SUCS6123R3B
SUCS6123R3B
    COSEL
    SMD-6P,32.6x18.6mm
    COSEL SUCS6123R3B是一款高效DC-DC转换器,具有单输出功能。它支持9V至18V的输入电压范围,输出电压为3.3V,最大输出电流为1.35A。该产品采用SMD封装,提供过流保护和远程O...
SUCS6123R3B 数据手册
DC-DC Converters PCB Mount Type Low Profile Isolated OCP Safety Approvals SUS, SUW-series / SUCS, SUCW-series / SUTS, SUTW-series Feature SMD mounting type and through-hole mounting type High efficiency (synchronous rectifier circuit) Built-in overcurrent protection circuits Built-in remote ON/OFF (SU / SUC / SUT 3-10) High reliability : not built-in aluminum and tantalum electrolytic capacitor CE marking Low Voltage Directive RoHS Directive Safety agency approvals UL60950-1, C-UL, EN62368-1 5-year warranty January 31, 2022 SU.SUC/SUT-1 Ordering information DC-DC Converters PCB Mount Type SUS1R5 SU S 1R5 12 05 1 2 3 4 5 B 6 P 7 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray (SMD type) R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUS1R5053R3 1.32 VOLTAGE[V] *1 3.3 CURRENT[A] 0.4 SUS1R50505 1.5 5 0.3 SUS1R50512 1.56 12 0.13 SUS1R50515 1.5 15 0.1 SUS1R5123R3 1.32 3.3 0.4 SUS1R51205 1.5 5 0.3 SUS1R51212 1.56 12 0.13 SUS1R51215 1.5 15 0.1 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) OVERCURRENT PROTECTION MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUS1R5053R3 SUS1R50505 SUS1R50512 SUS1R50515 SUS1R5123R3 DC4.5 - 9 DC9 - 18 0.377typ 0.153typ 0.405typ 0.422typ 0.405typ 70typ 72typ 74typ 74typ 74typ 3.3 3.3 5 12 15 0.4 0.4 0.3 0.13 0.1 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically SUS1R5243R3 1.32 VOLTAGE[V] *1 3.3 CURRENT[A] 0.4 SUS1R52405 1.5 5 0.3 SUS1R52412 1.56 12 0.13 SUS1R52415 1.5 15 0.1 SUS1R5483R3 1.32 3.3 0.4 SUS1R51205 SUS1R51212 SUS1R51215 0.164typ 76typ 5 0.3 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.171typ 76typ 12 0.13 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.164typ 76typ 15 0.1 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS1R54805 1.5 5 0.3 SUS1R54812 1.56 12 0.13 SUS1R54815 1.5 15 0.1 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) OVERCURRENT PROTECTION SU.SUC/SUT-2 SUS1R5243R3 SUS1R52405 SUS1R52412 SUS1R52415 SUS1R5483R3 DC18 - 36 DC36 - 76 0.076typ 0.038typ 0.082typ 0.084typ 0.081typ 72typ 72typ 76typ 77typ 77typ 3.3 3.3 5 12 15 0.4 0.4 0.3 0.13 0.1 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 50max 50max 150max 180max 80max 80max 80max 240max 290max 20max 20max 20max 48max 60max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically January 31, 2022 SUS1R54805 SUS1R54812 SUS1R54815 0.041typ 76typ 5 0.3 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.042typ 77typ 12 0.13 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.041typ 77typ 15 0.1 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS1R5 GENERAL SPECIFICATIONS ISOLATION INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 21.4X6.5X12.2mm [0.84X0.26X0.48 inches] (WXHXD) / 2g max Convection/Forced air *1 SUW1R5xx12/SUW1R5xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Model +Vout Recommended Pad and Hole dia. (TOP VIEW) +Vin type B 1.4 type C [0.004] [0.26] Adsorption area º6min 6.5 0˚) [0.13] [0.24] 23.62 ±0.6 (0-1 1.8 ±0.3 [0.07] 3.2 25.22 [0.99] 0.1min [0.84] Pin terminal part details [0.3] 7.62 ±0.2 21.4 3.2 [0.13] [0.1] 2.54 ±0.2 [0.48] 12.2 [0.07] -Vout [0.02] 0.6 ±0.1 [0.3] 7.62±0.2 -Vin (1.75) TRM [0.06] 1. SMD(type B) [0.93] 5-º0.9 Coplanarity within 0.1 [0.04] [0.004] Unit : 0.1inch Dimensions in mm, [ ]=inches 2. DIP(type C) Model +Vout ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 2g max +Vin [0.3] 7.62 ±0.2 21.4 [0.1] 2.54 ±0.2 [0.02] 6.5 [0.26] [0.48] [0.3] -Vin 3.68 ±0.25 [0.14] 12.2 -Vout 0.6±0.1 7.62 ±0.2 TRM 0.1min [0.84] [0.004] 20.32 [0.8] January 31, 2022 SU.SUC/SUT-3 Ordering information DC-DC Converters PCB Mount Type SUW1R5 SU W 1R5 12 12 1 2 3 4 5 DC OUTPUT P 7 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray (SMD type) R MODEL MAX OUTPUT WATTAGE[W] B 6 SUW1R50512 1.56 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.065 SUW1R50515 1.5 t15 or +30 0.05 SUW1R51212 1.56 t12 or +24 0.065 SUW1R51215 1.5 t15 or +30 0.05 SUW1R52412 1.56 t12 or +24 0.065 SUW1R52415 1.5 t15 or +30 0.05 SUW1R54812 1.56 t12 or +24 0.065 SUW1R54815 1.5 t15 or +30 0.05 SUW1R51215 SUW1R52412 DC18 - 36 0.167typ 0.087typ 75typ 75typ t15(+30) t12(+24) SUW1R52415 SUW1R54812 DC36 - 76 0.083typ 0.043typ 75typ 75typ t15(+30) t12(+24) SUW1R54815 0.05 75max 750max 120max 150max 150max 200max 180max 290max 60max 0.05 75max 750max 120max 150max 150max 200max 180max 290max 60max SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION ISOLATION INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD PROTECTION CIRCUIT AND OTHERS SUW1R50512 DC4.5 - 9 0.433typ 72typ t12(+24) SUW1R50515 SUW1R51212 DC9 - 18 0.417typ 0.173typ 72typ 75typ t15(+30) t12(+24) 0.065 0.05 0.065 60max 75max 60max 600max 750max 600max 120max 120max 120max 150max 150max 150max 150max 150max 150max 200max 200max 200max 150max 180max 150max 240max 290max 240max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable 0.065 60max 600max 120max 150max 150max 200max 150max 240max 50max by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 21.4X6.5X12.2mm [0.84X0.26X0.48 inches] (WXHXD) / 2g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-4 0.065 60max 600max 120max 150max 150max 200max 150max 240max 50max 0.042typ 75typ t15(+30) 0.05 75max 750max 120max 150max 150max 200max 180max 290max 60max January 31, 2022 SUW1R5 External view Model +Vout +Vin Recommended Pad and Hole dia. (TOP VIEW) COM [0.3] 3.2 [0.13] [0.1] 2.54±0.2 21.4 1.4 [0.1] 7.62±0.2 2.54±0.2 [0.48] 12.2 [0.07] -Vout type B [0.02] 0.6 ±0.1 [0.3] 7.62±0.2 (1.75) TRM -Vin Adsorption area º6min [0.26] 6.5 0˚) [0.07] [0.24] 23.62 ±0.6 (0-1 1.8 ±0.3 [0.13] type C [0.004] Pin terminal part details 3.2 25.22 [0.99] 0.1min [0.84] [0.06] 1. SMD(type B) [0.93] 6-º0.9 Coplanarity within 0.1 [0.04] [0.004] Unit : 0.1inch Dimensions in mm, [ ]=inches +Vout Model +Vin 21.4 [0.84] 7.62 ±0.2 [0.1] 6.5 [0.26] [0.1] [0.02] 3.68±0.25 [0.14] 2.54 ±0.2 [0.3] [0.48] 12.2 -Vout -Vin 0.6 ±0.1 7.62 ±0.2 TRM 2.54 ±0.2 COM ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 2g max [0.3] 2. DIP(type C) 0.1min [0.004] 20.32 [0.8] January 31, 2022 SU.SUC/SUT-5 DC-DC Converters PCB Mount Type SUS3 Ordering information SU S 1 2 3 12 05 B 3 4 5 DC OUTPUT P -O 7 8 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7 Packing form Blank:Plastic cover P : Tray (SMD type) 8 Optional G : C apacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] 6 SUS3053R3 1.98 VOLTAGE[V] *1 3.3 CURRENT[A] 0.6 SUS3123R3 1.98 3.3 0.6 SUS31205 3 5 0.6 SUS31212 3 12 0.25 SUS31215 3 15 0.2 SUS3053R3 SUS30505 SUS30512 SUS30515 SUS3123R3 DC4.5 - 9 DC9 - 18 0.780typ 0.760typ 0.760typ 0.536typ 0.218typ 77typ 79typ 79typ 74typ 76typ 5 12 15 3.3 3.3 0.6 0.25 0.2 0.6 0.6 20max 48max 60max 20max 20max 40max 100max 120max 40max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUS31205 SUS31212 SUS31215 0.317typ 79typ 5 0.6 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.309typ 81typ 12 0.25 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.313typ 80typ 15 0.2 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS3483R3 1.98 3.3 0.6 SUS34805 3 5 0.6 SUS34812 3 12 0.25 SUS34815 3 15 0.2 SUS3243R3 SUS32405 SUS32412 SUS32415 SUS3483R3 DC18 - 36 DC36 - 76 0.110typ 0.056typ 0.159typ 0.155typ 0.157typ 75typ 74typ 79typ 81typ 80typ 3.3 3.3 5 12 15 0.6 0.6 0.6 0.25 0.2 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 50max 50max 150max 180max 80max 80max 80max 240max 290max 20max 20max 20max 48max 60max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUS34805 SUS34812 SUS34815 0.080typ 79typ 5 0.6 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.078typ 81typ 12 0.25 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.078typ 81typ 15 0.2 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS30505 3 5 0.6 SUS30512 3 12 0.25 SUS30515 3 15 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUS3243R3 1.98 VOLTAGE[V] *1 3.3 CURRENT[A] 0.6 SUS32405 3 5 0.6 SUS32412 3 12 0.25 SUS32415 3 15 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-6 January 31, 2022 SUS3 GENERAL SPECIFICATIONS ISOLATION INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 24X6.5X15.1mm [0.94X0.26X0.59 inches] (WXHXD) / 3g max Convection/Forced air *1 SUW3xx12/SUW3xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Recommended Pad and Hole dia. (TOP VIEW) type B 1.SMD(type B) +Vout Model +Vin 1.4 [0.06] TRM RC -Vout [0.13] [1.09] type C [0.004] Pin terminal part details [0.26] [0.24] 6-º0.9 [0.04] 0˚) 6.5 Adsorption area º6min (0-1 [0.07] 3.2 27.76 0.1min [0.94] 1.8 ±0.3 [0.3] 7.62±0.2 2.54±0.2 24 3.2 [0.13] [0.1] 15.1 [0.59] [0.07] (1.8) [0.02] 0.6 ±0.1 [0.3] [0.1] 2.54±0.2 7.62±0.2 -Vin Unit : 0.1inch Dimensions in mm, [ ]=inches 26.16 ±0.6 Coplanarity within 0.1 [1.03] [0.004] ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 3g max 2.DIP(type C) +Vout Model +Vin TRM RC -Vout 3.68 ±0.25 [0.14] 6.5 [0.26] 24 [0.3] [0.1] 7.62±0.2 0.1min 2.54 ±0.2 [0.59] 15.1 0.6±0.1 [0.02] [0.3] [0.1] 2.54±0.2 