ISO9001: 2015
ISO14001: 2015
APPROVAL SPECIFICATIONS
Title. SELF LOCK
Product Model.
SWITCH
PB21E09471-32
Customer’s Part NO.
Customer’s Model:
Customer’s Approval Requested.
Please return this copy as a certification of your approval.
Checked by:
Date:
Approved by:
Date:
温州港源电子有限公司
Wenzhou Gangyuan Electronics Co.,Ltd
Address:No.2 Yonghe Yi Road,Chengdong
Street,Yueqing City,Zhejiang Province,China.
Tel:0577-06571538
Fax:0577-62573066
Website:http://www.gangyuan.com
APPROVE
REVIEW
PREPARE
黄自兵
林庆杰
薛 益
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
Document No.
Page
2/11
变更履历表:
版本
A/01
变更记录
版本更新
version updated
变更人
变 更 日 期
薛 益
Xue Yi
2019.8.16
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
Document No.
Page
3/11
1、 概述 GENERAL
1.1 适用范围 APPLICATION
此规格书适用于机械式自无锁类开关的相关要求
This specification is applied to the requirements for SELF LOCK switch (mechanical contact)
1.2 工作温度范围 Operating Temperature Range
-30℃~80℃(在标准大气压、标准湿度条件下)
-30℃~80℃(Normal humidity, normal air pressure)
1.3 贮藏温度范围 Storage Temperature Range
-30℃~85℃(在标准大气压、标准湿度条件下)
-30℃~85℃(Normal humidity, normal air pressure)
1.4 测试条件 Test Conditions
在没有其它特定的条件下,应该在以下的条件下进行测试和测量:
Unless otherwise specified, tests and measurement shall be made in the following standard conditions:
常温…………………………………5℃~35℃
Normal temperature………………5℃~35℃
标准湿度……………………………相对湿度 25%~85%
Normal humidity…………………relative humidity 25%~85%
标准大气压…………………………86Kpa~106Kpa
Normal air pressure…………………86Kpa~106Kpa
在制造过程中,测试和测量应该在以下的条件下进行:
If any doubt arise from the judgment, tests shall be conducted at the following conditions:
温度…………………………………20℃±2℃
Temperature………………………20℃±2℃
相对湿度……………………………65%±5%
Relative humidity…………….......…65%±5%
环境气压…………………………86Kpa~106Kpa
Air pressure…………………………86Kpa~106Kpa
1.5 存储方法 Storage method
1.使用前确保包装完整无破损,无浸湿.
Ensure that the product without package breaking or wetting before use.
2.存储条件 Storage conditions:
储存温度 Storage temperature:-5 ~ 35 ℃;
储存湿度 Storage humidity:25% ~80%;
未开封状态:6 个月内使用完毕(从发货日开始计算); 超过 6 个月后再使用的,使用前请先验证:端脚无氧
化、无发黑、塑料件无吸湿起泡,确保焊接的适宜性;
Unopened status: Use up the product as soon as possible before 6 months. (calculated from shipment
date).Over 6 months, please make sure below ;
before use it: terminal without oxidation or blackening, plastic parts without moisture absorption or
bubble, ensure solderability.
已开封状态:1 个月内使用完毕;
Opened status: use up within 1 month;
储存注意事项:避开高湿高温和有腐蚀性气体的环境及阳光直射;
Storage precautions: Please avoid the following environment: with high humidity, high temperature ,
corrosive gases and direct sunlight.
3.请勿超重叠放.
Do not stack too many switches.
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
2、
Document No.
Page
4/11
详细说明
Detailed specification
2.1
外观:应无影响、降低产品性能的缺陷;
Appearance: There should be no defects that affect the serviceability of product.
2.2
结构尺寸和安装尺寸:应符合装配图要求;
Style and dimension: shall conform to the assemble drawings.
2.3
操作形式:有触觉反应的操作
Type of actuating: Tactile feedback.
