RB1-125B8G1A
RB1-125B8G1A
    UDE
    插件
    千兆Transformer
RB1-125B8G1A 数据手册
To: Customer P/N: UDE P/N: RB1-125B8G1A Description: RJ45 1X1 Tab Down Through Hole 10/100/1000 Base-T Contact Area : Gold Flash LED:L-Green; R-Yellow Spec No. RB115260-00 Approved Checked Update Date 2015/11/4 Revision A Prepared RB1-125B8G1A Spec No. : RB115260-00 1. MECHANICAL DIMENSION General Tolerance : 1.1 Product Dimension -1- X.X : ± 0.38 X.XX : ± 0.20 www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 1.2 Recommended PCB Layout Component Side of Board All dimension tolerances are ±0.05mm unless otherwise specified -2- www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 1.3 Recommended Panel cutout 1.4 Packing Information 60 pcs finished goods per tray 7 trays(420 pcs finished goods) per inner box 4 Inner boxes(1680 pcs finished goods) per master carton -3- www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 1.5 Standard RJ45 Plug Specification - All dimensions follow : FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i) IEC 60603-7 - All plugs must be meeting the requirements of plug Go & No-Go gauge. Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i) - There must be no damage to Housing and Locking Latch. - There must be no nicks and cuts in cable. - Durability : 750 cycles generally -4- www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 2. REQUIREMENTS 2.1 Design and Construction Product shall be of design, construction and physical dimensions specified on applicable. 2.2 Material 2.2.1 Terminal Parts (Underplating : 50μ" min. Nickel overall) 2.2.1.1 RJ Terminal : PH. Bronze, Thickness=0.30mm Finish : Contact Area : Gold Flash 2.2.1.2 Input Terminal : Brass, Thickness=0.35mm Finish : 100μ" min. Tin 2.2.1.3 Case Terminal : Brass, Thickness=0.30mm Finish : 100μ" min. Tin 2.2.2 Plastic Parts 2.2.2.1 Housing : PA6T, Black 2.2.2.2 Case : PA6T, Black 2.2.3 Shield Parts : Stainless steel , Thickness=0.20mm, Pre-soldering -5- www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 2.3 Operating and Storage Temperature Operating Temperature : 0°C to +70°C Storage Temperature : -40°C to +85°C 2.4 RJ45 specifications Insulation Resistance :500MΩ min. Insertion force with the latch depressed : 22N max Removal force with the latch depressed :44N max Locking Force of Plug Latch : 50N min. @ 60+/-5 sec Durability : 750 cycles 2.5 Performance and Test Description Product is designed to meet electrical, mechanical and environmental performance requirements specified in below table. All tests are performed at ambient environmental conditions per MIL-STD-1344A and EIA-364 unless otherwise specified. 2.6 Packaging and Packing All parts shall be packaged and packed to protect against physical damage、corrosion and deterioration during shipment and storage. -6- www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 3. ELECTRICAL CHARACTERISTICS 3.1 Schematic INPUT RJ45 OUTPUT CT R1 75Ω 1:1 TD1+ R2 C1 TX1+ C2 TX1- TD1- R3 1:1 TD2+ R4 75Ω C3 TX2+ TD2- R5 C6 TX275Ω 1:1 TD3+ R6 C4 TX3+ TD3- R7 C5 TX375Ω 1:1 TD4+ R8 C7 TX4+ TD4- R9 C8 TX42KV 1000pF GND R10 Shield L4 L2 Green Yellow L3 Emitting Color Green Yellow L1 λp (nm) 565 585 Vf @If=20mA 1.7 ~2.6 V 1.7 ~2.6 V -7- Ir @Vr=5V 10μA max. 10μA max. www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 3.2 Transmitter filter & Receiver filter Type : Balance low pass 100Ω impedance Insertion loss : 1~100 MHz -1.0dB max. Return loss : 1~30 MHz -18dB min. load 100Ω 30~60MHz -16dB min. load 100Ω 60~80MHz -12dB min. load 100Ω 80~100MHz -10dB min. load 100Ω 3.3 Common Mode Rejection @ 1~100 MHz -30dB min. 3.4 Cross Talk @ 1~100 MHz 3.5 Inductance -30dB min. @ 100KHz, 0.1V, 8mA DC BIAS Input (R2-R3), Input(R4-R5), Input (R6-R7), Input(R8-R9): 350 μH min. 3.6 HiPot Test Input(R2-R3) To Output(C1-C2) : 1500Vac 60s or 2250Vdc 60s Input(R4-R5) To Output(C3-C6) : 1500Vac 60s or 2250Vdc 60s Input(R6-R7) To Output(C4-C5) : 1500Vac 60s or 2250Vdc 60s Input(R8-R9) To Output(C7-C8) : 1500Vac 60s or 2250Vdc 60s -8- www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 4. ORDER INFORMATION R B 1 - 1 2 5B A B 8G1 C A D A. LED Code : L-Green; R-Yellow. B. Mechanical Code : UDE Logo, All Spring C. Schematics Code : 8G1 : 8G1 circuit D. Plating Code : Underplating 50μ "min. Nickel overall Solder Tail 100μ " min. Bright Tin 100μ " min. Matted Tin A : Gold Flash 1 : Gold Flash C : 6μ " gold 6 : 6μ " gold B : 10μ " gold Contact Area D : 15μ " gold 2 : 15μ " gold F : 30μ " gold 3 : 30μ " gold G : 50μ " gold 4 : 50μ " gold -9- www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 5. DIPPING TEMPERATURE PROFILE - 10 - www.ude-corp.com RB1-125B8G1A Spec No. : RB115260-00 6. Revision History Issue Date Revision 2015/11/4 A Comments Initial Release . Operator Mark - 11 - www.ude-corp.com
RB1-125B8G1A 价格&库存
很抱歉,暂时无法提供与“RB1-125B8G1A”相匹配的价格&库存,您可以联系我们找货
RB1-125B8G1A
    • 1+14.68800
    • 10+12.57120
    • 60+10.87560
    库存:7
