1SMA5913A-1SMA5957A
Silicon Zener Diodes
VZ : 3.3 - 240 Volts
PD : 1.5 Watts
Features
SMA/DO-214AC
Complete Voltage Range 3.3 to 200 Volts
High peak reverse power dissipation
0. 181(4. 60)
0. 161( 4. 10)
High reliability
Low leakage current
0. 108( 2.75)
0. 096( 2. 45)
0. 063(1.60)
0. 051(1.30)
Mechanical Data
Case : SMA (DO-214AC) Molded plastic
Epoxy : UL94V-O rate flame retardant
0. 209( 5. 30)
0. 193( 4.90)
Lead : Lead formed for Surface mount
Polarity : Color band denotes cathode end
Mounting position : Any
0. 012(0.30)
0. 006(0.15)
0.096(2.45)
0.078(2.00)
0. 059(1. 50)
0. 035( 0. 90)
Weight : 0.093 gram
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS
Rating at 25 °C ambient temperature unless otherwise specified
Rating
Symbol
Value
Unit
DC Power Dissipation at T L = 75 °C (Note1)
PD
1.5
Watts
Maximum Forward Voltage at IF = 200 mA
VF
1.5
Volts
Junction Temperature Range
TJ
- 55 to + 150
°C
Storage Temperature Range
Ts
- 55 to + 150
°C
Note :
2
(1) TL = Lead temperature at 5.0 mm ( 0.013 mm thick ) copper land areas.
PD, MAXIMUM DISSIPATION
(WATTS)
Fig. 1 POWER TEMPERATURE DERATING CURVE
1.5
1.2
0.9
0.6
2
copper land areas.
0.3
50
75
100
125
150
175
TL, LEAD TEMPERATURE (°C)
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
1SMA5913A-1SMA5957A
ELECTRICAL CHARACTERISTICS
Rating at = 25 °C ambient temperature unless otherwise specified
Nominal Zener
Voltage
V Z @ I ZT
IZT
(V)
(mA)
TYPE
Z ZT @ I ZT
(Ω )
Maximum Zener
Impedance
Z ZK @ I ZK
(Ω )
IZK
(mA)
Maximum Reverse
Leakage Current
IR @ V R
(V)
(µA)
Maximum DC
Zener Current
IZM
(mA)
1SMA5913A
3.3
113.6
10
500
1.0
100
1.0
454
1SMA5914A
3.6
104.2
9.0
500
1.0
75
1.0
416
1SMA5915A
3.9
96.1
7.5
500
1.0
25
1.0
384
1SMA5916A
4.3
87.2
6.0
500
1.0
5.0
1.0
348
1SMA5917A
4.7
79.8
5.0
500
1.0
5.0
1.5
319
1SMA5918A
5.1
73.5
4.0
500
1.0
5.0
2.0
294
1SMA5919A
5.6
66.9
2.0
250
1.0
5.0
3.0
267
1SMA5920A
6.2
60.5
2.0
200
1.0
5.0
4.0
241
1SMA5921A
6.8
55.1
2.5
200
1.0
50
5.2
220
1SMA5922A
7.5
50.0
3.0
400
0.5
50
6.0
200
1SMA5923A
8.2
45.7
3.5
400
0.5
50
6.5
182
1SMA5924A
9.1
41.2
4.0
500
0.5
50
7.0
164
1SMA5925A
10
37.5
4.5
500
0.25
50
8.0
150
1SMA5926A
11
34.1
5.5
550
0.25
50
8.4
136
1SMA5927A
12
31.2
6.5
550
0.25
1.0
9.1
125
1SMA5928A
13
28.8
7.0
550
0.25
1.0
9.9
115
1SMA5929A
15
25.0
9.0
600
0.25
1.0
11.4
100
1SMA5930A
16
23.4
10
600
0.25
1.0
12.2
93
1SMA5931A
18
20.8
12
650
0.25
1.0
13.7
83
1SMA5932A
14
650
0.25
1.0
15.2
75
1SMA5933A
22
17.0
17.5
650
0.25
1.0
16.7
68
1SMA5934A
24
15.6
19
700
0.25
1.0
18.2
62
1SMA5935A
27
13.9
23
700
0.25
1.0
20.6
55
1SMA5936A
30
12.5
26
750
0.25
1.0
22.8
50
1SMA5937A
33
11.4
33
800
0.25
1.0
25.1
45
1SMA5938A
36
10.4
38
850
0.25
1.0
27.4
41
1SMA5939A
39
9.6
45
900
0.25
1.0
29.7
38
1SMA5940A
43
8.7
53
950
0.25
1.0
32.7
34
1SMA5941A
47
8.0
67
1000
0.25
1.0
35.8
31
1SMA5942A
51
7.3
70
1100
0.25
1.0
38.8
29
1SMA5943A
56
6.7
86
1300
0.25
1.0
42.6
26
1SMA5944A
62
6.0
100
1500
0.25
1.0
47.1
24
1SMA5945A
68
5.5
120
1700
0.25
1.0
51.7
22
1SMA5946A
75
5.0
140
2000
0.25
1.0
56.0
1SMA5947A
82
4.6
160
2500
0.25
1.0
62.2
18
1SMA5948A
91
4.1
200
3000
0.25
1.0
69.2
16
1SMA5949A
100
3.7
250
3100
0.25
1.0
76.0
15
1SMA5950A
110
3.4
300
4000
0.25
1.0
83.6
13
1SMA5951A
120
3.1
380
4500
0.25
1.0
91.2
12
1SMA5952A
130
2.9
450
5000
0.25
1.0
98.8
11
1SMA5953A
150
2.5
600
6000
0.25
1.0
114.0
10
1SMA5954A
160
2.3
700
6500
0.25
1.0
121.6
9.0
1SMA5955A
180
2.1
900
7000
0.25
1.0
136.8
8.0
1SMA5956A
200
1.9
1200
8000
0.25
1.0
152.0
7.0
1SMA5957A
240
1.5
1600
9000
0.25
1.0
182.4
6.0
Note :
( 1 ) Suffix " A " indicates ± 10% tolerance, suffix " B " indicates ± 5.0% tolerance.
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMA
5000/REEL
80000
36X30.6X31
12.00
11.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“1SMA5929A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52305
- 50+0.41937
- 150+0.36753
- 500+0.32865
- 2500+0.26730
- 5000+0.25175