2.4
开关结构:单回路单输出(具体的触点结构在装配图中已绘出);
Contact arrangement: 2 pole, 2 throw
(Details of contact arrangement are given in the assembly drawings.)
2.5
额定值:DC 30V
Ratings:
0.1A
DC 30V 0.1A
3.电气性能:
ELECTRICAL SPECIFICATION
项
目
试 验 条 件
ITEM
TEST CONDITIONS
要求
REQUIREMENTS
在以 5V 10mA 的直流电源或不低于 1KHz 的交流电
源的电路中,以一个等于 1.5 倍按力的静负荷施加于手柄
中心
3.1
接触电阻
Contact Resistance
Applying a static load of 1.5 times operating force to the
center of the stem, measurements shall be made by 5V DC
≤100mΩ
10mA or more than 1KHz AC small-current contact resistance
3.2
绝缘电阻
Insulation Resistance
耐 压
3.3
Dielectric
voltage proof
meter.
输入 100V DC 电压 1 分钟,按以下接触方法测试:
Apply a voltage of 100V DC shall be applied for 1 min.
After which measurement be made:
(1) 不接触的端子脚之间
Between conductors not to be contact
(2)端子脚与盖板之间
Between individual terminals and frame
输入 AC 250V (50-60HZ)电压,1 分钟,感应电流为 0.5mA,
按以下接触方法测试:
AC 250V rms(50-60Hz)For 1 MIN ,trip current:0.5mA
(1)不接触的端子脚之间
(2)端子脚与盖板之间
≥100MΩ
无击穿、无飞弧
There should be no
breakdown and
flashover
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
Document No.
Page
5/11
4.机械性能:
MECHANICAL SPECIFICATION
4.1
4.2
4.3
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
REQUIREMENTS
按力
Operating
Force
开关垂直于操作方向放置,在开关驱动件顶端中心逐渐施力,测
量开关导通所需的最大力度。
Placing the switch such that the direction of switch operation is
vertical and then gradually increasing the load applied to the center of
the stem, the maximum load required for the switch to come to a stop
shall be measured.
250±80 gf
总行程
Full Travel
开关垂直于操作方向放置,以一个等于 2 倍按力的静负荷施加在
开关驱动件顶端中心,测量顶端移动的最大距离。
vertical and then applying static load of 2times operating force to the
center of the stem; the travel distance for the switch to come to a stop
shall be measured.
2.5±0.2mm
操作部位强度
Operating
part
strength
在操作部位施加以下负载,时间 15 s。
Apply following load on the tip of of operating part 15 s.
□ 操作方向 Operation direction ... 80N
□ 引伸方向 Drawing direction ... 20N
□ 操作方向直方向 Right direction against operating direction ...
10N
柄部无严重变形,可以正常
工作.
The lever shall have no
serious deformation and
function is normally.
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
4.4
4.5
4.6
Document No.
Page
6/11
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
REQUIREMENTS
在端子脚前端任意一个方向加 5N 力度测试,时间为 10 秒
A static load of 500gf shall be applied to the Terminal
for 15 Sec.in any direction.
端子脚没有裂开、松动异
常,满足于机械,电气性能
Electrical
characteristics shall be
satisfied without damage
or excessive looseness of
terminals
端子强度
Terminal
Strength
锁紧强度
Locking
Strength
振动
Vibration
在锁紧状态下对引伸方向施加 5N 的力 10 秒(本标准适用于开关锁
开关锁定功能正常。
紧机构)
No abnormalities shall occur
Apply force 5N to drawing direction for 10s at locking condition of
in appearance and function.
switch.(This standard applies to switch lock mechanism.)
