WMZ11A-105S151XUU400B20-G5B
    TYOHM(幸亚电阻)
    Radial,P=5MM
WMZ11A-105S151XUU400B20-G5B 数据手册
Spec. No.: 20191224 Page (s): 1/5 Part No.: WMZ11A Series 料 号:WMZ11A Series PTC THERMISTOR Rev No.: 0/A (Dec 24, 2019) 1. APPEARANCE 外形 1-1. Dimensions 尺寸 See WMZ12A(V) series Spec. Table attached 参见所附 WMZ12A(V)系列规格表 1-2. Marking 标志 See WMZ11A series Spec. Table attached 参见所附 WMZ11A 系列规格表中标志 1-3.Coating 包封 □ No coating 无包封 ■ Coating 包封 Material 材料 ■ PF resin 酚醛树脂 ■ Silicon 硅树脂 ■ Epoxy 环氧树脂 ■ Others 其它 Color 颜色 ■ Green 绿色 ■ Red 红色 ■ Yellow 黄色 ■ Black 黑色 ■ Blue 兰色 1-4. Leads 引线 Tin-plated copper wire 镀锡铜线 Tin-plated steel wire 镀锡钢线 Straight 直线 Axis Formed 轴弯 In-Forming 内弯 2. MECHANICAL CHARACTERISTICS 机械性能 (Remark 注: The items with * are periodic inspection items 带*号者为例行周期性检验项目) Item Specification Test Conditions & Methods 项目 规格要求 测试条件 / 方法 The terminals shall be 2-1. Solder-ability 可焊性 uniformly tinned, and its area≥95% 浸润部分上锡均匀, 上锡面积≥95% Dipping the PTC terminals to a depth of 15mm in a soldering bath of 245℃±5℃ and to the place of 6mm far from PTC body for 3±0.5s (See IEC68-2-20 /GB2423.28 Ta ) 将引出端沾助焊剂后,浸入到温度为 245℃±5℃、深度为 15mm 的锡槽中锡面距 PTC 本体下端 6mm 处,持续 3±0.5 秒。(参见 IEC68-2-20 /GB2423.28 试验 Ta) Dipping the terminals to a depth of 15mm in a soldering bath of 260℃±5℃ and to the place of 6mm far from PTC body for 3 *2-2. Resistance To Soldering Heat 耐焊接热 No visible mechanical ± 0.5s. After recovering for 4~5 hours under normal damage. temperature. The resistance (RN') shall be measured. (See 试验前后阻值变化率 IEC68-2-20 /GB2423.28 Tb) ΔR/RN ≤20% 将引出端沾助焊剂后,浸入到温度为 260℃±5℃、深度为 (ΔR =∣RN-RN'∣) 15mm 的锡槽中锡面距 PTC 本体下端 6mm 处,持续 3±0.5 秒。在常温条件下恢复 4~5 小时后,复测额定零功率电阻值 RN'。(参见 IEC68-2-20 /GB2423.28 试验 Tb) Spec. No.:20191224 Page (s): 2/5 Part No.: WMZ11A Series 料 号:WMZ11A Series PTC THERMISTOR Rev No.: 0/A (Dec 24, 2019) Item Specification Test Conditions & Methods 项目 规格要求 测试条件 / 方法 No break out 无损坏(允许引线根部 包封材料部分脱落) Fasten the body and apply a force gradually to each lead until 10 N and then keep for 10sec.(See IEC68-2-21/GB24 23.29 Ua) Hold the body and apply a force to each lead until 90°slowly at 5 N in the direction of lead axis and then keep for 10sec, and do this in the opposite direction repeat for other terminal. (See IEC68-2-21/GB2423.29 Ub) 固定 PTC 本体,沿引线轴向逐步加力至 10N,持续 10 秒。 (参见 IEC68-2-21 /GB2423.29 试验 Ua) 固定 PTC 本体,将一条引线弯曲 90°后沿引线轴向缓慢加力 至 5N,持续 10 秒。