SD8910
SD8910
    SHOUDING(首鼎)
    SOT23-6
    SD8910是一款高效率的同步降压DC/DC转换器,支持4.5V到21V的宽输入电压范围,最大输出电流为2A,固定开关频率为600KHz。该器件具有内部补偿功能和低导通电阻的集成MOSFET,提供多种...
SD8910 数据手册
Shouding SD8910 2A , 21V 600KHz Synchronous Step-Down DC/DC Converter 85T Description Features The SD8910 is a synchronous step -down DC/DC converter that provides wide 4.5V to 21V input voltage range and 2A continuous load current capability.  High Efficiency up to 94%  Low Rds(on) Integrated Power MOSFET  Internal Compensation Function  Wide Input Voltage Range: 4.5V to 21V  Adjustable Output Voltage from 0.8V to 17.85V  2A Output Current  Fixed 600KHz Switching Frequency  Current Mode Operation  Cycle-by-Cycle Current Limit  Over-Temperature Protection with Auto Recovery  Output Overvoltage Protection  Under Voltage Lockout 
SD8910 价格&库存
很抱歉,暂时无法提供与“SD8910”相匹配的价格&库存,您可以联系我们找货