7.62 ±0.2 -Vin [0.004] [0.94] 22.86 [0.9] January 31, 2022 SU.SUC/SUT-7 Ordering information DC-DC Converters PCB Mount Type SUW3 SU W 1 2 3 12 12 B 3 4 5 6 P -O 7 8 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray (SMD type) 8 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUW30512 3.12 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.13 SUW30515 3 t15 or +30 0.1 SUW31212 3.12 t12 or +24 0.13 SUW31215 3 t15 or +30 0.1 SUW32412 3.12 t12 or +24 0.13 SUW32415 3 t15 or +30 0.1 SUW34812 3.12 t12 or +24 0.13 SUW34815 3 t15 or +30 0.1 SUW32415 SUW34812 DC36 - 76 0.161typ 0.084typ 78typ 78typ ( ) 15 +30 t t12(+24) SUW34815 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION REMOTE ON/OFF INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD SUW30512 DC4.5 - 9 0.822typ 76typ t12(+24) SUW30515 SUW31212 DC9 - 18 0.790typ 0.334typ 76typ 78typ ( ) 15 +30 t t12(+24) SUW31215 SUW32412 DC18 - 36 0.321typ 0.167typ 78typ 78typ ( ) 15 +30 t t12(+24) 0.13 0.1 0.13 0.1 0.13 0.1 0.13 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 24X6.5X15.1mm [0.94X0.26X0.59 inches] (WXHXD) / 3g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-8 0.081typ 78typ t15(+30) 0.1 75max 750max 120max 150max 150max 200max 180max 290max 60max January 31, 2022 SUW3 External view 1.SMD(type B) Recommended Pad and Hole dia. (TOP VIEW) type B +Vout COM Model +Vin 2.54 ±0.2 1.4 [0.06] [0.3] 27.76 [0.13] [1.09] type C [0.004] Adsorption area º6min Pin terminal part details [0.26] 7-º0.9 [0.04] 0˚) 6.5 [0.24] (0-1 1.8 ±0.3 3.2 3.2 [0.13] 0.1min [0.94] [0.07] [0.1] [0.59] 15.1 [0.07] (1.8) [0.02] 0.6±0.1 [0.3] [0.1] 7.62 ±0.2 2.54 ±0.2 24 7.62 ±0.2 -Vout -Vin [0.1] 2.54 ±0.2 TRM RC Unit : 0.1inch Dimensions in mm, [ ]=inches 26.16 ±0.6 Coplanarity within 0.1 [1.03] [0.004] [0.26] [0.1] 0.1min 24 7.62 ±0.2 [0.1] [0.59] 15.1 0.6 ±0.1 [0.02] 7.62 ±0.2 [0.3] [0.1] 2.54 ±0.2 [0.14] 6.5 2.54 ±0.2 -Vout -Vin 2.54 ±0.2 TRM RC [0.3] COM Model +Vin 3.68 ±0.25 ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 3g max +Vout 2.DIP(type C) [0.004] [0.94] 22.86 [0.9] January 31, 2022 SU.SUC/SUT-9 DC-DC Converters PCB Mount Type SUS6 Ordering information SU S 1 2 6 12 05 B 3 4 5 DC OUTPUT P -O 7 8 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7 Packing form Blank:Plastic cover P : Tray (SMD type) 8 Optional G : C apacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] 6 SUS6053R3 3.96 VOLTAGE[V] *1 3.3 CURRENT[A] 1.2 SUS6123R3 4.46 3.3 1.35 SUS61205 6 5 1.2 SUS61212 6 12 0.5 SUS61215 6 15 0.4 SUS6053R3 SUS60505 SUS60512 SUS60515 SUS6123R3 DC4.5 - 9 DC9 - 18 1.316typ 1.500typ 1.500typ 1.100typ 0.502typ 76typ 80typ 80typ 72typ 74typ 5 12 15 3.3 3.3 1 0.5 0.4 1.2 1.35 20max 48max 60max 20max 20max 40max 100max 120max 40max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUS61205 SUS61212 SUS61215 0.617typ 81typ 5 1.2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.588typ 85typ 12 0.5 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.588typ 85typ 15 0.4 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS6483R3 4.46 3.3 1.35 SUS64805 6 5 1.2 SUS64812 6 12 0.5 SUS64815 6 15 0.4 SUS6243R3 SUS62405 SUS62412 SUS62415 SUS6483R3 DC18 - 36 DC36 - 76 0.248typ 0.121typ 0.309typ 0.291typ 0.291typ 75typ 77typ 81typ 86typ 86typ 3.3 3.3 5 12 15 1.35 1.35 1.2 0.5 0.4 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 50max 50max 150max 180max 80max 80max 80max 240max 290max 20max 20max 20max 48max 60max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUS64805 SUS64812 SUS64815 0.154typ 81typ 5 1.2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.145typ 86typ 12 0.5 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.145typ 86typ 15 0.4 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS60505 5 5 1 SUS60512 6 12 0.5 SUS60515 6 15 0.4 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUS6243R3 4.46 VOLTAGE[V] *1 3.3 CURRENT[A] 1.35 SUS62405 6 5 1.2 SUS62412 6 12 0.5 SUS62415 6 15 0.4 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-10 January 31, 2022 SUS6 GENERAL SPECIFICATIONS ISOLATION INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 31.6X6.5X18.1mm [1.24X0.26X0.71 inches] (WXHXD) / 4g max Convection/Forced air *1 SUW6xx12/SUW6xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view 1.SMD(type B) Recommended Pad and Hole dia. (TOP VIEW) type B Model +Vin 0.6 ±0.1 [0.1] 2.54±0.2 RC [0.02] -Vout 1.4 type C [0.004] [0.28] 6.5 [0.26] 6-º0.9 0˚) [0.04] (0-1 33.78 ±0.6 [1.33] Unit : 0.1inch Dimensions in mm, [ ]=inches Coplanarity within 0.1 Model +Vin TRM 0.6 ±0.1 -Vout -Vin [0.02] [0.1] 2.54±0.2 RC 0.1min 31.6 6.5 5.08±0.2 [0.2] 12.7 ±0.2 [0.71] [0.5] 18.1 12.7±0.2 +Vout [0.5] ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 4g max 2.DIP(type C) 3.68±0.25 [0.13] [1.39] [0.004] [0.14] 3.2 35.38 Adsorption area º7min Pin terminal part details [0.07] 3.2 [0.13] 0.1min 31.6 [1.24] 1.8±0.3 [0.06] [0.5] TRM -Vin 5.08±0.2 [0.2] 12.7 ±0.2 [0.5] 18.1 [0.71] [0.07] 12.7 ±0.2 (1.69) +Vout [0.004] [1.24] [0.26] 30.48 [1.2] January 31, 2022 SU.SUC/SUT-11 Ordering information DC-DC Converters PCB Mount Type SUW6 SU W 1 2 6 12 12 B 3 4 5 6 P -O 7 8 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray (SMD type) 8 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUW60512 6 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.25 SUW60515 6 t15 or +30 0.2 SUW61212 6 t12 or +24 0.25 SUW61215 6 t15 or +30 0.2 SUW62412 6 t12 or +24 0.25 SUW62415 6 t15 or +30 0.2 SUW64812 6 t12 or +24 0.25 SUW64815 6 t15 or +30 0.2 SUW62415 SUW64812 DC36 - 76 0.291typ 0.145typ 86typ 86typ ( ) 15 +30 t t12(+24) SUW64815 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION REMOTE ON/OFF INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD SUW60512 DC4.5 - 9 1.538typ 78typ t12(+24) SUW60515 SUW61212 DC9 - 18 1.538typ 0.588typ 78typ 85typ ( ) 15 +30 t t12(+24) SUW61215 SUW62412 DC18 - 36 0.588typ 0.291typ 85typ 86typ ( ) 15 +30 t t12(+24) 0.25 0.2 0.25 0.2 0.25 0.2 0.25 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 31.6X6.5X18.1mm [1.24X0.26X0.71 inches] (WXHXD) / 4g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-12 0.145typ 86typ t15(+30) 0.2 75max 750max 120max 150max 150max 200max 180max 290max 60max January 31, 2022 SUW6 External view 1.SMD(type B) Recommended Pad and Hole dia. (TOP VIEW) type B Model 1.4 [0.06] [0.1] 12.7±0.2 TRM [0.13] Adsorption area º7min [0.28] [0.2] 0.1min [0.004] [0.26] Pin terminal part details 6.5 7-º0.9 [0.04] 0˚) (0-1 [0.07] [0.13] [1.39] 5.08±0.2 0.6 ±0.1 [0.02] [0.1] 2.54±0.2 -Vout 31.6 [1.24] 1.8 ±0.3 35.38 type C RC -Vin 3.2 3.2 [0.5] 18.1 [0.71] COM 2.54±0.2 [0.07] (1.69) +Vout [0.5] 12.7±0.2 +Vin Unit : 0.1inch Dimensions in mm, [ ]=inches 33.78 ±0.6 [1.33] Coplanarity within 0.1 [0.004] 2.54±0.2 [0.1] [0.2] 18.1 [0.71] [0.5] TRM 3.68 ±0.25 [0.14] -Vout -Vin [0.02] [0.1] 0.6±0.1 RC 2.54±0.2 12.7 ±0.2 COM 5.08±0.2 +Vout [0.5] Model +Vin 12.7 ±0.2 2.DIP(type C) ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 4g max 31.6 6.5 [1.24] 0.1min [0.004] [0.26] 30.48 [1.2] January 31, 2022 SU.SUC/SUT-13 Ordering information DC-DC Converters PCB Mount Type SUS10 SU S 10 12 05 B P -O 1 2 3 4 5 DC OUTPUT 7 8 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7 Packing form Blank:Plastic cover P : Tray (SMD type) 8 Optional G : C apacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] 6 SUS10053R3 8.58 VOLTAGE[V] *1 3.3 CURRENT[A] 2.6 SUS100505 10 5 2 SUS100512 10.8 12 0.9 SUS100515 10.5 15 0.7 SUS10123R3 8.58 3.3 2.6 SUS101205 10 5 2 SUS101212 12 12 1 SUS101215 12 15 0.8 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUS10053R3 SUS100505 SUS100512 SUS100515 SUS10123R3 DC4.5 - 9 DC9 - 18 2.12typ 2.41typ 2.54typ 2.47typ 0.872typ 81typ 83typ 85typ 85typ 82typ 3.3 5 12 15 3.3 2.6 2 0.9 0.7 2.6 20max 20max 48max 60max 20max 40max 40max 100max 120max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUS10243R3 8.58 VOLTAGE[V] *1 3.3 CURRENT[A] 2.6 SUS102405 10 5 2 SUS102412 12 12 1 SUS102415 12 15 0.8 SUS10483R3 8.58 3.3 2.6 SUS101205 SUS101212 SUS101215 0.980typ 85typ 5 2 20max 40max 80max 120max 120max 200max 50max 80max 20max 1.15typ 87typ 12 1 48max 100max 120max 150max 150max 200max 150max 240max 48max 1.15typ 87typ 15 0.8 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS104805 10 5 2 SUS104812 12 12 1 SUS104815 12 15 0.8 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-14 SUS10243R3 SUS102405 SUS102412 SUS102415 SUS10483R3 DC18 - 36 DC36 - 76 0.436typ 0.218typ 0.490typ 0.575typ 0.575typ 82typ 82typ 85typ 87typ 87typ 3.3 3.3 5 12 15 2.6 2.6 2 1 0.8 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) January 31, 2022 SUS104805 SUS104812 SUS104815 0.245typ 85typ 5 2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.287typ 87typ 12 1 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.287typ 87typ 15 0.8 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUS10 GENERAL SPECIFICATIONS ISOLATION INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 39.2X6.5X21.0mm [1.54X0.26X0.83 inches] (W XHXD) / 6g max Convection/Forced air *1 SUW10xx12/SUW10xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Recommended