将另一条引线向反方向弯曲 90°后沿引 线轴向缓慢加力至 5N,持续 10 秒。(参见 IEC68-2-21 /GB2423.29 试验 Ub) *2-3. Strength of lead terminal 引出端强度 *2-4. Non-burning Burning last 0 sec. Test as the standard of UL-94 (V-0). 不燃性 持续燃烧时间 0 秒 按 UL-94 (V-0).标准要求试验。 3. ELECTRICAL CHARACTERISTICS 电气性能 3-1. Rating 额定参数 See WMZ11 series Spec. Table attached 参见所附 WMZ11 系列规格表 3-2. Test Condition & Methods 试验条件/方法 (Remark 注: The items with * are periodic inspection items 带*号者为例行周期性检验项目) 3-2-1.Rated Zero-Power Resistance (RN) 额定零功率电阻 Ambient temp. TA: 25℃±2℃ Testing voltage: 1.5VDC After placing for 1~2 hours under TA, the resistance value shall be measured. See WMZ11A Series 环境温度 TA: 25℃±2℃ Spec. Table attached 参见所附 WMZ11A 系列 测试电压: 1.5VDC 规格表 在常温 TA 条件下,放置 1~2 小时 后测得阻值 RN。 *3-2-2. Curie Temp. (TC) (For Information Only) 居里温度(仅供参考) 3-2-3. Breakdown Voltage (Vb) 耐电压 The resistance value is twice of RN at TC. 在 TC 条件下测得的阻值等于 2RN。 See WMZ11A Series Spec. Table attached ΔRN/RN ≤20% (ΔRN =∣RN-RN'∣) 参见所附 WMZ11A 系 列规格表 TA: 25℃±2℃ Initial Current 起始电流 t: Imax Test vol. 测试电压: 220Vrms / 10s→Vb / 10s (Imax ,VB See WMZ11A series Spec. Table attached ) 参见所附 WMZ11A 系列规格表 Spec. No.:20191224 Page (s): 3/5 Part No.: WMZ11A Series 料 号:WMZ11A Series PTC THERMISTOR Rev No.: 0/A (Dec 24, 2019) Item Specification Test Conditions & Methods 项目 规格要求 测试条件 / 方法 *3-2-4. Max Permissible Repetitive Turn Over Current (Imax) ( Endurance ) 最大可重复通断电流 (耐久性) TA: 25℃±2℃ ΔRN/RN ≤20% Initial Current 起始电流: Imax (ΔRN =∣RN-RN'∣) 参见所附 WMZ11A 系列规格表 参见所附 WMZ11A 系列 See WMZ11Aseries Spec. Table attached Circles 通断次数: 20,000 times ( On / Off: 1s /59s ) 规格表 See WMZ11A Series After recovering for 4~5 hours under TA the resistance value RN' shall be measured. Spec. Table attached 在常温 TA 条件下恢复 4~5 小时后,复测额定零功率电阻值 RN'。 3-2-5. Over Current withstanding (Ib) 耐电流能力 TA: 25℃±2℃ Initial current 起始电流 : Ib=1.5*Imax (See WMZ11A series Spec. Table attached ) 参见所附 WMZ11A 系列规格表 Test Vol.测试电压 : 265Vrms Testing cycle 测试次数:20 times ( On / Off: 30S / 60S ) After recovering for 4~5 hours under normal temperature. The resistance value shall be measured. (RN') 在常温条件下恢复 4~5 小时后,复测额定零功率电阻值 RN'。 