R3000
R3000
    SUNMATE(森美特)
R3000 数据手册
R1500 - R3000 HIGH VOLTAGE RECTIFIER DIODES VOLTAGE RANGE: 1500 - 3000V CURRENT: 0.2 - 0.5A Features ! High voltage ! High current capability ! Low leakage current ! ! High surge capability Low cost B A C D Mechanical Data ! ! Case: D O - 4 1 Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.34 grams (approx.) Mounting Position: Any Marking: Type Number ! ! ! ! A DO-41 Dim Min Max A 25.40 ¾ B 4.06 5.21 C 0.71 0.864 D 2.00 2.72 All Dimensions in mm Maximum Ratings and Electrical Characteristics @ TA = 25°C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Symbol R1500 R2000 VRRM VRWM VR 1500 2000 3000 V VR(RMS) 1050 1400 2100 V Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage R3000 Unit Average Rectified Output Current IO 500 200 mA IFSM 30 25 A VFM 2.0 — — 3.0 V Peak Reverse Leakage Current at Rated DC Blocking Voltage IRM 5.0 Typical Junction Capacitance (Note 2) Cj 8.0 7.0 pF RqJA 70 117 K/W (Note 1) @ TL = 55°C Non-Repetitive Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Forward Voltage @ IF = 500mA @ IF = 200mA Typical Thermal Resistance Junction to Ambient Tj, TSTG Operating and Storage Temperature Range Notes: mA -65 to +125 °C 1. Valid provided that leads are kept at ambient temperature at a distance of 9.5mm from the case. 2. Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 1 of 2 www.sunmate.tw IF, INSTANTANEOUS FORWARD CURRENT (A) IO, PERCENT OF RATED AVERAGE CURRENT (%) 120 L = Lead Length 100 L = 5mm L = 10mm 80 L = 20mm 60 40 20 2 Copper Area = 5.5mm 0 0 20 40 60 80 100 120 140 160 1.0 R1500 R2000 0.01 0.001 0.6 30 1.4 1.8 2.0 100 24 18 Cj, JUNCTION CAPACITANCE (pF) IFSM, PEAK FWD SURGE CURRENT (A) 1.0 VF, INSTANTANEOUS FWD VOLTAGE (V) Fig. 2 Typical Forward Characteristics TA, AMBIENT TEMPERATURE (ºC) Fig. 1 Current Derating for Various Lead Lengths R1500 R2000 12 R3000 6 8.3ms Single Half Sine-Wave JEDEC Method 0 R3000 0.1 1 10 100 NUMBER OF CYCLES AT 60 Hz Fig. 3 Peak Fwd Surge Current vs # of Cycles @ 60 Hz 2 of 2 10 R1500 - R2000 R3000 1.0 1.0 10 100 VR, REVERSE VOLTAGE (V) Fig. 4 Typical Junction Capacitance 1000 www.sunmate.tw
R3000 价格&库存
很抱歉,暂时无法提供与“R3000”相匹配的价格&库存,您可以联系我们找货
