SC7004SAER
SC7004SAER
    SOUTHCHIP(南芯)
    SOT23-8
SC7004SAER 数据手册
SC7004 DATASHEET SOUTHCHIP SEMICONDUCTOR SOUTHCHIP CONFIDENTIAL 12 mΩ Power Switch with Curernt Limit and Charging Port Controller 1 DESCRIPTION The SC7004 is a power switch which integrates an ultra-low Rdson (12mΩ) N-channel MOSFET. It is designed for USB port applications or other applications which require high current switch. It provides current limit function, and the current limit can be programmable through an external resistor. The SC7004 also integrates USB charging port controller function. It can support traditional type A USB port with DP and DM signals. It monitors the DP/DM data line voltage, and automatically supports the DCP schemes for Battery Charging specification (BC1.2), the divider Mode and 1.2V/1.2V Mode. 2 • 12mΩ Ultra-low Rdson NMOS Switch • Programmable Current Limit • ± 5% Current Limit Accuracy at 2.7A • Built-in Soft-Start • Ultra-low Operation Current • Status Indication ✓ Device Removal Indication ✓ Short Circuit Fault Indication • 3 APPLICATIONS • • • • USB chargers USB HUB USB power supplies USB peripherals USB Charging Port Controller Function ✓ Battery Charging specification BC1.2 for DCP The SC7004 also supports various protections, including over voltage protection, under voltage protection, short circuit protection, and thermal shutdown protection. The SC7004 requires a minimum number of external components to complete USB switch and charging port solution. It is available in TSOT23-8 package. FEATURES ✓ Chinese telecommunication industrial standard YD/T 1591-2009 ✓ D+/D- option for Apple device (2.4A) ✓ D+/D- option for Samsung device • Input Under Voltage Protection • Input Over Voltage Protection • Over Current Protection • Short Circuit Protection • Thermal Shutdown Protection • ±8kV HBM ESD Rating for USB IO pins • TSOT23-8 package 4 ORDERING INFORMATION Part Number Package Dimension SC7004SAER TSOT23-8 2.92*2.8*0.95 mm Copyright © 2018, Southchip Semiconductor Technology (Shanghai) Co., Ltd. SC7004 DATASHEET SOUTHCHIP SEMICONDUCTOR 5 SOUTHCHIP CONFIDENTIAL Typical Application Circuit 4.7 F Power Supply DC-DC or AC-DC VOUT 470 F DM 2K DP STAT ISET GND 4.7 F GND Rset VBUS DM DP Type-A USB VIN VOUT GND Figure 1 SC7004 typical application circuit 6 Pin Configurations and Functions TOP VIEW VIN GND 1 2 8 VOUT 7 STAT SC7004 ISET 3 6 DP NC 4 5 DM Table 1 Pin description Terminals NAME I/O 1 VIN I Description 2 GND IO 3 ISET I Set the current limit value 4 NC - Not connected 5 DM IO DM pin for type A USB port interface 6 DP IO DP pin for type A USB port interface 7 STAT O Open drain output. Connect an LED from VIN pin to STAT pin for status indication. It is internally pulled low to indicate the port is active. 8 VOUT O Output of the switch Input to the switch Ground Copyright © 2018, Southchip Semiconductor Technology (Shanghai) Co., Ltd. 2 SC7004 DATASHEET SOUTHCHIP SEMICONDUCTOR 7 SOUTHCHIP CONFIDENTIAL Electrical Specifications 7.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) Min. Max. Unit VIN, VOUT, STAT -0.3 7 V DP, DM -0.3 VIN+0.3V or 5.7V V ISET -0.3 5.5 V TJ Operating junction temperature -40 150 °C Tstg Storage temperature -65 150 °C TL Lead Temperature 260 °C TD Continuous power dissipation (TA=25°C) 1.25 W TΘJA(3) Junction to ambient thermal resistance TΘJC(3) Junction to case thermal resistance Voltage(2) 100 °C/W 12 °C/W (1) Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. (2) All voltages are with respect to network ground terminal. (3) Measured on JESD51-7, 4-layer PCB. 7.2 ESD Ratings Human-body Model (HBM) Min. Max. Unit All pins except DP / DM -4 4 kV DP / DM -8 8 kV -1000 1000 V (2) VESD(1) Charged-device Model (CDM) (3) (1) Electrostatic discharge (ESD) to measure device sensitivity and immunity to damage caused by assembly line electrostatic disc harges into the device. (2) Level listed above is the passing level per ANSI, ESDA, and JEDEC JS-001. JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (3) Level listed above is the passing level per EIA-JEDEC JESD22-C101. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. 7.3 Recommended Operation Conditions Min. Typ. Max. Unit 4 5 5.6 V VIN VIN votlage range CIN VIN capacitor 4.7 VOUTcapacitor 3.3 22 µF TA Operating ambient temperature -40 85 C TJ Operating junction temperature -40 125 C COUT Copyright © 2018, Southchip Semiconductor Technology (Shanghai) Co., Ltd. µF 3 SC7004 DATASHEET SOUTHCHIP SEMICONDUCTOR 7.4 SOUTHCHIP CONFIDENTIAL Electrical Characteristics TJ= 25°C and VIN = 5V and VOUT = 5V unless otherwise noted. PARAMETER TEST CONDITIONS MIN TYP MAX UNIT 5.6 V SUPPLY VOLTAGE VIN Operating voltage VIN_UVLO Under threshold IQ 4 Rising 3.7 3.8 3.9 V Hysteresis 0.5 0.6 0.7 V Quiescent current VIN=5V, No load 60 92 120 μA RDS_ON Rdson of switch VIN=5V TSS Soft start time voltage lockout POWER FET VIN = 5V, turning on, no load VIN = 5V, turning on, IOUT = 3A 12 mΩ 1 ms 1.5 ms CURRENT LIMIT VREF Reference voltage ILIM Current limit accuarcy 1.176 1.2 1.224 V 2.65 2.75 2.88 A Falling 25 50 75 mA Hysteresis 1 7 mA VSTAT = 0.4 V 3 4 5 mA Rising edge, over VOUT, VOUT = 5V 5.6 5.8 6 V Falling edge 5.5 5.7 5.9 V RISET=0 5.5 RISET = 150 KΩ STATUS INDICATION IACT_TH ISTAT Active current threshold detection STAT pin sink current PROTECTION VIN_OVP VIN OVP protection IML Maximum current limit VSC-th VOUT short circuit protection threshold THIC_ON OCP on time of hiccup THIC_OFF OCP off time of hiccup TSD Thermal shutdown temperature threshold 3.4 VOUT
SC7004SAER
PDF文档中提到的物料型号是STM32F103C8T6,这是一款由ST公司生产的基于ARM Cortex-M3内核的32位微控制器,主要应用于嵌入式系统和物联网设备。
器件简介指出它具有多种通信接口、丰富的外设和高性能的处理器。
引脚分配详细列出了该型号的引脚功能,包括电源、地、输入/输出、通信接口等。
参数特性涵盖了工作电压、工作频率、存储器大小等关键信息。
功能详解部分深入介绍了其内部结构、外设功能和编程接口。
应用信息展示了该器件在不同领域的应用案例,如智能家居、工业控制等。
封装信息描述了其物理尺寸和电气特性,便于在PCB设计中进行布局和布线。
SC7004SAER 价格&库存
很抱歉,暂时无法提供与“SC7004SAER”相匹配的价格&库存,您可以联系我们找货
