THT-7-7546-3
THT-7-7546-3
    BRADY
    THT-7-7546-3
THT-7-7546-3 数据手册
Technical Data Sheet BRADY B­-7546 THERMAL TRANSFER PRINTABLE TAMPER EVIDENT GLOSSY WHITE POLYESTER TDS No. B­-7546 Effective Date: 10/05/2022 Description: GENERAL Print Technology: Thermal Transfer Material Type: Polyester Finish: Gloss Adhesive: Permanent acrylic APPLICATIONS B-­7546 is designed for applications such as rating and serial plates that require both high performance and protection against removal. RECOMMENDED RIBBONS Brady Series R6000 Halogen Free Brady Series R4900 Brady Series R7962 REGULATORY APPROVALS CSA: B­-422 is CSA Accepted to C22.2 No.0.15-­95 Adhesive Labels Standard when printed with the Brady Series R6000 ribbon. See CSA file 041833 for specific details. CSA information can be accessed online at https://www.csagroup.org/testing-certification/product-listing/ For information on the Weee-RoHS compliance status for a Brady Product go to one of the following websites: In Canada: www.bradycanada.ca/weee-rohs In Europe: www.bradyeurope.com/rohs In Japan: www.brady.co.jp/products/labelsuse/rohs All other regions: www.bradyid.com/weee-rohs SPECIAL FEATURES The material leaves a VOID footprint if removed. Recommended 24 hour room temperature dwell before removal for full tamper evident performance. The material gives an extremely high resolution printing when using the Brady Series R­7962 and R4900 ribbons. Details: Labels printed with the Brady Series R­7962 and R4900 ribbons PHYSICAL PROPERTIES Thickness TEST METHODS ASTM D 1000 - Substrate - Adhesive - Total (excluding liner) AVERAGE RESULTS 0.050 mm (0.0020 inch) 0.030 mm (0.0012 inch) 0.080 mm (0.0032 inch) Adhesion to: ASTM D 1000 - Stainless Steel 24 hour dwell 59 N/100 mm (54 oz/inch) - Smooth ABS 24 hour dwell 51 N/100 mm (47 oz/inch) - Polyethylene 24 hour dwell 33 N/100 mm (31 oz/inch) Performance properties tested on B­-7546 printed with the Brady Series R­4900, R6000 Halogen Free and R­7962 thermal transfer ribbons. Printed samples of B-­7546 were laminated to aluminum before exposure to the indicated environmental condition. PERFORMANCE PROPERTIES High Service Temperature Low Service Temperature Humidity Resistance UV Light Resistance Weatherability Abrasion Resistance TEST METHOD 30 days at 100°C (212°F) 30 days at ­-20°C (68°F) 30 days at 38°C (100°F) and 95% R.H. 30 days in UV light chamber 30 days in Q.U.V. (ASTM G 53) Method 5306 US Fed. Test 191A 100 Cycles TYPICAL RESULTS No visible effect No visible effect No visible effect No visible effect No visible effect R-­7962 (CS 10, 250g/arm) No visible effect R­-4900 (CS 10, 250g/arm) Text faded but still legible R­-6000HF (CS 10, 250g/arm) Text faded but still legible The tamper evident VOID pattern of B-­7546 was retained after exposure to all of the listed conditions. PERFORMANCE PROPERTIES CHEMICAL RESISTANCE Samples printed with the Brady Series R­7962, R­4900 and R6000 Halogen Free thermal transfer ribbons. Samples laminated to aluminum panels and allowed to dwell 24 hours prior to testing. Test conducted at room temperature. Testing consisted of 5 cycles of 10 minute immersions in the specified test fluid followed by a 30 minute recovery period. After final immersion, samples rubbed 10 times with cotton swab saturated with test fluid. CHEMICAL REAGENT Water Isopropanol EFFECT TO LABEL STOCK N.V.E. N.V.E. SUBJECTIVE OBSERVATION OF VISUAL CHANGE R­4900 R­6000 Halogen Free N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. w/o rub S.F. w/rubbing N.V.E. w/o rub, S.F. w/ rubbing N.V.E w/o rubbing, S.F. w/ rubbing Obsolete Acetone SL. Flaking S.F. w/o rubbing Methyl Ethyl Ketone SL. Flaking S.F. w/o rubbing Toluene N.V.E. 1,1,1-­trichloroethane N.V.E. Ethanol N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. Alcoholic Mixture* Diesel Gasfuel (unleaded) N.V.E. N.V.E. N.V.E. Sulfuric Acid (10%) Sodium Hydroxide (10%) Natrium Chloride (10%) Skydrol® 500 B 4 Mineral Oil Motor Oil (Power Ultralub 14W/40) n-­Hexane CHEMICAL REAGENT Water Isopropanol Acetone Methyl Ethyl Ketone Toluene N.V.E. R­7962 N.V.E. N.V.E. w/o rub S.F. w/ rubbing N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. w/o rubbing SL.F. w/ rubbing N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. S.F. w/o rubbing N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. w/o rubbing, S.F. w/rubbing N.V.E. Not Tested N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. N.V.E. N.V.E. N.V.E. Not Tested N.V.E. SUBJECTIVE OBSERVATION OF VISUAL CHANGE EFFECT TO LABEL STOCK R­4900 R­7962 N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. w/o rub S.F. w/ rubbing SL. Flaking S.F. w/o rubbing N.V.E. w/o rubbing S.F. w/ rubbing SL. Flaking S.F. w/o rubbing N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. w/o rubbing N.V.E. N.V.E. w/o rubbing SL.F. w/ rubbing S.F. w/ rubbing 1,1,1-­trichloroethane N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. N.V.E. Ethanol N.V.E. Alcoholic Mixture* Diesel Gasfuel (unleaded) N.V.E. N.V.E. N.V.E. Sulfuric Acid (10%) Sodium Hydroxide (10%) Natrium Chloride (10%) Skydrol® 500 B 4 N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. N.V.E. N.V.E. S.F. w/o rubbing Mineral Oil Motor Oil (Power Ultralub 14W/40) n­-Hexane N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. N.V.E. w/o rubbing S.F. w/ rubbing N.V.E. N.V.E. N.V.E. N.V.E.: No Visible Effect SL.F.: Slight Fading S.F.: Severe Fading w/o: Without rubbing w/: With rubbing * Alcoholic Mixture is a mixture of 50% Methanol, 30% Ethanol and 20% distilled water. Shelf Life: Shelf life is two years from the date of receipt​for this product as long as this product is stored in its original packaging in an environment below 80° F (27° C) and 60% RH. It remains the responsibility of the user to assess the risk of using this product. We encourage customers to develop testing protocols that will qualify a product's fitness for use in their actual application Trademarks: Skydrol® is a registered trademark of the Monsanto Company ASTM: American Society for Testing and Materials (U.S.A.) CSA: Canadian Standards Association Fed. Spec.: United States Federal Specification (U.S.A.) Note: All values shown are averages and should not be used for specification purposes. Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2022 W.H. Brady, N.V. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady Europe | Industriepark C3 Lindestraat 20 | B9240 Zele | Belgium | Tel: +32 52.45.7811 | Fax: +32 52.45.7812
THT-7-7546-3 价格&库存
很抱歉,暂时无法提供与“THT-7-7546-3”相匹配的价格&库存,您可以联系我们找货
THT-7-7546-3
