KBP310G-C5.5
KBP310G-C5.5
    JINGDAO(晶导微电子)
    KBPC-5.5
    KBP310G-C5.5
KBP310G-C5.5 数据手册
山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD KBP3005G-C5.5 THRU KBP310G-C5.5 GLASS PASSIVATED BRIDGE RECTIFIERS Reverse Voltage - 50 to 1000 V KBP-C5.5 Forward Current - 3.0 A FEATURES • Rating to 1000V PRV • Ideal for printed circuit board • Reliable low cost construction utilizing molded plastic technique • The plastic material has UL flammability classification 94V#0 MECHANICAL DATA • Polarity : As marked on body • Weight : 0.05 ounces, 1.52 grams • Mounting position : Any +~ ~ - MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ℃ ambient temperature unless otherwise specified. SYMBOL KBP 3005G -C5.5 KBP 301G -C5.5 KBP 302G -C5.5 KBP 304G -C5.5 KBP 306G -C5.5 KBP 308G -C5.5 KBP 310G -C5.5 Units Maximum Recurrent Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward (With heatsink) Rectified Current @TC=105°C (Without heatsink) I (AV) 3.0 1.9 A Peak Forward Surge Current 8.3ms single half sine-wave I FSM 55 A Peak Forward Surge Current 1.0ms single half sine-wave I FSM 110 A Maximum Forward Voltage at 3.0A DC VF 1.1 V Maximum DC Reverse Current at T a = 25°C T a =125°C IR 5 500 uA I 2 t Rating for fusing (3ms≤t ≤8.3ms) I 2t 17.5 A 2S Typical Junction Capacitance per element (Note 1) Cj 60 pF Typical thermal resistance (Unit mounted on 30mmx30mmx1mm Copper plate heat sink.) RθJA RθJC RθJL 30 10 12 °C/W Typical thermal resistance (without hea tsink) RθJA RθJC RθJL 40 12 18 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C CHARACTERISTICS rated Blocking Voltage Operating Junction Temperature Range Storage Temperature Range Note: (1) Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 2019.01 KBP-A-KBP3005G-C5.5~KBP310G-C5.5-3A1KV Page 1 of 3 山东晶导微电子股份有限公司 Average Forward Current (A) Fig.1 Forward Current Derating Curve Heat sink : 30*30*1 mm Copper plate 3.0 2.0 Without heatsink 1.0 RESISTIVE OR INDUCTIVE LOAD 0.0 25 50 75 100 125 150 175 INSTANTANEOUS REVERSE CURRENT, (uA) Jingdao Microelectronics co.LTD KBP3005G-C5.5 THRU KBP310G-C5.5 Fig.2 Typical Instaneous Reverse Characteristics 1000 100 T J =125°C 10 1.0 0.1 0.01 80 100 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) 10 1.0 T J =25°C 100 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 10 100 Instaneous Forward Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 70 60 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 1.0 Reverse Voltage (V) 80 10 0.1 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 60 Percent of rated peak reverse voltage (%) Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) 40 20 0 Case Temperature (°C) 100 10 Number of Cycles at 60Hz 2019.01 T J =25°C 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 Jingdao Microelectronics co.LTD KBP3005G-C5.5 THRU KBP310G-C5.5 KBP-C5.5 Package Outline Dimensions KBP-C5.5 B A F M K C L I E d G D J DIM. MIN. MAX. A 14.25 14.75 B 3.35 3.65 C 10.20 10.60 D 5.0 6.0 d 1.40 1.70 E 1.80 2.20 F 0.80 1.10 G 3.56 4.06 H 0.35 0.55 I 1.22 1.42 J 0.76 0.86 K H Unit :mm 2.7X45°(typ) L # 3° M # 2° All dimensions in millimrter 山东晶导微电子股份有限公司 SHANDONG JINGDAO MICROELECTRONICS CO.LTD 地址:山东省济宁市曲阜市春秋东路166号 电话:0537-4613079 邮箱:sales@sdjingdao.com 网站:www.sdjingdao.com 2019.01 PG901257B0 Page 3 of 3
KBP310G-C5.5 价格&库存
很抱歉,暂时无法提供与“KBP310G-C5.5”相匹配的价格&库存,您可以联系我们找货
