ST10100
ST10100
    MDD(辰达半导体)
    TO-277
    电压:100V 电流:10A
ST10100 数据手册
ST10100 Reverse Voltage - 100 Volts Forward Current -10.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features TO-277  Trench MOS Schottky barrier diodes  Low forward voltage drop  low profile - typical body height 1.1 mm  Moisture sensitivity: level 1, per J-STD-020  High temperature soldering guaranteed: 260℃/10 seconds - RoHS Compliant  Halogen-free according to IEC 61249-2-21 definition Mechanical Data Case : JEDEC TO-277 Molded plastic body Case Material: Molding compound meets UL 94V-0 flammability rating Terminals :Plated Leads Solderable per MIL-STD-202,Method 208 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.003 ounce, 0.092 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter MDD ST10100 SYMBOL UNIT Marking Code Maximum repetitive peak reverse voltage VRRM Maximum DC blocking voltage VDC RMS Reverse voltage 100 V VRMS 70 V Average Rectified Output Current I(O) 10 A Non-Repetitive Peak Forward Surge8.3ms Single Half Sine-Wave Superimposed on rated load(JEDEC Method) IFSM 240 A Electrical Characteristics Ta=25℃ unless otherwise noted Test Symbol Conditions Parameter TA=25℃ TA=125℃ vF Peak reverse curent at rated DC TA=25℃ blocking voltage TA=125℃ IR Forward Voltage Drop at 10A TTypical junction capacitance 4.0 V, 1 MHz Typical thermal resistance Junctionto Ambient Operating junction and storage temperaturerange Value Unit Typ 0.60 0.54 Max 0.65 0.59 25 70 uA 10 50 mA V CJ 240 PF RθJA 102 ℃/W -55 to +150 ℃ TJ,TSTG Note:1.The typical data above is for referenceonly. http://www.microdiode.com Rev:2024A2 Page :1 ST10100 Reverse Voltage - 100 Volts Forward Current -10.0 Ampere Ratings And Characteristic Curves The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 ST10100 Reverse Voltage - 100 Volts Forward Current -10.0 Ampere Packing information P0 P1 unit:mm d E Item Symbol Tolerance TO-277 Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 4.45 7.0 1.60 1.55 330.00 50.0 13.00 1.75 7.50 8.00 4.00 2.00 F B A W P D2 D1 T C W1 D 0.25 12.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) TO-277 13" 5,000 4.0 10,000 210*208*203 330 430*430*235 80,000 13.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) Unit (inch) A 0.142 B 3.60 5.35 C 1.50 0.059 D 1.85 0.073 E 4.30 0.169 Rev:2024A2 0.211 Page :3
ST10100
- 物料型号:ST10100 - 器件简介:表面安装肖特基势垒二极管,具有低正向电压降和1.1mm的低轮廓。 - 引脚分配:文档中提到了引脚的布置,但未提供具体的引脚分配图。 - 参数特性: - 最大重复峰值反向电压(VRRM):100V - 平均整流输出电流(I(AV)): 10A - 正向电压降在10A时:0.66V(TA=25°C),0.70V(TA=125°C) - 额定直流阻断电压下的峰值反向电流(IR):15uA(TA=25°C),30uA(TA=125°C) - 典型结电容(CJ):在4.0V, 1MHz时为240pF - 典型热阻(ReJA, ReJL):35°C/W(结到环境),10°C/W(结到引脚) - 功能详解:文档提供了正向输出电流降额曲线、最大非重复峰值正向浪涌电流曲线和典型瞬态正向特性图。 - 应用信息:文档未明确提供应用信息,但根据器件特性,适用于需要低正向电压降和高电流的应用。 - 封装信息:TO-277封装,符合EIA标准RS-481-A,提供了详细的封装尺寸和公差。
ST10100 价格&库存
很抱歉,暂时无法提供与“ST10100”相匹配的价格&库存,您可以联系我们找货
