FSAGMMC-128G
FSAGMMC-128G
    FORESEE(江波龙)
    FSAGMMC-128G
FSAGMMC-128G 数据手册
Rev. A5 mSATA SSD S40R FORESEE SATAIII mSATA SSD S40R Datasheet Version: A5 2019.08 Shenzhen Longsys Electronics Co., Ltd, together with any and all of its affiliates (herein after referred as “Longsys” or “Longsys Electronics”)LONGSYS RESERVES THE RIGHT TO CHANGE PRODUCTS, INFORMATION AND SPECIFICATIONS WITHOUT NOTICE. Products and specifications discussed herein are for reference purposes only. All information discussed herein is provided on an "AS IS" basis, without warranties of any kind. This document and all information discussed herein remain the sole and exclusive property of Longsys. No license of any patent, copyright, mask work, trademark or any other intellectual property right is granted by one party to the other party under this document, by implication, estoppel or other-wise. Longsys products are not intended for use in life support, critical care, medical, safety equipment, or similar applications where product failure could result in loss of life or personal or physical harm, or any military or defense application, or any governmental procurement to which special terms or provisions may apply. For updates or additional information about Longsys products, contact your nearest Longsys office. All brand names, trademarks and registered trademarks belong to their respective owners. ⓒ 2018 Shenzhen Longsys Electronics Co., Ltd. All rights reserved. www.longsys.com Page 1 Longsys Electronics Rev. A5 mSATA SSD S40R Revision History Revision Number Description Revision Date A5 Add 32GB capacity. 2019.08 A4 Update endurance. 2019.07 A3 Add 64GB performance. 2018.07 A2 Add 64GB. 2018.06 A1 Update PN. 2018.04 A0 Initial release. 2017.12 www.longsys.com Page 2 Longsys Electronics Rev. A5 mSATA SSD S40R Table of content 1. General Description ........................................................................................................................................... 4 2. Mechanical Specification .................................................................................................................................. 5 2.1 mSATA SSD physical dimensions and Weight .................................................................................... 5 3. Product Specifications....................................................................................................................................... 6 3.1 System Interface and Configuration .................................................................................................... 6 3.2 System Performance .................................................................................................................................. 6 3.3 Drive Capacity ............................................................................................................................................... 6 3.4 Supply Voltage .............................................................................................................................................. 6 3.5 System Power Consumption .................................................................................................................... 7 3.6 System Reliability ........................................................................................................................................ 7 3.7 Endurance ....................................................................................................................................................... 7 3.8 Environmental Specifications .................................................................................................................. 8 4. Electrical Interface Specification .................................................................................................................. 8 4.1 mSATA Pin Assignments ........................................................................................................................... 