change without notification. - 13 - SYN470R/SYN480R and Coilcraft wire wound 0603 or 0805 surface mount inductors were tested, however any wire wound inductor with high SRF (self resonance frequency) should do the job. Frequency (MHz) ZIN ( ) Z11 S11 LSHUNT(nH) LSERIES(nH) 300 12-j166 0.803-j0.529 15 72 305 12-j165 0.800-j0.530 15 72 310 12-j163 0.796-j0.536 15 72 315 13-j162 0.791-j0.536 15 72 320 12-j160 0.789-j0.543 15 68 325 12-j157 0.782-j0.550 12 68 330 12-j155 0.778-j0.556 12 68 335 12-j152 0.770-j0.564 12 68 340 11—j150 0.767-j0.572 15 56 345 11-j148 0.762-j0.578 15 56 350 11-j145 0.753-j0.586 12 56 355 11-j143 0.748-j0.592 12 56 360 11-j141 0.742-j0.597 10 56 365 11-j139 0.735-j0.603 10 56 370 10-j137 0.732-j0.612 12 47 375 10-j135 0.725-j0.619 12 47 380 10-j133 0.718-j0.625 10 47 385 10-j131 0.711-j0.631 10 47 390 10-j130 0.707-j0.634 10 43 395 10-j128 0.700-j0.641 10 43 400 10-j126 0.692-j0.647 10 43 405 10-j124 0.684-j0.653 10 39 410 10-j122 0.675-j0.660 10 39 415 10-j120 0.667-j0.667 10 39 420 10-j118 0.658-j0.673 10 36 425 10-j117 0.653-j0.677 10 36 430 10-j115 0.643-j0.684 10 33 435 10-j114 0.638-j0.687 10 33 440 8-j112 0.635-j0.704 8.2 33 Table 4. Input Impedance Versus Frequency *This specification is subject to change without notification. - 14 - SYN470R/SYN480R 14.2. Shutdown Function Duty-cycled operation of the SYN470R (often referred to as polling) is achieved by turning the SYN470R on and off via the SHUT pin. The shutdown function is controlled by a logic state applied to the SHUT pin. When VSHUT is high, the device goes into low-power standby mode. This pin is pulled high internally; it must be externally pulled low to enable the receiver. *This specification is subject to change without notification. - 15 - SYN470R/SYN480R 14.3. Power Supply Bypass Capacitors VDDBB and VDDRF should be connected together directly at the IC pins. Supply bypass capacitors are strongly recommended. They should be connected to VDDBB and VDDRF and should have the shortest possible lead lengths. For best performance, connect VSSRF to VSSBB at the power supply only (that is, keep VSSBB currents from flowing through the VSSRF return path). 14.4. Increasing Selectivity with an Optional BandPass Filter For applications located in high ambient noise environments, a fixed value band-pass network may be connected between the ANT pin and VSSRF to provide additional receive selectivity and input overload protection. A minimum input configuration is included in figure 2a. it provides some filtering and necessary overload protection. 14.5. Data Squelching During quiet periods (no signal) the data output (DO pin) transitions randomly with noise. Most decoders can discriminate between this random noise and actual data but for some system it does present a problem. There are three possible approaches to reducing this output noise: 1) Analog squelch to raise the demodulator threshold 2) Digital squelch to disable the output when data is not present 3) Output filter to filter the (high frequency) noise glitches on the data output pin. The simplest solution is add analog squelch by introducing a small offset, or squelch voltage, on the CTH pin so that noise does not trigger the internal comparator. Usually 20mV to 30mV is sufficient, and may be achieved by connecting a several-megohm resistor from the CTH pin to either VSS or VDD, depending on the desired offset polarity. Since the SYN470R has receiver AGC noise at the internal comparator input is always the same, set by the AGC. The squelch offset requirement does not change as the local noise