DIO3712LP10
DIO3712LP10
    DIOO(帝奥)
    DQFN10
    DIO3712LP10
DIO3712LP10 数据手册
Rev 1.2 DIO3712 High-bandwidth and Low on-resistance Analog switch Features Descriptions  Over-Voltage Tolerance (OVT) DIO3712  Voltage Operation: 1.8V to 5.5V single-pole/double-throw (SPDT) CMOS analog  Low On Resistance: 4.5Ω typ at 4.5Vcc switch, which is designed to operate from a  High Off-Isolation single  Low Crosstalk high-bandwidth (300MHz) and low on-resistance,  Low leakage current targeted applications for full speed USB and  Low power consumption audio switching.  Wide -3dB Bandwidth: >300MHz DIO3712 features power ON/OFF protection  Low Distortion effectively protecting device against external  Packaged: DQFN-10, MSOP-10 signal perturbation. It also offers excellent -3db  8kV HBM; 1.5kV CDM ESD Rating bandwidth and lower ON resistance, which can be is 1.8V used as a to 5.5V analog dual, bidirectional, supply. switch It in features multiple applications. Applications It operates under wide Vcc supply from 1.8V to  Cell Phones 5.5V, consuming very low quiescent current even  PDAs and MP3s when the voltage of S pin is lower than VCC  Portable Instrumentation supply. This new feature services the mobile  Battery Powered Communications handset applications very well allowing for the  Computer Peripherals direct interface with baseband processor general purpose I/Os with no need of level translator. Block Diagram NC1 COM1 NO1 NC2 COM2 NO2 IN 1 IN 2 C ontrol Ordering Information Order Part Top Marking Green TA DIO3712LP10 YWGM Yes -40 to 85℃ DQFN-10 Tape & Reel, 3000 DIO3712MP10 DIO3712 Yes -40 to 85℃ MSOP-10 Tape & Reel, 3000 Number www.dioo.com Package © 2018 DIOO MICROCIRCUITS CO., LTD DIO3712• Rev. 1.2 DIO3712 DQFN-10 MSOP-10 Figure 1 Top View Pin Descriptions Pin Name Description Vcc Power Supply GND Ground COM1, COM2 Common Port NO1, NO2 Data Port NC1,NC2 Data Port IN1, IN2 Control Port Truth Table www.dioo.com IN Function 1 COM Connected to NO 0 COM Connected to NC © 2018 DIOO MICROCIRCUITS CO., LTD DIO3712• Rev. 1.2 High-bandwidth and Low on-resistance Analog switch Pin Assignment DIO3712 Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability Symbol Parameter Min. Max. Unit VCC Supply Voltage -0.3 6 V Vs DC Switch Voltage -0.3 VCC+0.3 V VIN DC Input Voltage -0.3 VCC+0.3 V Isw Switch Current ±50 mA Peak Switch Current (Pulse at 1ms duration,
DIO3712LP10 价格&库存
很抱歉,暂时无法提供与“DIO3712LP10”相匹配的价格&库存,您可以联系我们找货