8 5. Command Descriptions .................................................................................................................................. 10 5.1 Supported ATA Commands .................................................................................................................... 10 5.2 SMART Attributes ....................................................................................................................................... 11 6. Identify Device Data ....................................................................................................................................... 12 7. Product Line up ................................................................................................................................................. 24 7.1 SATA3 mSATA ............................................................................................................................................ 24 8. Contact information ......................................................................................................................................... 24 www.longsys.com Page 3 Longsys Electronics Rev. A5 mSATA SSD S40R 1. General Description The FORESEE SSD (Solid State Drive) fully consists of semiconductor devices using NAND Flash Memory which provide high reliability and high performance for a storage media. The SSD doesn't have any moving parts such as platter (disk) and head media, which provides a better solution in a notebook PC, Tablet PC and industrial PC for a storage device providing higher performance, reduced latencies, and a low power consumption in a small form factor. SSD has the same host interface with Hard Disk Drives and has a same physical dimension. •Capacity •Power Consumption − 32/64/128/256GB is available − Active write:1030mW (256GB) − Active read: 980mW (256GB) •Host interface − Serial ATA interface of 6.0Gbps •Form Factor − Complies with ATA/ATAPI-8 − JEDEC MO-300 standard − Supports NCQ − Supports TRIM •Temperature − Operating : 0°C to 70°C •Performance ·32GB •Shock − Read: Up to 410MB/s − Shock : 1500G, duration 0.5ms, Half Sine Wave − Write: Up to 250MB/s − Vibration : 7~800Hz, 3.08Grms, 30min/axis(X,Y,Z) ·64GB * Applicable only for cased product − Read: Up to 410MB/s •MTBF − Write: Up to 250MB/s − 1,500,000 Hours ·128GB − Read: Up to 530MB/s •Weight − Write: Up to 430MB/s − 32/64/128/256GB ·256GB − Max 8g − Read: Up to 530MB/s − Write: Up to 440MB/s •SSD Functional Block Diagram [Figure 1-1] SSD Functional Block Diagram www.longsys.com Page 4 Longsys Electronics Rev. A5 mSATA SSD S40R 2. Mechanical Specification 2.1 mSATA SSD physical dimensions and Weight Capacity(GB) Height (mm) Width (mm) Length (mm) Weight (gram) 32/64/128/256 Max 4.85 29.85 ±0.15 50.80 ±0.15 Max 8g [Figure 2-1] mSATA Physical dimension www.longsys.com Page 5 Longsys Electronics Rev. A5 mSATA SSD S40R 3. Product Specifications 3.1 System Interface and Configuration Burst read/write rate is 600 MB/sec (6.0 Gb/sec). 3.2 System Performance SATA 6Gb/s host interface Parameter Unit 32GB 64GB 128GB 256GB Sequential Read (Max) MB/S 300 410 530 530 Sequential Write (Max) MB/S 145 250 430 440 Random Read (4K) QD=32 (Max) IOPS 24000 30720 39168 39680 Random Write (4K) QD=32 (Max) IOPS 32000 48640 51200 51200 * Actual performance may vary depending on use conditions and environment * Note 1. Performance measured using CrystalDiskMark 3.0.3 x64 2. Write cache enabled 3. 1MB/sec = 1,048,576 bytes/sec was used in sequential performance -System: Intel Z170 Chipset, Intel Core i5-6600K@3.5GHz, 4GB DDR4 -OS: Windows 7 x64 3.3 Drive Capacity Nominal Capacity 32GB 64GB 128GB 256GB Unformatted Capacity 29.82GB 59.63GB 119.24GB 238.47GB User-Addressable Sectors 62533296 125045424 250069680 500118192 Bytes per Sector 512 Bytes NOTE: 1 Megabyte (MB) = 1 Million bytes; 1 Gigabyte (GB) =1 Billion bytes *Actual usable capacity may be less (due to formatting, partitioning, operating system, applications or otherwise) 3.4 Supply Voltage Item Requirements Allowable voltage 3.3V ± 5% Allowable noise/ripple 100mV p-p or less www.longsys.com Page 6 Longsys Electronics Rev. A5 mSATA SSD S40R 3.5 System Power Consumption Input Voltage 3.3V±5% Parameter 32GB 64GB 128GB 256GB Sequential Read 340 mW 850 mW 920 mW 980 mW Sequential Write 290 mW 800 mW 1020 mW 1030 mW Random Read 260 mW 600 mW 610 mW 980 mW Random Write 290 mW 610 mW 620 mW 630 mW Idle 150mW 320 mW 320 mW 320 mW CPU : Intel Core i5-6600K DRAM : 4GB DDR4 Chipset : Intel Z170 OS : Windows 7 x64 Test Tool : IO Meter 2006 3.6 System Reliability MTBF 1,500,000 Hours MTBF is Mean Time Between Failure. As same word, annual failure ratio is 0.4%. 