TMI3244T
18V, Peak 4A Synchronous COT Step-Down Converter
Features
Description
60mΩ/30mΩ Low RDS(ON) internal FETs
The TMI3244T is a high efficiency 550kHz,
High Efficiency Synchronous-Mode
Constant-on-Time
Operation
synchronous step-down DC-DC converter capable
(COT)
control
mode,
of delivering up to Peak 4.0A current with 1.2V
Wide Input Range: 4.5V to 18V
Output Voltage from 0.765V
550kHz Switch Frequency
Up to 4A Output Current@1.2VOUT
ripple and small external inductor and capacitor
COT control to achieve fast transient
size are achieved with 550kHz switching frequency.
responses
It adopts the COT architecture to achieve fast
Power Save Mode at Light Load
transient responses for high voltage step down
Integrated internal compensation
applications.
Stable with Low ESR Ceramic Output
The TMI3244T requires a minimum number of
Capacitors
readily available standard external components
output voltage. TMI3244T integrates main switch
and synchronous switch with very low RDS(ON) to
minimize the conduction loss. Low output voltage
and is available in a 6-pin SOT23-6 ROHS
Over Current Protection with Hiccup Mode
Thermal Shutdown
Inrush Current Limit and Soft Start
Application
Build in Input Over Voltage Protection
⚫ Digital Set Top Boxes
Available in SOT23-6 Package
⚫ Flat Panel Television and Monitors
compliant package.
⚫ Notebook computer
⚫ Wireless and DSL Modems
Typical Application
Efficiency
C4
0.1µF
VOUT=3.3V, IOUT=0.01A to 4A, TA=25°C
100%
L
BS
CIN2
22µF
100nF
VOUT= 3.3V
LX
R3
100kΩ
90%
R1
33.2kΩ
Cfb
80%
20pF
EN
FB
GND
CO1
R2
10kΩ
22µF
CO2
22µF
Efficiency
VIN
CIN1
4.7µH
70%
60%
50%
TMI3244T Typical Application Circuits
40%
30%
0.001
TMI and SUNTO are the brands of TOLL microelectronic
TMI3244T V0.2 – 2020.06
9V-3.3V
12V-3.3V
16V-3.3V
0.01
0.1
1
Output Current (A)
10
www.toll-semi.com
1
TMI3244T
Absolute Maximum Ratings (Note 1)
Parameter
Min
Max
Unit
Input Supply Voltage, EN
LX Voltages
LX Voltage (
