BZX85B7V5
BZX85B7V5
    LGE(鲁光)
    DO-41(DO-204AL)
BZX85B7V5 数据手册
BZX85B Series Silicon Zener Diodes VZ : 2.4 - 220 Volts PD : 1.3 Watts Features — — — — — DO-41 Complete Voltage Range 2.4 to 220 Volts High peak reverse power dissipation High reliability Low leakage current Pb / RoHS Free .034(0.9) 1.0(25.4) MIN Mechanical Data — — — — — — DIA. .028(0.7) .205(5.2) .165(4.2) Case : DO-41 Molded plastic Epoxy : UL94V-0 rate flame retardant Lead : Axial lead solderable per MIL-STD-202, method 208 guaranteed Polarity : Color band denotes cathode end Mounting position : Any Weight : 0.34 gram .107(2.7) DIA .080(2.0) 1.0(25.4) MIN Dimensions in inches and (millimeters) MAXIMUM RATINGS Rating at 25 °C ambient temperature unless otherwise specified Rating Symbol Value Unit DC Power Dissipation at T L = 50 °C (Note1) PD 1.3 W Maximum Forward Voltage at IF = 200 mA VF 1.2 V RӨJA 130 K/W Junction Temperature Range TJ - 65 to + 200 °C Storage Temperature Range TSTG - 65 to + 200 °C Maximum Thermal Resistance Junction to Ambient Air (Note2) Notes : (1) TL = Lead temperature at 3/8 " (9.5mm) from body (2) Valid provided that leads are kept at ambient temperature at a distance of 10 mm from case. Fig. 1 POWER TEMPERATURE DERATING PD, MAXIMUM DISSIPATION (WATTS) 1.5 L = 3/8" (9.5mm) 1.2 0.9 0.6 0.3 0 ht t p : // Revision:20170701-P1 25 50 75 100 125 150 175 TL, LEAD TEMPERATURE (°C) www.lgesem i .c o m 200 mail:lge@lgesemi.com BZX85B Series Silicon Zener Diodes ELECTRICAL CHARACTERISTICS TYPE (Rating at 25 °C ambient temperature unless otherwise specified) Nominal Zener Maximum Zener Maximum Reverse Maximum DC Voltage IZK Leakage Current IR @ V R Zener Current IZM (mA) VZ @ IZT IZT ZZT @ IZT Impedance ZZK @ IZK (V) (mA) (Ω) (Ω) BZX85B2V4 2.4 80 20 400 1.0 BZX85B2V7 2.7 80 20 400 1.0 BZX85B3V0 3.0 80 20 400 1.0 BZX85B3V3 3.3 80 20 400 1.0 BZX85B3V6 3.6 70 20 500 1.0 BZX85B3V9 3.9 60 15 500 1.0 BZX85B4V3 4.3 50 13 500 1.0 BZX85B4V7 4.7 45 13 500 1.0 BZX85B5V1 5.1 45 10 500 1.0 BZX85B5V6 5.6 45 7.0 400 1.0 BZX85B6V2 6.2 35 4.0 300 1.0 BZX85B6V8 6.8 35 3.5 300 1.0 BZX85B7V5 7.5 35 3.0 200 0.5 BZX85B8V2 8.2 25 5.0 200 0.5 BZX85B9V1 9.1 25 5.0 200 0.5 BZX85B10 10 25 7.0 200 0.5 BZX85B11 11 20 8.0 300 0.5 BZX85B12 12 20 9.0 350 0.5 BZX85B13 13 20 10 400 0.5 BZX85B15 15 15 15 500 0.5 BZX85B16 16 15 15 500 0.5 BZX85B18V 18 15 20 500 0.5 BZX85B19 19 15 20 550 0.5 BZX85B20 20 10 24 600 0.5 BZX85B22 22 10 25 600 0.5 BZX85B24 24 10 25 600 0.5 BZX85B27 27 8.0 30 750 0.25 BZX85B30 30 8.0 30 1000 0.25 BZX85B33 33 8.0 35 1000 0.25 BZX85B36 36 8.0 40 1000 0.25 BZX85B39 39 6.0 50 1000 0.25 BZX85B43 43 6.0 50 1000 0.25 BZX85B47V 47 4.0 90 1500 0.25 BZX85B51 51 4.0 115 1500 0.25 BZX85B56 56 4.0 120 2000 0.25 BZX85B62 62 4.0 125 2000 0.25 BZX85B68 68 4.0 130 2000 0.25 BZX85B75 75 4.0 135 2000 0.25 82 2.7 200 3000 0.25 BZX85B82V BZX85B91 91 2.7 250 3000 0.25 BZX85B100 100 2.7 350 3000 0.25 BZX85B110 110 2.7 450 4000 0.25 BZX85B120 120 2.0 550 4500 0.25 BZX85B130 130 2.0 700 5000 0.25 BZX85B150 150 2.0 1000 6000 0.25 BZX85B160 160 1.5 1100 6500 0.25 BZX85B180 180 1.5 1200 7000 0.25 BZX85B200 200 1.5 1900 9990 0.25 BZX85B220 220 1.5 1500 8000 0.25 Notes : (1) The type number listed have a standard tolerance on the nominal zener voltage of ± 2.0%. (2) " BZX " will be omitted in marking on the diode ht t p : // Revision:20170701-P1 www.lgesem i .c o m (µA) (V) (mA) 150 150 100 40 20 10 3.0 3.0 1.0 1.0 1.0 50 50 50 50 50 50 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.5 2.0 3.0 4.0 4.5 6.2 6.8 7.5 8.2 9.1 10 11 12 13 14 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 130 150 167 410 370 340 320 290 280 250 215 200 190 170 155 140 130 120 105 97 88 79 71 66 62 58 56 52 47 41 36 33 30 28 26 23 21 19 16 15 14 12 10 9.4 8.6 7.8 7.0 6.4 5.8 5.2 4.7 4.5 mail:lge@lgesemi.com
BZX85B7V5 价格&库存
很抱歉,暂时无法提供与“BZX85B7V5”相匹配的价格&库存,您可以联系我们找货
BZX85B7V5
  • 10+0.42190
  • 100+0.33895
  • 300+0.29748
  • 1000+0.26638
  • 5000+0.21557
  • 10000+0.20304
库存:439
