APSE2R5EC3681MH06S
APSE2R5EC3681MH06S
    NCC(贵弥功)
    插件,D6.3xL8mm
    贴片铝电解电容 AEC_D6.3X8MM_TM
APSE2R5EC3681MH06S 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP PSE - Series Radial Lead PSE ・Super low ESR, high ripple current capability ・Endurance : 20,000 hours at 105℃ ・Rated voltage range : 2.5 to 6.3Vdc ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant ・Halogen Free Longer life Downsized PSC ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current *Note Dissipation Factor (tanδ) Low Temperature Characteristics (Max.Impedance Ratio) Endurance Bias Humidity Test Surge Voltage Test -55 to +105℃ 2.5 to 6.3Vdc ±20% (M) I=0.2CV or 500μA, whichever is greater Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) 0.10 max. (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.15 Z(-55℃)/Z(+20℃)≦1.25 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 20,000 hours at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦150% of the initial specified value ESR ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to DC voltage at 60℃, 90 to 95% RH for 1,000 hours. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦The initial specified value ESR ≦The initial specified value Leakage current ≦The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105℃ for 30 seconds through a protective resistor(R=1kΩ) and discharge for 5 minutes 30 seconds. Rated voltage (Vdc) 2.5 4.0 6.3 Surge voltage (Vdc) 2.9 4.6 7.2 Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦The initial specified value ESR ≦The initial specified value Leakage current ≦The initial specified value 0.5% per 1,000 hours maximum (Confidence level 60% at 105℃) Failure Rate *Note : If any doubt arises, measure the leakage current after the following voltage treatment. Voltage treatment : DC rated voltage is applied to the capacitors for 120 minutes at 105℃. ◆DIMENSIONS [mm] ● Terminal Code : E φD' φd F±0.5 Coated Case L' 15min. Size code φD φd F φD' L' F08 6.3 0.6 2.5 φD+0.5max. L+1.5max. ◆MARKING EX) 2.5V820µF E 6D6 820 2.5V 4min. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Radial Lead PSESeries - ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 A PSE 2 R 5 E AA 5 6 1 M F 0 8 S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 820µF:821) Lead forming·Taping code Terminal code Voltage code (ex. 2.5V:2R5, 4V:4R0, 6.3V:6R3) Series code Category Please refer to "Product code guide (conductive polymer type)" ◆STANDARD RATINGS WV (Vdc) Cap (µF) 2.5 4 820 560 470 560 6.3 Case size φD×L(mm) ESR (mΩ max./20℃, 100k to 300kHz) 6.3 ×8 6.3×8 6.3 ×8 6.3× 8 7 7 8 8 Rated ripple current (mArms/105℃, 100kHz) Part No. 5,000 5,000 4,700 4,700 APSE2R5E□□821MF08S APSE4R0E□□561MF08S APSE6R3E□□471MF08S APSE6R3E□□561MF08S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Radial lead type 120 0.10 1k 0.35 10k 0.60 50k 0.80 100k to 500k 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
APSE2R5EC3681MH06S 价格&库存
很抱歉,暂时无法提供与“APSE2R5EC3681MH06S”相匹配的价格&库存,您可以联系我们找货
