FN15679
FN15679
    LEDIL(芬兰)
    FN15679
FN15679 数据手册
PRODUCT DATASHEET RONDA-S RONDA-S ~25° spot beam with holder A compatible with 3rd party connectors from TE, Bender+Wirth and IDEAL TECHNICAL SPECIFICATIONS: Dimensions Ø 69.9 mm Height 17.2 mm Fastening screw ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour F15667_RONDA-S Single lens PMMA clear F15155_RONDA-HLD-A Holder PC white Finish ORDERING INFORMATION: Quantities for one set: Single lens 1 Holder 1 Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET RONDA-S Component Qty in box MOQ MPQ Box weight (kg) F15667_RONDA-S » Box size: 480 x 280 x 300 mm Single lens 420 120 30 6.3 F15155_RONDA-HLD-A » Box size: 480 x 280 x 300 mm Holder 420 120 30 4.4 Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET RONDA-S Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET RONDA-S See also our general installation guide: www.ledil.com/installation_guide Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET RONDA-S PHOTOMETRIC DATA (MEASURED): LED V13 Gen7 FWHM / FWTM 32.0° / 79.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Vero SE 13 FWHM / FWTM 33.0° / 73.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C16402_CLAMP-VEROSE-13-18 LED VERO13 FWHM / FWTM 32.0° / 70.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 LED VERO18 FWHM / FWTM 39.0° / 109.0° Efficiency 81 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET RONDA-S PHOTOMETRIC DATA (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 33.0° / 87.0° Efficiency 83 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C16791_CLAMP-Z45-A TE Connectivity: 2325807-3 LED CMA1840 FWHM / FWTM 38.0° Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C14123_CLAMP-CXA15-18 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 33.0° / 69.0° Efficiency 88 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C14123_CLAMP-CXA15-18 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 31.0° / 71.0° Efficiency 83 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: TE Connectivity: 2213401-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET RONDA-S PHOTOMETRIC DATA (MEASURED): LED PrevaLED Core G7 L15 H1 FWHM / FWTM 35.0° / 96.0° Efficiency 82 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C16685_CLAMP-PRV-A LED Fortimo SLM L13 CoB FWHM / FWTM 34.0° / 73.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Fortimo SLM L15 + SLM holder FWHM / FWTM 34.0° / 92.0° Efficiency 79 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED AC Zhaga COB FWHM / FWTM 36.0° / 84.0° Efficiency 83 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: Optosource: SEHSMJD-A Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET RONDA-S PHOTOMETRIC DATA (MEASURED): LED MJT COB LES 14.5 FWHM / FWTM 38.0° / 93.0° Efficiency 78 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: TE Connectivity: 2213254-2 + OPTIC CLIP Z50 TYPE1 2213194-1 Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET RONDA-S PHOTOMETRIC DATA (SIMULATED): LED V13 Gen7 FWHM / FWTM 24.0° / 64.0° Efficiency 73 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2103CT + 50-2100AN LED CLL02x/CLU02x (LES10) FWHM / FWTM 25.0° / 49.0° Efficiency 86 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 LED CXA/B 15xx FWHM / FWTM 22.0° / 42.0° Efficiency 89 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 LED Duris S10 FWHM / FWTM 17.0° / 36.0° Efficiency 87 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET RONDA-S GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 31/10/2019 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
FN15679 价格&库存
很抱歉,暂时无法提供与“FN15679”相匹配的价格&库存,您可以联系我们找货
