PESD5V2S2UT
Features
300 W peak pulse power (tp = 8/20μs)
Bidirectional and unidirectionalconfigurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=120 pF typ.)
Protection two data lines
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 20A(8/20μs)
1
1
3
3
2
2
SOT-23 (Top View)
Applications
Mechanical Data
Dataline
Automatic Teller Machines
SOT-23 package
Net works
Molding compound flammability rating: UL 94V-0
Power line
Packaging: Tape and Reel
RoHS/WEEE Compliant
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
300
W
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
A
VESD
30
30
kV
Lead SolderingTemperature
TL
260
JunctionTemperature
TJ
-55 to + 125
StorageTemperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2(Air)
ESD per IEC 61000-4-2 (Contact)
www.umw-ic.com
1
友台半导体有限公司
PESD5V2S2UT
Electrical Characteristics
Parameter
Symbol
Reverse Stand-OffVoltage
Conditions
Min
Typical
Max
Units
5
V
7.0
8.5
V
0.5
1
μA
VRWM
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=5V,T=25℃
Peak PulseCurrent
IPP
tp =8/20μs
A
IPP=10A,tp=8/20μs
12
V
Clamping Voltage
VC
IPP=20A,tp=8/20μs
16
V
Reverse BreakdownVoltage
Cj
JunctionCapacitance
6.0
VR = 0V, f =1MHz
(pin1、pin2 to pin3)
120
pF
Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RW M
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
VC VBR VRWM
Maximum Reverse Leakage Current @ V RW M
IR V F
IT
Breakdown Voltage @ IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
www.umw-ic.com
2
友台半导体有限公司
PESD5V2S2UT
TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
100
Percent of Rated Power for Ipp
P pp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
300w 8/20μs waveform
1
0.1
0.01
0.1
1
10
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
100
125
150
18
Clamping Voltage–VC (V)
Ipp
90
80
Percent
75
Waveform
Paramters
tr=8µs
td=20µs
100
e-1
60
50
Ambient Temperature - TA (℃)
Figure 4: Clamping Voltage vs.Ipp
110
70
25
40
td=Ipp/
2
16
14
12
Test
Waveform
Paramters
tr=8µs
td=20µs
10
8
6
4
2
www.umw-ic.com
10
15
Time (µs)
30
2
3
4
5
6
Peak Pulse Current–IPP (A)
3
友台半导体有限公司
PESD5V2S2UT
Outline Drawing – SOT-23
DIMENSIONS
D
SYMBOL
3
A
E1 E
θ
1
L
0.25
2
e
A
INCHES
MAX
MIN
MAX
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.000
0.035
0.004
0.041
D
2.800
3.000
0.110
0.118
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A2
MILLIM ETER
MIN
0.950 BSC
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
8○
A1
Marking
Wu1
Ordering information
Order code
UMW PESD5V2S2UT
www.umw-ic.com
Package
SOT-23
Base qty
3000
4
Delivery mode
Tape and reel
友台半导体有限公司
很抱歉,暂时无法提供与“PESD5V2S2UT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23220
- 200+0.17777
- 600+0.14764
- 3000+0.12950
- 9000+0.11384
- 21000+0.10530
- 国内价格
- 1+0.68970
- 200+0.22914
- 1500+0.14478
- 3000+0.11400
