Chip Type Cermet Trimmer Potentiometer
チップ型サーメット皮膜セラミック半固定可変抵抗器
3mm size, Low profile type
3mm サイズ、薄形
■ Features
・Low profile type ( 1.2mm in height )
・Achieved good endurance characteristics by using “Metal-glaze” for the material of resistor
・Conforms to RoHS Directives
・Reflow solderable
■Outline Dimensions (Unit : mm)
摺動子回転範囲
Wiper Rotating Area
TERM.2
1.6
0.7
1.2
推奨ランドパターン寸法
Pattern Application Example
1.5
0.75
1.5
裏面封止樹脂
Maximum resin sealedResin
area
0.8
0.65
TERM.3
2.7
1.2
0.95
1.2
2
3.8
(1)
0.5
1.75
φ3.7
3
2.1
1.2
0.8
1.2
TERM.1
C.W.
Circuit
Term. 1
Term. 3
Term. 2
■Specification
Item
Nominal Total Resistance
Resistance Tolerance
Rotational Torque
Effectively Rotary Angle
Rated Wattage
Max. Rated Voltage
T.C.R(Temperature Coefficient)
Operating Temp. Range
Specification
Unit
100~1M
±25
0.98~11.76
270 ± 20
0.15
Ω
mN.m
W
V
ppm/℃
50 or V= PR
whichever is smaller
±250
-40 ~ +100
Note
Non stopper
■Part Designation
VG 039N
SN
XT B***
Resistance law and Resistance value ( 3 figures )
Taping type (8mm width×4mm pitch emboss taping for auto insertion)
SMD Type ( Non stopper )
Size
Resistive element type : Metal-glaze
*Packaging Quantity : 2500 pcs / Reel
2018.7.1
HOKURIKU
※Specifications are subject to change without notice
1
䕔Features
Low profile type (1.2mm in height)
With rotation stopper
Achieved exellent endurance characteristics by using "Metal-glaze" film.
Conform to RoHS Directives
Reflow solderable
䕔Dimensions (Unit: mm)
䃥3. 7
㸦Wiper Rotating Area)
3
1. 5
1. 2
Terminal 2
Maximum resin sealed area
0. 75
1.6
Terminal 1
0. 65
1.5
1.2
1.2
0. 8
Terminal 3
1.2
0. 95
2
3. 8
( 1 )
0. 5
1. 75
0.7
2. 1
0.8 1.2
2. 7
PCB Footprint
C.W.
Circuit
Terminal 1
Terminal 3
Terminal 2
䕔Specification
Item
Specification
Unit
100 ~ 1 M
±25
䃈
Rotational Torque
0.98䡚 11.76
mN䞉m
End Stop Strength
14.7 min.
mN䞉m
Total Mechanical Rotation Angle
270㼼20
0.15
㼻
W
50 or V= PR whichever is smaller
V
Nominal Total Rasistance
Rasistance Tolerance
Rated Wattage
Max. Working Voltage
T.C.R. (Temperature Coefficient of Resistance)
Operating Temperature Range
±250
ppm/䉝
-40 䡚 100
䉝㻌
Note
䕔Model Designation
VG 039N CH XT B***
Characteristics and Resistance value (3 figures)
Taping type (8mm width㽢4mm pitch emboss taping for auto insertion)
SMD type
Size
Model No. Resistive element type (Metal glaze)
*Packaging Quantity : 2,500pcs / Reel
2018.7.1
HOKURIKU
Specifications are subject to change without notice.
2
很抱歉,暂时无法提供与“VG039NSNXTB103”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.64322
- 50+1.34396
- 150+1.21576
- 500+1.05570
- 2500+0.82059
- 5000+0.77782
