SMA59xxA SERIES
Surface Mount Silicon Zener Diodes
Zener Voltage 3.3 ~ 200 V
DO214AC(SMA)
1.5 Watt Power Dissipation
Features
● Glass passivated chip
● Built-in strain relief
● Low inductance
● High peak reverse power dissipation
● Low reverse leakage
● For use in stabilizing and clipping
with high power rating
● RoHS compliant
Mechanical Data
● Case: DO214AC Molded plastic
● Lead: Solderable per MIL-STD-750, method 2026
● Epoxy: UL 94V-0 rate flame retardant
Unit: inch(mm)
● Polarity: Color band denotes cathode end
● Mounting position: Any
Parameter
Symbols
Value
Unit
DC Power dissipation at TL = 75 °C
PD
1.5
W
Maximum forward voltage at if=200mA
VF
1.2
V
Junction temperature range
TJ,TSTG
-55 to +150
Storage temperature range
TJ,TSTG
-55 to +150
(1)
Note:
(1)TL=Lead temperature at 3/8'' (9.5mm)from body
REV.1.1,2017-07
Changzhou zhide Electronics CO.,LTD
www.cz-zhide.com
SMA59xxA SERIES
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
REV.1.1,2017-07
www.cz-zhide.com
SMA59xxA SERIES
Part Number
Device
Marking
Code
Nominal Zener Voltage @IT
Maximum Zener Impedance
IZT(mA)
VZ AVE.(V)
VZ MIN.(V)
VZ MAX.(V)
ZZT MAX.(Ω)
@IZT
ZZK MAX.(Ω)
@IZK
IZK(mA)
10
500.0
1.00
Maximum Reverse
Leakage Current
IR(uA)@V
Maximum
DC Zener
Current
VR(V)
IZM(mA)
100.0
1.0
274.0
R
SMA5913A
913A
3.3
3.14
3.47
113.6
SMA5914A
914A
3.6
3.42
3.78
104.2
9.0
500.0
1.00
100.0
1.0
251.0
SMA5915A
915A
3.9
3.71
4.10
96.1
7.5
500.0
1.00
50.0
1.0
232.0
SMA5916A
916A
4.3
4.09
4.52
87.2
6.0
500.0
1.00
10.0
1.0
210.0
SMA5917A
917A
4.7
4.47
4.94
79.8
5.0
500.0
1.00
10.0
1.5
192.0
SMA5918A
918A
5.1
4.85
5.36
73.5
4.0
350.0
1.00
10.0
2.0
177.0
SMA5919A
919A
5.6
5.32
5.88
66.9
2.0
250.0
1.00
10.0
3.0
161.0
SMA5920A
920A
6.2
5.89
6.51
60.5
2.0
200.0
1.00
10.0
4.0
146.0
SMA5921A
921A
6.8
6.46
7.14
55.1
2.5
200.0
1.00
10.0
5.2
133.0
SMA5922A
922A
7.5
7.13
7.88
50.0
3.0
400.0
0.50
10.0
6.0
121.0
SMA5923A
923A
8.2
7.79
8.61
45.7
3.5
400.0
0.50
10.0
6.5
110.0
SMA5924A
924A
9.1
8.65
9.56
41.2
4.0
500.0
0.50
10.0
7.0
100.0
SMA5925A
925A
10.0
9.50
10.50
37.5
4.5
500.0
0.25
10.0
8.0
91.0
SMA5926A
926A
11.0
10.45
11.55
34.1
5.5
550.0
0.25
0.5
8.4
83.0
SMA5927A
927A
12.0
11.40
12.60
31.2
6.5
550.0
0.25
0.5
9.1
76.0
SMA5928A
928A
13.0
12.35
13.65
28.8
7.0
550.0
0.25
0.5
9.9
69.0
SMA5929A
929A
15.0
14.25
15.75
25.0
9.0
600.0
0.25
0.5
11.4
61.0
SMA5930A
930A
16.0
15.20
16.80
23.4
10.0
600.0
0.25
0.5
12.2
57.0
SMA5931A
931A
18.0
17.10
18.90
20.8
12.0
650.0
0.25
0.5
13.7
50.0
SMA5932A
932A
20.0
19.00
21.00
18.7
14.0
650.0
0.25
0.5
15.2
45.0
SMA5933A
933A
22.0
20.90
23.10
17.0
17.5
650.0
0.25
0.5
16.7
41.0
SMA5934A
934A
24.0
22.80
25.20
15.6
19.0
700.0
0.25
0.5
18.2
38.0
SMA5935A
935A
27.0
25.65
28.35
13.9
23.0
700.0
0.25
0.5
20.6
34.0
SMA5936A
936A
30.0
28.50
31.50
12.5
26.0
750.0
0.25
0.5
22.8
30.0
SMA5937A
937A
33.0
31.35
34.65
11.4
33.0
800.0
0.25
0.5
25.1
27.0
SMA5938A
938A
36.0
34.20
37.80
10.4
38.0
850.0
0.25
0.5
27.4
25.0
SMA5939A
939A
39.0
37.05
40.95
9.6
45.0
900.0
0.25
0.5
29.7
23.0
SMA5940A
940A
43.0
40.85
45.15
8.7
53.0
950.0
0.25
0.5
32.7
22.0
SMA5941A
941A
47.0
44.65
49.35
8.0
67.0
1000.0
0.25
0.5
35.8
19.0
SMA5942A
942A
51.0
48.45
53.55
7.3
70.0
1100.0
0.25
0.5
38.8
18.0
SMA5943A
943A
56.0
53.20
58.80
6.7
86.0
1300.0
0.25
0.5
42.6
16.0
SMA5944A
944A
62.0
58.90
65.10
6.0
100.0
1500.0
0.25
0.5
47.1
14.0
SMA5945A
945A
68.0
64.60
71.40
5.5
120.0
1700.0
0.25
0.5
51.7
13.0
SMA5946A
946A
75.0
71.25
78.75
5.0
140.0
2000.0
0.25
0.5
56.0
12.0
SMA5947A
947A
82.0
77.90
86.10
4.6
160.0
2500.0
0.25
0.5
62.2
11.0
SMA5948A
948A
91.0
86.45
95.55
4.1
200.0
3000.0
0.25
0.5
69.2
10.0
SMA5949A
949A
100.0
95.00
105.00
3.7
250.0
3100.0
0.25
0.5
76.0
9.0
SMA5950A
950A
110.0
104.50
115.50
3.4
300.0
4000.0
0.25
0.5
83.6
8.6
SMA5951A
951A
120.0
114.00
126.00
3.1
380.0
4500.0
0.25
0.5
91.2
7.8
SMA5952A
952A
130.0
123.50
136.50
2.9
450.0
5000.0
0.25
0.5
98.8
7.0
SMA5953A
953A
150.0
142.50
157.50
2.5
600.0
6000.0
0.25
0.5
114.0
6.4
SMA5954A
954A
160.0
152.00
168.00
2.3
700.0
6500.0
0.25
0.5
121.6
5.8
SMA5955A
955A
180.0
171.00
189.00
2.1
900.0
7000.0
0.25
0.5
136.8
5.2
SMA5956A
956A
200.0
190.00
210.00
1.9
1200.0
8000.0
0.25
0.5
152.0
4.7
REV.1.1,2017-07
www.cz-zhide.com
很抱歉,暂时无法提供与“SMA5918A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.73732
- 50+0.61593
- 150+0.55534
- 500+0.50987
- 2500+0.43492
- 5000+0.41667
