7X-30.000MBC-T
7X-30.000MBC-T
    TXC(台晶)
    SMD4
    7X-30.000MBC-T
7X-30.000MBC-T 数据手册
7X MHz CMOS Oscillator Features Applications Frequency range : 1MHz to 133MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 3.2 x W : 2.5 x H : 1.0 RoHS compliant & Pb free Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, xDSL, xPON PC mainboard, Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, Printer, DSC, IP CAM, Consumer products Electrical Characteristics Item Frequency Range (F0) Frequency Stability (Fstab) Operating Temperature Range (T OTR) Supply Voltage (VDD) Current Consumption (IDD) 7X 1MHz ~ 133MHz ±50 , ±25 ppm -10°C ~ +70°C; Note [1] ±50 , ±25 , ±20 ppm -40°C ~ +85°C; Note [1] -10°C ~ +70°C -40°C ~ +85°C 1.8V, 2.5V, 3.3V 1MHz ~ 75MHz 15 mA Max. 75MHz ~ 133MHz CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Phase Jitter, RMS Aging (Faging) Storage Temperature Range (T STR) VDD ± 10% 10 mA Max. Output Type Duty Cycle Start-up Time Enable Voltage High, Logic "1" Enable Voltage Low, Logic "0" Conditions 45% ~ 55% 5 ms Max. 70% VDD Min. 30% VDD Max. 1 ps Max. ±3 ppm Max. 10% ~ 90% of VDD Input to Pin1 Note [2] Note [3] at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.04-a Page 1 www.txccrystal.com 7X MHz CMOS Oscillator Dimensions (Unit: mm) Ordering Information 7X 30.000M B B - T - Frequency in Hz Packaging Method T Please contact us for available frequencies Frequency Stability Supply Voltage B C D Rev. 1.04-a Tape & Reel 3.3 V 2.5 V 1.8 V B C F Page 2 ± 50 ppm (-10˚C ~ +70˚C) ± 100 ppm (-10˚C ~ +70˚C) ± 100 ppm (-40˚C ~ +85˚C) www.txccrystal.com 7X MHz CMOS Oscillator Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04-a 60 sec Page 3 Time (sec) www.txccrystal.com
7X-30.000MBC-T 价格&库存
很抱歉,暂时无法提供与“7X-30.000MBC-T”相匹配的价格&库存,您可以联系我们找货