Pad and Hole dia. (TOP VIEW) 1.SMD(type B) type B Model +Vout [0.1] 1.4 [0.06] 7.62±0.2 15.24±0.2 [0.6] 3.2 43 [0.13] [1.69] type C 0.1min 39.2 [0.004] [1.54] Pin terminal part details 3.2 [0.13] -Vout [0.02] -Vin 0.6±0.1 2.54 ±0.2 RC TRM [0.3] [0.6] 21 [0.83] [0.09] 15.24 ±0.2 (2.16) +Vin Adsorption area º8min 0˚) 6.5 [0.26] [0.31] 1.8±0.3 (0-1 [0.07] 41.4 ±0.6 6-º0.9 Coplanarity within 0.1 [1.63] [0.04] [0.004] Unit : 0.1inch Dimensions in mm, [ ]=inches ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 6g max 2.DIP(type C) Model +Vin 0.6 ±0.1 3.68±0.25 [0.14] -Vout -Vin [0.02] [0.1] 2.54±0.2 RC 0.1min 39.2 6.5 [0.6] TRM 7.62 ±0.2 [0.3] 15.24±0.2 [0.6] 21 [0.83] 15.24±0.2 +Vout [0.004] [1.54] [0.26] 38.1 [1.5] January 31, 2022 SU.SUC/SUT-15 Ordering information DC-DC Converters PCB Mount Type SUW10 SU W 10 12 12 B P -O 1 2 3 4 5 6 7 8 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray(SMD type) 8 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUW100512 10.8 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.45 SUW100515 10.5 t15 or +30 0.35 SUW101212 10.8 t12 or +24 0.45 SUW101215 10.5 t15 or +30 0.35 SUW102412 10.8 t12 or +24 0.45 SUW102415 10.5 t15 or +30 0.35 SUW104812 10.8 t12 or +24 0.45 SUW104815 10.5 t15 or +30 0.35 SUW102415 SUW104812 DC36 - 76 0.509typ 0.262typ 86typ 86typ ( ) 15 +30 t t12(+24) SUW104815 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION REMOTE ON/OFF INPUT-OUTPUT OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD SUW100512 DC4.5 - 9 2.51typ 86typ t12(+24) SUW100515 SUW101212 DC9 - 18 2.44typ 1.05typ 86typ 86typ ( ) 15 +30 t t12(+24) SUW101215 SUW102412 DC18 - 36 1.02typ 0.523typ 86typ 86typ ( ) 15 +30 t t12(+24) 0.45 0.35 0.45 0.35 0.45 0.35 0.45 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 39.2X6.5X21.0mm [1.54X0.26X0.83 inches] (WXHXD) / 6g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-16 0.254typ 86typ t15(+30) 0.35 75max 750max 120max 150max 150max 200max 180max 290max 60max January 31, 2022 SUW10 External view 1.SMD(type B) Recommended Pad and Hole dia. (TOP VIEW) type B Model +Vin 1.4 [0.6] [0.1] 15.24 ±0.2 [0.06] 43 [0.13] [1.69] 0.1min type C [0.004] 39.2 3.2 [0.13] Adsorption area º8min 6.5 [0.26] [0.31] (0-1 0˚) 1.8 ±0.3 -Vout [1.54] Pin terminal part details [0.07] 3.2 [0.3] 0.6±0.1 [0.02] [0.1] -Vin TRM 7.62 ±0.2 21 [0.83] [0.6] 2.54±0.2 RC 2.54±0.2 COM [0.09] 15.24±0.2 (2.16) +Vout 41.4 ±0.6 Coplanarity within 0.1 [1.63] 7-º0.9 [0.004] [0.04] Unit : 0.1inch Dimensions in mm, [ ]=inches Model +Vin 7.62±0.2 2.54±0.2 [0.3] 15.24 ±0.2 [0.1] +Vout [0.6] 21 [0.83] 15.24 ±0.2 COM TRM 0.6 ±0.1 3.68±0.25 [0.14] -Vout -Vin [0.02] [0.1] 2.54 ±0.2 RC ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Weight : 6g max [0.6] 2.DIP(type C) 0.1min 39.2 [0.004] [1.54] 6.5 [0.26] 38.1 [1.5] January 31, 2022 SU.SUC/SUT-17 Ordering information DC-DC Converters PCB Mount Type SUCS1R5 SUC S 1R5 12 05 B P -O 1 2 3 4 5 6 7 8 8 Optional 1 Series name C : with coating (only 2 Single output DIP type)* 3 Output wattage 4 Input voltage *S afety standards 5 Output voltage are pending 6 Mounting type B : SMD C : DIP 7 Packing form Blank:Plastic cover P : Tray (SMD type) R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCS1R5053R3 1.32 VOLTAGE[V] *1 3.3 CURRENT[A] 0.4 SUCS1R50505 1.5 5 0.3 SUCS1R50512 1.56 12 0.13 SUCS1R50515 1.5 15 0.1 SUCS1R5123R3 1.32 3.3 0.4 SUCS1R51205 1.5 5 0.3 SUCS1R51212 1.56 12 0.13 SUCS1R51215 1.5 15 0.1 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) OVERCURRENT PROTECTION MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCS1R5053R3 SUCS1R50505 SUCS1R50512 SUCS1R50515 SUCS1R5123R3 DC4.5 - 9 DC9 - 18 0.388typ 0.157typ 0.417typ 0.433typ 0.417typ 68typ 70typ 72typ 72typ 72typ 3.3 3.3 5 12 15 0.4 0.4 0.3 0.13 0.1 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically SUCS1R5243R3 1.32 VOLTAGE[V] *1 3.3 CURRENT[A] 0.4 SUCS1R52405 1.5 5 0.3 SUCS1R52412 1.56 12 0.13 SUCS1R52415 1.5 15 0.1 SUCS1R5483R3 1.32 3.3 0.4 SUCS1R51205 SUCS1R51212 SUCS1R51215 0.169typ 74typ 5 0.3 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.176typ 74typ 12 0.13 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.169typ 74typ 15 0.1 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS1R54805 1.5 5 0.3 SUCS1R54812 1.56 12 0.13 SUCS1R54815 1.5 15 0.1 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) OVERCURRENT PROTECTION SU.SUC/SUT-18 SUCS1R5243R3 SUCS1R52405 SUCS1R52412 SUCS1R52415 SUCS1R5483R3 DC18 - 36 DC36 - 76 0.079typ 0.039typ 0.084typ 0.087typ 0.083typ 70typ 70typ 74typ 75typ 75typ 3.3 3.3 5 12 15 0.4 0.4 0.3 0.13 0.1 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 50max 50max 150max 180max 80max 80max 80max 240max 290max 20max 20max 20max 48max 60max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically January 31, 2022 SUCS1R54805 SUCS1R54812 SUCS1R54815 0.042typ 74typ 5 0.3 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.043typ 75typ 12 0.13 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.042typ 75typ 15 0.1 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS1R5 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 22.4X7.0X13.2mm [0.88X0.28X0.52 inches] (WXHXD) / 3g max Convection/Forced air *1 SUCW1R5xx12/SUCW1R5xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Recommended Pad and Hole dia. (TOP VIEW) Adsorption area 1. SMD(type B) Component area Model +Vin type B 1 1.9 1.3 [0.1] º1.6 [0.06] Unit : 0.1inch Dimensions in mm, [ ]=inches [0.004] Component area Model +Vin ¶ Weight : 3g max [0.1] +0.5 2.44 -0.25 Closeup of part A Part A ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. [0.1] [0.004] +0.5 0.1min 22.4 [0.88] 2.44 -0.25 0.6 ±0.1 7 [0.3] TRM -Vout [0.28] 7.62 ±0.2 [0.1] 2.54 ±0.2 -Vin [0.52] [0.5] 12.7 +Vout 13.2 [0.3] [0.07] [0.06] 1.4 +0.5 type C Coplanarity within 0.1 23.62 ±0.6 2. DIP(type C) [0.02] 3.2 [0.13] [0.04] [0.93] 7.62 ±0.2 [0.99] 5-º0.9 [0.04] 3.68 ±0.25 25.22 +0.5 2.54 -0.25 [0.004] 2 [0.08] [0.1] [0.03] [0.03] 7 [0.28] (0-1 0.1min Closeup of part A [0.88] 2.54 -0.25 Part A 0.8 min 0˚) 1.8 ±0.3 [0.07] [0.3] 3.2 [0.13] 22.4 [0.05] 0.6 ±0.1 0.7±0.4 [0.02] -Vout Pin terminal part details [0.14] [0.1] TRM 7.62 ±0.2 2.54 ±0.2 [0.5] [0.52] 12.7 13.2 -Vin [0.3] 7.62 ±0.2 +Vout 1 [0.04] 20.32 [0.8] January 31, 2022 SU.SUC/SUT-19 Ordering information DC-DC Converters PCB Mount Type SUCW1R5 SUC W 1R5 12 12 B P -O 1 2 3 4 5 6 7 8 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray (SMD type) 8Optional C : with coating (only DIP type)* R * S afety standards are pending MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCW1R50512 1.56 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.065 SUCW1R50515 1.5 t15 or +30 0.05 SUCW1R51212 1.56 t12 or +24 0.065 SUCW1R51215 1.5 t15 or +30 0.05 SUCW1R52412 1.56 t12 or +24 0.065 SUCW1R52415 1.5 t15 or +30 0.05 SUCW1R54812 1.56 t12 or +24 0.065 SUCW1R54815 1.5 t15 or +30 0.05 SUCW1R52415 SUCW1R54812 DC36 - 76 0.086typ 0.045typ 73typ 73typ t15(+30) t12(+24) SUCW1R54815 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT SAFETY AGENCY APPROVALS CASE SIZE/WEIGHT OTHERS COOLING METHOD PROTECTION CIRCUIT AND OTHERS SUCW1R50512 DC4.5 - 9 0.446typ 70typ t12(+24) SUCW1R50515 SUCW1R51212 DC9 - 18 0.429typ 0.178typ 70typ 73typ t15(+30) t12(+24) SUCW1R51215 SUCW1R52412 DC18 - 36 0.171typ 0.089typ 73typ 73typ t15(+30) t12(+24) 0.065 0.05 0.065 0.05 0.065 0.05 0.065 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 Works over 105% of rating and recovers automatically AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 22.4X7.0X13.2mm [0.88X0.28X0.52 inches] (WXHXD) / 3g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-20 0.043typ 73typ t15(+30) 0.05 75max 750max 120max 150max 150max 200max 180max 290max 60max January 31, 2022 SUCW1R5 External view Recommended Pad and Hole dia. (TOP VIEW) Adsorption area Component area Model [0.13] 1.9 [0.07] 1.3 [0.05] [0.3] [0.004] Closeup of part A 3.2 2 [0.08] 25.22 [0.99] 3.2 [0.13] type C [0.1] 22.4 +0.5 Part A 0.1min 2.54 -0.25 2.54 ±0.2 -Vout [0.03] 0.6 ±0.1 0.7±0.4 [0.02] TRM [0.88] 1.4 7.62 ±0.2 [0.52] [0.5] 13.2 12.7 -Vin [0.3] 7.62 ±0.2 COM [0.06] +Vout [0.1] 2.54 ±0.2 type B +Vin [0.1] 1. SMD(type B) [0.1] +0.5 2.54 -0.25 [0.03] 7 [0.28] º1.6 6-º0.9 [0.06] 1 [0.04] Unit : 0.1inch Dimensions in mm, [ ]=inches [0.004] [0.93] 2. DIP(type C) [0.04] Coplanarity within 0.1 23.62 ±0.6 +Vout Model Component area 2.54±0.2 COM [0.004] +0.5 2.44 -0.25 [0.1] 2.54 ±0.2 -Vout 0.1min [0.3] [0.1] 7.62±0.2 [0.5] [0.52] Part A TRM Closeup of part A +0.5 [0.28] 22.4 [0.88] ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 3g max 1 [0.1] 7 2.44 -0.25 [0.02] 3.68±0.25 [0.14] 13.2 12.7 [0.3] -Vin 0.6±0.1 7.62 ±0.2 +Vin [0.1] 0˚) [0.07] (0-1 1.8±0.3 0.8 min Pin terminal part details [0.04] 20.32 [0.8] January 31, 2022 SU.SUC/SUT-21 Ordering information DC-DC Converters PCB Mount Type SUCS3 SUC S 3 12 05 B P -O 1 2 3 4 DC OUTPUT 6 7 8 1 Series name 8 Optional G : Capacitor between 2 Single output Input and Output is 3 Output wattage removed. 