To:
Customer P/N:
UDE P/N: RVB-ZZ-0004
Description: RJ45 1X1 Vertical
Through Hole
10/100 Base-T
Contact Area : Gold Flash
LED:L-Green; R-Orange
Packing With Hard Tray
Spec No.
RVB18003-00
Approved
Checked
Update Date
2018/9/14
Revision
B
Prepared
Revision History
Issue Date
2018/8/21
2018/9/14
Revision
Comments
A
Initial Release .
B
Add the Transmitter filter & Receiver filter
Operator
Eagle
Kevin
UD-P09-R03E
RVB18003-00
RVB-ZZ-0004
1. MECHANICAL DIMENSION
Product Dimension
U. D. Electronic Corp.
Unit:mm
1/9
General Tolerance :
X.X : ± 0.38
X.XX : ± 0.20
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
Recommended PCB Layout. Component side of board
All dimension units are "mm".
All dimension tolerances are ±0.05mm unless otherwise specified.
2/9
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
Recommended Panel cutout
2. Packing Information
60 pcs finished goods per tray
9trays(480pcs finished goods) per inner box
4 Inner boxes(1920 pcs finished goods) per master carton
3/9
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
3. Standard RJ45 Plug Specification
- All dimensions follow :
FCC subpart F, 68,500, Figure (C)(2)(i) & (C)(2)(ii) & (C)(3)(i)
IEC 60603-7
- All plugs must be meeting the requirements of plug Go & No-Go gauge.
Gauge follow : FCC subpart F, 68,500, Figure (C)(4)(i) & (C)(5)(i)
- There must be no damage to Housing and Locking Latch.
- There must be no nicks and cuts in cable.
- Durability : 750 cycles generally
4/9
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
4. REQUIREMENTS
Design and Construction
Product shall be of design, construction and physical
dimensions specified on applicable.
Material
Terminal Parts(Underplating : 50μ" min. Nickel overall)
RJ Terminal : Phosphor Bronze, Thickness=0.35mm
Finish : Contact Area : Gold Flash
Input Terminal : Brass, Thickness=0.35mm
Finish : 100μ" min. Matte Tin
Case Terminal : Brass, Thickness=0.30mm
Plastic Parts
Housing : PA6T, Black
Case : PA6T, Black
Shield Parts : Stainless Steel, Thickness=0.20mm, Pre-soldering
5/9
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
5. Operating and Storage Temperature
Operating Temperature :
0°C to +70°C
Storage Temperature :
-40°C to +85°C
6. RJ45 specifications
Insulation Resistance :
500MΩ min.
Insertion force with the latch depressed : 20N max.
Removal force with the latch depressed : 20N max.
Locking Force of Plug Latch :
Durability :
50N min. @ 60+/-5 sec.
750 cycles
7. Performance and Test Description
Product is designed to meet electrical, mechanical and environmental
performance requirements specified in below table.
All tests are performed at ambient environmental conditions per MIL-STD-1344A
and EIA-364 unless otherwise specified.
8. Packaging and Packing
All parts shall be packaged and packed to protect against physical damage, corrosion
and deterioration during shipment and storage.
6/9
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
9. ELECTRICAL CHARACTERISTCS @25℃
PHY Side
(Input)
Cable Side
(RJ45 Output)
1:1
TD+ R1
C1 TX+
TD- R3
C2 TX75Ω
75Ω
TCT R2
C4
RCT R5
C5
1:1
RD+ R4
C3 RX+
RD- R6
C6 RX75Ω
NC R7
75Ω
C7
2KV,1000pF
GND R8
C8
Emitting Color
λp (nm)
Vf @If=20mA
Ir @Vr=5V
Green
570
1.7 ~2.6 V
10μA max.
Orange
605
1.7 ~2.6 V
10μA max.
7/9
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
Type : Balance low pass 100Ω impedance
Insertion loss : 1~100MHz
-1.0dB Max.
Return loss :
1~30MHz
-18dB Min.
load 100Ω
30~60MHz
-16dB Min.
load 100Ω
60~80MHz
-12dB Min.
load 100Ω
Common Mode Rejection
@1~100 MHz
-30dB Min.
Cross Talk
@ 1~100MHz
-30dB Min.
Inductance (OCL) @ 100KHz, 0.1V, 8mA DC BIAS
Input(TD+, TD-); (RD+, RD-) :
350 μH Min.
HiPot Test
PHY Side(Input)
To
Cable Side(Output) :
8/9
1500Vac 60s or 2250Vdc 60s
UD-P09-R60A
RVB18003-00
RVB-ZZ-0004
10. WAVE SOLDERING TEMPERATURE PROFILE
Note:
The measuring point for the specified temperature shall
be on the soldered part of the lead.
9/9
UD-P09-R60A
很抱歉,暂时无法提供与“RVB-ZZ-0004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.14714
- 10+8.38242
- 60+7.30512
- 120+6.20730
- 480+5.71482
- 1020+5.49936
