S1206-FC-3.0A
S1206-FC-3.0A
    SART(萨特)
S1206-FC-3.0A 数据手册
Surface Mount Fuses File No.: JS-S1206-FC-00 Revision: D Page: 1/6 1206 Size >Fast Acting>S1206-FC Series General • AEC-Q200 Automotive Grade Certified • 3.1mm× 1.6mm physical size • Thick film manufacturing method, ceramic • substrate, silver fusing element • -55℃~125℃ operating temperature • Excellent environmental integrity • RoHS compliant • Halogen-free • Lead free Application Agency / Certificate Information Agency File Number Ampere Range E319512 1.0A~5.0A • Battery pack • PC related equipment and peripherals (Hard driver, Printer, etc.) • Digital camera (Digital still camera) • Game equipment • LCD monitor, LCD modules • Wireless base station • Power supply • Medical device Electrical Specifications Typical Cold DCR* (mΩ) Typical I2T** (A2s) 100 320 0.022 1.5 100 153 0.065 N 2.0 100 100 0.100 S1206-FC-2.5A O 2.5 100 64.5 0.125 S1206-FC-3.0A P 3.0 100 45.5 0.263 S1206-FC-3.5A R 3.5 100 41 0.368 S1206-FC-4.0A S 4.0 100 31 0.480 S1206-FC-5.0A T 5.0 100 16 0.558 Part Number Marking Current Rating (A) Voltage Rating (V) S1206-FC-1.0A H 1.0 S1206-FC-1.5A K S1206-FC-2.0A * Measured at at 10 times of rated current *:Resistance test on the coating surface Interrupting Rating (V) 50A 100V DC ≤10% rated current and 25℃ ** Melting I2T Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S1206-FC-00 Revision: D Page: 2/6 1206 Size >Fast Acting>S1206-FC Series Catalo Part Number Information S 1206—FC—3.0A “3.0A” Ampere Rating: 3A “FC” Electrical Characteristic: FC = Fast action for AEC-Q200 “1206” Size Number “ S” Symbol of SART Shape & Dimensions: (mm) Dimensions Type L (mm) W (mm) T (mm) B (mm) S1206-FC 3.10±0.20 1.60±0.20 0.80±0.20 0.45±0.20 Recommended Land Patterns D Materials A C Components Material Body Ceramic Terminations Silver Element Silver or Silver/Palladium B Type A(mm) B(mm) C(mm) D(mm) S1206-FC 2.00±0.20 4.40±0.50 2.40±0.20 1.20±0.30 Dimensions of Standard Test Board Type Ampere Rating Board Thickness (mm) Copper Layer Thickness (mm) Copper Trace Width (mm) S1206-FC 1.0A~5.0A 1.6 0.035 5.0 Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses 1206 Size >Fast Acting>S1206-FC Series Time Current Curve Ti File No.: JS-S1206-FC-00 Revision: D Page: 3/6 I2T VS Time Curve Electrical Characteristics Type S1206-FC Ampere Rating % of Current Rating Opening Time 1.0A~5.0A 100 >4hours 1.0A~5.0A 350 ≤5sec 1.0A~5.0A 1000 >0.1ms Temperature Derating Curve Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses 1206 Size >Fast Acting>S1206-FC Series File No.: JS-S1206-FC-00 Revision: D Page: 4/6 Product Characteristics Item Test condition/ Methods Performance Standard 100% of current rating No Fusing, 4hours Min. UL248-14 350% of current rating ≤5sec SART SPEC. IEC60127-4 1000% of current rating >0.1ms IEC60127-4 Voltage Drop 100% of current rating Deviation between the mean value: <15% 1.0A~1.5A<500mV 2.0A~5.0A<300mV IEC-60127-4 Endurance Test Repeating 100 cycles of 1In for 1hour “ON”, for 15min “OFF”, then following by 1hour of 1.25In and testing Temperature rise Interrupting Ability 50A 