4 Input voltage C : with coating (only 5 Output voltage 6 Mounting type DIP type)* B : SMD C : DIP * S afety standards are pending 7 Packing form Blank:Plastic cover P : Tray (SMD type) R MODEL MAX OUTPUT WATTAGE[W] 5 SUCS3053R3 1.98 VOLTAGE[V] *1 3.3 CURRENT[A] 0.6 SUCS30505 3 5 0.6 SUCS30512 3 12 0.25 SUCS30515 3 15 0.2 SUCS3123R3 1.98 3.3 0.6 SUCS31205 3 5 0.6 SUCS31212 3 12 0.25 SUCS31215 3 15 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCS3053R3 SUCS30505 SUCS30512 SUCS30515 SUCS3123R3 DC4.5 - 9 DC9 - 18 0.550typ 0.800typ 0.780typ 0.780typ 0.223typ 72typ 75typ 77typ 77typ 74typ 3.3 5 12 15 3.3 0.6 0.6 0.25 0.2 0.6 20max 20max 48max 60max 20max 40max 40max 100max 120max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUCS3243R3 1.98 VOLTAGE[V] *1 3.3 CURRENT[A] 0.6 SUCS32405 3 5 0.6 SUCS32412 3 12 0.25 SUCS32415 3 15 0.2 SUCS3483R3 1.98 3.3 0.6 SUCS31205 SUCS31212 SUCS31215 0.325typ 77typ 5 0.6 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.317typ 79typ 12 0.25 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.321typ 78typ 15 0.2 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS34805 3 5 0.6 SUCS34812 3 12 0.25 SUCS34815 3 15 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-22 SUCS3243R3 SUCS32405 SUCS32412 SUCS32415 SUCS3483R3 DC18 - 36 DC36 - 76 0.114typ 0.057typ 0.163typ 0.159typ 0.161typ 73typ 72typ 77typ 79typ 78typ 3.3 3.3 5 12 15 0.6 0.6 0.6 0.25 0.2 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) January 31, 2022 SUCS34805 SUCS34812 SUCS34815 0.082typ 77typ 5 0.6 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.080typ 79typ 12 0.25 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.080typ 79typ 15 0.2 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS3 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 25X7.0X16.1mm [0.98X0.28X0.63 inches] (WXHXD) / 5g max Convection/Forced air *1 SUCW3xx12/SUCW3xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Adsorption area 1.SMD(type B) +Vout Recommended Pad and Hole dia. (TOP VIEW) type B Component area Model Coplanarity within 0.1 1.9 1.3 º1.6 6-º0.9 [0.06] [0.16] [0.04] Unit : 0.1inch Dimensions in mm, [ ]=inches Component area Model +Vout RC 7.62 ±0.2 0.1min +0.5 [0.1] [0.15] Closeup of part A 3.84 -0.25 2.54 ±0.2 Part A [0.004] [0.15] -Vout ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 5g max +0.5 -0.25 TRM 3.84 25 [0.98] [0.3] [0.63] [0.61] 15.5 [0.02] 0.6 ±0.1 [0.3] 7.62 7 [0.28] 16.1 -Vin ±0.2 [0.05] type C +0.5 3.94 -0.25 [0.04] +Vin [0.1] 3.2 [0.13] [0.004] 26.16 ±0.6 2.DIP(type C) 2.54±0.2 27.76 [1.09] [1.03] [0.004] 3.68 ±0.25 [0.07] 1.4 [0.3] [0.1] 7.62 ±0.2 2.54±0.2 16.1 [0.03] 1.27 [0.05] [0.14] 2 [0.08] Closeup of part A 0˚) 7 [0.28] 0.8min -Vout 1 (0-1 1.8±0.3 [0.07] [0.63] 3.94 +0.5 -0.25 [0.03] [0.1] Pin terminal part details [0.98] [0.13] Part A 0.1min TRM 25 3.2 [0.16] 0.6 ±0.1 0.7 ±0.4 [0.02] [0.3] 15.5 [0.61] -Vin 2.54 ±0.2 7.62 ±0.2 RC [0.06] +Vin 1 1.27 [0.05] [0.04] 22.86 [0.9] January 31, 2022 SU.SUC/SUT-23 Ordering information DC-DC Converters PCB Mount Type SUCW3 SUC W 3 12 12 B P -O 1 2 3 4 5 6 7 8 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray (SMD type) 8 Optional G : Capacitor between Input and Output is removed. C : with coating (only DIP type)* R * S afety standards are pending MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCW30512 3.12 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.13 SUCW30515 3 t15 or +30 0.1 SUCW31212 3.12 t12 or +24 0.13 SUCW31215 3 t15 or +30 0.1 SUCW32412 3.12 t12 or +24 0.13 SUCW32415 3 t15 or +30 0.1 SUCW34812 3.12 t12 or +24 0.13 SUCW34815 3 t15 or +30 0.1 SUCW30512 SUCW30515 SUCW31212 SUCW31215 SUCW32412 SUCW32415 SUCW34812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 76 0.844typ 0.811typ 0.343typ 0.329typ 0.172typ 0.165typ 0.086typ 74typ 74typ 76typ 76typ 76typ 76typ 76typ t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) 0.13 0.1 0.13 0.1 0.13 0.1 0.13 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis SUCW34815 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION REMOTE ON/OFF INPUT-OUTPUT INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD UL60950-1, C-UL, EN62368-1 25X7.0X16.1mm [0.98X0.28X0.63 inches] (WXHXD) / 5g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-24 January 31, 2022 0.083typ 76typ t15(+30) 0.1 75max 750max 120max 150max 150max 200max 180max 290max 60max 14.25 - 15.75 SUCW3 External view [0.05] [0.1] 1.9 [0.07] 1.3 [0.05] type C º1.6 7-º0.9 [0.06] [0.04] Unit : 0.1inch Dimensions in mm, [ ]=inches 26.16 ±0.6 [1.03] Model Component area [0.3] 7.62 ±0.2 2.54 ±0.2 Part A 0.1min [0.98] +0.5 [0.004] 1 [0.15] +0.5 3.84 -0.25 Closeup of part A [0.04] [0.1] 25 7 [0.28] 3.84 -0.25 [0.02] 0.6 ±0.1 -Vout ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 5g max [0.15] [0.61] 16.1 15.5 [0.3] [0.63] TRM -Vin [0.1] COM 2.54±0.2 +Vout RC 7.62 ±0.2 3.2 [0.13] [1.09] [0.16] +0.5 3.94-0.25 1.27 +Vin [0.1] 2.54 ±0.2 3.94+0.5 -0.25 [0.16] 16.1 [0.63] [0.61] 15.5 [0.03] (0-1 [0.04] 2.DIP(type C) 2.54 ±0.2 27.76 [0.004] 1 [0.004] [0.14] 2 [0.08] Closeup of part A Coplanarity within 0.1 3.68 ±0.25 3.2 [0.13] 0.1min [0.98] [0.03] 7 [0.28] 0˚) 1.8 ±0.3 [0.07] 0.8min 0.6 ±0.1 0.7 ±0.4 [0.02] [0.3] [0.1] Pin terminal part details Part A 25 1.4 -Vout 7.62 ±0.2 TRM RC [0.06] COM [0.1] Model +Vin Recommended Pad and Hole dia. (TOP VIEW) type B Component area [0.3] +Vout 2.54 ±0.2 Adsorption area -Vin 2.54 ±0.2 7.62 ±0.2 1.SMD(type B) 1.27 [0.05] 22.86 [0.9] January 31, 2022 SU.SUC/SUT-25 Ordering information DC-DC Converters PCB Mount Type SUCS6 SUC S 6 12 05 B P -O 1 2 3 4 DC OUTPUT 6 7 8 8 Optional 1 Series name G : Capacitor between 2 Single output Input and Output is 3 Output wattage removed. 4 Input voltage C : with coating (only 5 Output voltage DIP type)* 6 Mounting type B : SMD C : DIP * S afety standards are pending 7 Packing form Blank:Plastic cover P : Tray (SMD type) R MODEL MAX OUTPUT WATTAGE[W] 5 SUCS6053R3 3.96 VOLTAGE[V] *1 3.3 CURRENT[A] 1.2 SUCS60505 5 5 1 SUCS60512 6 12 0.5 SUCS60515 6 15 0.4 SUCS6123R3 4.46 3.3 1.35 SUCS61205 6 5 1.2 SUCS61212 6 12 0.5 SUCS61215 6 15 0.4 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCS6053R3 SUCS60505 SUCS60512 SUCS60515 SUCS6123R3 DC4.5 - 9 DC9 - 18 1.100typ 1.316typ 1.500typ 1.500typ 0.502typ 72typ 76typ 80typ 80typ 74typ 3.3 5 12 15 3.3 1.2 1 0.5 0.4 1.35 20max 20max 48max 60max 20max 40max 40max 100max 120max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUCS6243R3 4.46 VOLTAGE[V] *1 3.3 CURRENT[A] 1.35 SUCS62405 6 5 1.2 SUCS62412 6 12 0.5 SUCS62415 6 15 0.4 SUCS6483R3 4.46 3.3 1.35 SUCS61205 SUCS61212 SUCS61215 0.617typ 81typ 5 1.2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.588typ 85typ 12 0.5 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.588typ 85typ 15 0.4 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS64805 6 5 1.2 SUCS64812 6 12 0.5 SUCS64815 6 15 0.4 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-26 SUCS6243R3 SUCS62405 SUCS62412 SUCS62415 SUCS6483R3 DC18 - 36 DC36 - 76 0.248typ 0.121typ 0.309typ 0.291typ 0.291typ 75typ 77typ 81typ 86typ 86typ 3.3 3.3 5 12 15 1.35 1.35 1.2 0.5 0.4 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) January 31, 2022 SUCS64805 SUCS64812 SUCS64815 0.154typ 81typ 5 1.2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.145typ 86typ 12 0.5 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.145typ 86typ 15 0.4 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS6 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 32.6X7.0X19.1mm [1.28X0.28X0.75 inches] (WXHXD) / 7g max Convection/Forced air *1 SUCW6xx12/SUCW6xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Adsorption area Compornent area 1.4 [0.06] 1.9 1.3 [0.5] Compornent area TRM Part A 32.6 0.1min [1.28] [0.004] [0.11] [0.02] ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 7g max -Vout -Vin 2.85 +0.5 -0.25 0.6 ±0.1 [0.5] [0.75] 19.1 [0.73] 18.6 [0.5] 5.08 ±0.2 [0.2] 12.7±0.2 +Vout RC 1 [0.11] Closeup of part A 2.85 +0.5 -0.25 [0.1] [0.06] [1.33] +Vin [0.28] f1.6 Unit : 0.1inch Dimensions in mm, [ ]=inches Model 7 [0.04] 33.78 ±0.6 2.DIP(type C) 2.54 ±0.2 [1.39] 6-f0.9 [0.04] [0.004] [0.14] 3.2 [0.13] [0.12] [0.12] 2.95 +0.5 -0.25 [0.03] 7 0.8min [0.28] (0- 1 Coplanarity within 0.1 3.68 ±0.25 type C 2 [0.08] 35.38 Closeup of part A 10 ˚) 0.1min [0.004] Pin terminal part details 12.7±0.2 2.95 +0.5 -0.25 0.7±0.4 Part A [0.03] [0.1] 32.6 [1.28] 1.8 ±0.3 3.2 [0.13] -Vout -Vin [0.07] 12.7 ±0.2 TRM [0.2] 19.1 [0.75] 18.6 [0.73] [0.02] 0.6±0.1 [0.5] 12.7 ±0.2 2.54 ±0.2 RC 5.08 ±0.2 +Vout +Vin Recommended Pad and Hole dia. (TOP VIEW) type B [0.07] Model [0.05] 1.SMD(type B) [0.04] 30.48 [1.2] January 31, 2022 SU.SUC/SUT-27 Ordering information DC-DC Converters PCB Mount Type SUCW6 SUC W 6 12 12 B P -O 1 2 3 4 5 6 7 8 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray (SMD type) 8 Optional G : Capacitor between Input and Output is removed. C : with coating (only DIP type)* R * S afety standards are pending MODEL MAX OUTPUT WATTAGE[W] SUCW64812 6 t12 or +24 0.25 SUCW64815 6 t15 or +30 0.2 SUCW60512 SUCW60515 SUCW61212 SUCW61215 SUCW62412 SUCW62415 