strength changes from installation to installation. Introducing squelch will reduce sensitivity and also reduce range. Only introduce an amount of offset sufficient to quiet the output. Typical squelch resistor values range from 6.8MΩ to 10MΩ. 14.6. Wake-Up Function The WAKEB output signal can be used to reduce system power consumption by enabling the rest of a system when an RF signal is present. The WAKEB is an output logic signal which goes active low when the IC detects a constant RF carrier. The wake-up function is unavailable when the IC is in shutdown mode. To activate the Wake-Up function, a received constant RF carrier must be present for 128 counts or the internal system clock. The internal system clock is derived from the reference oscillator and is 1/256 the reference oscillator frequency. For example: fT = 6.4MHz fS = fT/256 = 25kHz *This specification is subject to change without notification. - 16 - SYN470R/SYN480R PS = 1/fS = 0.04ms 128 counts x 0.04ms = 5.12ms Where: fT = reference oscillator frequency fS = system clock frequency PS = system clock period The Wake-Up counter will reset immediately after a detected RF carrier drops. The duration of the Wake-Up signal output is then determined by the required wake up time plus an additional RF carrier on time interval to create a wake up pulse output. WAKEB Output Pulse Time = TWAKE + Additional RF Carrier on Time For designers who wish to use the wakeup function while squelching the output, a positive squelching offset voltage must be used. This simply requires that the squelch resistor be connected to a voltage more positive than the quiescent voltage on the CTH pin so that the data output is low in absence of a transmission. *This specification is subject to change without notification. - 17 - SYN470R/SYN480R 15. Applications Example 15.1. 315MHz Receiver/Decoder Application Figure 2a illustrates a typical application for the SYN470R UHF Receiver IC. This receiver operates continuously (not duty cycled) in sweep mode, and features 6-bit address decoding and two output code bits. Operation in this example is at 315MHz, and may be customized by selection of the appropriate frequency reference (Y1), and adjustment of the antenna length. The value of C4 would also change if the optional input filter is used. Changes from the 1kb/s data rate may require a change in the value of R1. A bill of materials accompanies the schematic. Figure 2a. 315MHz, 1kbps On-Off Keyed Receiver/Decoder Item Part Number Manufacturer U1 SYN470R Synoxo UHF Reveiver U2 HT-12D Holtek Logic Decoder CR1 CSA6.00MG Murata 6.00MHz Ceramic Resonator D1 SSF-LX100LID Lumex Red LED R1 Description 68K 1/4W 5% R2 Vishay 1K 1/4W 5% C1 Vishay 4.7uF dipped tantalum capacitor C3 Vishay 4.7uF dipped tantalum capacitor C2 Vishay 2.2uF dipped tantalum capacitor C4 Vishay 8.2pF COG ceramic capacitor Figure 2b. Bill of Material *This specification is subject to change without notification. - 18 - SYN470R/SYN480R 16. Package Information 16-Pin SOP (M) 8-Pin SOP (M) *This specification is subject to change without notification. - 19 -
SYN470R
1. 物料型号:SYN470R和SYN480R是单芯片ASK/OOK (开关键控) RF接收器IC,SYN470R是16脚封装,而SYN480R是8脚封装,具有较少的功能。
2. 器件简介:SYN470R是一个真正的“天线输入到数据输出”的单片设备,自动完成所有RF和IF调谐,无需手动调谐,降低生产成本,提供高可靠性且低成本的解决方案。
3. 引脚分配:文档详细列出了16脚和8脚SOP封装的引脚分配和功能。
4. 参数特性:包括工作电流、待机电流、接收灵敏度、IF中心频率、IF带宽、最大接收器输入、AGC攻击到衰减比率、AGC漏电流等。
5. 功能详解:介绍了SYN470R的工作原理,包括UHF下变频器、OOK解调器、参考和控制、唤醒功能的四个部分。
6. 应用信息:提供了设计步骤、天线阻抗匹配、关机功能、电源旁路电容、增加选择性的可选带通滤波器、数据静噪和唤醒功能等应用信息
7. 封装信息:提供了16脚和8脚SOP封装的详细尺寸信息。
SYN470R 价格&库存
很抱歉,暂时无法提供与“SYN470R”相匹配的价格&库存,您可以联系我们找货
