QB0402A20ESS3
QB0402A20ESS3
    ATC
    QB0402A20ESS3
QB0402A20ESS3 数据手册
i c s .c o m ATC Q-BRIDGE THERMAL CONDUCTOR ATC Q-Bridge Thermal Conductor ATC’s new Q-Bridge Thermal Conductor is manufactured with the highest quality materials for reliable and repeatable performance providing a cost effective thermal management solution. These devices are constructed with Aluminum Nitride (AlN) or Beryllium Oxide (BeO) and are available in standard EIA form factors. Q-Bridge provides the designer with the ability to manage thermal conditions by directing heat to a thermal ground plane, heat sink or any other specific thermal point of interest. The inherently low capacitance makes this device virtually transparent at RF / microwave frequencies. This device has the added benefit of offering additional layers of protection to adjacent components from hot spot thermal loads. Q-Bridge provides the benefit of increased overall circuit reliability. ATC’s Q-Bridge is manufactured using onepiece construction, providing a RoHS compliant SMT package that is fully compatible with high speed automated pick-and-place processing. It is available in various EIA case sizes. Custom configurations are also available. Applications: • GaN Power Amplifiers • High RF Power Amplifiers • Filters • Synthesizers • Industrial Computers • Switch Mode Power Supplies • Pin & Laser Diodes Features: • High Thermal Conductivity Functional Applications: • Low Thermal Resistance • Between active device and adjacent ground planes • Low Capacitance • Specific contact pad to case • Increases Circuit Reliability • Contact pad to contact pad • RoHS Compliant • Direct component contact to via pad or trace • More efficient thermal management • Edges fully metalized Termination Materials ATC Termination Code Termination Materials Y Silver Platinum Non-Magnetic Termination S Silver over Magnetic Termination Note: Non-edge wrapped style in all case sizes is supplied with S termination Edge wrapped style in case sizes 0302 through 1111 is supplied with Y termination Edge wrapped style in case sizes 2010 through 3737 are supplied with S termination ATC # 001-1143 Rev. I, 4/20 i c s .c o m ATC Q-BRIDGE THERMAL CONDUCTOR t t Mechanical Configurations L W W L T T Wrapped Non-Wrapped Typical Characteristics Thermal Thermal Resistance (°C/W) Conductivity (mW/°C) Case Size Length (L) Width (W) Thickness (T) Terminal (t) 0302 .030 ±.002 (.77 ±.051) .020 ±.002 (0.51 ±.051) 20 (0.51 ±.05) 10 (0.25) 19 12 53 81 0402 .040 ±.002 (1.02 ±.051) .020 ±.002 (0.51 ±.051) 20 (0.51 ±.05) 10 (0.25) 25 16 40 61 0505 .050 ±.002 (1.27 ± .051) .050 ±.002 (1.27 ±.051) 25 (0.64 ±.05) 15 (0.38) 10 7 100 153 0603 .060 ±.002 (1.52 ±.051) .030 ±.002 (.76 ±.051) 25 (0.64 ±.05) 15 (0.38) 20 13 50 76 0805 .080 ±.002 (2.03 ±.051) .050 ±.002 (1.27 ±.051) 40 (1.02 ±.05) 20 (0.51) 10 7 100 153 1005 .100 ±.002 (2.54 ±.051) .050 ±.002 (1.27 ±.051) 40 (1.02 ±.05) 20 (0.51) 13 8 77 122 1020 .100 ±.002 (2.54 ±.051) .200 ±.002 (5.08 ±.051) 40 (1.02 ±.05) 20 (0.51) 3 2 320 508 1111 .110 ±.002 (2.79 ±.051) .110 ±.002 (2.79 ±.051) 40 (1.02 ±.05) 20 (0.51) 7 4 153 240 2010 .195 ±.010 (4.95 ±.254) .095 ±.010 (2.41 ±.254) 60 (1.52 ±.05) 30 (0.77) 10 6 100 159 2525 .240 ±.010 (6.10 ±.254) .250 ±.010 (6.35 ±.254) 60 (1.52 ±.05) 40 (1.02) 4 3 240 380 3725 .370 ±.010 (9.40 ±.254) .245 ±.010 (6.22 ±.254) 60 (1.52 ±.05) 50 (1.27) 6 4 160 254 3737 .365 ±.010 (9.27 ±.254) .375 ±.010 (9.53 ±.254) 60 (1.52 ±.05) 50 (1.27) 4 3 240 380 AlN BeO AlN BeO Available Configurations Style W E W E W E W E W E W E W E W E W E W E W E W E Termination Y S Y S Y S Y S Y S Y S Y S Y S S S S S S S S S inches (mm) Note: Thermal conductivity is normalized to chip size. All values are approximate. Consult factory for extended thermal conductivity options. 2 i c s .c o m ATC Q-BRIDGE THERMAL CONDUCTOR Capacitance Case Size 0302 0402 0505 0603 0805 1005 Part Number Capacitance (pF) QB0302A20WY QB0302A20ES QB0302B20WY QB0302B20ES QB0402A20WY QB0402A20ES QB0402B20WY QB0402B20ES QB0505A25WY QB0505A25ES QB0505B25WY QB0505B25ES QB0603A25WY QB0603A25ES QB0603B25WY QB0603B25ES QB0805A40WY QB0805A40ES QB0805B40WY QB0805B40ES QB1005A40WY QB1005A40ES QB1005B40WY QB1005B40ES 0.039 0.011 0.028 0.006 0.028 0.018 0.025 0.009 0.070 0.032 0.061 0.027 0.035 0.007 0.029 0.007 0.081 0.018 0.055 0.015 0.046 0.008 0.038 0.007 Case Size 1020 1111 2010 2525 3725 3737 Part Number Capacitance (pF) QB1020A40WY QB1020A40ES QB1020B40WY QB1020B40ES QB1111A40WY QB1111A40ES QB1111B40WY QB1111B40ES QB2010A60WS QB2010A60ES QB2010B60WS QB2010B60ES QB2525A60WS QB2525A60ES QB2525B60WS QB2525B60ES QB3725A60WS QB3725A60ES QB3725B60WS QB3725B60ES QB3737A60WS QB3737A60ES QB3737B60WS QB3737B60ES 0.204 0.121 0.158 0.092 0.096 0.042 0.078 0.031 0.070 0.042 0.055 0.086 0.156 0.114 0.122 0.075 0.105 0.076 0.080 0.058 0.164 0.130 0.126 0.099 ATC Part Number Code QB 0603 A 25 W Y T Packaging T = Tape and Reel, std. 1000 pc., 7” Reel 500 pc., 7” Reel C = ATC Matrix Tray Q-Bridge Case Size Substrate A = AlN; B = BeO Termination Code Y = Silver Platinum Non-Magnetic Termination S = Silver over Magnetic Termination Thickness (mils) Style: W = Edge Wrap; E = No Wrap The above part number refers to a Q-Bridge, (EIA case size 0603), Aluminum Nitride (AlN) substrate, Thickness 25 mils., Style W, Y Termination (Silver Platinum Non-Magnetic Termination), with Tape and Reel Packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at +1-631-622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC’s website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2015 American Technical Ceramics Corp. All Rights Reserved. 3 ATC # 001-1143, Rev. I, 4/20
QB0402A20ESS3 价格&库存
很抱歉,暂时无法提供与“QB0402A20ESS3”相匹配的价格&库存,您可以联系我们找货