SUCW64812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 76 INPUT 1.538typ 1.538typ 0.588typ 0.588typ 0.291typ 0.291typ 0.145typ 78typ 78typ 85typ 85typ 86typ 86typ 86typ t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) 0.25 0.2 0.25 0.2 0.25 0.2 0.25 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max OUTPUT 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 PROTECTION OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically CIRCUIT AND REMOTE ON/OFF Provided (Negative logic L : ON, H : OFF) OTHERS INPUT-OUTPUT AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) ISOLATION INPUT-CASE AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) OUTPUT-CASE AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) , OPERATING TEMP. HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max ENVIRONMENT VIBRATION 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis SAFETY AGENCY APPROVALS UL60950-1, C-UL, EN62368-1 CASE SIZE/WEIGHT 32.6X7.0X19.1mm [1.28X0.28X0.75 inches] (WXHXD) / 7g max OTHERS Convection/Forced air COOLING METHOD SUCW64815 DC OUTPUT SUCW60512 6 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.25 SUCW60515 6 t15 or +30 0.2 SUCW61212 6 t12 or +24 0.25 SUCW61215 6 t15 or +30 0.2 SUCW62412 6 t12 or +24 0.25 SUCW62415 6 t15 or +30 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-28 January 31, 2022 0.145typ 86typ t15(+30) 0.2 75max 750max 120max 150max 150max 200max 180max 290max 60max 14.25 - 15.75 SUCW6 External view Component area Model 1.9 1.3 [0.05] [0.07] 1.4 Component area Model [0.06] [0.1] [0.5] [0.2] [0.11] 12.7 ±0.2 2.54 ±0.2 ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 7g max -Vout -Vin [0.02] 5.08 ±0.2 [0.75] 19.1 [0.73] 18.6 TRM RC 2.85 +0.5 -0.25 +Vout [0.5] f1.6 Unit : 0.1inch Dimensions in mm, [ ]=inches [1.33] COM Part A 7 32.6 0.1min [0.28] [1.28] [0.004] 2.85 +0.5 -0.25 Closeup of part A 1 [0.11] 0.6±0.1 [0.04] 33.78 ±0.6 +Vin [0.1] 7-f0.9 [0.04] 2.DIP(type C) 12.7 ±0.2 [1.39] type C [0.12] 2.95 +0.5 -0.25 0.8min [0.03] 7 [0.28] (0-1 1 [0.004] 2.54±0.2 3.2 Closeup of part A Coplanarity within 0.1 [0.14] [0.5] 2.54±0.2 [0.1] [0.2] 2.95 +0.5 -0.25 [0.004] Pin terminal part details 0˚) 0.1min 2 [0.08] [0.13] 35.38 [0.12] 0.7±0.4 Part A [0.03] [0.1] 32.6 [1.28] 3.68±0.25 3.2 [0.13] -Vout -Vin 1.8 ±0.3 12.7 ±0.2 TRM 5.08 ±0.2 19.1 COM [0.75] [0.73] 18.6 0.6 ±0.1 [0.02] [0.5] 12.7 ±0.2 2.54±0.2 RC [0.06] +Vout +Vin [0.07] Recommended Pad and Hole dia. (TOP VIEW) type B Adsorption area 1.SMD(type B) [0.04] 30.48 [1.2] January 31, 2022 SU.SUC/SUT-29 Ordering information DC-DC Converters PCB Mount Type SUCS10 SUC S 10 12 05 B P -O 1 2 3 4 DC OUTPUT 6 7 8 8 Optional 1 Series name G : Capacitor between 2 Single output Input and Output is 3 Output wattage removed. 4 Input voltage C : with coating (only 5 Output voltage DIP type)* 6 Mounting type B : SMD C : DIP * S afety standards are pending 7 Packing form Blank:Plastic cover P : Tray (SMD type) R MODEL MAX OUTPUT WATTAGE[W] 5 SUCS10053R3 8.58 VOLTAGE[V] *1 3.3 CURRENT[A] 2.6 SUCS100505 10 5 2 SUCS100512 10.8 12 0.9 SUCS100515 10.5 15 0.7 SUCS10123R3 8.58 3.3 2.6 SUCS101205 10 5 2 SUCS101212 12 12 1 SUCS101215 12 15 0.8 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCS10053R3 SUCS100505 SUCS100512 SUCS100515 SUCS10123R3 DC4.5 - 9 DC9 - 18 2.12typ 2.41typ 2.54typ 2.47typ 0.872typ 81typ 83typ 85typ 85typ 82typ 3.3 5 12 15 3.3 2.6 2 0.9 0.7 2.6 20max 20max 48max 60max 20max 40max 40max 100max 120max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUCS10243R3 8.58 VOLTAGE[V] *1 3.3 CURRENT[A] 2.6 SUCS102405 10 5 2 SUCS102412 12 12 1 SUCS102415 12 15 0.8 SUCS10483R3 8.58 3.3 2.6 SUCS101205 SUCS101212 SUCS101215 0.980typ 85typ 5 2 20max 40max 80max 120max 120max 200max 50max 80max 20max 1.15typ 87typ 12 1 48max 100max 120max 150max 150max 200max 150max 240max 48max 1.15typ 87typ 15 0.8 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS104805 10 5 2 SUCS104812 12 12 1 SUCS104815 12 15 0.8 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-30 SUCS10243R3 SUCS102405 SUCS102412 SUCS102415 SUCS10483R3 DC18 - 36 DC36 - 76 0.436typ 0.218typ 0.490typ 0.575typ 0.575typ 82typ 82typ 85typ 87typ 87typ 3.3 3.3 5 12 15 2.6 2.6 2 1 0.8 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) January 31, 2022 SUCS104805 SUCS104812 SUCS104815 0.245typ 85typ 5 2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.287typ 87typ 12 1 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.287typ 87typ 15 0.8 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUCS10 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 40.2X7.0X22.0mm [1.58X0.28X0.87 inches] (WXHXD) / 10g max Convection/Forced air *1 SUCW10xx12/SUCW10xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Recommended Pad and Hole dia. (TOP VIEW) type B Adsorption area Compornent area 1.9 2 3.2 [0.08] Closeup of part A 3.13 +0.5 -0.25 1.27 6-f0.9 [0.05] 41.4 ±0.6 [0.004] [0.3] [0.02] -Vout 0.1min [0.004] 40.2 Part A Closeup of part A [1.58] 7 [0.28] 3.03 +0.5 -0.25 3.68 ±0.25 ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 10g max [0.12] [0.1] 0.6 ±0.1 TRM [0.6] 7.62±0.2 22 [0.85] 21.5 [0.6] Compornent area 15.24 ±0.2 +Vout [0.06] Unit : 0.1inch Dimensions in mm, [ ]=inches 3.03 +0.5 -0.25 Model +Vin [0.87] 2.DIP(type C) f1.6 [0.04] Coplanarity within 0.1 [1.63] RC -Vin type C [0.12] (0 [0.04] 3.13 +0.5 -0.25 [0.004] [0.03] 0.8min 7 0.1min 1 -1 [0.07] -Vout Part A [0.12] 40.2 0˚ ) 1.8 ±0.3 [0.28] Pin terminal part details 15.24 ±0.2 3.2 [0.13] [0.12] 0.7±0.4 [0.03] RC -Vin [1.58] 2.54 ±0.2 43 [1.69] [0.1] 2.54 ±0.2 [0.13] [0.14] [0.07] 1.4 [0.06] [0.6] 1.3 [0.02] [0.3] 22 [0.85] [0.87] 0.6 ±0.1 [0.6] 21.5 15.24 ±0.2 TRM 15.24 ±0.2 +Vout [0.05] Model +Vin 7.62 ±0.2 1.SMD(type B) 1 [0.04] 1.27 [0.05] 38.1 [1.5] January 31, 2022 SU.SUC/SUT-31 Ordering information DC-DC Converters PCB Mount Type SUCW10 SUC W 10 12 12 B P -O 1 2 3 4 5 6 7 8 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Mounting type B : SMD C : DIP 7Packing form Blank:Plastic cover P : Tray(SMD type) 8 Optional G : Capacitor between Input and Output is removed. C : with coating (only DIP type)* R * S afety standards are pending MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUCW100512 10.8 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.45 SUCW100515 10.5 t15 or +30 0.35 SUCW101212 10.8 t12 or +24 0.45 SUCW101215 10.5 t15 or +30 0.35 SUCW102412 10.8 t12 or +24 0.45 SUCW102415 10.5 t15 or +30 0.35 SUCW104812 10.8 t12 or +24 0.45 SUCW104815 10.5 t15 or +30 0.35 SUCW100512 SUCW100515 SUCW101212 SUCW101215 SUCW102412 SUCW102415 SUCW104812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 76 2.51typ 2.44typ 1.05typ 1.02typ 0.523typ 0.509typ 0.262typ 86typ 86typ 86typ 86typ 86typ 86typ 86typ t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) 0.45 0.35 0.45 0.35 0.45 0.35 0.45 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis SUCW104815 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION REMOTE ON/OFF INPUT-OUTPUT INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD UL60950-1, C-UL, EN62368-1 40.2X7.0X22.0mm [1.58X0.28X0.87 inches] (WXHXD) / 10g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-32 January 31, 2022 0.254typ 86typ t15(+30) 0.35 75max 750max 120max 150max 150max 200max 180max 290max 60max 14.25 - 15.75 SUCW10 External view 1.SMD(type B) Compornent area Model Compornent area +Vin [0.004] [1.58] [0.28] Part A 3.03 +0.5 -0.25 Closeup of part A 1.9 [0.07] 1.3 3.03 +0.5 -0.25 [0.12] 0.1min 40.2 7 ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]=inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 10g max [0.12] 0.6 ±0.1 [0.02] -Vout RC -Vin [0.6] [0.1] 15.24 ±0.2 7.62 ±0.2 [0.87] 22 [0.85] 21.5 [0.6] TRM [0.3] 2.54 ±0.2 +Vout COM [0.06] Unit : 0.1inch Dimensions in mm, [ ]=inches [0.004] Model f1.6 [0.04] Coplanarity within 0.1 2.DIP(type C) [0.1] [0.05] 1.4 [0.06] [0.6] 2.54 ±0.2 [0.1] 7-f0.9 [1.63] 15.24±0.2 type C 1.27 41.4 ±0.6 3.2 [0.13] [1.69] [0.12] [0.004] Closeup of part A 3.13 +0.5 -0.25 -1 (0 3.13 +0.5 -0.25 0.1min 1 [0.04] [0.05] 2.54 ±0.2 [0.08] 43 [0.12] 0.7±0.4 Part A [0.03] 0.8min 7 [0.28] 0˚ ) [0.03] 40.2 [1.58] [0.14] 2 3.2 [0.13] RC -Vin Pin terminal part details 3.68±0.25 15.24 ±0.2 [0.3] 22 [0.87] [0.85] 21.5 [0.6] 0.6 ±0.1 [0.02] TRM -Vout [0.1] 2.54 ±0.2 15.24 ±0.2 COM 7.62 ±0.2 +Vout +Vin 1.8±0.3 [0.07] Recommended Pad and Hole dia. (TOP VIEW) type B Adsorption area 1 [0.04] 1.27 [0.05] 38.1 [1.5] January 31, 2022 SU.SUC/SUT-33 Ordering information DC-DC Converters PCB Mount Type SUTS3 SUT 1 S 2 3 3 12 4 DC OUTPUT -O 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] 05 5 SUTS3053R3 1.98 VOLTAGE[V] *1 3.3 CURRENT[A] 0.6 SUTS30505 3 5 0.6 SUTS30512 3 12 0.25 SUTS30515 3 15 0.2 SUTS3123R3 1.98 3.3 0.6 SUTS31205 3 5 0.6 SUTS31212 3 12 0.25 SUTS31215 3 15 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUTS3053R3 SUTS30505 SUTS30512 SUTS30515 SUTS3123R3 DC4.5 - 9 DC9 - 18 0.550typ 0.800typ 0.780typ 0.780typ 0.223typ 72typ 75typ 77typ 77typ 74typ 3.3 5 12 15 3.3 0.6 0.6 0.25 0.2 0.6 20max 20max 48max 60max 20max 40max 40max 100max 