AW33901/AW33902/AW33905
AW33909/AW33910
Sep. 2018 V1.2
Over-Voltage Protection Load Switch
FEATURES
GENERAL DESCRIPTION
Highly reliable1.2mm × 1.2mm FCQFN-9
package
Integrated low Rdson nFET switch: typical 30m
5A continuous current capability
Default Over-Voltage Protection (OVP) threshold
AW33901: 5.95V
AW33902: 6.2V
AW33905: 6.8V
AW33909: 9.98V
AW33910: 10.5V
OVP threshold adjustable range: 4V to 20V
Input maximum voltage rating: 32VDC
Fast turn-off response: typical 50ns
Over-Temperature Protection (OTP)
Under-Voltage Lockout (UVLO)
The AW339XX features an ultra-low 30m (typ.)
Rdson nFET load switch. When input voltage
exceeds the OVP threshold, the switch is turned off
very fast to prevent damage to the protected
downstream devices. The IN pin is capable of
withstanding fault voltages up to 32VDC.
The default OVP threshold is 5.95V (AW33901),
6.2V (AW33902), 6.8V (AW33905), 9.98V
(AW33909) and 10.5V (AW33910). The OVP
threshold can be adjusted from 4V to 20V through
external OVLO pin.
The device features an open-drain output ACOK,
when VIN_UVLO VIN_UVLO to ACOK
low
30
ms
tON
Switch turn-on time
RL = 100, CL = 22F, VOUT
from 10% VIN to 90% VIN
2
ms
tOFF
Switch turn-off time
CL = 0F, RL = 100, VIN >
VIN_OVLO to VOUT stop rising,
VIN rise at 10V/s
50
ns
tDEB
tSTART
TIMING DIAGRAM
OVP trip level
VIN
tDEB
tDEB
VOUT
tON
VACOK
tON
tOFF
tSTART
tSTART
Figure 6 Timing diagram
www.awinic.com.cn
9
Copyright © 2016 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW33909/AW33910
Sep. 2018 V1.2
TYPICAL CHARACTERISTICS
Table 1 Table of Figures
INDEX
Figure No
Rdson vs. Output Current
FIGURE 7
Rdson vs. Temp. (IOUT = 1A)
FIGURE 8
Rdson vs. Input Voltage (IOUT = 1A)
FIGURE 9
Input Supply Current vs. Supply Voltage
FIGURE 10
Normalized Internal OVP Threshold
FIGURE 11
External OVP Threshold
FIGURE 12
Power-up (COUT = 1F, 100mA load)
FIGURE 13
Power-up (COUT = 100F, 100mA load)
FIGURE 14
OVP Response (AW33905)
FIGURE 15
400V Surge Response (AW33905 with 12V TVS)
FIGURE 16
VIN = 5V, VOVLO = 0V, CIN = 0.1F, COUT = 1F, and TA = 25°C unless otherwise specified.
40.0
50.0
35.0
Rdson(mΩ)
Rdson(mΩ)
45.0
40.0
35.0
30.0
30.0
25.0
20.0
25.0
2
3
4
5
-40
Output Current(A)
Figure 7 Rdson vs. Output Current
www.awinic.com.cn
-15
10
35
60
85
Temperature(℃)
Figure 8 Rdson vs. Temp. (IOUT = 1A)
10
AW33909/AW33910
Sep. 2018 V1.2
TYPICAL CHARACTERISTICS (CONTINUED)
40.0
Input Supply Current (A)
400
Rdson(mΩ)
35.0
30.0
25.0
350
–40°
C
300
25°
C
85°
C
250
200
150
100
50
20.0
8
12
16
10
Input Voltage(V)
30
35
Input Voltage (V)
Figure 9 Rdson vs. Input Voltage (IOUT = 1A)
Figure 10 Input Supply Current vs. Supply Voltage
1.10
External OVP Threshold Voltage
Normalized Threshold Voltage
15
Normalized to TA = 25°
C
1.05
1.00
0.95
0.90
1.22
1.21
1.20
1.19
1.18
-40
-15
10
35
Temperature (°C)
60
85
-40
Figure 11 Normalized Internal OVP Threshold
-15
10
35
Temperature (°C)
VIN
5V / div
C1
C1
VOUT
5V / div
20ms / div
IOUT
500mA / div
C4
20ms / div
Figure 13 Power-up (COUT = 1F, 100mA load).
