ESMG500ELL330ME11D
ESMG500ELL330ME11D
    NCC(贵弥功)
ESMG500ELL330ME11D 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS SMG Series Standard, 85℃ SMQ Downsized ・Endurance : 2,000 hours at 85℃ ・Solvent resistant type except 350 to 450Vdc (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant SMG ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +85℃(6.3 to 400Vdc) -25 to +85℃(450Vdc) 6.3 to 450Vdc ±20% (M) 6.3 to 100Vdc I=0.03CV or 4µA, whichever is greater. (at 20℃, 120Hz) 160 to 450Vdc Time After 1minute After 5minute CV CV≦1,000 I=0.1CV+40 max. I=0.03CV+15 max. (after 1 minute) CV>1,000 I=0.04CV+100 max. I=0.02CV+25 max. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V tanδ(Max.) 0.34 0.24 0.20 0.16 0.14 0.12 0.09 0.08 0.20 0.24 0.24 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V Z(-25℃)/Z(+20℃) 5 4 3 2 2 2 2 2 3 6 6 Z(-40℃)/Z(+20℃) 12 10 8 5 4 3 3 3 4 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 85℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3 to 100Vdc 160 to 450Vdc Capacitance change ≦±20% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] φD' φd Sleeve (PET : Black) F±0.5 Code : E F±0.5 ● Terminal 15min. L' Vent (except φ5) 4min. (φ5 to φ10) (φ12.5 to φ18) 5 φD φd 0.5 2.0 F φD' L' 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 18 0.8 7.5 Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E S MG A A A E A A A A A M A A A N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3,100V:101,315V:3B1) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Standard, 85℃ SMGSeries ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 50 63 Cap (µF) 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 22,000 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 100 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 47 100 220 330 470 1,000 2,200 3,300 4,700 6,800 47 100 220 330 470 1,000 2,200 3,300 4,700 1.0 2.2 3.3 4.7 10 22 33 47 100 220 330 470 1,000 2,200 3,300 10 is not solvent resistant. Rated ripple current Case size tanδ (mArms/ φD×L(mm) 85℃, 120Hz) 5 ×11 6.3×11 6.3×11 8 ×11.5 10 ×20 10 ×20 12.5× 20 12.5× 25 16 ×25 16 ×35.5 18 ×40 5 ×11 6.3×11 6.3×11 10 ×12.5 10 ×20 12.5× 20 12.5× 25 16 ×25 16 ×35.5 18 ×35.5 5 ×11 6.3×11 8 ×11.5 8 ×11.5 10 ×16 12.5× 20 12.5× 25 16 ×25 16 ×31.5 18 ×35.5 5 ×11 6.3×11 8 ×11.5 8 ×11.5 10 ×12.5 10 ×20 12.5× 25 16 ×25 16 ×31.5 18 ×35.5 5 ×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 12.5× 20 16 ×25 16 ×35.5 18 ×35.5 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 10 ×20 12.5× 25 16 ×35.5 18 ×35.5 5 ×11 0.34 0.34 0.34 0.34 0.36 0.38 0.40 0.44 0.52 0.62 0.76 0.24 0.24 0.24 0.24 0.26 0.28 