MC1403
Low Voltage Reference
A precision band−gap voltage reference designed for critical
instrumentation and D/A converter applications. This unit is designed
to work with D/A converters, up to 12 bits in accuracy, or as a
reference for power supply applications.
• Output Voltage: 2.5 V 25 mV
• Input Voltage Range: 4.5 V to 40 V
• Quiescent Current: 1.2 mA Typical
• Output Current: 10 mA
• Temperature Coefficient: 10 ppm/°C Typical
• Guaranteed Temperature Drift Specification
• Equivalent to AD580
• Standard 8−Pin DIP, and 8−Pin SOIC Package
PRECISION LOW VOLTAGE
REFERENCE
PDIP−8
P1 SUFFIX
CASE 626
8
1
Typical Applications
Voltage Reference for 8 to 12 Bit D/A Converters
Low TC Zener Replacement
High Stability Current Reference
Voltmeter System Reference
Pb−Free Package is Available
SOIC−8
D SUFFIX
CASE 751
8
1
PIN CONNECTIONS
MAXIMUM RATINGS (TA = 25°C, unless otherwise noted.)
Vin 1
8 NC
Symbol
Value
Unit
Vout 2
7 NC
VI
40
V
GND 3
6 NC
Tstg
−65 to 150
°C
NC 4
5 NC
Junction Temperature
TJ
+175
°C
Operating Ambient Temperature Range
MC1403B
MC1403
TA
−40 to +85
0 to + 70
°C
°C
Rating
Input Voltage
Storage Temperature
Maximum ratings are those values beyond which device damage can occur.
Maximum ratings applied to the device are individual stress limit values (not
normal operating conditions) and are not valid simultaneously. If these limits are
exceeded, device functional operation is not implied, damage may occur and
reliability may be affected.
http://www.hgsemi.com.cn
1
ORDERING INFORMATION
See detailed ordering and shipping information in the package
dimensions section on page 6 of this data sheet.
2018 AUG
MC1403
+ 5.0 V
1
MC1403
2 2.5V
Full Scale
Adjust 500
1.0 k
R1
3
R2
Reference
Amplifier
IRef
*0.1 F
C1
Monolithic D/A
Converter
1.2 k
R3
* Caution: System stability may be affected if output capacitance
* exceeds 1.0 F. Using higher capacitance values is not
* recommended and should be carefully considered.
Figure 1. A Reference for Monolithic D/A Converters
Providing the Reference Current
for ON Semiconductor Monolithic D/A Converters
The resistor R3 improves temperature performance by
matching the impedance on both inputs of the D/A reference
amplifier. The capacitor decouples any noise present on the
reference line. It is essential if the D/A converter is located
any appreciable distance from the reference.
A single MC1403 reference can provide the required
current input for up to five of the monolithic D/A converters.
The MC1403 makes an ideal reference for many monolithic D/A converters, requiring a stable current reference of
nominally 2.0 mA. This can be easily obtained from the
MC1403 with the addition of a series resistor, R1. A variable
resistor, R2, is recommended to provide means for full−
scale adjust on the D/A converter.
ELECTRICAL CHARACTERISTICS (Vin = 15 V, TA = 25°C, unless otherwise noted.)
Characteristic
Output Voltage
(IO = 0 mA)
Temperature Coefficient of Output Voltage*
MC1403
Output Voltage Change*
(Over specified temperature range)
MC1403B 0 to + 70°C
MC1403B −40 to + 85°C
Symbol
Min
Typ
Max
Unit
Vout
2.475
2.5
2.525
V
VO/T
10
40
ppm/°C
VO
mV
7.0
12.5
1.2
0.6
4.5
3.0
Line Regulation (IO = 0 mA)
(15 V VI 40 V)
(4.5 V VI 15 V)
Regline
Load Regulation
(0 mA < IO < 10 mA)
Regload
10
mV
IQ
1.2
1.5
mA
Quiescent Current
(IO = 0 mA)
mV
*Guaranteed but not tested.
2
2018 AUG
MC1403
Vin
2.0 k
2.0 k
2.0 k
2.0 k
1.0 k
32
Vout
1.5 k
C1
30 pF
10 k
1.73k
2.37 k
1.483 k
1.0 k
5.61 k
This device contains 15 active transistors.
