FCI3216F-4R7K
FCI3216F-4R7K
    TAI-TECH(台庆)
    固定电感器 1206
FCI3216F-4R7K 数据手册
Form No: Specification for Approval Date: 2021/08/16 Customer : 天诚科技 TAI-TECH P/N: FCI3216F-4R7K CUSTOMER P/N: DESCRIPTION: QUANTITY: REMARK: Customer Approval Feedback 西 北 臺 慶 科 技 股 份 有 限 公司 TAI-TECH Advanced Electronics Co., Ltd Sales Dep. 代理商: ■ 深圳市天诚科技有限公司 Shenzhen TsaSun Technology Co., Ltd. Room 209, 2/F, Block A, Tengfei Industrial Building, No.6, Taohua Road, Futian District, Shenzhen TEL: 0755-8335 8885 / 0755-8335 9885 E-mail: sales@tsasun.com www.tsacoil.com □ 西北臺慶科技股份有限公司 TAI-TECH Advanced Electronics Co., Ltd Headquarter: NO.1 YOU 4TH ROAD, YOUTH INDUSTRIAL DISTRICT, YANG-MEI, TAO-YUAN HSIEN, TAIWAN, R.O.C. TEL: +886-3-4641148 FAX: +886-3-4643565 http://www.tai-tech.com.tw E-mail: sales@tai-tech.com.tw APPROVED CHECKED 夏暁曼 夏暁曼 R&D Center APPROVED CHECKED DRAWN 羅宜春 梁周虎 卜文娟 □ 臺慶精密電子(昆山)有限公司 TAI-TECHADVANCEDELECTRONICS(KUNSHAN)CO., LTD SHINWHA ROAD, KUNJIA HI-TECH INDUSTRIAL PARK, KUN-SHAN, JIANG-SU, CHINA TEL: +86-512-57619396 FAX: +86-512-57619688 E-mail: hui@tai-tech.com.tw TA734003 TAI-TECH KBM01-200700472 Ferrite Chip Inductor(Lead Free) P2. FCI3216F-4R7K 1.Features Halogen 1. Monolithic inorganic material construction. Halogen-free 2. Closed magnetic circuit avoids crosstalk. 3. S.M.T. type. 4. Suitable for reflow soldering. 5. Shapes and dimensions follow E.I.A. spec. 6. Available in various sizes. 7. Excellent solder ability and heat resistance. 8. High reliability. 9.100% Lead(Pb) & Halogen-Free and RoHS compliant. 10. Operating Temperature: -55~+105℃(Including self-temperature rise) 2. Dimensions Chip Size 3. Part Numbering FCI 3216 F A B C A 3.20±0.20 B 1.60±0.20 C 1.10±0.30 D 0.50±0.30 Units: mm - 4R7 K D A: Series B: Dimension C: Material D: Inductance E: Inductance Tolerance E LxW Lead Free Material 4R7=4.7uH K=±10%, L=±15%, M=±20% 4.Specification Tai-Tech Inductance(uH) Q Rated Current DCR SRF Tolerance Test Frequency (Hz) min. Test Frequency (MHz) (mA) max. (Ω) max. (MHz) min. FCI3216F-4R7K 4.7±10% 60mV / 10M 45 10 50 0.90 35 ● Rated current: based on temperature rise test In compliance with EIA 595 Inductance-Frequency Characteristics „ L vs Freq. 8 6 Inductance(uH) ● Part Number 4R7 4 2 0 -2 -4 1 10 100 FREQUENCY(MHz) www.tai-tech.com.tw 1000 TAI-TECH KBM01-200700472 P3. 5. Reliability and Test Condition Item Series No. Performance FCI FHI Test Condition FCH HCI -55~+105℃ (Including self-temperature rise) Operating Temperature -55~+105℃ (on board) Transportation Storage Temperature --For long storage conditions, please see the Application Notice Agilent4291 Inductance (Ls) Agilent E4991 Agilent4287 Q Factor Refer to standard electrical characteristics list Agilent16192 DC Resistance Agilent 4338 Rated Current DC Power Supply Over Rated Current requirements, there will be some risk Temperature Rise Test 1. Applied the allowed DC current. 2. Temperature measured by digital surface thermometer. Rated Current < 1A ∆T 20℃Max Rated Current ≧ 1A ∆T 40℃Max Life test Appearance: no damage. Impedance: within±15%of initial value. Inductance: within±10%of initial value. Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Load Humidity Appearance: no damage. Thermal shock Impedance: within±15%of initial value. Inductance: within±10%of initial value. Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Temperature: 105±2℃ Applied current: rated current. Duration: 1000±12hrs. Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Humidity: 85±2%R.H. Temperature: 85±2℃. Duration:1000hrsMin.Bead:with100%ratedcurr ent , Inductance: with 10% rated current Measured at room temperature after placing for 24±2 hrs.. Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Condition for 1 cycle Step1: -55±2℃ 30±5 min. Step2: 25±2℃ ≦0.5min Step3: +105±2℃ 30±5min. Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs. Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Oscillation Frequency: 10Hz ~ 2KHz ~ 10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Bending Appearance:No damage. Impedance:within±10% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Shall be mounted on a FR4 substrate of the following dimensions: >=0805inch(2012mm):40x100x1.2mm =0805inch(2012mm):1.2mm 1GΩ a.Method B, 4 hrs @155°C dry heat @235°C±5°C Test time:5 +0/-0.5 seconds. Solderability More than 95% of the terminal electrode should be covered with solder. www.tai-tech.com.tw b. Method D category 3. (steam aging 8hours ± 15 min)@ 260°C±5°C Test time: 30 +0/-0.5 seconds. TAI-TECH KBM01-200700472 Item Performance P4. Test Condition Number of heat cycles: 1 Resistance to Soldering Heat Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Temperature (°C) Time (s) Temperature ramp/immersion and emersion rate 260 ±5 (solder temp) 10 ±1 25mm/s ±6 mm/s Depth: completely cover the termination Terminal strength Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Component mounted on a PCB apply a force >0805inch(2012mm):1kg
FCI3216F-4R7K 价格&库存
很抱歉,暂时无法提供与“FCI3216F-4R7K”相匹配的价格&库存,您可以联系我们找货