265V / Ib 20times ΔR/RN ≤20% (ΔR =∣RN-RN'∣) 4. INSPECTION 交收检验 Sampling with 抽样方法按 IEC410 / DIN ISO 2859-1 (GB/T2828.1-2003) ; Testing with 试验方法按 IEC60738-1 / QC 440000 (GB7153-2002) , Spec. No. WL11A-130619-1 Item 检验项目 IL AQL 4-1. Appearance 外观 Ⅱ 0.65 4-2. Solder-ability 可焊性 S-2 2.5 4-3. Rated Zero Power Resistance RN 额定零功率电阻值 Ⅱ 0.65 Item 检验项目 IL AQL 4-4. Breakdown Voltage VB 耐电压 S-2 2.5 4-5. Over Current withstanding IB 耐电流能力 S-2 2.5 Spec. No.:20191224 Page (s): 4/5 Part No.: WMZ12A(V) Series 料 号 PTC THERMISTOR Rev No.:0/A (Dec 24, 2019) 5. NUMBERING SYSTEM AND PACKING 编号方法和包装方式 5-1. Part Numbering 料号编号方法 WMZ11A ① 75 A 151 N U P ② ③ ④ ⑤ ⑥ ⑦ 500 B 10 ⑧ ⑨ ⑩ - E 6 B 11 12 ○ 13 ○ ○ ① Series WMZ11A: PTC Thermistors for preheating of the CFL / Ballast 系列 用于电子节能灯 / 镇流器预热启动系列 PTC 热敏电阻器 ② Curie temperature 居里温度 105: 105℃ (80 : 80℃ 85: 85℃ ……) ③ Diameter 外径 Dmax A : 6.5mm (M: 11.5mm A : 6.5mm HV : 6.5mm L: 5.5mm……) ④ Rated zero power resistance 额定零功率电阻(RN)121: 120Ω(681: 680Ω; 202: 2KΩ 153:10KΩ … ) ⑤ ⑥ ⑦ ⑧ ⑨ ⑩ Tolerance 电阻允差 M: ±20% (V: ±25% N:±30% P: ±50% ;X:Else 其它 …… ) Leads form 引线形状 U: Inside kink 内弯( A: Axis wind 轴弯 S: Straight 直形 F: No coating 无包封) Leads 引线材质 P:铜包钢线(U:Tin-plated copper wire 铜线) Breakdown Voltage 耐电压 500:500V (600:600V 800:800V) Packing Type 包装方式 B: Bulk 散装 ( A: Ammo 条带 C: Reel 盘带 ……) Leads length 引线长度:10: 10.0±1.0mm 8: 8±1.0mm 5: 5.0±1.0mm 25: 25.0±1.0mm Coating Material 包封材料:S - Black Silicone 硅树脂 G – Green Silicone 绿色硅树脂 N – No Coating 无包封 P-PF Resin 酚酫树指 E-Epoxy 环氧树脂 12 ○ Leads Diameter 引线直径:5 – Φ0.5mm 6 – Φ0.6mm 8 – Φ0.8mm 1 – Φ1.0mm 13 Leads Distance 引线间距:A – 2.5mm B – 5.5mm C – 7.5mm D – 10.0mm ○ 5-2.Lot Numbering 批号编号方法 75 ① A ② A 1307226 ③ ④ - 1/2 ⑤ ① Curie temperature 居里温度 75: 75℃(105: 105℃ 85: 85℃ ……). ② Diameter 外径 Dmax S : 5.0mm (M: 11.5mm S: 4.5mm L: 5.5mm……). ③ Series 系列:WMZ11A- PTC Thermistors for preheating of the CFL / Ballast 系列 用于电子节能灯 / 镇流器预热启动系列 PTC 热敏电阻器 ④ Pipelined batch number 流水批号: 1307226 : ⑤ Shipment branch card batch number 分卡号:1/2 ; 5-3. Packing Type 包装方式 See Appendix Ⅱ attached 参见附件Ⅱ 6. Operating Temp. Range 工作温度范围 -10℃~+60℃ (V=Vmax) Spec. No.: 20191224 Part No.: WMZ11A Series 料 号:WMZ11A Series Page (s): 5/5 PTC THERMISTOR Rev No.: 0/A (Dec 24, 2019) 7. STORAGE CONDITIONS 贮存环境条件 7-1.Temperature 温度: -10℃~+40℃ 7-2. Humidity 湿度: ≤70%RH 7-3. Term 期限: ≤6 months (First-in/ First-out 先进先出) 7-4. Place 地点: Do not exposing PTC components to the following conditions; otherwise, it may result in deterioration of characteristics. 