100V DC without permanent arcing, ignition and bursting of fuse link UL248-14 IEC60127-1 Solderability 235℃±5℃, 5sec±0.5sec 95% coverage Min. J-STD-002 Resistance to Soldering 260℃±5℃, 10sec±0.5sec |△R|:<10% Legible appearance MIL-STD-202 Method 210 Bending Test Distance between holding points: 90mm Bending: 2mm, time: 60sec |△R|:<10% No mechanical damages ACE-Q200-005 High Temperature Operating Life T=125℃±2℃, 60%In, 1000hours |△R|: <10%; No fusing MIL-STD-202 Method 108 Humidity (Steady State) T=85℃±2℃, 85%RH, 1000hours |△R|: <10% MIL-STD-202 Method 103 Low Temperature Storage T=-55℃±3℃,96hours |△R|: <10% IEC60068-2-1 High Temperature Storage T=125℃±2℃,1000hours |△R|: <10% MIL-STD-202 Salt Spray 5% salt solution,96hours |△R|: <10% Legible appearance MIL-STD-202 Method 101 Time/Current |△R|:<10% △T<75℃ IEC-60127-4 Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses 1206 Size >Fast Acting>S1206-FC Series File No.: JS-S1206-FC-00 Revision: D Page: 5/6 Thermal Shock 100 cycles between -65℃/+125℃ 60 minutes, each extreme |△R|: <10%R No mechanical damages JESD22 Method JA-104 Moisture Resistance 10 cycles between the specified humidity 24 hours, each cycles |△R|: <10%R MIL-STD-202 Terminal Strength Side thrust: 17.7N, time: 60sec |△R|: <10%R AEC-Q200-006 Mechanical shock Pulse acceleration:1000m/s2 time: 6 millisecond stock number:18 times |△R|: <10%R MIL-STD-202 Method 213 Vibration High Frequency Frequency: 10Hz~2000Hz, Displacement amplitude: 0.75mm, Acceleration: 150m/s2,time: 12 hours |△R|: <10%R MIL-STD-202 Method 204 Recommended Solder Curve 1. Infrared Reflow: • Temperature: 260℃ • Time: 5sec Max. • Recommend Reflow profile 2. Wave soldering • Reservoir Temperature: 260℃ • Time in Reservoir: 10secMax. Profile Feature Average Ramp-up Rate(Tsmax to Tp) Preheat Temperature Min.(Tsmin) Temperature Max.(Tsmax) Time(tsmin to tsmax) Peak Temperature(Tp) Time within 5℃ of actual Peak Temperature(tp) Pb-Free Assembly Melting tin time(tL) 60sec~150sec Ramp-down Rate 6℃/sec Max. Time 25℃ to peak Temperature 8minutes Max. 3℃/sec Max. 150℃ 200℃ 60sec~120sec 260℃ 20sec 3.Hand Soldering • Temperature: 350℃ • Time: 5secMax. Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S1206-FC-00 Revision: D Page: 6/6 1206 Size >Fast Acting>S1206-FC Series Packaging • 5000 pieces of fuses in emboss taper and reeled on a 178mm(7 inch) reel. Type A(mm) B(mm) W(mm) E(mm) F(mm) S1206-FC 3.50±0.20 1.90±0.20 8.00±0.20 1.75±0.10 3.50±0.05 Type P(mm) P0(mm) P1(mm) D0(mm) T(mm) S1206-FC 4.00±0.10 4.00±0.10 2.00±0.10 1.50±0.10 0.91±0.10 Type M(mm) W(mm) T(mm) A(mm) B(mm) C(mm) D(mm) S1206-FC 178.00±2.00 9.50±1.00 12.50±1.50 2.00±0.50 13.00±0.50 21.00±0.50 58.00±2.00 Storage: • The ambient temperature recommended for storage shall be between 5℃~30℃ • The relative humidity recommended for storage shall be between 25%RH~60%RH • Sealed plastic bags with desiccant shall be used to reduce the oxidation of the termination and shall only be opened prior to use • The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com
S1206-FC-3.0A 价格&库存
很抱歉,暂时无法提供与“S1206-FC-3.0A”相匹配的价格&库存,您可以联系我们找货