www.awinic.com.cn
ACOK
2V / div
C3
IOUT
100mA / div
C4
VOUT
5V / div
C2
ACOK
2V / div
C3
85
Figure 12 External OVP Threshold
VIN
5V / div
C2
60
Figure 14 Power-up (COUT = 100F, 100mA load)
11
AW33909/AW33910
Sep. 2018 V1.2
VIN
5V / div
C1
C2
VOUT
5V / div
C3
ACOK
2V / div
Figure 15 OVP Response (AW33905)
IIN
100A / div
C2
VOUT
5V / div
C3
1ms / div
www.awinic.com.cn
VIN
10V / div
C1
20us / div
Figure 16 400V Surge Response (AW33905 with 12V TVS)
12
AW33909/AW33910
Sep. 2018 V1.2
DETAILED FUNCTIONAL DESCRIPTION
Device Operation
If the input voltage is between UVLO and OVP threshold, the internal charge pump begins to work after
debounce time, the gate of the nFET switch will be slowly charged high till the switch is fully on. ACOK will be
driven low about 30ms after VIN valid, indicating the switch is on with a good power input. If the input voltage
exceeds the OVP trip level, the switch will be turned off in about 50ns. If input voltage falls below UVLO threshold,
or over-temperature happens, the switch will also be turned off.
If the input voltage exceeds the OVP rising trip level, the switch will be turned off in about 50ns. The switch will
remain off until VIN falls below the OVP falling trip level.
OVP Threshold Adjustment
If the default OVP threshold is used, OVLO pin must be grounded. If OVLO pin is not grounded, and by
connecting external resistor divider to OVLO pin as shown in the typical application circuit, between IN and GND,
the OVP threshold can be adjusted as following:
VIN_OVLO =
R1+R2
VOVLO_TH
R2
The adjustment range is 4V to 20V. When the OVLO pin voltage VOVLO exceeds VOVLO_SEL (0.26V typical), VOVLO
is compared with the reference voltage VOVLO_TH (1.2V typical) to judge whether input supply is over-voltage. It
is recommended that the total resistance of R1 and R2 is less than 100kΩ.For example, if we select R1 = 51kΩ
and R2 = 12.4kΩ, then the new OVP threshold calculated from the above formula is 6.14V.
ACOK Output
The device features an open-drain output ACOK, it should be connected to the system I/O rail through a pullup resistor. If the device is enabled and VIN_UVLO260°C
Time within 5°C of actual peak temp
20-40 sec
Ramp-down rate
Max. 6°C /sec
Time from 25°C to peak temp
Max. 8min
NOTE 1: All data are compared with the package-top temperature, measured on the package surface;
NOTE 2: AW339XX adopted the Pb-Free assembly.
www.awinic.com.cn
19
AW33909/AW33910
Sep. 2018 V1.2
REVISION HISTORY
Vision
Date
V0.9
November 2017
Change Record
Datasheet V0.9 Released.
1. Added AW33901 part number.
V1.0
December,2017
2. Added Typical Characteristics.
3. Added Tape and Reel information.
4. Added Solder Mask Details.
1. Modified Reel information.
V1.1
February,2018
2. Modified POD information.
3. Modified Solder Mask Details.
V1.2
www.awinic.com.cn
September, 2018
Storage Temperature Modified
AW33909/AW33910
Sep. 2018 V1.2
DISCLAIMER
Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology
Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the
accuracy or completeness of such information and shall have no liability for the consequences of use of such
information.
AWINIC Technology reserves the right to make changes to information published in this document, including
without limitation specifications and product descriptions, at any time and without notice. Customers shall
obtain the latest relevant information before placing orders and shall verify that such information is current and
complete. This document supersedes and replaces all information supplied prior to the publication hereof.
AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical,
military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC
Technology product can reasonably be expected to result in personal injury, death or severe property or
environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology
products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications that are described herein for any of these products are for illustrative purposes only. AWINIC
Technology makes no representation or warranty that such applications will be suitable for the specified use
without further testing or modification.
All products are sold subject to the general terms and conditions of commercial sale supplied at the time of
order acknowledgement.
Nothing in this document may be interpreted or construed as an offer to sell products that is open for
acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other
industrial or intellectual property rights.
Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is
without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC
is not responsible or liable for such altered documentation. Information of third parties may be subject to
additional restrictions.
Resale of AWINIC components or services with statements different from or beyond the parameters stated by
AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC
component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for
any such statements.
www.awinic.com.cn
21
