SDCW2012H-2-121TF
SDCW2012H-2-121TF
    SUNLORD(顺络)
    共模电感 0805
SDCW2012H-2-121TF 数据手册
Wire Wound Chip Common Mode Choke Coil – SDCW-H Series Operating Temp. : -40℃~+85℃ FEATURES ● ● ● Winding type realizes small size and low profile Suppress noise for the high-speed differential signal lines Excellent solder ability APPLICATIONS ● High speed differential signal lines for HDMI, DVI, etc PRODUCT IDENTIFICATION SDCW 2012 H ① ② ③ ② ① SDCW Type Winding Type Common Mode Choke Coil -900 ④ ⑤ Impedance Nominal Value 90Ω T F ⑥ ⑦ ③ External Dimensions (L×W) (mm) 1210 [0504] 1.2×1.0 2012 [0805] 2.0×1.2 H ④ Number of Lines 2 ⑤ Example 900 -2 ⑦ ⑥ Hazardous Substance Free Products Packing T Code For High-speed Differential Signal Lines Tape & Reel F SHAPE AND DIMENSIONS SDCW1210H TYPE Recommended Land Pattern Unit: mm Recommended Land Pattern Unit: mm SDCW2012H TYPE Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SDCW1210H TYPE Part Number Units Symbol SDCW1210H-2-350TF SDCW1210H-2-900TF Common Mode Impedance @100MHz Ω Z 35±25% 90±25% Max. DC Resistance Ω DCR 0.32 0.50 Max. Rated Current mA Ir 320 280 Common Mode Impedance @100MHz Ω Z 67±25% 90±25% 120±25% Max. DC Resistance Ω DCR 0.30 0.40 0.40 Max. Rated Current mA Ir 320 280 280 Min. Insulation Resistance MΩ IR 10 10 Rated Voltage Volts V DC 20 20 SDCW2012H TYPE Part Number Units Symbol SDCW2012H-2-670TF SDCW2012H-2-900TF SDCW2012H-2-121TF Min. Insulation Resistance MΩ IR 10 10 10 Rated Voltage Volts V DC 20 20 20 ※: Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales. EQUIVALENT CIRCUIT TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs. Frequency SDCW1210H TYPE SDCW2012H TYPE Common Mode SDCW2012H-2-121TF SDCW2012H-2-900TF SDCW2012H-2-670TF SDCW2012H-2-121TF SDCW2012H-2-900TF SDCW2012H-2-670TF Differential Mode Frequency(MHz) Sunlord Frequency(MHz) Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com TYPICAL ELECTRICAL CHARACTERISTICS Insertion Loss SDCW1210H TYPE SDCW2012H TYPE SDCW2012H-2-670TF SDCW2012H-2-900TF SDCW2012H-2-121TF SDCW2012-2-900TF Frequency(MHz) Frequency(MHz) Differential Mode Impedance Characteristics SDCW2012H-2-900TF Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/05/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SDCW2012H-2-121TF 价格&库存
很抱歉,暂时无法提供与“SDCW2012H-2-121TF”相匹配的价格&库存,您可以联系我们找货
SDCW2012H-2-121TF
    • 10+0.61855
    • 100+0.50579
    • 400+0.40709
    • 800+0.40098
    • 2000+0.35284
    库存:1010
    SDCW2012H-2-121TF
    • 1+0.61600
    • 50+0.41140
    • 2000+0.37180
    库存:3202