3.7 Endurance TBW 32GB 64GB 128GB 256GB 48TB 96TB 192TB 384TB Notes: 1-TBW (Terabytes Written) is a measurement of SSDs’ expected lifespan, which represents the amount of data written to the device. To calculate the TBW of a SSD, the following equation is applied: TBW = [(NAND Endurance) x (SSD Capacity)] / WAF NAND Endurance: NAND endurance refers to the P/E (Program/Erase) cycle of a NAND flash. SSD Capacity: The SSD capacity is the specific capacity in total of a SSD. WAF: Write Amplification Factor (WAF) is a numerical value representing the ratio between the amount of data that a SSD controller needs to write and the amount of data that the host’s flash controller writes. A better WAF, which is near 1, guarantees better endurance and lower frequency of data written to flash memory. 2-The above TBW values are calculated based on WAF=1. 3-TBW may differ according to flash configuration and platform. 4-The endurance of SSD could be estimated based on user behavior, NAND endurance cycles, and write amplification factor. It is not guaranteed by flash vendor. www.longsys.com Page 7 Longsys Electronics Rev. A5 mSATA SSD S40R 3.8 Environmental Specifications Features Operating Non-Operating Temperature 0°C to 70°C -40°C to 85°C Humidity 5% to 95%, non-condensing Vibration 7~800Hz, 3.08Grms, 30min/axis(X,Y,Z) Shock 1500G, duration 0.5ms, Half Sine Wave Notes: 1-Temperature is measured by SMART Temperature .Proper airflow recommended. 2-Humidity is measured in non-condensing. 3-Test condition for shock: 0.5ms duration with half sine wave. 4-Test condition for vibration: 10Hz to 2,000Hz, 15mins/axis on 3axis. 4. Electrical Interface Specification 4.1 mSATA Pin Assignments Pin# Assignment Description Pin# Assignment Description 1 N/A N/A 27 GND Return Current Path 2 +3.3V 3.3V source 28 N/A N/A 3 N/A N/A 29 GND Return Current Path 4 GND 30 N/A N/A 5 N/A N/A 31 -A (port 1) 6 N/A N/A 32 N/A 7 N/A N/A 33 +A (port 1) 8 N/A N/A 34 GND Return Current Path 9 GND 35 GND Return Current Path 10 N/A N/A 36 N/A N/A 11 N/A N/A 37 GND Return Current Path 12 N/A N/A 38 N/A N/A 13 N/A N/A 39 +3.3V 3.3V Source 14 N/A N/A 40 GND Return Current Path 15 GND 41 +3.3V 3.3V Source 16 N/A N/A 42 N/A N/A 17 N/A N/A 43 N/A N/A 18 GND 44 DEVSLP 19 N/A 45 N/A www.longsys.com Return Current Path Return Current Path Return Current Path Return Current Path N/A Page 8 SATA Differential RX- based on SSD N/A SATA Differential RX+ based on SSD Device Sleep Mode Enable (Unused) N/A Longsys Electronics Rev. A5 mSATA SSD S40R 20 N/A 21 GND 22 N/A 23 +B(port 1) 24 +3.3V 25 -B(port 1) 26 GND N/A Return Current Path N/A SATA Differential TX+ based on SSD 3.3V Source SATA Differential TX- based on SSD Return Current Path 46 N/A N/A 47 N/A N/A 48 N/A N/A Device Activity / 49 DA/DSS Disable Staggered Spin-up 50 51 52 GND Return Current Path Presence Shall be pulled to Detection GND by device +3.3V 3.3V Source Table 4-1: mSATA Connector Pin Assignment www.longsys.com Page 9 Longsys Electronics Rev. A5 mSATA SSD S40R 5. Command Descriptions 5.1 Supported ATA Commands Command Code Protocol Execute Device Diagnostic 90h Execute device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Initialize Drive Parameters 91h Non-data Read DMA C8h DMA Read Multiple C4h PIO data-in Read Sector(s) 20h PIO data-in Read Verify Sector(s) 40h or 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out Write Sector(s) 30h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Check Power Mode E5h or 98h Non-data Idle