Surface Mount Fuses
File No.: JS-S1206-F-00
Revision: F
Page: 1/ 6
1206 Size >Fast Acting>S1206-F Series
General
• Fast acting
• 3.10mm× 1.55mm physical size
• Thick film manufacturing method, ceramic
substrate, silver fusing element
• -55℃~125℃ operating temperature
• Excellent environmental integrity
• RoHS compliant
• Halogen-free
• Lead free
Agency / Certificate Information
Application
Agency
• Battery pack
• PC related equipment and peripherals
(Hard driver, Printer, etc.)
• Digital camera (Digital still camera)
• Game equipment
• LCD monitor, LCD modules
• Wireless base station
• Power supply
• Medical device
File Number
Ampere Range
E319512
0.5A~7A
Electrical Specifications
Typical Cold
DCR* (mΩ)
Typical I2T**
(A2s)
32
1200
0.0075
0.75
32
540
0.0169
H
1.0
32
240
0.0279
S1206-F-1.5A
K
1. 5
32
115
0.0491
S1206-F-2.0A
N
2.0
32
64
0.1251
S1206-F-2.5A
O
2.5
32
33
0.1255
S1206-F-3.0A
P
3.0
32
27
0.2880
S1206-F-3.15A
Z
3.15
32
26
0.2977
S1206-F-3.5A
R
3.5
32
20.5
0.5366
S1206-F-4.0A
S
4.0
32
15.5
0.8928
S1206-F-5.0A
T
5.0
32
12.5
0.9325
S1206-F-6.0A
6
6.0
32
11.0
1.5192
S1206-F-7.0A
U
7.0
32
7.2
2.2050
Part Number
Marking
Current
Rating (A)
Voltage
Rating (V)
S1206-F-0.5A
F
0.5
S1206-F-0.75A
G
S1206-F-1.0A
Interrupting
Rating (V)
50A
32V DC
35A
32V DC
Measured at≤10% rated current and 25℃
at 10 times of rated current
** Melting I2T
Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary)
ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China
TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com
Surface Mount Fuses
Revision: F
Page: 2/ 6
Catalo
Part Number Information
S
1206—F—1.0A
“1.0A” Ampere Rating: 1A
“ F” Electrical Characteristic: F = Fast acting
“1206” Size Number
“ S” Symbol of SART
Shape
& Dimensions: (mm)
Dimensions
Type
L
(mm)
W
(mm)
T
(mm)
B
(mm)
S1206-F
3.10±0.20
1.55±0.20
0.55±0.20
0.50±0.20
Recommended Land Patterns
D
Materials
A
C
Components
Material
Body
Ceramic
Terminations
Silver over plated
with tin (100%)
Element
Silver or Silver/Palladium
B
Dimensions
A(mm)
B(mm)
C(mm)
D(mm)
Spec
2.00±0.30
4.40±0.50
2.40±0.30
1.20±0.30
Dimensions of Standard Test Board
Type
Ampere Rating
Board Thickness
(mm)
Copper Layer Thickness
(mm)
Copper Trace Width
(mm)
0.5A~6.0A
1.6
0.035
5.0
7.0A
1.6
0.070
7.5
S1206-F
Surface Mount Fuses
Revision: F
Page: 3/ 6
I2T VS Time Curve
1.5A
2.0A
2.5A
3.0A
3.15A
3.5A
4.0A
5.0A
6.0A
7.0A
1.0A
0.5A
100
0.75A
Time Current
Current Curve
Time
Curve:
100000
7.0A
6.0A
5.0A
4.0A
3.5A
3.15A
3.0A
2.5A
2.0A
1.5A
10000
10
1.0A
0.75A
1
100
0.5A
2
I T (A S)
Time (s)
1000
10
2
0.1
1
0.01
0.1
1E-3
1
10
Current (A)
100
0.01
1E-3
0.01
0.1
1
10
Time(s)
Electrical Characteristics
Type
S1206-F
Ampere Rating
% of Current Rating
Opening Time
0.5A~7.0A
100
>4hours
0.5A~0.75A
250
≤20sec
1.0A~7.0A
250
≤5sec
0.5A~7.0A
1000
>0.1ms
Temperature Derating Curve
100
Surface Mount Fuses
Revision: F
Page: 4/ 6
Product Characteristics
Item
Test condition/ Methods
Performance
Standard
100% of current rating
No Fusing, 4hours Min.
