ABS1 THRU ABS10
1A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER
FEATURES:
PINNING
• Glass Passivated Chip Junction
• Reverse Voltage - 100 to 1000 V
• Forward Current - 1 A
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
• High Surge Current Capability
3
Output Anode(+)
• Designed for Surface Mount Application
4
Output Cathode(-)
MECHANICAL DATA
• Case: ABS/LBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 88mg / 0.0031oz
3
4
2
1
ABS
Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
ABS1
ABS2
ABS4
ABS6
ABS8
ABS10
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
Parameter
Average Rectified Output Current
at T c = 125 °C
IO
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
35
A
Forward Voltage per element
@I F =1.0A
VF
1.1
V
Maximum DC Reverse Current
at Rated DC Blocking Voltage
@ T A =100℃
IR
5
50
100
μA
Cj
13
pF
RθJA
RθJC
72
°C/W
T j , T stg
-55 ~ +150
°C
@ T A =25 °C
@ T A =125 °C
Typical Junction Capacitance(Note1)
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm) copper pad.
www.yongyutai.com
PAGE 1
ABS1 THRU ABS10
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.yongyutai.com
PAGE 2
ABS1 THRU ABS10
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
ABS
∠ALL ROUND
∠ALL ROUND
C
A
a
L1
d
L
HE
e
D
e
E
ABS/LBF mechanical data
A
C
D
E
HE
d
e
max
1.5
0.22
5.2
4.5
6.4
4.2
0.7
min
1.3
0.15
4.9
4.2
6.0
3.8
0.5
max
59
8.7
205
177
252
165
28
min
51
5.9
193
166
236
150
UNIT
mm
L
L1
a
0.95
0.6
0.2
7°
37
mil
24
8
The recommended mounting pad size
6.2
244
4.0
157
1.0
39
2.0
79
www.yongyutai.com
mm
Unit :
(mil)
PAGE 3
很抱歉,暂时无法提供与“ABS10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11114
- 500+0.08662
- 1500+0.07301
- 5000+0.06297
- 25000+0.05584
- 50000+0.05206
