PTD15N10
100 V/15A N-Channel Advanced Power MOSFET
Features
V DS
100
V
N-Channel,5V Logic Level Control
R DS(on),typ@VGS=10V
78
mΩ
Enhancement mode
R DS(on),typ@VGS=4.5V
82
mΩ
ID
15
A
Very low on-resistance @ VGS=4.5 V
Fast Switching
100% Avalanche test
Pb-free lead plating; RoHS compliant
To-252
Maximum ratings, at T j=25 °C, unless otherwise specified
Symbol
V(BR)DSS
VGS
ID
Parameter
Rating
Unit
100
V
±20
V
TC =25°C
15
A
TC =70°C
9.6
A
Drain-Source breakdown voltage
Gate-Source voltage
Continuous drain current@VGS=10V
IDM
Pulse drain current tested ①
TC =25°C
40
A
PD
Maximum power dissipation
TC =25°C
30
W
IS
Diode Continuous Forward Current
TC =25°C
15
A
IAS
Avalanche Current Max
L=0.5mH
11
A
9
mJ
-55 to 175
°C
EAS
Avalanche energy, single pulsed ②
TSTG , TJ
Storage and operating temperature range
Thermal characteristics
R JA
Thermal Resistance Junction-Ambient
60
°C/W
R JC
Thermal Resistance-Junction to Case
5
°C/W
- 1-
2015-3-26
PTD15N10
Typical Electrical Characteristics
Symbol
Parameter
Condition
Min.
Typ.
Max.
Unit
Static Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
100
V
Zero Gate Voltage Drain Current(Tc=25℃)
VDS=100V,VGS=0V
1
μA
Zero Gate Voltage Drain Current(Tc=125℃)
VDS=100V,VGS=0V
100
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.0
2.0
3.0
V
RDS(ON)
Drain-Source On-State Resistance③
VGS=10V, ID=10A
78
90
mΩ
RDS(ON)
VGS=4.5V, ID=5A
82
100
mΩ
525
pF
V(BR)DSS
IDSS
Dynamic Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
Ciss
Input Capacitance
Coss
Output Capacitance
VDS=30V,VGS=0V,
41
pF
Crss
Reverse Transfer Capacitance
f=1MHz
36
pF
Rg
Gate Resistance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
2.6
VDS=50V,ID=3A,
VGS=10V
Ω
15.6
nC
3.2
nC
4.4
nC
8
nS
Switching Characteristics
t d(on)
Turn-on Delay Time
tr
Turn-on Rise Time
ID=1A,
4.5
nS
t d(off)
Turn-Off Delay Time
RG=6.8Ω,
26
nS
tf
Turn-Off Fall Time
3.8
nS
VDD=50V,
VGS=4.5V
Source- Drain Diode Characteristics@ TJ = 25°C (unless otherwise stated)
VSD
Forward on voltage
t rr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
ISD=10A,VGS=0V
0.89
1.20
V
Tj=25℃,Isd=10A,
26
nS
VGS=0V
di/dt=500A/μs
115
nC
NOTE:
①
Repetitive rating; pulse width limited by max. junction temperature
② Limited by TJmax, starting TJ = 25°C, L = 0.5mH,RG = 25Ω, IAS = 6A, VGS =10V. Part not recommended for use above this value.
③ Pulse width ≤ 300μs; duty cycle≤ 2%.
- 2-
2015-3-26
PTD15N10
ID, Drain-Source Current (A)
VGS(TH), Gate -Source Voltage (V)
Typical Characteristics
Fig1. Typical Output Characteristics
Fig2. VGS(TH) Gate -Source Voltage Vs.Tj
Normalized On Resistance
Tj - Junction Temperature (°C)
VDS, Drain -Source Voltage (V)
Fig3. Typical Transfer Characteristics
Fig4. Normalized On-Resistance Vs. Tj
ID - Drain Current (A)
ISD, Reverse Drain Current (A)
VGS, Gate -Source Voltage (V)
VSD, Source-Drain Voltage (V)
Fig5. Typical Source-Drain Diode Forward Voltage
Fig6. Maximum Safe Operating Area
- 3-
2015-3-26
PTD15N10
C, Capacitance (pF)
VGS, Gate-Source Voltage (V)
VDS, Drain-Source Voltage (V)
Qg, Total Gate Charge (nC)
Fig8. Typical Gate Charge Vs. Gate-Source Voltage
Thermal Resistance
ZqJA Normalized Transient
Fig7. Typical Capacitance Vs. Drain-Source Voltage
Pulse Width (s)
Fig9. Normalized Maximum Transient Thermal Impedance
Fig10. Unclamped Inductive Test Circuit and waveforms
Fig11. Switching Time Test Circuit and waveforms
- 4-
2015-3-26
很抱歉,暂时无法提供与“PTD15N10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.87254
- 50+0.71702
- 150+0.63926
- 500+0.58094
- 2500+0.46862
- 5000+0.44529