根据以下给定条件进行测试:
Measurement shall be made following the test set forth below:
(1) 振动频率范围:10~55~10Hz
Vibration frequency range: 10 to 55 to 10Hz
(2) 振幅(峰-峰):1.5mm
Amplitude: 1.5mm
(3) 振动方向:包括手柄行程方向在内的三个相互垂直的方向
Direction of vibration:Three mutually perpendicular
direction including the direction of stem travel
(4) 测试时间:每次 2 小时
Item 3
Item4.1
Item4.2
Item4.3
Duration: Each 2 hours.
4.7
冲击
Shock
根据下列条件进行冲击试验
Test by following conditions
(1)安装方法:正常安装
(1)installation method: normal
(2)加速度:784m/s²
(2)Acceleration: 784m/s²
(3)作用时间:11ms
(3)Acting time: 11ms
(4)测试方向:6 个方向
冲击次数:每个方向 3 次,共计 18 次
(4)Test direction: 6 directions
Times: 3 times/direction ,total 18 times
Item3
Item4.1
Item4.2
Item4.3
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
Document No.
Page
7/11
5、环境耐久性:
ENVIRONMENTAL SPECIFICATION
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
样品应按照以下实验条件进行测试,实验后样品应放在常温及
标准湿度的环境中 1 小时后做性能测试:
Following the test set forth below the sample shall be left in normal
temperature and humidity conditions for 1 h before measurements
are made:
(1) 温度:-30±2℃
Temperature : -30±2℃
(2) 时间:96h
Time: 96h
are made:
(1) 温度:80±2℃
temperature:80±2℃
(2) 时间:96h
time: 96h
根据下面的测试要求进行 5 次循环的温度周期性测试, 实验后
样品应放在常温及标准湿度的环境中 1 小时后做性能测试。测
试期间样品应保持干燥.
After 5 cycles of following conditions, the sample shall be allowed
to stand under normal temperature and humidity conditions for 1 h.
and measurements shall be made. During the test water drops shall
be removed. 温度(°C )
1个循环
A:+80±2℃
A: +90±2°
C
A
B:-30±2℃
B: -40±2°
C
C: 2小时
C:2 小时
D: 1小时
0°
C
D:1 小时
E: 2小时
B
F: 1小时
E:2 小时
F:1 小时
时间(hour)
REQUIREMENTS
5.1
低温测试
Resistance to low
temperature
5.2
高温测试
Heat resistance
5.3
温度变化测试
Change of
temperature
C
5.4
恒定湿热测试
Moisture
resistance
D
E
Item3
Item4.1
Item4.2
Item4.3
Item3
Item4.1
Item4.2
Item4.3
Item3
Item4.1
Item4.2
Item4.3
F
are made:
(1) 温度:60±2℃
temperature: 60±2℃
(2) 相对湿度:90%~95%
relative humidity:90% to 95%
(3) 时间:96h
time: 96h
接触电阻:≤200mΩ
Contact resistance≤200mΩ
绝缘电阻:≥10MΩ
Insulation
Resistance≥10MΩ
Item3.3
Item4.1
Item4.2
Item4.3
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
5.5
5.6
5.7
5.8
Document No.
Page
8/11
项目
试 验 条 件
要求
ITEM
TEST CONDITIONS
REQUIREMENTS
盐雾试验
Salt Mist
在以下设定条件下进行测量:
The switch shall be checked after following test:
(1)温度:35℃±2℃
temperature: 35℃±2℃
(2)盐溶液浓度:5±1%(质量百分比)
salt solution : 5±1%(solids by mass)
(3)时间:8±1h
Time: 8±1h
实验后的盐沉积物后水冲掉
After test, salt deposit shall be removed by running water.
金属件上没有腐蚀斑点
No remarkable corrosion
shall be recognized in metal
part.
