MOBILE ANTENNAS
Low-Profile Antenna
BMLPVMB/LTE
BMLPVMB/LTE Low-Profile 4G LTE Antenna
RoHS
COMPLIANT
The BMLPVMB/LTE low-profile vertical antenna provides superior multi-band
pattern coverage for mobile or fixed applications operating in frequencies from
600 MHz to 2700 MHz. This antenna is designed to provide industry leading
wide-band performance and optimal coverage of LTE frequencies, with minimum loss
and no tuning required. It features an attractive, compact housing that makes the
antenna ideal for indoor or outdoor applications requiring minimum visibility to
the antenna. PCTEL’s high efficiency permanent mount is recommended for
most efficient performance.
Features
BMLPVMB/LTE
Attractive, low-profile design
Multiple band coverage with no tuning required
Can be used for mobile and fixed base applications
Environmentally tested to MIL-STD-810F
MLFML195C
MLF high efficiency mount
(sold separately)
STANDARD CONFIGURATION
Model
BMLPVMB/LTE
BMLPVMB/LTE-VP
Cable
Connector
Pro-Flex™ Plus 195 OR PFP240 high
frequency cables are recommended
with this antenna. Cable assemblies
or mount/cable assemblies are sold
separately.
Mount
Various connector options
are offered with PCTEL high
frequency mounts (sold
separately)
For optimal performance, use higher
frequency rated mounts (e.g. MLFML195C,
MTPM800 and GMLFML195C).
Mount sold separately.
N Female
Built-in N connector accomodates surfaces
up to 1/2-in thick
ELECTRICAL SPECIFICATIONS (ALL FREQUENCIES)
Frequency Range
Gain*
Maximum Power
Polarization
Nominal
Impedance
VSWR
BMLPVMB/LTE
600-960/1710-2700 MHz
3 dBi
150 watts
Vertical, linear
50 ohms
< 2:1
BMLPVMB/LTE-VP
3 dBi
150 watts
Vertical, linear
50 ohms
< 2:1
Model
MECHANICAL & ENVIRONMENTAL SPECIFICATIONS
Model
Dimensions
Weight (Mass)
BMLPVMB/LTE
2.4 H x 1.4 in OD (6.1 x 3.6 cm)
0.29 lbs (0.13 kg)
BMLPVMB/LTE-VP
3.5 H x 1.4 in OD (8.9 x 3.6 cm)
0.31 lbs (0.14 kg)
Temperature
Range
-40°F to +158°F
(-40°C to +70°C)
-40°F to +158°F
(-40°C to +70°C)
Ingress
Protection
Housing
Color***
IP66**
Black
IP66**
Black
* Measures on a 1x1 ft ground plane. Gain is ground plane dependent.
** When installed per PCTEL installation instructions on a roof top surface
*** For white housing option, add the prefix “W” to the part number.
PCTEL, Inc. WEB: www.antenna.com
很抱歉,暂时无法提供与“BMLPVMB/LTE”相匹配的价格&库存,您可以联系我们找货