不要暴露在下列环境条件下,否则将导致性能衰退或参数飘移: 1) Corrosive gas or deoxidizing gas 腐蚀性或易氧化气体 2) Flammable and explosive gases 易燃易爆气体 3) Oil, water and chemical liquid 油、水和化学溶液 4) Under the sunlight 太阳光下 7-5. Handling after seal open 开封后的处理: After unpacking of the minimum package, reseal it promptly or store it inside a sealed container with a drying agent. 尽量保证开口最小化,立即重新封好,并贮存在密封、带有干燥剂的容器中。 8. WARNING 注意、警告 ! Do not apply the components under the following conditions; otherwise, it may result in deterioration of characteristics, destruction of product or in the worst case, to catching fire. 请不要在下列条件下使用本元件,否则将可能导致产品性能衰退或产品损毁,甚至引发火灾: 1) Exceeding Imax or Vmax. 超过最大工作电流或工作电压 2) Exceeding rated temperature range. 超过许可工作温度范围 3) Inferior thermal dissipation. (Due to badly inferior thermal dissipation, some part of the components will become overheated and then be damaged.) 散热不良(由于散热不良,本元件可能因部分过热而导致破坏) ■ SPECIFICATIONS TABLE 规格表 Max. Operating Vol. 最大工作电压: UMax = 265VAC 最大可重 零功率 商品编号 商品名称 厂家型号 电阻值 R25(Ω) WMZ11A-105S151XUU 居里温度 耐电压 Tc(℃) 热敏电阻 100-200 105±7 C471621 热敏电阻 WMZ11A-105S100-200XUU 100-200 105±7 C471561 热敏电阻 WMZ11A-105S151MAP 150±20% 105±7 C471695 热敏电阻 WMZ11A-105S151NUU 150±30% 105±7 C471666 热敏电阻 WMZ11A-80S151MAP 150±20% 80±7 C471706 热敏电阻 WMZ12A-50S201PLS 200±50% 50±7 C471742 热敏电阻 WMZ11A-75S201PUP 100-300 75±7 C471556 热敏电阻 WMZ11A-85S200-300UP 250±20% 85±7 C471664 热敏电阻 WMZ11A-50S301XUU 200-400 50±7 C471618 压敏电阻 WMZ11A-75S331NSP 330±30% 75±7 C471633 热敏电阻 WMZ11A-75S401VUP 300-500 75±7 C471690 热敏电阻 WMZ11A-75S401VUU 300-500 75±7 C471683 热敏电阻 WMZ12A-75S401MUU 400±20% 75±7 C471735 热敏电阻 WMZ11A-75S501MUP 500±20% 75±7 C471684 热敏电阻 WMZ11A-50S681XUU 500-800 50±7 C471721 热敏电阻 WMZ11A-75S701XUP 550-850 75±7 C471705 热敏电阻 WMZ11A-75S751XSP 500-1000 75±7 C471744 热敏电阻 WMZ11A-50S102MIU 1000±20% 50±7 C471704 热敏电阻 WMZ11A-50S102VUP 1000±25% 50±7 C471750 热敏电阻 WMZ11A-50S102MSU 1000±20% 50±7 C471707 热敏电阻 WMZ11A-50S102MUU 1000±20% 50±7 C471697 热敏电阻 WMZ11A-75S102XUP 800-1.3K 75±7 C471653 热敏电阻 WMZ11A-75S102MSU 1000±20% 75±7 C471661 热敏电阻 WMZ11A-75S102NUP 1000±30% 75±7 C471533 热敏电阻 WMZ11A-75S102MSP 1000±20% 75±7 C471674 热敏电阻 WMZ12A(V)-75S222NUP 2200±30% 75±7 C471736 热敏电阻 WMZ12A-75S222MUU 2200±20% 75±7 C471547 热敏电阻 WMZ11A-75S252MSU 2500±20% 75±7 C471733 热敏电阻 WMZ11A-75S252NUU 2500±30% 75±7 C471699 热敏电阻 WMZ11A-75S252XUP 2.5K-3.5K 75±7 C471693 热敏电阻 WMZ11A-75S252MUU 2500±20% 75±7 C471741 热敏电阻 WMZ11-75S252MUP 2500±20% 75±7 C471549 热敏电阻 WMZ11A-75S 2K-3K SU 2000-3000 75±7 C471702 热敏电阻 2.5K-4.5K 热敏电阻 22 