E3h or 97h Non-data Idle Immediate E1h or 95h Non-data Sleep E6h or 99h Non-data Standby E2h or 96h Non-data Standby Immediate E0h or 94h Non-data SMART Read Data B0h PIO data-in SMART Read Threshold B0h PIO data-in F8h Non-data Flush Cache Ext EAh Non-data Read Sector(s) Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Read Native Max Address Ext 27h Non-data Read Verify Sector(s) Ext 42h Non-data Write DMA Ext 35h DMA Write Multiple Ext 39h PIO data-out Write Sector(s) Ext 34h PIO data-out General Feature Set Power Management Feature Set SMART Feature Set Host Protected Area Feature Set Read Native Max Address 48-bit Address Feature Set NCQ Feature Set www.longsys.com Page 10 Longsys Electronics Rev. A5 mSATA SSD S40R Read FPDMA Queued 60h DMA Queued Write FPDMA Queued 61h DMA Queued Data Set Management 06h DMA Seek 70h Non-data Others 5.2 SMART Attributes The following table defines the vendor specific data in byte 2 to 361 of the 512-byte SMART data. SMART Data Vendor-specific Attributes Attribute ID (hex) Attribute Name 05 Number of New Bad Block 09 Power On Hours 0C Power Cycle Count A1 Reserved A4 Total Erase Count A5 Max Erase Count A6 Min Erase Count A7 Average Erase Count A9 Remain Life Percentage. C0 Power off Retract Count C2 Controlled temperature C3 Reserved B0 Reserved B1 Reserved B2 Reserved C7 SATA CRC Error Count F1 Total LBAs Written (each write unit = 1GB) F2 Total LBAs Read (each read unit = 1GB) F3 Reserved F4 Reserved FA Reserved FB Reserved FC Reserved FD Reserved FE Reserved www.longsys.com Page 11 Longsys Electronics Rev. A5 mSATA SSD S40R 6. Identify Device Data The Identify Device command enables the host to receive parameter information from the SSD. This command has the same protocol as the Read Sector(s) command. The parameter words in the buffer have the arrangement and meanings defined in the following table. ID Table Information Word Default Value Description General configuration 15 0=ATA device 14:8 Retired 0 045Ah 7:6 Obsolete 5:3 Retired 2 Response incomplete 1 Retired 0 Reserved 1 3FFFh Obsolete 2 C837h Specific configuration 3 0010h Obsolete 00000000h Retired 003Fh Obsolete 00000000h Reserved for the CompactFlash Association 9 0000h Retired 10 - 19 X..Xh Serial number in ASCII (Right justified) 20 - 21 00000000h Retired 22 0000h Obsolete 23 - 26 X..Xh Firmware revision in ASCII 27 - 46 X..Xh Model number in ASCII (Left justified) Big Endian Byte Order in Word 4-5 6 7-8 15:8 80h 47 8001h 7:0 01h=Maximum number of logical sectors that shall be DRQ data block on READ/WRITE MULTIPLE commands Trusted Computing feature set options 15 Shall be cleared to zero 48 4000h 14 Shall be set to one 13:1 Reserved for the Trusted Computing Group 0 1=Trusted Computing feature set is supported www.longsys.com Page 12 Longsys Electronics Rev. A5 mSATA SSD S40R Capabilities 15:14 Reserved for the IDENTIFY PACKET DEVICE command. 13 1 = Standby timer values as specified in this standard are supported 0 = Standby timer values shall be managed by the device 12 Reserved for the IDENTIFY PACKET DEVICE command. 49 2F00h 11 1 = IORDY supported 0 = IORDY may be supported 10 1 = IORDY may be disabled 9 Shall be set to one to indicate that LBA is supported. 8 1 = DMA supported 7:2 Reserved 1:0 Current Long Physical Sector Alignment setting Capabilities 15 Shall be cleared to zero 14 Shall be set to one 50 4000h 13:2 Reserved 1 Obsolete 0 Shall be set to one to indicate a vendor specific Standby timer value minimum 51 - 52 00000000h Obsolete 15:8 Free-fall Control Sensitivity 00h = Vendor’s recommended setting 01h-FFh = Sensitivity level. A larger number is a more sensitive setting. 