PMPB55XNEA
PMPB55XNEA
    NEXPERIA(安世)
    PMPB55XNEA
PMPB55XNEA 数据手册
PMPB55XNEA 30 V, N-channel Trench MOSFET 29 March 2017 Product data sheet 1. General description N-channel enhancement mode Field-Effect Transistor (FET) in a leadless medium power DFN2020MD-6 (SOT1220) Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology. 2. Features and benefits • • • • • • Extended temperature range Tj = 175 °C Small and leadless ultra thin SMD plastic package: 2 x 2 x 0.65 mm Tin-plated 100% solderable side pads for optical solder inspection ElectroStatic Discharge (ESD) protection > 1.5 kV HBM Trench MOSFET technology AEC-Q101 qualified 3. Applications • • • • Relay driver High-speed line driver Low-side loadswitch Switching circuits 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj = 25 °C - - 30 V VGS gate-source voltage -12 - 12 V ID drain current - - 3.8 A - 55 72 mΩ VGS = 4.5 V; Tamb = 25 °C [1] Static characteristics RDSon [1] drain-source on-state resistance VGS = 4.5 V; ID = 3.8 A; Tj = 25 °C 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 6 cm . PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 D drain 2 D drain 3 G gate Simplified outline 1 Graphic symbol 7 2 5 G 3 4 4 S source 5 D drain Transparent top view DFN2020MD-6 (SOT1220) 6 D drain 7 D drain 8 S source D 6 8 S 017aaa255 6. Ordering information Table 3. Ordering information Type number Package Name PMPB55XNEA Description Version DFN2020MD-6 DFN2020MD-6: plastic thermal enhanced ultra thin small outline SOT1220 package; no leads; 6 terminals 7. Marking Table 4. Marking codes Type number Marking code PMPB55XNEA 3Q PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 2 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - 30 V VGS gate-source voltage -12 12 V ID drain current VGS = 4.5 V; Tamb = 25 °C [1] - 3.8 A VGS = 4.5 V; Tamb = 100 °C [1] - 2.4 A IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs - 16 A EDS(AL)S non-repetitive drainsource avalanche energy Tj(init) = 25 °C; ID = 0.3 A; DUT in avalanche (unclamped) - 6.2 mJ Ptot total power dissipation Tamb = 25 °C [2] - 550 mW [1] - 1.95 W - 10 W Tsp = 25 °C Tj junction temperature -55 175 °C Tamb ambient temperature -55 175 °C Tstg storage temperature -65 175 °C Source-drain diode IS source current Tamb = 25 °C [1] - 1.9 A HBM [3] - 1500 V ESD maximum rating VESD [1] [2] [3] electrostatic discharge voltage 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 6 cm . Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper; tin-plated and standard footprint. Measures between all pins. PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 3 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET aaa-026120 120 aaa-026121 120 Pder (%) Ider (%) 80 80 40 40 0 -75 Fig. 1. 25 125 Tj (°C) 0 -75 225 Fig. 2. Normalized total power dissipation as a function of junction temperature 25 125 Tj (°C) 225 Normalized continuous drain current as a function of junction temperature aaa-026134 102 ID (A) Limit RDSon = VDS/ID tp = 10 µs 10 100 µs 1 1 ms 10 ms DC; Tsp = 25 °C 10-1 10-2 10-1 Fig. 3. 100 ms DC; Tamb = 25 °C; 6 cm2 1 10 102 VDS (V) Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) [1] thermal resistance from junction to solder point Min Typ Max Unit [1] - 236 272 K/W [2] - 67 77 K/W - 12 15 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 4 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET [2] 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm . aaa-026122 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.50 0.33 0.25 0.20 0.10 0.05 10 0.02 0.01 0 1 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 102 aaa-026123 duty cycle = 1 0.75 Zth(j-a) (K/W) 0.50 0.25 0.33 0.20 0.10 10 0.05 0.02 0.01 0 1 10-3 10-2 10-1 FR4 PCB, mounting pad for drain 6 cm Fig. 5. 