Tmax d ±0.05 F ±1 500 200 5 600 90 60 2.5-4.5K Dmax 400 50±7 WMZ11A-50S2.5K-4.5KSUB C471542 电流 Imax(mA) C471761 WMZ11A-50S332XIU Vb(VAC) 外型尺寸 复通断 50±7 4.8 0.5 5.0 C471728 热敏电阻 WMZ11A-50S4~7KSP 4-7K 50±7 C471756 热敏电阻 WMZ11A-50S4-7K 4-7K 50±7 C471722 热敏电阻 WMZ11A-75S552XUP 4-7K 75±7 C471660 热敏电阻 WMZ11-50S682XUU 5K-8K 50±7 C471641 热敏电阻 WMZ11A-75S682XUP 5K-8K 75±7 C471751 热敏电阻 WMZ11A-75S702XSP 5-9K 75±7 C471668 热敏电阻 WMZ11A-75S103MUP 8K-12K 75±7 C471724 热敏电阻 WMZ12A-120L121VSP 120±25% 120±7 C471689 热敏电阻 WMZ11A-75L201PUU 200±50% 75±7 C471732 热敏电阻 WMZ11A-75L201PUP 200±50% 75±7 C471565 热敏电阻 WMZ11A-75L201PSU 200±50% 75±7 C471647 热敏电阻 WMZ11A-75L221MAP 220±20% 75±7 C471759 热敏电阻 WMZ11A-75L331NUP 330±30% 75±7 C471678 热敏电阻 WMZ11A-75L401VUU 400±25% 75±7 C471667 热敏电阻 WMZ11A-75L401NUP 400±30% 75±7 C471696 热敏电阻 WMZ12A-130L501NUU 500±30% 130±7 C471563 热敏电阻 WMZ11A-75L601XUP 500-700 75±7 C471701 热敏电阻 WMZ11A-75L600-750UP 600-750 75±7 C471629 热敏电阻 WMZ11A-75L500-800AP 500-800 75±7 C471745 热敏电阻 WMZ11A-75L681XSU 500-800 75±7 C471730 热敏电阻 WMZ11A-75L102MUP 1000±20% 75±7 C471672 热敏电阻 WMZ11A-75L102MUU 1000±20% 75±7 C471747 热敏电阻 WMZ12A-75L102MUU 1000±20% 75±7 C471657 热敏电阻 WMZ11A-75L122NSP 1200±30% 75±7 C471636 热敏电阻 WMZ11A-105L122XSP 1K-1.5K 105±7 C471623 热敏电阻 WMZ11A-75L122XUP 800-1.5K 75±7 C471567 压敏电阻 WMZ11A-75L122XIP 800-1.5K 75±7 C471543 热敏电阻 WMZ12A-130L152NUUB C471639 热敏电阻 WMZ11A-75L162XAP 1.3K-1.9K 75±7 C471628 热敏电阻 WMZ11A-75L162XUP 1.2K-2K 75±7 C471566 压敏电阻 WMZ12A-75L202MUU 2000±20% 75±7 C471654 热敏电阻 WMZ11A-75L252MAU 2500±20% 75±7 C471648 热敏电阻 WMZ11A-75L252MUU 2500±20% 75±7 C471726 热敏电阻 WMZ12A-75L302MUU 3000±20% 75±7 C471638 热敏电阻 WMZ11A-120L332NAU 3300±30% 120±7 C471553 热敏电阻 WMZ11A-75L402VIP 4000±25% 75±7 C471749 热敏电阻 WMZ11A-75L402VUP 4000±25% 75±7 C471698 热敏电阻 WMZ11-75L402VUP 4000±25% 75±7 C471694 热敏电阻 WMZ12A-125L472MSP 4700±20% 125±7 C471671 热敏电阻 WMZ11A-75L502MAP 5000±20% 75±7 C471540 热敏电阻 WMZ11A-75L502MUP 5000±20% 75±7 C471624 热敏电阻 WMZ12A-75HV68RXUP 50-100 75±7 C471644 热敏电阻 WMZ11A-125A68RNUP 68±30% 125±7 1500±30% 130±7 40 400 500 300 200 600 5.5 5.0 0.6 5.0 6.5 5.5 0.6 5.0 140 90 60 40 400 400 C471717 热敏电阻 WMZ12A-75HV151NUP 150±30% 75±7 C471528 热敏电阻 WMZ11A-75A151XUP 100-200 75±7 C471655 热敏电阻 WMZ12A-75HV151MUP 150±20% 75±7 C471737 热敏电阻 WMZ11A-105A201PUU 200±50% 105±7 C471676 热敏电阻 WMZ11A-110A201PSP 200±50% 110±7 C471680 热敏电阻 WMZ11A-105A201PAU 200±50% 