Figure 2. MC1403, B Schematic
3
2018 AUG
∆Vout , CHANGE IN OUTPUT VOLTAGE (mV)
MC1403
∆ Vout , CHANGE IN Vout (mV)
2.0
1.0
25°C
−1.0
0°C
−2.0
75°C
−3.0
−4.0
−5.0
−6.0
Vin, INPUT VOLTAGE (V)
40
10
9.0
8.0
7.0
6.0
5.0
4.0
75°C
3.0
2.0
0°C
1.0
25°C
2.0
3.0 4.0 5.0 6.0
7.0
Iout, OUTPUT CURRENT (mA)
8.0
9.0
10
Figure 4. Change in Output Voltage
versus Load Current
Figure 3. Typical Change in Vout versus Vin
(Normalized to Vin = 15 V @ TC = 25°C)
(Normalized to Vout @ Vin = 15 V, Iout = 0 mA)
1.20
I1, QUIESCENT CURRENT (mA)
1.25
1.15
1.10
1.05
1.00
0.95
0.90
Iout = 2 mA
Vin = 15 V
−2.0
Vin = 5.0 V
−4.0
−6.0
−8.0
−10
−12
−40 −30 −20 −10
0 10 20 30 40 50
TA, TEMPERATURE (°C)
60 70
−14
−40 −30 −20 −10
80 85
60 70
80 85
Figure 5. Quiescent Current versus Temperature
Figure 6. Change in Vout versus Temperature
(Vin = 15 V, Iout = 0 mA)
(Normalized to Vout @ Vin = 15 V)
4.0
2.0
IO = 0 mA
= 2.0 mA
−2.0
= 8.0 mA
−4.0
= 5.0 mA
−6.0
−8.0
−10
−12
−40 −30 −20 −10
40
50
60 70
80 85
Figure 7. Change in Vout versus Temperature
(Normalized to TA = 25°C, Vin = 15 V, Iout = 0 mA)
4
2018 AUG
MC1403
3−1/2−Digit Voltmeter − Common Anode
Displays, Flashing Overrange
is done by dividing the EOC pulse rate by 2 with 1/2
MC14013B flip−flop and blanking the display using the
blanking input of the MC14543B.
The display uses an LED display with common anode
digit lines driven with an MC14543B decoder and an
MC1413 LED driver. The MC1413 contains 7 Darlington
transistor drivers and resistors to drive the segments of the
display. The digit drive is provided by four MPS−A12
Darlington transistors operating in an emitter−follower
configuration. The MC14543B, MC14013B and LED
displays are referenced to VEE via Pin 13 of the MC14433.
This places the full power supply voltage across the display.
The current for the display may be adjusted by the value of
the segment resistors shown as 150 in Figure 8.
An example of a 3−1/2−digit voltmeter using the
MC14433 is shown in the circuit diagram of Figure 8. The
reference voltage for the system uses an MC1403 2.5 V
reference IC. The full scale potentiometer can calibrate for
a full scale of 199.9 mV or 1.999 V. When switching from
2.0 V to 200 mV operation, RI is also changed, as shown on
the diagram.
When using RC equal to 300 k, the clock frequency for
the system is about 66 kHz. The resulting conversion time
is approximately 250 ms.
When the input is overrange, the display flashes on and
off. The flashing rate is one−half the conversion rate. This
MC1403
20 k
2
−5.0 V
0.1F
+5.0 V
3
0.1F
300 k
RC
11 10
VX
2
MC14433
0.1 F **
13
7
8
0.1 F
4 1
2
3
5
23
22
21
5
6
+5.0 V
0.1 F
12 24
3
1
RI *
+5.0 V
0.1 F
−5.0 V
16 9
6
8
7
6
5
4
3
2
1
10
11
12
13
14
15
7
−5.0 V
9
14
Segment Resistors
150 (7)
MC1413
1
MC14543B
+5.0 V
−5.0 V
−5.0 V
15 19 18 17 16
5.0 V
DS1
DS2
−5.0 V
6
5
DS3
3
DS4
D
C
S
R
10
11
12
13
14
15
16
1
2
Q
Q
51 k
MC14013B
4
+5.0 V
8
Minus Sign
f g e d c b a
200
MPS−A12 Plus Sign
110
Common
Anode
LED
Display
9
D S Q 13
11 C
Q 12
R
14
7 10
* RI = 470 k for 2.0 V Range
RI = 27 k for 200 mV Range
** Mylar Capacitor
50 F
−5.0 V
0.1 F
MPS−A12
(4)
+5.0 V
−5.0 V
Figure 8. 3−1/2−Digit Voltmeter
5
2018 AUG
很抱歉,暂时无法提供与“MC1403M/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.63952
- 50+2.12242
- 150+1.90080
- 500+1.62432
- 2500+1.40778
- 5000+1.33380
- 国内价格
- 1+1.62800
- 100+1.25400
- 1250+1.09120
- 2500+1.02960
