WWW.BDS666.COM
1/1
No. of DIM.A
PCB TOLERANCE:±0.05 (TOP VIEW)
RECOMMEND P.C.B LAYOUT
深圳市金航标电子有限公司
PROJECT
PROUCT NO.
1.27FH 2xnPin H4.3 DIP
UNIT
APPROVED:
SCALE
PAGE
0755-83044319
A4
A
CHECKED:
REV
SIZE
KH-1.27FH-2X2P-H4.3
UNLESS OTHEWIXE SPECIFIED TOLERANCE
12/03/07
X°
:±5°
X.X° :±1°
X.XX°:±0.5°
LI BEI LIN
X
:±0.3
X.X :±0.2
X.XX:±0.1
DRAW:
DIM.B
SPECIFICATIONS
Current Rating:
1.0 Amps
Withstanding Voltage: AC 500V
Insulation Resistance:1000M Ω Min
Contact Resistance:
20 mΩ Max
Operation Temperature:-40 °to+105°
Insrlator Material:
Polyester(UL94V-0)
Contact Material:
Phosphor bronze
Standard:
PA6T
Contact Plating:
Gold Flash
Max.Processing Temp: 240 °C for30-60seconds
(260 °C for5seconds)
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
(1) Pin Spacing:127=1.27mm
(2) Product Name:FH=Female Header
(3) No.of Rows:1=Single Row ;2=Dual Row
(4) No.of Pins Per Row:1~50
(5) Insulator Material Height:20=2.0mm;43=4.3mm
(6) Connector Type:S=Straight;R=Right; Angle M=SMT
(7) Connector Material Length: 24=2.4mm; 30=3.0mm
(8) Insulator Material Width: 18=1.8mm 21=2.1mm
(9) Contact Plating: G0=Gold Flash;AU10=Au 1.0u"
(10) Insulator Material Option:
A=BK-PA6T;B=BK-PA46;C=KB-LCP;S=Special
No. of DIM.A
KH-1.27FH-2X2P-H4.3 价格&库存
很抱歉,暂时无法提供与“KH-1.27FH-2X2P-H4.3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.95494
- 50+0.76832
- 150+0.67500
- 500+0.54087
- 2500+0.48492
- 5000+0.45684
