APSC6R3EC3821MH081
APSC6R3EC3821MH081
    NCC(贵弥功)
    AEC_D8X8MM_TM
    APSC6R3EC3821MH081
APSC6R3EC3821MH081 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Radial Lead PSC - Series ・Super low ESR, high ripple current capability ・Rated voltage range : 2.5 to 16Vdc ・Nominal capacitance range : 270 to 2,700µF ・Endurance : 15,000 hours at 105℃ ・Suitable for DC-DC converters, voltage regulators and decoupling applications for computer motherboards ・Added 2.5V 820µF (ESR 5mΩ max.) ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant ・Halogen Free PSE Longer life Downsizing PSC ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current *Note Dissipation Factor (tanδ) Low Temperature Characteristics (Max.Impedance Ratio) Endurance Bias Humidity Test Surge Voltage Test -55 to +105℃ 2.5 to 16Vdc ±20% (M) I=0.2CV or 500μA, whichever is greater. Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (Vdc) (at 20℃, 120Hz) (at 20℃ after 2 minutes) 0.10 max. (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.15 Z(-55℃)/Z(+20℃)≦1.25 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 15,000 hours at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to DC voltage at 60℃, 90 to 95% RH for 1,000 hours. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105℃ for 30 seconds through a protective resistor(R=1kΩ) and discharge for 5 minutes 30 seconds. Rated voltage (Vdc) 2.5 4.0 6.3 10 16 Surge voltage (Vdc) 2.9 4.6 7.2 12 18 Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value 0.5% per 1,000 hours maximum (Confidence level 60% at 105℃) Failure Rate *Note : If any doubt arises, measure the leakage current after the following voltage treatment. Voltage treatment : DC rated voltage is applied to the capacitors for 120 minutes at 105℃. ◆DIMENSIONS [mm] ●Terminal ◆MARKING Code : E φd φD' L' 15min. EX) 2.5V820µF F±0.5 Coated Case 4min. Size code H08 φD 8.0 φd 0.6 F 3.5 φD' L' L+1.0max. HB5 JB5 8.0 10.0 0.8(Note1) 0.8(Note1) 3.5 5.0 φD+0.5max. L+1.5max. JC5 10.0 0.6 5.0 C 3D6 820 2.5V Note1 : 0.6 for rated volt 16V. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Radial Lead PSCSeries - ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 A PSC AAA E AA AAA M AAA S Supplement code (Note2) Size code Capacitance tolerance code Capacitance code (ex. 330µF:331, 1000µF:102) Lead forming·Taping code Terminal code Voltage code (ex. 4V:4R0,6.3V:6R3,10V:100) Series code Category (Note2) PSC series, 2.5V820µF(ESR 5mΩ max.) has supplement code "J". Can case, terminal and terminal plating are the same as all others in PSC series. Please refer to "Product code guide (conductive polymer type)" ◆STANDARD RATINGS WV (Vdc) 2.5 4 6.3 10 16 Cap (µF) Case size φD×L(mm) ESR (mΩ max./20℃, 100k to 300kHz) Rated ripple current (mArms/105℃, 100kHz) Part No. 7 5 7 7 7 7 8 7 7 6 8 8 7 10 9 7 11 10 10 10 6,100 6,100 6,100 6,100 6,100 6,100 5,560 6,100 6,100 6,640 5,700 5,700 6,640 5,560 5,650 6,100 5,080 6,100 6,100 6,100 APSC2R5E□□561MH08S APSC2R5E□□821MH08J APSC2R5E□□821MH08S APSC2R5E□□102MH08S APSC2R5E□□102MHB5S APSC2R5E□□152MHB5S APSC2R5E□□272MJB5S APSC4R0E□□561MH08S APSC4R0E□□681MHB5S APSC4R0E□□102MJB5S APSC6R3E□□471MH08S APSC6R3E□□561MH08S APSC6R3E□□821MJB5S APSC6R3E□□152MJB5S APSC100E□□391MHB5S APSC100E□□681MJB5S APSC160E□□271MHB5S APSC160E□□331MJB5S APSC160E□□331MJC5S APSC160E□□471MJB5S 8 ×8 8×8 8×8 8×8 8× 11.5 8 × 11.5 10 ×11.5 8 ×8 8× 11.5 10×11.5 8 ×8 8×8 10× 11.5 10×11.5 8 × 11.5 10×11.5 8× 11.5 10× 11.5 10× 12.5 10× 11.5 560 820 820 1,000 1,000 1,500 2,700 560 680 1,000 470 560 820 1,500 390 680 270 330 330 470 □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Radial lead type 120 0.10 1k 0.35 10k 0.60 50k 0.80 100k to 500k 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
APSC6R3EC3821MH081
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,包括输入侧的LED引脚和输出侧的晶体管引脚。
4. 参数特性:包括最大正向二极管电流、最大反向二极管电压等参数。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装形式。