53 0007h 7:3 Reserved 2 1 = the fields reported in word 88 are valid 0 = the fields reported in word 88 are not valid 1 1 = the fields reported in words (70:64) are valid 0 = the fields reported in words (70:64) are not valid X 0 Obsolete 54 - 58 X..Xh Obsolete 15 1 = The BLOCK ERASE EXT command is supported 14 1= The OVERWRITE EXT command is supported 13 1 = The CRYPTO SCRAMBLE EXT command is supported 59 0000h 12 1 = The Sanitize feature set is supported 11:9 Reserved 8 1 = Multiple logical sector setting is valid 7:0 Current setting for number of logical sectors that shall be transferred per DRQ data block on READ/WRITE Multiple commands 60 - 61 X..Xh 62 0000h www.longsys.com Total number of user addressable logical sectors for 28-bit commands (DWord) Obsolete Page 13 Longsys Electronics Rev. A5 mSATA SSD S40R 15:11 Reserved 10 1 = Multiword DMA mode 2 is selected 0 = Multiword DMA mode 2 is not selected 9 1 = Multiword DMA mode 1 is selected 0 = Multiword DMA mode 1 is not selected 63 0007h 8 1 = Multiword DMA mode 0 is selected 0 = Multiword DMA mode 0 is not selected 7:3 Reserved 2 1 = Multiword DMA mode 2 and below are supported 1 1 = Multiword DMA mode 1 and below are supported 0 1 = Multiword DMA mode 0 is supported 64 0003h 65 0078h 66 0078h 67 0078h 68 0078h 15:8 Reserved 7:0 PIO modes supported Minimum Multiword DMA transfer cycle time per word 15:0 Cycle time in nanoseconds Manufacturer’s recommended Multiword DMA transfer cycle time 15:0 Cycle time in nanoseconds Minimum PIO transfer cycle time without flow control 15:0 Cycle time in nanoseconds Minimum PIO transfer cycle time with IORDY flow control 15:0 Cycle time in nanoseconds Additional Supported 15 1 = CFast Specification Support 14 1 = Deterministic read after Trim is supported 13 1 = Long Physical Sector Alignment Error Reporting Control is supported 12 1 = DEVICE CONFIGURATION IDENTIFY DMA and DEVICE CONFIGURATIONSET DMA are supported 69 4C20h 11 1 = READ BUFFER DMA is supported 10 1 = WRITE BUFFER DMA is supported 9 1 = SET MAX SET PASSWORD DMA and SET MAX UNLOCK DMA are supported 8 1 = DOWNLOAD MICROCODE DMA is supported 7 Reserved for IEEE-1667 6 0 = Optional ATA device 28-bit commands supported 5 1 = Read zero after Trim is supported 4:0 Reserved 70 0000h Reserved 71 - 74 X..Xh Reserved for the IDENTIFY PACKET DEVICE command Queue depth 75 001Fh 15:5 Reserved 4:0 Maximum queue depth - 1 www.longsys.com Page 14 Longsys Electronics Rev. A5 mSATA SSD S40R Serial ATA Capabilities 15:13 Reserved for Serial ATA 12 1 = Supports NCQ priority information 11 1 = Supports Unload while NCQ commands are outstanding 10 1 = Supports Phy Event Counters 76 E10Eh 9 1 = Supports receipt of host initiated power management requests 8 1 = Supports the NCQ feature set 7:3 Reserved for Serial ATA 2 1 = Supports SATA Gen2 Signaling Speed (3.0Gb/s) 1 1 = Supports SATA Gen1 Signaling Speed (1.5Gb/s) 0 Shall be cleared to zero 77 00C6h Reserved for Serial ATA Serial ATA features supported 15:7 Reserved for Serial ATA 6 1 = Device supports Software Settings Preservation 5 Reserved for Serial ATA 78 0104h 4 1 = Device supports in-order data delivery 3 1 = Device supports initiating power management 2 1 = Device supports DMA Setup auto-activation 1 1 = Device supports non-zero buffer offsets 0 Shall be cleared to zero Serial ATA features enabled 15:7 Reserved for Serial ATA 6 1 = Software Settings Preservation enabled 5 Reserved for Serial ATA 79 00C4h 4 1 = In-order data delivery enabled 3 1 = Device initiated power management enabled 2 1 = DMA Setup auto-activation enabled 1 1 = Non-zero buffer offsets enabled 0 Shall be cleared to zero Major version number 15:9 Reserved 8 1 = supports ATA8-ACS 7 1 = supports ATA/ATAPI-7 6 1 = supports ATA/ATAPI-6 80 07F8h 5 1 = supports ATA/ATAPI-5 4 1 = supports ATA/ATAPI-4 3 Obsolete 2 Obsolete 1 Obsolete 0 Reserved 81 011Bh www.longsys.com Minor version number Page 15 Longsys Electronics Rev. A5 mSATA SSD S40R Commands and feature sets supported 15 Obsolete 14 1 = The NOP command is supported 13 1 = The READ BUFFER command is supported 12 1 = The WRITE BUFFER command is supported 11 Obsolete 10 1 = The HPA feature set is supported 9 Shall be cleared to zero to indicate that the DEVICE RESET command is not supported 82 7069h 8 1 = The SERVICE interrupt is supported 7 1 = The release interrupt is supported 6 1 = Read look-ahead is supported 5 1 = The volatile write cache is supported 4 Shall be cleared to zero to indicate that