120max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUTS3243R3 1.98 VOLTAGE[V] *1 3.3 CURRENT[A] 0.6 SUTS32405 3 5 0.6 SUTS32412 3 12 0.25 SUTS32415 3 15 0.2 SUTS3483R3 1.98 3.3 0.6 SUTS31205 SUTS31212 SUTS31215 0.325typ 77typ 5 0.6 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.317typ 79typ 12 0.25 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.321typ 78typ 15 0.2 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUTS34805 3 5 0.6 SUTS34812 3 12 0.25 SUTS34815 3 15 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-34 SUTS3243R3 SUTS32405 SUTS32412 SUTS32415 SUTS3483R3 DC18 - 36 DC36 - 76 0.114typ 0.057typ 0.163typ 0.159typ 0.161typ 73typ 72typ 77typ 79typ 78typ 3.3 3.3 5 12 15 0.6 0.6 0.6 0.25 0.2 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) January 31, 2022 SUTS34805 SUTS34812 SUTS34815 0.082typ 77typ 5 0.6 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.080typ 79typ 12 0.25 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.080typ 79typ 15 0.2 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUTS3 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 30.0X23.4X9.15mm [1.18X0.92X0.36 inches] (WXHXD) / 8g max Convection/Forced air *1 SUTW3xx12/SUTW3xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Model Recommended Pad and Hole dia. (TOP VIEW) 6.01 6.85 [0.04] 17.78 ±0.2 [0.7] 3.5 ±0.25 [0.02] 1 Part B [0.14] 0.6 ±0.1 1 [0.04] 6.01 6.85 1.9 [0.24] [0.27] [0.07] +Vout NC TRM 8.35 +Vin 5.08 [0.36] 6.01 ±0.2 [0.2] -Vout [0.33] RC 2.54 ±0.2 [0.24] 4-f1.6 [0.06] Unit : 0.1inch Dimensions in mm, [ ]= inches ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]= inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 8g max 9.15 -Vin [0.04] [0.27] 23.4 0.5 [0.02] Outline Part A 6.01 7-f0.9 [0.92] [0.24] [0.24] [0.1] 30 [1.18] ¶ Back View Closeup of part A Closeup of part B 6.01 6.85 [0.24] [0.27] : Conduction Area January 31, 2022 SU.SUC/SUT-35 Ordering information DC-DC Converters PCB Mount Type SUTW3 SUT W 1 2 3 3 12 4 12 5 -O 6 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUTW30512 3.12 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.13 SUTW30515 3 t15 or +30 0.1 SUTW31212 3.12 t12 or +24 0.13 SUTW31215 3 t15 or +30 0.1 SUTW32412 3.12 t12 or +24 0.13 SUTW32415 3 t15 or +30 0.1 SUTW34812 3.12 t12 or +24 0.13 SUTW34815 3 t15 or +30 0.1 SUTW30512 SUTW30515 SUTW31212 SUTW31215 SUTW32412 SUTW32415 SUTW34812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 76 0.844typ 0.811typ 0.343typ 0.329typ 0.172typ 0.165typ 0.086typ 74typ 74typ 76typ 76typ 76typ 76typ 76typ t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) 0.13 0.1 0.13 0.1 0.13 0.1 0.13 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis SUTW34815 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION REMOTE ON/OFF INPUT-OUTPUT INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD UL60950-1, C-UL, EN62368-1 30.0X23.4 X9.15mm [1.18X0.92X0.36 inches] (WXHXD) / 8g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-36 January 31, 2022 0.083typ 76typ t15(+30) 0.1 75max 750max 120max 150max 150max 200max 180max 290max 60max 14.25 - 15.75 SUTW3 External view Model 6.85 17.78 ±0.2 [0.7] +Vout +Vin 6.01 6.85 [0.24] [0.27] COM TRM 8.35 RC 5.08 2.54 ±0.2 [0.04] 6.01 [0.24] 4-f1.6 [0.06] Outline Unit : 0.1inch Dimensions in mm, [ ]= inches ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]= inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 8g max -Vout 6.01 ±0.2 [0.2] 1 [0.04] 7-f0.9 [0.27] 23.4 [0.04] 3.5 ±0.25 [0.02] Part B [0.14] 1 [0.33] 0.5 6.01 [0.24] [0.02] Part A 0.6 ±0.1 -Vin [0.92] Recommended Pad and Hole dia. (TOP VIEW) [0.24] [0.1] 30 [1.18] ¶ Back View Closeup of part A Closeup of part B 6.01 6.85 [0.24] [0.27] : Conduction Area January 31, 2022 SU.SUC/SUT-37 Ordering information DC-DC Converters PCB Mount Type SUTS6 SUT 1 S 2 6 3 12 4 DC OUTPUT -O 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] 05 5 SUTS6053R3 3.96 VOLTAGE[V] *1 3.3 CURRENT[A] 1.2 SUTS60505 5 5 1 SUTS60512 6 12 0.5 SUTS60515 6 15 0.4 SUTS6123R3 4.46 3.3 1.35 SUTS61205 6 5 1.2 SUTS61212 6 12 0.5 SUTS61215 6 15 0.4 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUTS6053R3 SUTS60505 SUTS60512 SUTS60515 SUTS6123R3 DC4.5 - 9 DC9 - 18 1.100typ 1.316typ 1.500typ 1.500typ 0.502typ 72typ 76typ 80typ 80typ 74typ 3.3 5 12 15 3.3 1.2 1 0.5 0.4 1.35 20max 20max 48max 60max 20max 40max 40max 100max 120max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUTS6243R3 4.46 VOLTAGE[V] *1 3.3 CURRENT[A] 1.35 SUTS62405 6 5 1.2 SUTS62412 6 12 0.5 SUTS62415 6 15 0.4 SUTS6483R3 4.46 3.3 1.35 SUTS61205 SUTS61212 SUTS61215 0.617typ 81typ 5 1.2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.588typ 85typ 12 0.5 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.588typ 85typ 15 0.4 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUTS64805 6 5 1.2 SUTS64812 6 12 0.5 SUTS64815 6 15 0.4 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-38 SUTS6243R3 SUTS62405 SUTS62412 SUTS62415 SUTS6483R3 DC18 - 36 DC36 - 76 0.248typ 0.121typ 0.309typ 0.291typ 0.291typ 75typ 77typ 81typ 86typ 86typ 3.3 3.3 5 12 15 1.35 1.35 1.2 0.5 0.4 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) January 31, 2022 SUTS64805 SUTS64812 SUTS64815 0.154typ 81typ 5 1.2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.145typ 86typ 12 0.5 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.145typ 86typ 15 0.4 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUTS6 GENERAL SPECIFICATIONS INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 37.6X26.4X9.15mm [1.48X1.04X0.36 inches] (WXHXD) / 11g max Convection/Forced air *1 SUTW6xx12/SUTW6xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Model Recommended Pad and Hole dia. (TOP VIEW) 9.81 [0.7] [0.06] RC +Vout +Vin 5.08 [0.04] ±0.25 6.85 1.9 [0.39] [0.27] [0.07] NC TRM -Vout 9.15 [0.36] 9.81 ±0.2 [0.2] 1 9.81 8.35 -Vin 2.54 ±0.2 9.81 [0.39] [0.27] 6.85 26.4 ±0.2 3.5 [0.04] 17.78 [0.14] [0.02] 1 Part B [0.33] 0.5 [0.02] 0.6 ±0.1 [0.04] 4-f1.6 Outline Part A 7-f0.9 [1.04] [0.39] Unit : 0.1inch Dimensions in mm, [ ]= inches ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]= inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 11g max [0.39] [0.1] 37.6 [1.48] ¶ Back View Closeup of part A 9.81 [0.39] Closeup of part B 6.85 [0.27] : Conduction Area January 31, 2022 SU.SUC/SUT-39 Ordering information DC-DC Converters PCB Mount Type SUTW6 SUT W 1 2 6 3 12 4 12 5 -O 6 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] SUTW64812 6 t12 or +24 0.25 SUTW64815 6 t15 or +30 0.2 SUTW60512 SUTW60515 SUTW61212 SUTW61215 SUTW62412 SUTW62415 SUTW64812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 76 INPUT 1.538typ 1.538typ 0.588typ 0.588typ 0.291typ 0.291typ 0.145typ 78typ 78typ 85typ 85typ 86typ 86typ 86typ t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) 0.25 0.2 0.25 0.2 0.25 0.2 0.25 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max OUTPUT 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 PROTECTION OVERCURRENT PROTECTION Works over 105% of rating and recovers automatically CIRCUIT AND REMOTE ON/OFF Provided (Negative logic L : ON, H : OFF) OTHERS INPUT-OUTPUT AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) ISOLATION INPUT-CASE AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) OUTPUT-CASE AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) , OPERATING TEMP. HUMID.AND ALTITUDE -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max ENVIRONMENT VIBRATION 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis SAFETY AGENCY APPROVALS UL60950-1, C-UL, EN62368-1 CASE SIZE/WEIGHT 37.6X26.4X9.15mm [1.84X1.04X0.36 inches] (WXHXD) / 11g max OTHERS Convection/Forced air COOLING METHOD SUTW64815 DC OUTPUT SUTW60512 6 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.25 SUTW60515 6 t15 or +30 0.2 SUTW61212 6 t12 or +24 0.25 SUTW61215 6 t15 or +30 0.2 SUTW62412 6 t12 or +24 0.25 SUTW62415 6 t15 or +30 0.2 SPECIFICATIONS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-40 January 31, 2022 0.145typ 86typ t15(+30) 0.2 75max 750max 120max 150max 150max 200max 180max 290max 60max 14.25 - 15.75 SUTW6 External view Model Recommended Pad and Hole dia. (TOP VIEW) [0.04] 17.78 ±0.2 [0.7] +Vout 9.81 6.85 1.9 [0.27] [0.07] COM TRM 5.08 [0.36] 9.81 ±0.2 [0.2] -Vout 2.54 ±0.2 [0.06] Unit : 0.1inch Dimensions in mm, [ ]= inches [0.04] [0.39] 8.35 +Vin 9.81 [0.39] 4-f1.6 1 [0.33] RC [0.04] Outline 9.15 -Vin 7-f0.9 [0.27] [1.04] 6.85 [0.02] 1 3.5 0.6 ±0.1 Part B [0.14] Part A ±0.25 [0.02] 0.5 26.4 9.81 [0.39] ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]= inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 11g max [0.39] [0.1] 37.6 [1.48] ¶ Back View Closeup of part A 9.81 [0.39] Closeup of part B 6.85 [0.27] : Conduction Area January 31, 2022 SU.SUC/SUT-41 Ordering information DC-DC Converters PCB Mount Type SUTS10 SUT S 10 12 05 -O 1 2 3 4 DC OUTPUT 6 1 Series name 2 Single output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] 5 SUTS10053R3 8.58 VOLTAGE[V] *1 3.3 CURRENT[A] 2.6 SUTS100505 10 5 2 SUTS100512 10.8 12 0.9 SUTS100515 10.5 15 0.7 SUTS10123R3 8.58 3.3 2.6 