0.30 0.34 0.42 0.52 0.20 0.20 0.20 0.20 0.20 0.22 0.24 0.26 0.30 0.38 0.16 0.16 0.16 0.16 0.16 0.16 0.18 0.20 0.22 0.26 0.14 0.14 0.14 0.14 0.14 0.14 0.16 0.18 0.20 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.16 0.09 200 270 320 540 1,000 1,185 1,545 1,915 2,330 2,845 3,320 240 290 350 650 1,070 1,420 1,780 2,220 2,670 3,080 160 260 370 440 785 1,295 1,655 2,090 2,520 2,920 115 190 330 440 545 955 1,540 1,975 2,420 2,880 130 210 385 490 645 1,145 1,785 2,275 2,700 17 28 35 41 60 95 125 155 260 430 585 755 1,340 2,075 2,500 65 Part No. ESMG6R3E□□221ME11D ESMG6R3E□□331MF11D ESMG6R3E□□471MF11D ESMG6R3E□□102MHB5D ESMG6R3E□□222MJ20S ESMG6R3E□□332MJ20S ESMG6R3E□□472MK20S ESMG6R3E□□682MK25S ESMG6R3E□□103ML25S ESMG6R3E□□153MLP1S ESMG6R3E□□223MM40S ESMG100E□□221ME11D ESMG100E□□331MF11D ESMG100E□□471MF11D ESMG100E□□102MJC5S ESMG100E□□222MJ20S ESMG100E□□332MK20S ESMG100E□□472MK25S ESMG100E□□682ML25S ESMG100E□□103MLP1S ESMG100E□□153MMP1S ESMG160E□□101ME11D ESMG160E□□221MF11D ESMG160E□□331MHB5D ESMG160E□□471MHB5D ESMG160E□□102MJ16S ESMG160E□□222MK20S ESMG160E□□332MK25S ESMG160E□□472ML25S ESMG160E□□682MLN3S ESMG160E□□103MMP1S ESMG250E□□470ME11D ESMG250E□□101MF11D ESMG250E□□221MHB5D ESMG250E□□331MHB5D ESMG250E□□471MJC5S ESMG250E□□102MJ20S ESMG250E□□222MK25S ESMG250E□□332ML25S ESMG250E□□472MLN3S ESMG250E□□682MMP1S ESMG350E□□470ME11D ESMG350E□□101MF11D ESMG350E□□221MHB5D ESMG350E□□331MJC5S ESMG350E□□471MJ16S ESMG350E□□102MK20S ESMG350E□□222ML25S ESMG350E□□332MLP1S ESMG350E□□472MMP1S ESMG500E□□1R0ME11D ESMG500E□□2R2ME11D ESMG500E□□3R3ME11D ESMG500E□□4R7ME11D ESMG500E□□100ME11D ESMG500E□□220ME11D ESMG500E□□330ME11D ESMG500E□□470MF11D ESMG500E□□101MHB5D ESMG500E□□221MJC5S ESMG500E□□331MJ16S ESMG500E□□471MJ20S ESMG500E□□102MK25S ESMG500E□□222MLP1S ESMG500E□□332MMP1S ESMG630E□□100ME11D WV (Vdc) 63 100 160 200 250 350 400 450 Cap (µF) 22 33 47 100 220 330 470 1,000 1.0 2.2 3.3 4.7 10 22 33 47 100 220 330 470 1,000 3.3 4.7 10 22 33 47 100 220 330 3.3 4.7 10 22 33 47 100 220 2.2 3.3 4.7 10 22 33 47 100 220 1.0 2.2 3.3 4.7 10 22 33 47 100 1.0 2.2 3.3 4.7 10 22 33 47 2.2 3.3 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 85℃, 120Hz) 5 × 11 6.3 × 11 6.3 × 11 10 × 12.5 10 × 16 10 × 20 12.5 × 20 16 × 25 5 × 11 5 × 11 5 × 11 5 × 11 6.3 × 11 8 × 11.5 8 × 11.5 10 × 12.5 10 × 20 12.5 × 25 12.5 × 25 16 × 25 18 × 40 6.3 × 11 6.3 × 11 10 × 12.5 10 × 20 10 × 20 12.5 × 20 12.5 × 25 16 × 31.5 18 × 35.5 6.3 × 11 8× 11.5 10 × 12.5 10 × 20 10 × 20 12.5 × 20 16 × 25 18 × 35.5 6.3 × 11 8 × 11.5 8 × 11.5 10 × 16 10 × 20 12.5× 20 12.5 × 25 16 × 31.5 18 × 40 6.3 × 11 8 × 11.5 8 × 11.5 10 × 12.5 10 × 20 12.5× 20 