the PACKET feature set is not supported 3 Shall be set to one to indicate that the mandatory Power Management feature set is supported 2 Obsolete 1 1 = The Security feature set is supported 0 1 = The SMART feature set is supported Commands and feature sets supported 15 Shall be cleared to zero 14 Shall be set to one 13 1 = The FLUSH CACHE EXT command is supported 12 Shall be set to one to indicate that the mandatory FLUSH CACHE command is supported 11 1 = The DCO feature set is supported 10 1 = The 48-bit Address feature set is supported 9 1 = The AAM feature set is supported 83 7409h 8 1 = The SET MAX security extension is supported 7 Reserved for the Address Offset Reserved Area Boot Method 6 1 = SET FEATURES subcommand is required to spin-up after power-up 5 1 = The PUIS feature set is supported 4 Obsolete 3 1 = The APM feature set is supported 2 1 = The CFA feature set is supported X 1 Obsolete 0 1 = The DOWNLOAD MICROCODE command is supported www.longsys.com Page 16 Longsys Electronics Rev. A5 mSATA SSD S40R Commands and feature sets supported 15 Shall be cleared to zero 14 Shall be set to one 13 1 = The IDLE IMMEDIATE command with UNLOAD feature is supported 12 Reserved for TLC 11 Reserved for TLC 10:9 Obsolete 8 1 = The 64-bit World wide name is supported 84 4160h 7 Obsolete 6 1 = The WRITE DMA FUA EXT and WRITE MULTIPLE FUA EXT commandsare supported 5 1 = The GPL feature set is supported 4 1 = The Streaming feature set is supported 3 1 = The Media Card Pass Through Command feature set is supported 2 1 = Media serial number is supported 1 1 = The SMART self-test is supported 0 1 = SMART error logging is supported Commands and feature sets supported or enabled 15 Obsolete 14 1 = The NOP command is supported 13 1 = The READ BUFFER command is supported 12 1 = The WRITE BUFFER command is supported 11 Obsolete 10 1 = HPA feature set is supported 9 Shall be cleared to zero to indicate that the DEVICE RESET command is not supported 85 0769h 8 1 = The SERVICE interrupt is enabled 7 1 = The release interrupt is enabled 6 1 = Read look-ahead is enabled 5 1 = The volatile write cache is enabled 4 Shall be cleared to zero to indicate that the PACKET feature set is not supported 3 Shall be set to one to indicate that the mandatory Power Management feature set is supported 2 Obsolete 1 1 = The Security feature set is enabled 0 1 = The SMART feature set is enabled www.longsys.com Page 17 Longsys Electronics Rev. A5 mSATA SSD S40R Commands and feature sets supported or enabled 15 1 = Words 119..120 are valid 14 Reserved 13 1 = FLUSH CACHE EXT command supported 12 1 = FLUSH CACHE command supported 11 1 = The DCO feature set is supported 10 1 = The 48-bit Address features set is supported 9 1 = The AAM feature set is enabled 8 1 = the SET MAX security extension is enabled by SET MAX SET 86 B409h PASSWORD 7 Reserved for Address Offset Reserved Area Boot Method 6 1 = SET FEATURES subcommand is required to spin-up after power-up 5 1 = The PUIS feature set is enabled 4 Obsolete 3 1 = The APM feature set is enabled 2 1 = The CFA feature set is supported 1 Obsolete 0 1 = The DOWNLOAD MICROCODE command is supported Commands and feature sets supported or enabled 15 Shall be cleared to zero 14 Shall be set to one 13 1 = The IDLE IMMEDIATE command with UNLOAD FEATURE is supported 12 Reserved for TLC 11 Reserved for TLC 10:9 Obsolete 8 1 = The 64-bit World wide name is supported 87 4160h 7 Obsolete 6 1 = The WRITE DMA FUA EXT and WRITE MULTIPLE FUA EXT commandsare supported 5 1 = The GPL feature set is supported 4 Obsolete 3 1 = The Media Card Pass Through Command feature set is supported 2 1 = Media serial number is valid 1 1 = SMART self-test supported 0 1 = SMART error logging is supported Ultra DMA modes 15 Reserved 14 1 = Ultra DMA mode 6 is selected 88 407Fh 0 = Ultra DMA mode 6 is not selected 13 1 = Ultra DMA mode 5 is selected 0 = Ultra DMA mode 5 is not selected 12 1 = Ultra DMA mode 4 is selected 0 = Ultra DMA mode 4 is not selected www.longsys.com Page 18 Longsys Electronics Rev. A5 mSATA SSD S40R 11 1 = Ultra