PSIP-08V-LE
PSIP-08V-LE
    JST
    P=4mm
    2X4P 4MM
PSIP-08V-LE 数据手册
PSI CONNECTOR 4.0mm pitch/Disconnectable Crimp style connectors Wire-to-wire type Side entry type • Secure locking structure • Mis-mating prevention mechanism by keying (2 to 4 circuits/3 kinds of keying) • Finger-friendly design • Large electric current was realized. Specifications ––––––––––––––––––– Single type Double type • Current rating: 12 A AC, DC (Refer to the following table.) • Voltage rating: 300 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Note: The current rating differs depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit: A Top entry type Circuits 2 3 4, 5, 6, 8 10, 12 14 This PSI connector is designed for wire-toboard and wire-to-wire 4.0 mm pitch connector. Low insertion force type contact is adopted and it provides excellent operability. This connector has the secure locking device that has the mechanism for preventing the inverse insertion. By adopting key shape and multi colors of housing, prevention function of mis-mating is considered. 1 # 16 # 18 12 11 10 9 9 10 9 8 7 7 Wire size (AWG) # 20 # 22 8 7 6 6 6 5 5 5 5 4.5 # 24 # 26 4 4 4 4 4 3 3 3 3 3 Note: Do not branch in parallel current which exceeds the rated current (e.g. more than 12 A in the case of 2 circuits with AWG #12). If branched in parallel, current imbalance or other problems may develop. If it is absolutely necessary to branch such a large current in parallel, design the circuits without causing any imbalance and provide an extra margin for each circuit. Standards –––––––––––––––––––––– 0 Recognized E 60389 1 Certified LR 20812 2 R50259465 PSI CONNECTOR PC board layout and Assembly layout Top entry type ● Single type ● Double type 10 1.65 4.5 ±0.05 +0.1 0 φ1.3 17.8 4 +0.1 0 17.8 φ1.3 ±0.05 ±0.05 ±0.05 ±0.05 +0.1 0 4.5 φ1.65 15.95 +0.1 0 5.95 φ1.65 1.65 ±0.05 A ±0.05 4 ±0.05 A ±0.05 Side entry type Wire-to-wire type 22.1 9.35 10.25 10 F ±0.05 4 ±0.05 +0.1 0 30.9 +0.1 0 ±0.05 H 8.7 +0.1 0 9 3 3 ±0.05 9 ±0.05 φ1.7 φ1.65 0.8 4 ±0.05 ±0.05 +0.1 0 ±0.05 A±0.05 A ±0.05 φ1.65 +0.1 0 ±0.05 G 7.2 19.6 +0.1 0 φ1.7 +0.1 0 φ1.7 +0.1 0 Keying: A, B types φ1.7 +0.1 0 F Circuits Keying: C type 0.8 t 1.2 1.2 t 2.0 2 3 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 13 17 13.3 17.3 G H Applicable panel thickness (mm) 9 13 6.8 8.4 0.8∼2.0 Socket contact Applicable wire mm2 AWG# Model No. SPSI-001T-M1.1 SPSI-41T-M1.1 0.13∼0.33 26∼22 1.3∼2.4 2,600 0.5 ∼1.25 20∼16 1.7∼3.2 2,600 11.3 6.5 2.2 Insulation O.D. (mm) Q'ty/reel Material and Finish 4 2.8 Copper alloy, tin-plated RoHS compliance Contact Crimping machine Crimp applicator MKS-L SPSI-001T-M1.1 AP-K2N SPSI-41T-M1.1   ―   MKS-L   ―   Applicator Dies Crimp applicator with dies MK/SPSI/M-001-11 APLMK SPSI/M001-11 ― ― MK/SPSI/M-41-11 APLMK SPSI/M41-11 ― ― 2 PSI CONNECTOR Socket housing Top entry type B A B 10 15.95 14.9 14.9 A RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PSIP-02V-LE-A LE...light blue Y...yellow R...red Header Top entry type 9.1 12.35 B φ1.1 4 1.65 3.7 □1.14 4.5 A 15.05 12.35 B RoHS compliance This product displays (LF)(SN) on a label. Note: Other kinds of post-omitted products are available. Contact JST for details. φ1.1 4 1.65 A 3.7 □1.14 4.5 5.95 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 3 B02B-PSILE-A1 LE...light blue Y...yellow R...red PSI CONNECTOR Header Side entry type S02B-PSILE-A1 S02B-PSIY-B1 S02B-PSIR-C2 S03B-PSILE-A1 S03B-PSIY-B1 S03B-PSIR-C2 S04B-PSILE-A1 S04B-PSIY-B1 S04B-PSIR-C2 16.65 3.7 9.35 B 3 □1.14 9 4 RoHS compliance This product displays (LF)(SN) on a label. Note: Other kinds of post-omitted products are available. Contact JST for details. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. A ex. S02B-PSILE-A1 LE...light blue Y...yellow R...red Pin contact Applicable wire mm2 AWG# Model No. SPSM-001T-M1.1 SPSM-41T-M1.1 26∼22 1.3∼2.4 2,600 0.5 ∼1.25 20∼16 1.7∼3.2 2,600 Material and Finish 18 2.2 Insulation O.D. (mm) Q'ty/reel 0.13∼0.33 6.6 4 Copper alloy, tin-plated 2.8 RoHS compliance Contact Crimping machine Crimp applicator MKS-L SPSM-001T-M1.1 AP-K2N SPSM-41T-M1.1 Applicator Dies   ―   MKS-L Crimp applicator with dies MK/SPSI/M-001-11 APLMK SPSI/M001-11 ― ― MK/SPSI/M-41-11 APLMK SPSI/M41-11   ―   ― ― Receptacle housing Circuits Keying A 2 3 C A B A B Model No. PSIR-02V-LE-A PSIR-02V-Y-B PSIR-03V-LE-A PSIR-03V-Y-B Dimensions (mm) A B C Q’ty/ bag 4.0 16.1 12.5 200 4.0 16.1 12.5 200 8.0 20.1 16.5 150 8.0 20.1 16.5 150 Material 9.1 Glass-filled PBT, UL94V-0 15.85 RoHS compliance 25.45 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B PSIR-03V-LE-A LE...light blue Y...yellow 8.45 4 PSI CONNECTOR Contact position location numbers Socket housing 5 4 3 2 14 13 12 11 10 9 8 7 2 1 Header Header ● Top entry ● Side entry 14 13 12 11 10 1 6 5 4 3 5 4 3 2 9 8 2 1 1 1 7 6 5 4 3 2 Receptacle housing 3 3 4 2 1 Single Double Single Double Single Single Pin-omitted Header 1) When setting two times of pitch in single type header with omitting every other one pin However, pins shall be inserted in No.1-circuit and No. N-circuit. B *1 (8.0)B-PSI ; With circuit (pin) e.g.) *1; No. of circuits (No. of pins) Circuit No. 3 ; Without circuit (pin) 2 1 Circuit (pin) Model No. 5 Circuit No. 4 e.g.) Circuit No. Model No. B3(8.0)B-PSILE-1 6 5 4 3 2 1 Circuit (pin) *1; No. of circuits (No. of pins) *2; Circuit No. of used original header *3; Circuit number without pin (Circuit number in which pin was removed) Circuit No. Circuit (pin) Model No. B4(6-2, 5)B-PSILE-1 3) When setting three times of pitch in double type header with omitting every other two pins However, pins shall be inserted in the both ends of circuit. B *1 (*2-*3)B-PSI e.g.) Circuit No. 14 13 12 11 10 9 8 7 6 5 4 3 2 1 Circuit (pin) Circuit No. Circuit (pin) Model No. B6(14-2, 3, 5, 6, 9, 10, 12, 13)B-PSILE-1 4) When omitting a pin of No.3 circuit in single type herder However, pins shall be inserted in the both ends of circuit. B *1 (*2-*3)B-PSI e.g.) Circuit No. 5 4 3 2 Circuit (post) Model No. B4(5-3)B-PSILE-1 Note) As for pin-omitted product, there is a setting that cannot be used. Contact JST for details. 5 2 Circuit (pin) B2(8.0)B-PSILE-A1 2) When setting two times of pitch in double type header with omitting every other one pin However, pins shall be inserted in the both ends of circuit. B *1 (*2-*3)B-PSI 3 1 1 PSI CONNECTOR Keying Socket housing Shape A type B type C type A type B type C type A type B type C type 2 circuits 3 circuits 4 circuits Header Top entry type Shape 2 circuits 3 circuits 4 circuits Side entry type Shape 2 circuits 3 circuits 4 circuits Receptacle housing Shape A type B type 2 circuits 3 circuits 6
PSIP-08V-LE 价格&库存
很抱歉,暂时无法提供与“PSIP-08V-LE”相匹配的价格&库存,您可以联系我们找货
PSIP-08V-LE
    • 200+0.74580
    库存:3800
