R2500F THRU R5000F
Reverse Voltage - 1200 to 2000 Volts
Forward Current - 0.2 Ampere
HIGH VOLTAGE FAST RECOVERY RECTIFIER
Features
DO-41
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Construction utilizes void-free molded plastic technique
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
DO-15
1.0 (25.4)
MIN.
1.0 (25.4)
MIN.
0.140 (3.6)
0.104(2.6)
DIA.
0.107 (2.7)
0.080 (2.0)
DIA.
250°C/10 seconds,0.375”(9.5mm) lead
length, 5 lbs. (2.3kg) tension
0.300(7.6)
0.230(5.8)
0.205 (5.2)
0.160(4.1)
Mechanical Data
Case : JEDEC DO-41/DO-15 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight :0.012 ounce, 0.33 grams(DO-41)
1.0 (25.4)
MIN.
1.0 (25.4)
MIN.
0.034 (0.86)
0.028 (0.70)
DIA.
0.034 (0.86)
0.028 (0.70)
DIA.
Dimensions in inches and (millimeters)
0.014 ounce, 0.40 grams(DO-15)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Maximum instantaneous forward voltage at 0.2A
TA=25°C
Maximum DC reverse current
at rated DC blocking voltage
TA=100°C
Maximum reverse recovery time (NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
SYMBOLS
MDD
R2500F
MDD
R3000F
MD
R4000F
MDD
R5000F
UNITS
VRRM
VRMS
VDC
2500
1750
2500
3000
2100
3000
4000
2800
4000
5000
3500
5000
V
V
V
I(AV)
0.2
A
IFSM
30.0
A
VF
IR
trr
CJ
RθJA
TJ,TSTG
4.0
5.0
5.0
50.0
500
15.0
50.0
-65 to +150
6.5
V
μA
ns
pF
°C/W
°C
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
R2500F THRU R5000F
FIG. 1- FORWARD CURRENT DERATING CURVE
0.25
0.20
0.15
0.10
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.05
50
75
100
125
150
175
*EAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
0.01
R2500F
R3000F
R4000F-R5000F
0.001
1.0
2.0
3.0
4.0
5.0
5.5
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
2
1,000
100
10
TJ=100 C
1
0.1
0.01
TJ=25 C
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
TJ=25 C
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
1
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“R3000F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27562
- 100+0.22270
- 300+0.19624
- 1000+0.15326
- 5000+0.13738
- 10000+0.12950
- 国内价格
- 20+0.49170
- 100+0.29320
- 500+0.20530
- 1000+0.14660
- 2000+0.13930
- 10000+0.12900