UL248-14
250% of current rating
0.5A~0.75A:≤20sec
1.0A~7.0A:≤5sec
SART SPEC.
1000% of current rating
>0.1ms
IEC60127-4
Voltage Drop
Deviation between the mean
value: <15%
IEC60127-4
Temperature Rise
△T<75℃
IEC60127-4
Endurance Test
100 cycles of 1In for 1h “ON”, for 15min
“OFF”, then following by 1h at 125%In
|△R|:<10%
IEC60127-4
Interrupting Ability
0.5A~3.5A: 50A 32V DC
4.0A~7.0A: 35A 32V DC
without permanent arcing,
ignition and bursting of fuse link
UL248-14
IEC60127-4
Time/Current
Solderability
240℃±5℃, 3sec±0.5sec
95% coverage Min.
IEC60127-4
MIL-STD-202
Method 208
Resistance to
Soldering
260℃±5℃, 10sec±0.5sec
|△R|:<10%
Legible appearance
MIL-STD-202
Method 210
Bending Test
Distance between holding points: 90mm
Bending: 1mm, time: 10sec
|△R|:<10%
No mechanical damages
IEC60127-4
High Temperature
Operating Life
T=70℃±2℃, 60%In, 96hours
|△R|: <10%; No fusing
MIL-STD-202
Method 108
Humidity
(Steady State)
T=40℃±2℃, 90%~95%RH,
1000hours
|△R|: <10%
MIL-STD-202
Method 103
Low Temperature
Storage
T=-55℃±3℃,96hours
|△R|: <10%
IEC60068-2-1
High Temperature
Storage
T=125℃±2℃,96hours
|△R|: <10%
IEC60068-2-2
Salt Spray
5% salt solution,48hours
|△R|: <10%
Legible appearance
MIL-STD-202
Method 101
Thermal Shock
100 cycles between -65℃/+125℃
60 minutes, each extreme
|△R|: <10%R
MIL-STD-202
Method 107
Surface Mount Fuses
Revision: F
Page: 5/ 6
Recommended Solder Curve
1. Infrared Reflow:
• Temperature: 260℃
• Time: 5sec Max.
• Recommend Reflow profile
Profile Feature
Average Ramp-up
Rate(Tsmax to Tp)
Preheat
Temperature Min.(Tsmin)
Temperature Max.(Tsmax)
Time(Tsmin to Tsmax)
Peak Temperature(Tp)
Time within 5℃ of actual
2. Wave soldering
• Reservoir Temperature: 260℃
• Time in Reservoir: 10secMax.
Pb-Free Assembly
3℃/sec Max.
150℃
200℃
60sec~120sec
260℃
5sec
Melting tin time(TL)
20sec~30sec
Ramp-down Rate
6℃/sec Max.
Time 25℃ to peak
Temperature
8minutes Max.
3.Hand Soldering
• Temperature: 350℃
• Time: 5secMax.
Packaging
• 5000 pieces of fuses in emboss taper and reeled on a 178mm(7 inch) reel.
Type
A(mm)
B(mm)
W(mm)
E(mm)
F(mm)
Spec
3.50±0.20
1.90±0.20
8.00±0.20
1.75±0.10
3.50±0.05
Type
P(mm)
P0(mm)
P1(mm)
D0(mm)
T(mm)
Spec
4.00±0.10
4.00±0.10
2.00±0.10
1.50±0.10
0.75±0.10
Surface Mount Fuses
Revision: F
Page: 6/ 6
Type
M(mm)
W(mm)
T(mm)
A(mm)
B(mm)
C(mm)
D(mm)
Spec
178.00±2.00
9.50±1.00
12.50±1.50
2.00±0.50
13.00±0.50
21.00±0.50
58.00±2.00
Storage
Storage:
• The ambient temperature recommended for storage shall be between 5℃~30℃
• The relative humidity recommended for storage shall be between 25%RH~60%RH
• Sealed plastic bags with desiccant shall be used to reduce the oxidation of the termination and shall only be
opened prior to use
• The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present
很抱歉,暂时无法提供与“S1206-F-1.0A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48924
- 100+0.39280
- 300+0.34463
- 1000+0.30845
- 5000+0.25953
- 10000+0.24506