SUTS101205 10 5 2 SUTS101212 12 12 1 SUTS101215 12 15 0.8 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUTS10053R3 SUTS100505 SUTS100512 SUTS100515 SUTS10123R3 DC4.5 - 9 DC9 - 18 2.12typ 2.41typ 2.54typ 2.47typ 0.872typ 81typ 83typ 85typ 85typ 82typ 3.3 5 12 15 3.3 2.6 2 0.9 0.7 2.6 20max 20max 48max 60max 20max 40max 40max 100max 120max 40max 80max 80max 80max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 120max 120max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) SUTS10243R3 8.58 VOLTAGE[V] *1 3.3 CURRENT[A] 2.6 SUTS102405 10 5 2 SUTS102412 12 12 1 SUTS102415 12 15 0.8 SUTS10483R3 8.58 3.3 2.6 SUTS101205 SUTS101212 SUTS101215 0.980typ 85typ 5 2 20max 40max 80max 120max 120max 200max 50max 80max 20max 1.15typ 87typ 12 1 48max 100max 120max 150max 150max 200max 150max 240max 48max 1.15typ 87typ 15 0.8 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUTS104805 10 5 2 SUTS104812 12 12 1 SUTS104815 12 15 0.8 SPECIFICATIONS MODEL VOLTAGE[V] *2 INPUT CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] OUTPUT -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t3%) PROTECTION OVERCURRENT PROTECTION CIRCUIT AND REMOTE ON/OFF OTHERS SU.SUC/SUT-42 SUTS10243R3 SUTS102405 SUTS102412 SUTS102415 SUTS10483R3 DC18 - 36 DC36 - 76 0.436typ 0.218typ 0.490typ 0.575typ 0.575typ 82typ 82typ 85typ 87typ 87typ 3.3 3.3 5 12 15 2.6 2.6 2 1 0.8 20max 20max 20max 48max 60max 40max 40max 40max 100max 120max 80max 80max 80max 120max 120max 120max 120max 120max 150max 150max 120max 120max 120max 150max 150max 200max 200max 200max 200max 200max 50max 150max 180max 50max 50max 80max 240max 290max 80max 80max 20max 48max 60max 20max 20max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 3.21 - 3.42 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 3.21 - 3.42 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) January 31, 2022 SUTS104805 SUTS104812 SUTS104815 0.245typ 85typ 5 2 20max 40max 80max 120max 120max 200max 50max 80max 20max 0.287typ 87typ 12 1 48max 100max 120max 150max 150max 200max 150max 240max 48max 0.287typ 87typ 15 0.8 60max 120max 120max 150max 150max 200max 180max 290max 60max 4.90 - 5.21 11.64 - 12.36 14.55 - 15.45 SUTS10 GENERAL SPECIFICATIONS AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis UL60950-1, C-UL, EN62368-1 45.2X29.3 X9.15mm [1.78X1.15X0.36 inches] (WXHXD) / 14g max INPUT-OUTPUT ISOLATION INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE ENVIRONMENT VIBRATION IMPACT AGENCY APPROVALS SAFETY CASE SIZE/WEIGHT OTHERS COOLING METHOD Convection/Forced air *1 SUTW10xx12/SUTW10xx15 is available as single output, +24V/+30V. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. External view Model Recommended Pad and Hole dia. (TOP VIEW) ±0.25 [0.04] 3.5 0.6 ±0.1 [0.02] 17.78 ±0.2 [0.7] Part B [0.14] 1 [0.04] 6.85 1.9 [0.54] [0.27] [0.07] 9.15 [0.36] +Vout +Vin NC TRM -Vout 8.35 RC 5.08 [0.54] Unit : 0.1inch Dimensions in mm, [ ]= inches ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]= inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 14g max 13.61 ±0.2 [0.2] [0.33] -Vin 13.61 [0.06] 1 13.61 [0.04] 4-f1.6 Outline Part A 7-f0.9 [0.27] 6.85 [1.15] [0.54] [0.02] 0.5 29.3 13.61 2.54 ±0.2 [0.54] [0.1] 45.2 [1.78] ¶ Back View Closeup of part A Closeup of part B 13.61 [0.54] 6.85 [0.27] : Conduction Area January 31, 2022 SU.SUC/SUT-43 Ordering information DC-DC Converters PCB Mount Type SUTW10 SUT W 10 12 12 -O 1 2 3 4 5 6 1 Series name 2 Dual output 3 Output wattage 4 Input voltage 5 Output voltage 6 Optional G : Capacitor between Input and Output is removed. R MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT SUTW100512 10.8 VOLTAGE[V] *1 t12 or +24 CURRENT[A] 0.45 SUTW100515 10.5 t15 or +30 0.35 SUTW101212 10.8 t12 or +24 0.45 SUTW101215 10.5 t15 or +30 0.35 SUTW102412 10.8 t12 or +24 0.45 SUTW102415 10.5 t15 or +30 0.35 SUTW104812 10.8 t12 or +24 0.45 SUTW104815 10.5 t15 or +30 0.35 SUTW100512 SUTW100515 SUTW101212 SUTW101215 SUTW102412 SUTW102415 SUTW104812 DC4.5 - 9 DC9 - 18 DC18 - 36 DC36 - 76 2.51typ 2.44typ 1.05typ 1.02typ 0.523typ 0.509typ 0.262typ 86typ 86typ 86typ 86typ 86typ 86typ 86typ t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) t15(+30) t12(+24) 0.45 0.35 0.45 0.35 0.45 0.35 0.45 60max 75max 60max 75max 60max 75max 60max 600max 750max 600max 750max 600max 750max 600max 120max 120max 120max 120max 120max 120max 120max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 150max 200max 200max 200max 200max 200max 200max 200max 150max 180max 150max 180max 150max 180max 150max 240max 290max 240max 290max 240max 290max 240max 50max 60max 50max 60max 50max 60max 50max 20max (Minimum input, Io=100%) Fixed (TRM pin open) t5% adjustable by external VR 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 14.25 - 15.75 11.40 - 12.60 Works over 105% of rating and recovers automatically Provided (Negative logic L : ON, H : OFF) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) AC500V 1minute, Cutoff current = 10mA, DC500V 50MW min (20t15C) -40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000feet) max -40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000feet) max 10 - 55Hz, 98.0m/s2 (10G), 3minutes period, 60minutes each along X, Y and Z axis 490.3m/s2 (50G), 11ms, once each along X, Y and Z axis SUTW104815 SPECIFICATIONS INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY OTHERS MODEL VOLTAGE[V] *2 CURRENT[A] *2 EFFICIENCY[%] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] -20 to +55C *3 RIPPLE[mVp-p] -40 to -20C *3 -20 to +55C *3 RIPPLE NOISE[mVp-p] -40 to -20C *3 -20 to +55C TEMPERATURE REGULATION[mV] -40 to +55C *4 DRIFT[mV] START-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE OUTPUT VOLTAGE SETTING[V] (t5%) OVERCURRENT PROTECTION REMOTE ON/OFF INPUT-OUTPUT INPUT-CASE OUTPUT-CASE OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS CASE SIZE/WEIGHT COOLING METHOD UL60950-1, C-UL, EN62368-1 45.2X29.3 X9.15mm [1.78X1.15X0.36 inches] (WXHXD) / 14g max Convection/Forced air *1 Output pins can be connected in series to make a 24V/30V output. *2 Rated input 5V, 12V, 24V or 48V DC Io=100% *3 Ripple and Ripple Noise is measured by using measuring board with capacitor with in 25mm from output pin terminals. *4 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. * Parallel operation with other model is not possible. SU.SUC/SUT-44 January 31, 2022 0.254typ 86typ t15(+30) 0.35 75max 750max 120max 150max 150max 200max 180max 290max 60max 14.25 - 15.75 SUTW10 External view Model Recommended Pad and Hole dia. (TOP VIEW) 13.61 17.78 ±0.25 3.5 ±0.2 [0.7] [0.14] 1 [0.04] 0.6 ±0.1 [0.02] 6.85 Part B 1 [0.04] 13.61 6.85 1.9 [0.54] [0.27] [0.07] 9.15 +Vout +Vin COM TRM -Vout 5.08 [0.2] [0.36] [0.33] RC 8.35 -Vin [0.04] 13.61 [0.54] 4-f1.6 [0.06] Outline Part A 7-f0.9 [0.27] 29.3 [0.02] 0.5 [1.15] [0.54] Unit : 0.1inch Dimensions in mm, [ ]= inches ¶ Tolerance ±0.5 [±0.02] ¶ Dimensions in mm, [ ]= inches ¶ Pin terminal thickness : 0.3±0.1 [0.012] ¶ Pin terminal material : Copper alloy ¶ Plating treatment of terminal : Lead free plating ¶ Case thickness : 0.2±0.05 [0.008] ¶ Case material : Brass ¶ Plating treatment of case : Nickel plating ¶ Please keep enough creepage distance with the pattern on PCB and other components. ¶ Weight : 14g max 13.61 ±0.2 2.54 ±0.2 [0.54] [0.1] 45.2 [1.78] ¶ Back View Closeup of part A Closeup of part B 13.61 [0.54] 6.85 [0.27] : Conduction Area January 31, 2022 SU.SUC/SUT-45 SU-SUC/SUT-series Pin Configuration ¿ SU/SUC Single Output Pin No. View from Above 1 2 Input 3 +Vin +Vout RC TRM -Vin -Vout 8 1 2 3 4 5 4 6 Load 7 Case Connecting Pin 6 7 ¿ SU/SUC Dual (±) Output View from Above 1 Input +Vin COM RC 2 3 TRM -Vin 8 4 +Vout 5 Load 6 Load Pin Terminal Name +Vin RC -Vin +Vout COM Function +DC Input Remote ON/OFF (excluding 1R5) -DC Input +DC Output GND of Output Voltage (for Dual Output) Output Voltage Adjustment (please see TRM Instruction Manual 1.4) -Vout -DC Output If connected to -Vin, a case potential becomes Case Connecting fixed and radiation noise decreases (applicable Pin only to SUC series). Load -Vout 7 8 Case Connecting Pin ¿ SU/SUC Single Output, Dual (±) Output Bottom View 8 1 2 3 4 5 Pin No. 8 6 1 2 3 4 7 8 8 5 6 7 8 Pin Terminal Name -Vin RC +Vin +Vout NC (Single output) COM (Dual output) TRM -Vout Case Connecting Pin Function -DC Input Remote ON/OFF +DC Input +DC Output GND of Output Voltage Output Voltage Adjustment -DC Output If connected to -Vin, a case potential becomes fixed and radiation noise decreases. ¡Case Connecting Pin Terminal Units come with a case connecting pin terminal. If this pin terminal is connected to -Vin, radiation noise from the main body decreases. Solder the case connecting pin terminal to PCB to improve reliability. Assembling and Installation Method Installation ¡You can install the units in any direction. Place them in such a way that there is enough ventilation so that heat does not get accumulated around them. ¡Do not place a rand or a pattern layout in the hatched area shown in below. Doing so may cause insulation failure on the PCB surface on which the power