TMI3113
TMI3113B
1.0MHz, Peak 3A Synchronous Step-Down Converter
FEATURES
GENERAL DESCRIPTION
The TMI3113 and TMI3113B are 1.0MHz constant
frequency, current mode step-down converter. It is
ideal for portable equipment requiring high current
up to peak 3A from single-cell Lithium-ion batteries.
They also can run at 100% duty cycle for low
dropout operation, extending battery life in
portable systems while light load operation
provides very low output ripple for noise sensitive
applications. The high switching frequency of
TMI3113/TMI3113B could minimize the size of
external components while keeping switching
losses low. The internal slope compensation setting
allows the device to operate with smaller inductor
values to optimize size and provide efficient
operation. TMI3113 has power good function and it
is offered in 6 pin, SOT23-6 package. The TMI3113B
is offered in 5-pin, SOT23-5 package with adjustable
output voltage without PG pin.
These devices offer two operation modes, PWM
control and PFM Mode switching control, which
allow a high efficiency over the wider range of the
load.
High Efficiency: Up to 95%
1.0MHz Constant Frequency Operation
Peak 3A Output Current with VOUT=1.2V
No Schottky Diode Required
2.7V to 5.5V Input Voltage Range
Output Voltage as Low as 0.6V
PFM Mode for High Efficiency in Light Load
100% Duty Cycle in Dropout Operation
Low Quiescent Current: 50μA
Short Circuit Protection
Thermal Fault Protection
Power Good Output Function (TMI3113 only)
Inrush Current Limit and Soft Start
Input overvoltage protection (OVP)
很抱歉,暂时无法提供与“TMI3113B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.62400
- 100+0.43154
- 600+0.38343
- 1200+0.34492
- 国内价格
- 3+0.68073
- 30+0.54076
- 90+0.47078
- 300+0.41829
- 1500+0.37628
- 3000+0.35532
- 国内价格
- 1+0.49280
- 3000+0.43590