DMA mode 3 is selected 0 = Ultra DMA mode 3 is not selected 10 1 = Ultra DMA mode 2 is selected 0 = Ultra DMA mode 2 is not selected 9 1 = Ultra DMA mode 1 is selected 0 = Ultra DMA mode 1 is not selected 8 1 = Ultra DMA mode 0 is selected 0 = Ultra DMA mode 0 is not selected 7 Reserved 6 1 = Ultra DMA mode 6 and below are supported 5 1 = Ultra DMA mode 5 and below are supported 4 1 = Ultra DMA mode 4 and below are supported 3 1 = Ultra DMA mode 3 and below are supported 2 1 = Ultra DMA mode 2 and below are supported 1 1 = Ultra DMA mode 1 and below are supported 0 1 = Ultra DMA mode 0 is supported 15:8 Reserved 89 0005h 7:0 Time required for Normal Erase mode SECURITY ERASE UNIT command 15:8 Reserved 90 0005h 7:0 Time required for an Enhanced Erase mode SECURITY ERASE UNIT command 91 00FEh Current APM level value 92 0000h Master Password Identifier Hardware reset result 15 Shall be cleared to zero. 14 Shall be set to one. 13 1 = device detected CBLID- above ViHB 0 = device detected CBLID- below ViLB 12:8 Device 1 hardware reset result. Device 0 shall clear these bits to zero. Device 1 shall set these bits as follows: 12 Reserved. 11 0 = Device 1 did not assert PDIAG-. 93 0000h 1 = Device 1 asserted PDIAG-. 10:9 These bits indicate how Device 1 determined the device number: 00 = Reserved. 01 = a jumper was used. 10 = the CSEL signal was used. 11 = some other method was used or the method is unknown. 8 Shall be set to one. 7:0 Device 0 hardware reset result. Device 1 shall clear these bits to zero. Device 0 shall set these bits as follows: 7 Reserved. www.longsys.com Page 19 Longsys Electronics Rev. A5 mSATA SSD S40R 6 0 = Device 0 does not respond when Device 1 is selected. 1 = Device 0 responds when Device 1 is selected. 5 0 = Device 0 did not detect the assertion of DASP-. 1= Device 0 detected the assertion of DASP-. 4 0 = Device 0 did not detect the assertion of PDIAG-. 3 0 = Device 0 failed diagnostics. 1 = Device 0 passed diagnostics. 2:1 These bits indicate how Device 0 determined the device number: 00 = Reserved. 01 = a jumper was used. 10 = the CSEL signal was used. 11 = some other method was used or the method is unknown. 0 Shall be set to one. Current AAM value 94 0000h 15:8 Vendor’s recommended AAM value. 7:0 Current AAM value. 95 0000h Stream Minimum Request Size 96 0000h Streaming Transfer Time - DMA 97 0000h Streaming Access Latency - DMA and PIO 00000000h Streaming Performance Granularity (DWord) 98 - 99 100 - 103 X..Xh 104 0000h 105 0008h Total Number of User Addressable Logical Sectors for 48-bit commands (QWord) Streaming Transfer Time - PIO Maximum number of 512-byte blocks of LBA Range Entries per DATA SET MANAGEMENT command Physical sector size / logical sector size 15 Shall be cleared to zero 14 Shall be set to one 106 4000h 13 1 = Device has multiple logical sectors per physical sector. 12 1 = Device Logical Sector longer than 256 Words 11:4 Reserved 3:0 2XP logical sectors per physical sector 107 0000h Inter-seek delay for ISO 7779 standard acoustic testing 108 - 111 X..Xh World wide name 112 - 115 X..Xh Reserved 116 0000h Reserved for TLC 00000000h Logical sector size (DWord) 117 - 118 Commands and feature sets supported (Continued from words 82..84) 15 Shall be cleared to zero 119 401Ch 14 Shall be set to one 13:8 Reserved 7 1 = Extended Power Conditions feature set is supported 6 1 = Extended Status Reporting feature set is supported www.longsys.com Page 20 Longsys Electronics Rev. A5 mSATA SSD S40R 5 1 = The Free-fall Control feature set is supported 4 1 = The DOWNLOAD MICROCODE command with mode 3 is supported 3 1 = The READ LOG DMA EXT and WRITE LOG DMA EXT commands are supported 2 1 = The WRITE UNCORRECTABLE EXT command is supported 1 1 = The Write-Read-Verify feature set is supported 0 Reserved for DDT Commands and feature sets supported or enabled (Continued from words 85..87) 15 Shall be cleared to zero 14 Shall be set to one 13:8 Reserved 7 1 = At least one Extended Power Conditions Idle timer is enabled 6 1 = Extended Status Reporting feature set is enabled 120 401Ch 