16 × 25 16 × 25 18 × 31.5 6.3 × 11 8× 11.5 10 × 12.5 10 × 16 10 × 20 12.5 × 25 16 × 25 16 × 31.5 10 × 12.5 10 × 16 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.09 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 100 140 170 300 490 710 900 1,300 21 30 40 45 75 130 180 230 370 620 760 1,000 1,380 40 48 94 170 205 270 430 760 995 40 55 94 170 205 270 475 810 32 46 55 105 170 230 295 515 825 22 38 46 65 115 185 275 325 530 22 38 54 71 115 205 275 350 32 44 Part No. ESMG630E□□220ME11D ESMG630E□□330MF11D ESMG630E□□470MF11D ESMG630E□□101MJC5S ESMG630E□□221MJ16S ESMG630E□□331MJ20S ESMG630E□□471MK20S ESMG630E□□102ML25S ESMG101E□□1R0ME11D ESMG101E□□2R2ME11D ESMG101E□□3R3ME11D ESMG101E□□4R7ME11D ESMG101E□□100MF11D ESMG101E□□220MHB5D ESMG101E□□330MHB5D ESMG101E□□470MJC5S ESMG101E□□101MJ20S ESMG101E□□221MK25S ESMG101E□□331MK25S ESMG101E□□471ML25S ESMG101E□□102MM40S ESMG161E□□3R3MF11D ESMG161E□□4R7MF11D ESMG161E□□100MJC5S ESMG161E□□220MJ20S ESMG161E□□330MJ20S ESMG161E□□470MK20S ESMG161E□□101MK25S ESMG161E□□221MLN3S ESMG161E□□331MMP1S ESMG201E□□3R3MF11D ESMG201E□□4R7MHB5D ESMG201E□□100MJC5S ESMG201E□□220MJ20S ESMG201E□□330MJ20S ESMG201E□□470MK20S ESMG201E□□101ML25S ESMG201E□□221MMP1S ESMG251E□□2R2MF11D ESMG251E□□3R3MHB5D ESMG251E□□4R7MHB5D ESMG251E□□100MJ16S ESMG251E□□220MJ20S ESMG251E□□330MK20S ESMG251E□□470MK25S ESMG251E□□101MLN3S ESMG251E□□221MM40S ESMG351E□□1R0MF11D ESMG351E□□2R2MHB5D ESMG351E□□3R3MHB5D ESMG351E□□4R7MJC5S ESMG351E□□100MJ20S ESMG351E□□220MK20S ESMG351E□□330ML25S ESMG351E□□470ML25S ESMG351E□□101MMN3S ESMG401E□□1R0MF11D ESMG401E□□2R2MHB5D ESMG401E□□3R3MJC5S ESMG401E□□4R7MJ16S ESMG401E□□100MJ20S ESMG401E□□220MK25S ESMG401E□□330ML25S ESMG401E□□470MLN3S ESMG451E□□2R2MJC5S ESMG451E□□3R3MJ16S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Standard, 85℃ SMGSeries ◆STANDARD RATINGS is not solvent resistant. WV (Vdc) Cap (µF) Rated ripple current Case size tanδ (mArms/ φD×L(mm) 85℃, 120Hz) 450 4.7 10 22 10 × 20 12.5× 20 16 ×25 0.24 0.24 0.24 56 91 165 Part No. ESMG451E□□4R7MJ20S ESMG451E□□100MK20S ESMG451E□□220ML25S WV (Vdc) Cap (µF) 450 33 47 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 85℃, 120Hz) 16 × 31.5 16 × 35.5 0.24 0.24 215 265 Part No. ESMG451E□□330MLN3S ESMG451E□□470MLP1S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) 1.0 10 100 2,200 Frequency(Hz) to 4.7 to 47 to 1,000 to 50 0.65 0.75 0.80 0.85 120 1.00 1.00 1.00 1.00 300 1.35 1.25 1.15 1.03 1k 1.75 1.50 1.30 1.05 10k 2.30 1.75 1.40 1.08 100k 2.50 1.80 1.50 1.08 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
ESMG500ELL330ME11D 价格&库存
很抱歉,暂时无法提供与“ESMG500ELL330ME11D”相匹配的价格&库存,您可以联系我们找货
