M95FA-03-STDN
M95FA-03-STDN
    QUECTEL(移远)
    M95FA-03-STDN
M95FA-03-STDN 数据手册
Build a Smarter World Quectel M95 Quad-band GSM/GPRS Module l e t l c a e i t u n Q ide f n o C M95 is a highly compact Quad-band GSM/GPRS module in LCC castellation packaging in the market. It adopts the latest MTK chipset and features compact size of 19.9mm × 23.6mm × 2.65mm, ultra low power consumption and extended temperature range. With surface mounted technology, the low profile and small size of LCC package make M95 easily embedded into the lowvolume applications and ensure the reliable connectivity with the applications. This kind of package is ideally suited for large-scale manufacturing which has the strict requirements for cost and efficiency. Built-in unique QuecFOTATM technology allows M95 to update the firmware remotely. Additional features such as integrated TCP/IP protocol stacks, serial multiplexer and enhanced AT commands guarantee fast and reliable transmission of data, voice, SMS via GSM/GPRS network and extend the functionality of the application at no additional cost. Its compact size and ultra low power consumption makes M95 a very cost effective and feature-rich platform that is quite suitable for a wide range of M2M applications such as VTS, industry PDA, personal tracking, wireless POS, smart metering and many other M2M applications. Key Benefits Highly compact Quad-band GSM/GPRS module Quad-band GPRS Multi-slot Class 12 Extended Temperature Range -40°C to +85°C Highly Compact Size LCC Type Embedded Internet Services Protocols Serial Port PCM Easier soldering process with LCC package Embedded Class-AB amplifier Power consumption as low as 1.3mA Embedded powerful Internet service protocols, multiple Sockets & IP addresses eCall QuecFOTATM Jamming detection DTMF QuecLocator EMAIL US: info@quectel.com VISIT US: www.quectel.com 23.6 mm Quectel M95 Quad-band GSM/GPRS Module 19.9 mm 2.65 mm Frequency Band Enhanced Features Approvals Quad-band: eCall RoHS Compliant 850/ 900/ 1800/ 1900MHz Jamming Detection CE/ GCF/ Vodafone/ UCRF/ ATEX/ Vodafone DTMF (Europe) Audio Play/ Audio Record DoC (Russia) Dual SIM Single Standby FCC/ PTCRB/ IC/ Rogers (North America) Max. 85.6kbps (Uplink & Downlink) QuecFOTATM Anatel (Brazil)) PBCCH QuecCell NCC (Taiwan) QuecLocator ICASA (South Africa) Data GPRS Class 12: Coding Schemes: CS 1, 2, 3. 4 USSD Non-transparent Mode l e t l c a e i t u n Q ide f n o C RIL for Android MUX Electrical & Sensitivity SMS Point-to-point MO and MT SMS Cell Broadcast Text and PDU Mode Output Power: Class 4 (2W @850/ 900MHz) Class 1 (1W @1800/ 1900MHz) Consumption: 1.3mA @DRX=5 Voice Speech Codec Modes: Half Rate (HR) Full Rate (FR) Enhanced Full Rate (EFR) Adaptive Multi-Rate (AMR) Echo Arithmetic: Echo Cancellation Echo Suppression Noise Reduction 1.2mA @DRX=9 Sensitivity: GSM850: -109dBm GSM900: -109dBm DCS1800: -109dBm PCS1900: -109dBm Supply Voltage: 3.3V~4.6V, 4.0V Typ. Software Features Protocols: PPP/ TCP/ UDP/ FTP/ HTTP/ SMTP/ Interfaces (U)SIM Card Interface: × 2, (U)SIM 3.0V/ 1.8V UART: ×2 Analog Audio Channel: SSL/ MUX General Features GPRS Multi-slot Class: 12, 1~12 Configurable GPRS Mobile Station: Class B Extended Temperature: -40°C ~ +85°C × 2 (Embedded Class-AB Amplifier in One Dimensions: 19.9mm × 23.6mm × 2.65mm Channel) LCC Package PCM Weight: Approx. 3.0g RTC Backup GSM 07.07, 07.05 and other Enhanced AT Antenna Pad Commands Copyright © 2017 Quectel Wireless Solutions Co., Ltd. All Rights Reserved http://www.quectel.com HQ address: Office 501, Building 13, No.99, Tianzhou Road, Shanghai, China 200233 Tel: +86 21 51086236 Fax: +86 21 54453668 Email: info@quectel.com
M95FA-03-STDN 价格&库存
很抱歉,暂时无法提供与“M95FA-03-STDN”相匹配的价格&库存,您可以联系我们找货