105±7 C471758 热敏电阻 WMZ11A-75A201MUP 200±20% 75±7 C471643 热敏电阻 WMZ11-75A201MUP 200±20% 75±7 C471656 热敏电阻 WMZ11A-75A251XUP 150-350 75±7 C471718 热敏电阻 WMZ11A-75HV251MSP 250±20% 75±7 C471560 热敏电阻 WMZ11A-75HV251MUP 250±20% 75±7 C471649 热敏电阻 WMZ11A-75HV301NSP 300±30% 75±7 C471651 热敏电阻 WMZ11A-75A331NUP 330±30% 75±7 C471740 热敏电阻 WMZ11A-75A331NUP 330±30% 75±7 C471713 热敏电阻 WMZ12A-75HV331MUP 330±20% 75±7 C471632 热敏电阻 WMZ11-75A351XUP 300-400 75±7 C471729 热敏电阻 WMZ11A-105A100-300PUU 100-300 105±7 C471755 热敏电阻 WMZ11A-75HV300-500UP 300-500 75±7 C471743 热敏电阻 WMZ11A-75HV401MAP 400±20% 75±7 C471719 热敏电阻 WMZ11A-75HV401VUP 400±25% 75±7 C471677 热敏电阻 WMZ11A-75HV401VUU 400±25% 75±7 C471675 热敏电阻 WMZ11A-105A471NUU 470±30% 105±7 C471738 热敏电阻 WMZ11A-75A471NUP 470±30% 75±7 C471551 热敏电阻 WMZ12A(IV)-85HV471MUU 470±20% 85±7 C471681 热敏电阻 WMZ11-75A601XUP 500-700 75±7 C471652 热敏电阻 WMZ11A-75HV631MUP 630±20% 75±7 C471650 热敏电阻 WMZ11A-75HV681XUP 500-800 75±7 C471635 热敏电阻 WMZ11A-75A681NUP 680±30% 75±7 C471714 热敏电阻 WMZ11A-50HV681MUP 680±20% 50±7 C471665 热敏电阻 WMZ12A-75HV102MUP 1000±20% 75±7 C471544 热敏电阻 WMZ11A-75HV102MUP 1000±20% 75±7 C471682 热敏电阻 WMZ11A-75A102MUU 1000±20% 75±7 C471688 热敏电阻 WMZ11A-75HV122MAP 1200±20% 75±7 C471692 热敏电阻 WMZ12A-75A122VUP 1200±25% 75±7 C471715 热敏电阻 WMZ11A-75HV122MUP 1200±20% 75±7 C471691 热敏电阻 WMZ11A-75A152XIP 1.2K-2K 75±7 C471687 热敏电阻 WMZ12A-75HV152MSP 150±20% 75±7 C471646 热敏电阻 WMZ12A-75HB152MSP 1500±20% 75±7 C471564 热敏电阻 WMZ11A-75HV152MSP 1500±20% 75±7 C471529 热敏电阻 WMZ11A-75A172XUP 1K-2.5K 75±7 C471536 热敏电阻 WMZ11A-75A202XUP 1.5K-2.5K 75±7 C471535 热敏电阻 WMZ11A-75A252MUP 2500±20% 75±7 C471685 热敏电阻 WMZ11A-75HV252MUP 2500±20% 75±7 500 300 600 200 140 90 C471752 热敏电阻 WMZ11A-75A252MUU 2500±20% 75±7 C471739 热敏电阻 WMZ11A-75A252MAU 2500±20% 75±7 C471727 热敏电阻 WMZ11A-50A302XSP 2.5K-4K 50±7 C471753 热敏电阻 WMZ11A-50A332XSU 2.5K-4K 50±7 C471659 热敏电阻 WMZ11A-50A2.5K-4KAU 2.5K-4K 50±7 C471634 热敏电阻 WMZ11A-75A352XUP 3K-4K 75±7 C471754 热敏电阻 WMZ11A-75A452NSU 3.5K-5.5K 75±7 C471622 热敏电阻 WMZ12A-75HV502MUU 5000±20% 75±7 C471746 热敏电阻 WMZ11A-75HV502MSU 5000±20% 75±7 C471703 热敏电阻 WMZ11A-50B101NUU 100±30% 50±7 C471679 热敏电阻 WMZ12A-85B251MUP 250±20% 85±7 C471625 热敏电阻 WMZ11A-80B561NUP 560±30% 80±7 C471531 热敏电阻 WMZ11A-75BHV452MAU 4500±20% 75±7 60 40 500 600 800 300 40 8.5 5.5 0.6 5.0
WMZ11A-105S151XUU400B20-G5B 价格&库存
很抱歉,暂时无法提供与“WMZ11A-105S151XUU400B20-G5B”相匹配的价格&库存,您可以联系我们找货