1 10 102 tp (s) 2 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 5 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 - - V VGSth gate-source threshold voltage ID = 250 µA; VDS=VGS; Tj = 25 °C 0.75 1 1.25 V IDSS drain leakage current VDS = 30 V; VGS = 0 V; Tj = 25 °C - - 1 µA IGSS gate leakage current VGS = 12 V; VDS = 0 V; Tj = 25 °C - - 10 µA VGS = -12 V; VDS = 0 V; Tj = 25 °C - - -10 µA VGS = 4.5 V; VDS = 0 V; Tj = 25 °C - - 2 µA VGS = -4.5 V; VDS = 0 V; Tj = 25 °C - - -2 µA VGS = 4.5 V; ID = 3.8 A; Tj = 25 °C - 55 72 mΩ VGS = 4.5 V; ID = 3.8 A; Tj = 175 °C - 102 133 mΩ VGS = 2.5 V; ID = 3.1 A; Tj = 25 °C - 77 110 mΩ RDSon drain-source on-state resistance gfs forward transconductance VDS = 10 V; ID = 3.8 A; Tj = 25 °C - 20 - S RG gate resistance f = 1 MHz - 10.8 - Ω VDS = 15 V; ID = 3.6 A; VGS = 4.5 V; Tj = 25 °C - 3 5 nC - 0.5 - nC - 0.9 - nC - 255 - pF - 31 - pF - 23 - pF - 7 - ns - 20 - ns Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 18 - ns tf fall time - 8 - ns VDS = 15 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C VDS = 15 V; ID = 3.6 A; VGS = 4.5 V; RG(ext) = 6 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 1.9 A; VGS = 0 V; Tj = 25 °C - 0.8 1.2 V trr reverse recovery time - 12.6 - ns Qr recovered charge IS = 2.5 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 10 V; Tj = 25 °C - 4 - nC PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 6 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET aaa-026124 16 3.0 V 4.5 V ID (A) aaa-022454 10-3 ID (A) 2.6 V 12 10-4 min 2.2 V 8 2.0 V 4 0 Fig. 6. typ 10-5 VGS = 1.8 V 0 1 2 3 VDS (V) 10-6 4 0 0.5 1.0 1.5 Tj = 25 °C; VDS = 5 V Output characteristics: drain current as a Fig. 7. function of drain-source voltage; typical values Subthreshold drain current as a function of gate-source voltage aaa-026125 aaa-026126 400 2.0 V 1.8 V RDSon (mΩ) RDSon (mΩ) 300 300 2.6 V 200 200 3.0 V Tj = 175 °C 100 100 VGS = 4.5 V 0 4 8 12 ID (A) Tj = 25 °C 0 16 Tj = 25 °C Fig. 8. VGS (V) Tj = 25 °C 400 0 max Product data sheet 2 4 6 8 10 VGS (V) ID = 3.6 A Drain-source on-state resistance as a function of gate-source voltage; typical values PMPB55XNEA 0 Fig. 9. Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 7 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET aaa-026127 16 Tj = 175 °C ID (A) 12 a 1.5 Tj = 25 °C 8 1.0 4 0.5 0 0 1 2 aaa-026128 2.0 3 VGS (V) 0 -60 4 0 60 120 Tj (°C) 180 VDS > ID x RDSon Fig. 10. Transfer characteristics: drain current as a function of gate-source voltage; typical values Fig. 11. Normalized drain-source on-state resistance as a function of junction temperature; typical values aaa-026129 2.0 aaa-026130 103 VGS(th) (V) C (pF) 1.5 Ciss max 1.0 102 typ min 0.5 Coss Crss 0 -60 0 60 120 Tj (°C) 10 10-1 180 Fig. 12. Gate-source threshold voltage as a function of junction temperature Product data sheet 10 VDS (V) 102 f = 1 MHz; VGS = 0 V ID = 250 μA; VDS = VGS PMPB55XNEA 1 Fig. 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 8 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET aaa-026131 5.0 VDS VGS (V) ID 4.0 VGS(pl) 3.0 VGS(th) VGS 2.0 QGS1 1.0 0 QGS2 0 1 2 3 QG (nC) QGS QGD QG(tot) 003aaa508 Fig. 15. Gate charge waveform definitions 4 VDS = 15 V; ID = 3.6 A; Tamb = 25 °C Fig. 14. Gate-source voltage as a function of gate charge; typical values aaa-026132 8.0 IS (A) 175 °C 6.0 4.0 25 °C 2.0 0 0 0.4 0.8 VSD (V) 1.2 VGS = 0 V Fig. 16. Source current as a function of source-drain voltage; typical values PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 9 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 11. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 17. Duty cycle definition Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 10 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 12. Package outline DFN2020MD-6: plastic thermal enhanced ultra thin small outline package; no leads; 6 terminals; body 2 x 2 x 0.65 mm SOT1220 (8×) pin 1 index area B E A X D A A1 detail X solderable lead end protrusion max. 0.02 mm (6×) C Lp E2 J1 D2 3 4 2 5 e J D1 bp (6×) e 1 v E1 0 2 mm scale Dimensions (mm are the original dimensions) Unit A A1 bp min 0.25 nom max 0.65 0.04 0.35 D D1 D2 E E1 E2 1.9 1.0 0.2 1.9 1.1 0.51 2.1 1.2 0.3 2.1 1.3 0.61 e J J1 0.65 0.27 0.64 Lp 0.2 0.3 v y y1 0.1 0.05 0.1 Note 1. Dimension A is including plating thickness. Outline version A B 6 pin 1 index area mm y y1 C sot1220_po References IEC JEDEC JEITA European projection Issue date 12-04-23 12-04-30 SOT1220 Fig. 18. Package outline DFN2020MD-6 (SOT1220) PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 11 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 13. Soldering Footprint information for reflow soldering of DFN2020MD-6 package 0.33 (6×) SOT1220 0.76 0.43 (6×) 0.66 0.53 (6×) 0.56 0.25 0.35 0.45 0.775 0.65 2.06 0.285 1.25 1.35 0.35 (6×) 1.05 0.25 (6×) 0.65 0.45 (6×) 0.9 1.1 1.2 0.935 0.935 2.5 solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sot1220_fr Fig. 19. Reflow soldering footprint for DFN2020MD-6 (SOT1220) PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 12 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMPB55XNEA v.2 20170329 Product data sheet - PMPB55XNEA v.1 - - Modifications> PMPB55XNEA v.1 PMPB55XNEA Product data sheet • Marking code corrected 20170222 Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 13 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PMPB55XNEA Product data sheet Trademarks All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 14 / 15 PMPB55XNEA Nexperia 30 V, N-channel Trench MOSFET 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 6 11. Test information....................................................... 10 12. Package outline........................................................ 11 13. Soldering................................................................... 12 14. Revision history........................................................13 15. Legal information..................................................... 14 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 29 March 2017 PMPB55XNEA Product data sheet All information provided in this document is subject to legal disclaimers. 29 March 2017 © Nexperia B.V. 2017. All rights reserved 15 / 15
PMPB55XNEA
物料型号: PMPB55XNEA
器件简介: - 这是一款N-channel增强型场效应晶体管(FET),使用Trench MOSFET技术,封装在无引线中等功率DFN2020MD-6 (SOT1220)表面贴装设备(SMD)塑料包中。
引脚分配: - 引脚1和5: 漏极(Drain) - 引脚2和7: 漏极(Drain) - 引脚3: 栅极(Gate) - 引脚4: 源极(Source) - 引脚6和8: 漏极(Drain)
参数特性: - 漏源电压(Vps)最大30V - 栅源电压(VGs)在-12V至12V之间 - 漏极电流(ID)在4.5V下最大3.8A - 栅源阈值电压(VGsth)在0.75V至1.25V之间 - 导通电阻(RDSon)在25°C时,当Vs=4.5V且ID=3.8A时,范围为55mΩ至72mΩ
功能详解: - 该MOSFET具备扩展的温度范围(Tj = 175°C),小型无引线超薄SMD塑料封装,尺寸为2 x 2 x 0.65 mm。 - 采用锡镀100%可焊侧垫,适用于光学焊接检查。 - 具有静电放电(ESD)保护,等级大于1.5 kV HBM。 - 符合AEC-Q101认证。
应用信息: - 适用于继电器驱动器、高速线路驱动器、低侧负载开关和开关电路。
封装信息: - 封装类型为DFN2020MD-6 (SOT1220),塑料热增强超薄小型封装,无引线,6个终端,尺寸为2 x 2 x 0.65 mm。
PMPB55XNEA 价格&库存
很抱歉,暂时无法提供与“PMPB55XNEA”相匹配的价格&库存,您可以联系我们找货
