ES1JD
ES1JD
    ST(先科)
    SMA(DO-214AC)
    耐压:600V 电流:1A 反向恢复时间:35ns
ES1JD 数据手册
ES1AD THRU ES1MD Surface Mount Superfast Recovery Rectifier Reverse Voltage - 50 to 1000 V Forward Current - 1 A Features • Glass passivated junction • Plastic package has Underwriters Laboratories Flammability Classification 94V-0 • Easy pick and place • For surface mounted applications • Low profile package • Built-in strain relief • Superfast recovery times for high efficiency Mechanical Data • Case: SMA (DO-214AC), molded plastic • Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 guaranteed • Polarity: Color band denotes cathode end Absolute Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols ES1AD ES1BD ES1CD ES1DD ES1ED ES1GD ES1JD ES1KD ES1MD Units Parameter Marking ES1A ES1B ES1C ES1D ES1E ES1G ES1J ES1K ES1M - Maximum Recurrent Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 800 1000 V Maximum RMS Voltage VRMS 25 70 105 140 210 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 800 1000 V Maximum Average Forward Rectified Current IF(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) IFSM 30 A Maximum Forward Voltage at 1 A VF Maximum Reverse Current at Rated DC Blocking Voltage at TJ = 25℃ at TJ = 125℃ 1 1.3 1.7 V IR 5 50 µA Typical Junction Capacitance at VR = 4 V, f = 1 MHZ CJ 10 pF Typical Reverse Recovery Time at IF = 0.5 A, IR = 1 A, Irr = 0.25 A trr 35 ns RθJL RθJA 35 85 ℃/W - 55 to + 150 ℃ Typical Thermal Resistance Operating Junction and Storage Temperature Range Tj ,Tstg SEMTECH ELECTRONICS LTD. ® Dated : 10/03/2016 JG Rev:01 ES1AD THRU ES1MD SEMTECH ELECTRONICS LTD. ® Dated : 10/03/2016 JG Rev:01
ES1JD 价格&库存
很抱歉,暂时无法提供与“ES1JD”相匹配的价格&库存,您可以联系我们找货
ES1JD
  • 10+0.34312
  • 100+0.26849
  • 300+0.23112
库存:169