电气寿命
Operation life
根据下面的测试要求进行测试:
(1) DC 5V,0.5A 带负载
DC 5V, 0.5A resistive load
(2) 按动速率:10~15 次/分钟
Rate of operation: 10~15 times/min
(3) 按力:按力的 1.5 倍
Operating Force:1.5 times as much as Operating Force
(4) 无故障寿命:5,000 次
fault-free life:5,000cycles
可焊性
Solderability
在以下设定条件下进行测量:
Measurements shall be made following the test set forth below:
(1) 焊接温度:245±5℃
Solder temperature : 245±5℃
(2) 浸入时间:5s±0.5s
Immersion time: 5s±0.5s
除边缘外涂层应均匀覆盖
90%以上
Except for the edge, the
coating should cover a
minimum 90%
在以下设定条件下进行测量:
(1)焊接温度:260±5℃
Solder temperature : 260±5℃
(2)浸入时间:3s±1s
Immersion time: 3s±1s
本体无变形,能满足于机
械、电气性能。
Without deformation of case
terminal selectrical
satisfied
耐焊性试验
Resistance to
soldering heat test
接触电阻≤2Ω
Contact resistance≤2Ω
绝缘电阻≥10MΩ
Insulation
Resistance≥10MΩ
Item3.3
Item4.1
Item4.2
Item4.3
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
Document No.
Page
9/11
6.焊接条件:
SOLDERING CONDITIONS:
6.1
项目
推 荐 条 件
ITEM
Recommended conditions
手工焊接
Hand soldering
请按以下条件进行焊接:
(1) 焊锡温度:≤350℃
(2) 连续焊接时间:≤3 s
Please practice according to below conditions:
(1) Soldering temperature: ≤350℃
(2) Continuous soldering time: ≤3 s
助焊剂附着量
Flux built-up
预热温度
自动浸焊
6.2
Conditions for
Auto-dip
Preheating temperature
不附着于零部件贴装面的程度
Mounting surface should not be coated with flux
印刷电路板焊接面的周围温度 100℃ max.
Ambient temperature of the soldered surface of
PC board. 100℃ max.
预热温度时间
60s max.
Preheating time
焊接温度
260℃ max.
焊接浸渍时间
5s max.
Continuous dipping time
焊接次数
Number of soldering
最多两次
2 times max.
注意事项(Notes):
a、防止助焊剂从开关的顶端渗入
Prevent flux penetration from the top of the switch
b、开关浸焊后,注意不要用溶剂或类似品清洗开关。
After switches were soldered,please be careful not to clean switches with solvent or other similar products.
c、浸焊后,注意不要在顶部施加负荷。
Right after switches were soldered;please be careful not to load to on the knobs of switches.
d、注意不要施加超负荷的压力或晃动开关。
Please be cautions not to give excessive static load or shock to switches.
e、开关浸焊后,印刷基板注意不要叠放。
Please be careful not to pile up P.W.B.after switches were soldered
GANGYUAN
Product name
P/N
Version
Self Lock switch
PB21E09471-32
A/01
Document No.
Page
10/11
常态:2与3,5与6导通
按下:1与2,4与5导通
1
2
3
4
5
6
电路图
印制线路板
General tolerance:±0.2mm
NO.
NAME
MATERITAL
QTY.
PLATING
1
BASE
PBT
1
Black
2
TERMINAL
BRASS
2
Ag plating
3
SPRING
CARBON WIRE
1
4
CONTACT
SILVER COPPER
2
Ag plating
5
STEM
POM
1
Blue
6
COVER
PBT
1
Dark Grey
GANGYUAN
Product name
Self Lock switch
P/N
Version
PB21E09471-32
A/01
Document No.
11/11
7、包装规格:
7.1:每个包装袋装 1000 只,封口要紧密
A=190mm、B=195mm
7.2:每个内盒装 1 袋,共 1000 只
包装袋
C=216mm、D=165mm、E=61mm
内 盒
7.3:每个外箱装 16 盒,共 16000 只
X=350mm、Y=455mm、Z=280mm
外箱
Page
很抱歉,暂时无法提供与“PB21E09471-32”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.64336
- 50+0.50858
- 150+0.44118