5 1 = The Free-fall Control feature set is enabled 4 1 = The DOWNLOAD MICROCODE command with mode 3 is supported 3 1 = The READ LOG DMA EXT and WRITE LOG DMA EXT commands are supported 2 1 = The WRITE UNCORRECTABLE EXT command is supported 1 1 = The Write-Read-Verify feature set is enabled 0 Reserved for DDT 121 - 126 X..Xh Reserved for expanded supported and enabled settings 127 0000h Obsolete Security status 15:9 Reserved 8 Master Password Capability: 0 = High, 1 = Maximum 7:6 Reserved 128 0000h 5 1 = Enhanced security erase supported 4 1 = Security count expired 3 1 = Security frozen 2 1 = Security locked 1 1 = Security enabled 0 1 = Security supported 129 - 159 X..Xh Vendor specific CFA power mode 15 Word 160 supported 14 Reserved 160 0000h 13 CFA power mode 1 is required for one or more commands implemented by the device 12 CFA power mode 1 disabled 11:0 Maximum current in ma 161 - 167 X..Xh 168 0000h www.longsys.com Reserved for the CompactFlash Association 15:4 Reserved 3:0 Device Nominal Form Factor Page 21 Longsys Electronics Rev. A5 mSATA SSD S40R DATA SET MANAGEMENT is supported 169 0001h 15:1 Reserved 0 1 = the Trim bit in the DATA SET MANAGEMENT is supported 170 - 173 X..Xh Additional Product Identifier (ATA String) 174 - 175 X..Xh Reserved 176 - 205 X..Xh Current media serial number (ATA string) SCT Command Transport 15:12 Vendor Specific 11:6 Reserved 5 The SCT Data Tables command is supported 206 0000h 4 The SCT Feature Control command is supported 3 The SCT Error Recovery Control command is supported 2 The SCT Write Same command is supported 1 Obsolete 0 The SCT Command Transport is supported 207 - 208 00000000h Reserved for CE-ATA. Alignment of logical blocks within a physical block 15 Shall be cleared to zero 209 4000h 14 Shall be set to one 13:0 Logical sector offset within the first physical sector where the first logical sector is placed 210 - 211 00000000h Write-Read-Verify Sector Count Mode 3 (DWord) 212 - 213 00000000h Write-Read-Verify Sector Count Mode 2 (DWord) NV Cache Capabilities 15:12 NV Cache feature set version 11:8 NV Cache Power Mode feature set version 214 0000h 7:5 Reserved 4 1 = NV Cache feature set enabled 3:2 Reserved 1 1 = NV Cache Power Mode feature set enabled 0 1 = NV Cache Power Mode feature set supported 215 - 216 00000000h NV Cache Size in Logical Blocks (DWord) 217 0001h Nominal media rotation rate 218 0000h Reserved NV Cache Options 219 0000h 15:8 Reserved 7:0 Device Estimated Time to Spin Up in Seconds 220 0000h 221 0000h www.longsys.com 15:8 Reserved 7:0 Write-Read-Verify feature set current mode Reserved Page 22 Longsys Electronics Rev. A5 mSATA SSD S40R Transport major version number 0000h or FFFFh = device does not report version 15:12 Transport Type 0h = Parallel 1h = Serial 2h-Fh = Reserved 222 10FFh Parallel Serial 11:6 Reserved Reserved 5 Reserved SATA Rev 3.0 4 Reserved SATA Rev 2.6 3 Reserved SATA Rev 2.5 2 Reserved SATA II: Extensions 1 ATA/ATAPI-7 SATA 1.0a 0 ATA8-APT ATA8-AST 223 0000h Transport minor version number 224 - 233 X..Xh Reserved 234 0008h 235 0400h 236 - 254 X..Xh Minimum number of 512-byte data blocks per DOWNLOAD MICROCODE command for mode 03h Maximum number of 512-byte data blocks per DOWNLOAD MICROCODE command for mode 03h Reserved Integrity word 255 XXXXh 15:8 Checksum 7:0 Checksum Validity Indicator Notes: X = content (byte) is vendor specific and may be fixed or variable. www.longsys.com Page 23 Longsys Electronics Rev. A5 mSATA SSD S40R 7. Product Line up 7.1 SATA3 mSATA Type Capacity MODEL Part Number SATA3 mSATA SSD 32GB S40RM032G FSAGMMC-032G SATA3 mSATA SSD 64GB S40RM064G SATA3 mSATA SSD 128GB S40RM128G SATA3 mSATA SSD 256GB S40RM256G FSAGMMC-064G FSAGMNC-064G FSAGMMC-128G FSAGMNC-128G FSAGMMC-256G FSAGMOC-256G 8. Contact information Tel: +86-755-8616-8848 Fax: +86-755-8616-9388 Email: Website: Add: sales@longsys.com www.longsys.com 8/F, 1 Building, Finance Base,No.8,Kefa Road, High-Tech Park, Shenzhen, China www.longsys.com Page 24 Longsys Electronics
FSAGMMC-128G 价格&库存
很抱歉,暂时无法提供与“FSAGMMC-128G”相匹配的价格&库存,您可以联系我们找货