supply is mounted. A Outline +Vout -Vin -Vout A: SU Series 2mm 5.2 SUC Series 2.5mm Area where Pattern Layout should not be Placed for SU/SUC SU.SUC/SUT-46 2.3 +Vin 4.4 Outer Contour of the Unit 1.75 2.3 A Case Connecting Pin Area where Pattern Layout should not be Placed for SUT January 31, 2022 SU-SUC/SUT-series Assembling and Installation Method Automatic Mounting (TYPE: BP) ¡To mount SU series automatically, use the transformer area near the center of the PCB as a pickup point. To mount SUC series automatically, use the central area of the case as a pickup point. If the bottom dead point of a suction nozzle is too low when mounting, excessive force is applied to the transformer, which could cause damage. Please mount carefully. Please see the External View for details of the pickup point. Hand Mounting (TYPE:B,C SUT) push push ¡To mount SU series manually, it must be push the transformer placed center of PS. ¡To mount SUC series manually, it must be push the center of case. ¡Due to prevent failure, PS should not be pull after soldering with PCB. Soldering Conditions (1) Reflow Soldering (except SUT, SUC□□C-C) +Vin ¡Right figure shows conditions for the reflow soldering for SU/SUC series. Please make sure that the temperatures of pin terminals +Vin and -Vout shown in right figure . do not exceed the tempera- -Vout tures shown in right figure. ¡If time or temperature of the reflow soldering goes beyond the conditions, reliability of internal components may be compromised. *View from Above (C) Please use the unit under the recommended reflow conditions. Tp ¡With this reflow profile, internal solder melts down. When transporting the unit within the reflow oven, please do not give vibration Tx Ty2 to the unit. Ty1 ¡Please avoid reflow soldering after applying adhesive or coating to the unit. ¡You can reflow solder up to 2 times. Do not reflow solder when the power supply is mounted on the back surface of the PCB because the unit may drop. A (2) Flow Soldering : 260C 15 seconds or less B B’ C time(s) A A’ (3) Soldering Iron : maximum 360C 5 seconds or less A’ B B’ C 1.0 - 5.0C/s Ty1 : 160 ±20C Ty2 : 180 ±20C Ty1 - Ty2 : 120s max 1.0 - 5.0C/s Tp : Max 245C 10s max Tx : 220C or more : 70s max 1.0 - 5.0C/s Stress to Pin Terminals ¡If too much stress is applied to input/output pin terminals of thepower supply, internal connection may come down. If you apply stress as shown below, please kept it at 19.6N (2kgf) or less vertically. ¡Input/output pin terminals are soldered to the PCB internally. Do not pull or bend a lead powerfully. ¡If it is expected that stress is applied to the input/output pin terminals due to vibration or impact, reduce the stress to the pin terminals by taking such measures as fixing the unit to the PCB by silicone rubber, etc. A part 19.6N(2kgf) or less 19.6N(2kgf) or less 19.6N(2kgf) or less 19.6N(2kgf) or less Less than A Strength of Input/Output Pin Terminals for SU/SUC 19.6N(2kgf) Strength of Input/Output Pin Terminals for SUT January 31, 2022 SU.SUC/SUT-47 SU-SUC/SUT-series Derating Ambient temperature derating curve ¡It is necessary to note thermal fatigue life by power cycle.Please reduce the temperature fluctuation range as much as possible when the up and down of temperature are frequently generated. ¡In the case of forced air cooling,Please have sufficient ventilation to keep the temperature of point in Instruction Manual 7 . Please also make sure that the ambient temperature does not exceed 85C. ¿ SU/SUC1R5 (2) In the case of Forced Air Cooling (1m/s) (1) In the case of Convection Cooling 100 A Load Factor [%] Load Factor [%] 100 B 50 0 -40 -20 0 20 40 (55) 60 80 (85) A 50 0 -40 100 -20 0 Ambient Temperature [C] Output Voltage(V) Input Voltage(V) 5 12 24 48 3.3 5 12 15 ±12 ±15 A A A B A A A B A A A B A A A B A A A B A A A B Output Voltage(V) Input Voltage(V) 5 12 24 48 ¿ SU/SUC3 60 80 (85) 100 3.3 5 12 15 ±12 ±15 A A A A A A A A A A A A A A A A A A A A A A A A 100 100 A Load Factor [%] Load Factor [%] 40 (2) In the case of Forced Air Cooling (1m/s) (1) In the case of Convection Cooling B 50 C 0 -40 -20 0 20 40 (55) 60 (71) 80 (85) B 0 -40 100 Input Voltage(V) 5 12 24 48 A 50 -20 0 Ambient Temperature [C] Output Voltage(V) 20 40 60 80 (85) 100 Ambient Temperature [C] 3.3 5 12 15 ±12 ±15 A A A B A A A B B B B B B B B B A A A A B B B C Output Voltage(V) Input Voltage(V) 5 12 24 48 ¿ SU/SUC6 3.3 5 12 15 ±12 ±15 A A A A B A A A B A B A B A A A B A A A B B B B (2) In the case of Forced Air Cooling (1m/s) (1) In the case of Convection Cooling 100 100 A Load Factor [%] Load Factor [%] 20 Ambient Temperature [C] 50 B 0 -40 -20 0 20 40 (55) 60 (71) 80 (85) 100 50 0 -40 -20 0 Ambient Temperature [C] Output Voltage(V) Input Voltage(V) 5 12 24 48 SU.SUC/SUT-48 A B 20 40 60 (75) 80 (85) 100 Ambient Temperature [C] 3.3 5 12 15 ±12 ±15 B B B B B B B B B B B A B B B A B B B A B B B A Output Voltage(V) Input Voltage(V) 5 12 24 48 January 31, 2022 3.3 5 12 15 ±12 ±15 B B B B B B B B A A A A A A A A A A A A A A A A SU-SUC/SUT-series Derating ¿ SU/SUC10 (2) In the case of Forced Air Cooling (1m/s) (1) In the case of Convection Cooling 100 A Load Factor [%] Load Factor [%] 100 50 B 0 -40 -20 0 20 40 (55) 60 (71) 80 (85) 50 0 -40 100 -20 0 Ambient Temperature [C] Output Voltage(V) Input Voltage(V) 5 12 24 48 3.3 5 12 15 ±12 ±15 B B B B A A A B A A A B A A A B A A A B A A A B Output Voltage(V) Input Voltage(V) 5 12 24 48 40 60 (71) 80 (85) 100 3.3 5 12 15 ±12 ±15 B B B B B B B B B B B B B B B B A A A B A A A B (2) In the case of Forced Air Cooling (1m/s) (1) In the case of Convection Cooling 100 100 A Load Factor [%] Load Factor [%] 20 Ambient Temperature [C] ¿ SUT3 B 50 C 0 -40 -20 0 20 40 (55) 60 (71) 80 (85) 50 0 -40 100 Output Voltage(V) Input Voltage(V) 5 12 24 48 A B -20 0 Ambient Temperature [C] 20 40 60 80 (85) 100 Ambient Temperature [C] 3.3 5 12 15 ±12 ±15 A A A B A A A B B B B B B B B B A A A A B B B C Output Voltage(V) Input Voltage(V) 5 12 24 48 ¿ SUT6 3.3 5 12 15 ±12 ±15 A A A A B A A A B A B A B A A A B A A A B B B B (2) In the case of Forced Air Cooling (1m/s) (1) In the case of Convection Cooling 100 100 A Load Factor [%] Load Factor [%] A B B 50 0 -40 -20 0 20 40 (55) 60 (71) 80 100 A B 50 0 -40 -20 0 Ambient Temperature [C] Output Voltage(V) Input Voltage(V) 5 12 24 48 20 40 60 (71) 80 (85) 100 Ambient Temperature [C] 3.3 5 12 15 ±12 ±15 B B B B B B B B B B B A B B B A B B B A B B B A Output Voltage(V) Input Voltage(V) 5 12 24 48 January 31, 2022 3.3 5 12 15 ±12 ±15 B B B B B B B B B A A A B A A A B A A A B A A A SU.SUC/SUT-49 SU-SUC/SUT-series Derating ¿ SUT10 (1) In the case of Convection Cooling (2) In the case of Forced Air Cooling (1m/s) 100 B Load Factor [%] Load Factor [%] 100 A C 50 0 -40 -20 0 20 40 50 (55) 60 (71) 80 A 50 0 -40 100 -20 0 Ambient Temperature [C] Output Voltage(V) Input Voltage(V) 5 12 24 48 20 40 60 (71) 80 (85) 100 Ambient Temperature [C] 3.3 5 12 15 ±12 ±15 C B C C C A C C A A C C A A C C C B C C C A B C Output Voltage(V) Input Voltage(V) 5 12 24 48 3.3 5 12 15 ±12 ±15 A A A A A A A A A A A A A A A A A A A A A A A A Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual https://en.cosel.co.jp/product/powersupply/SUS/ Instruction Manual https://en.cosel.co.jp/product/powersupply/SUW/ Instruction Manual https://en.cosel.co.jp/product/powersupply/SUCS/ Instruction Manual https://en.cosel.co.jp/product/powersupply/SUCW/ Instruction Manual https://en.cosel.co.jp/product/powersupply/SUTS/ Instruction Manual https://en.cosel.co.jp/product/powersupply/SUTW/ Before using our product https://en.cosel.co.jp/technical/caution/index.html SUS SUCS SUTS SUW SUCW SUTW NOTICE Basic Characteristics Data Model Circuit method Switching frequency [kHz] Inrush current protection Input current [A] (reference) Series/Parallel operation availability PCB/Pattern Single sided Material Double Series Parallel sided operation operation SU/SUC1R5 Flyback converter 350 - 1900 Refer to Table1,2 - glass fabric base,epoxy resin Yes Yes *1 SU/SUC3 Flyback converter 200 - 1400 Refer to Table1,2 - glass fabric base,epoxy resin Yes Yes *1 SU/SUC6 Flyback converter 230 - 1950 Refer to Table1,2 - glass fabric base,epoxy resin Yes Yes *1 SU/SUC10 Flyback converter 250 - 300 Refer to Table1,2 - glass fabric base,epoxy resin Yes Yes *1 SUT3 Flyback converter 200 - 1400 Refer to Table1,2 - glass fabric base,epoxy resin Yes Yes *1 SUT6 Flyback converter 230 - 1950 Refer to Table1,2 - glass fabric base,epoxy resin Yes Yes *1 SUT10 Flyback converter 250 - 300 Refer to Table1,2 - glass fabric base,epoxy resin Yes Yes *1 *1 Refer to Instruction Manual. * The value of input current is measured at rated input and load. Table1 (SUS*** +5V output) [A] Input Voltage Table2 (SUW*** t12V output) [A] Input Voltage Output Power 5V 12V 24V 48V Output Power 5V 12V 24V 48V 1.5W 0.41 0.16 0.08 0.04 1.5W 0.43 0.17 0.09 0.04 3W 0.78 0.32 0.16 0.08 3W 0.82 0.33 0.17 0.08 6W 1.32 0.62 0.31 0.15 6W 1.54 0.59 0.29 0.15 10W 2.41 0.98 0.49 0.25 10W 2.51 1.05 0.52 0.26 SU.SUC/SUT-50 January 31, 2022
SUCS6123R3B 价格&库存
很抱歉,暂时无法提供与“SUCS6123R3B”相匹配的价格&库存,您可以联系我们找货
