M71C-785-412
M71C-785-412
    BRADY
    M71C-785-412
M71C-785-412 数据手册
Technical Data Sheet BRADY B­412 THERMAL TRANSFER PRINTABLE POLYPROPYLENE TAG STOCK TDS No. B­412 Effective Date: 06/11/2009 Description: GENERAL  Print Technology:  Thermal Transfer Material Type:  Polypropylene Tag Finish:  Matte   APPLICATIONS Wire and cable identification and product inventory identification, where legibility and tensile strength are needed.   RECOMMENDED RIBBONS Brady Series R4300 and Brady Series R6200   REGULATORY B­412 is RoHS compliant to 2005/618/EC MCV amendment to RoHS Directive 2002/95/EC. Details: PHYSICAL PROPERTIES Total Thickness Tensile Strength and Elongation TEST METHODS AVERAGE RESULTS ASTM D 1000 0.0080 inch (0.201 mm) ASTM D 1000   ­Machine direction 45 lbs/inch (788 N/100 mm), 65% Hole Tear Strength Brady LAB F003 * 9 lbs (4.1 kg) Tear Propagation Resistance ASTM D1938   ­Machine direction 1.2 oz (32.7 g) * LAB F003 is a Brady Worldwide, Inc. laboratory test procedure and is available upon request. Performance properties tested on B­412 printed with Series R4300 and R6200 ribbons and a BradyPrinter™ THT Model 203X thermal transfer printer. Results the same for both ribbons unless noted otherwise. PERFORMANCE PROPERTIES High Service Temperature Low Service Temperature Humidity Resistance UV Light Resistance Weatherability TEST METHOD TYPICAL RESULTS 30 days at 100ºC (212ºF) Slight discoloration at 100ºC 30 days at ­40ºC (­40ºF) No visible effect 30 days at 100°F (37°C) and 95% R.H. No visible effect 30 days in UV Sunlighter™ 100 No visible effect ASTM G155, Cycle 1 No visible effect 30 days in Xenon Arc Weatherometer Salt Fog Resistance ASTM B 117 No visible effect 30 days in 5% salt fog solution chamber PERFORMANCE PROPERTY CHEMICAL RESISTANCE Samples printed with Series R4300 and R6200 ribbons. Test was conducted at room temperature except where noted. Testing consisted of 5 cycles of 10 minute immersions in the specified test fluid followed by a 30 minute recovery period. After final immersion, samples rubbed 10 times with cotton swab saturated with test fluid. CHEMICAL REAGENT Methyl Ethyl Ketone 1,1,1­Trichloroethane Toluene Isopropyl Alcohol SUBJECTIVE OBSERVATION OF VISUAL CHANGE LABEL STOCK R4300 R6200 SUBSTRATE No visible effect No visible effect w/o rub, No visible effect w/o rub, slight moderate print smear with rub print removal with rub No visible effect No visible effect w/o rub, slight No visible effect w/o rub, print smear with rub moderate print smear with rub No visible effect No visible effect w/o rub, No visible effect w/o rub, moderate print smear with rub moderate print smear with rub No visible effect No visible effect with or without No visible effect with or without rub rub Mineral Spirits No visible effect JP­8 Jet Fuel No visible effect ASTM #3 Oil Slight discoloration Mil 5606 Oil Slight discoloration Skydrol® 500B­4 No visible effect Super Agitene® No visible effect Deionized Water No visible effect 3% Alconox® Detergent No visible effect 10% Sodium Hydroxide Solution 10% Sulfuric Acid Solution Slight discoloration Northwoods™ Buzz Saw Degreaser Slight discoloration Slight discoloration No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub Slight print bleed w/o rub, complete print removal with rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub No visible effect with or without rub Slight print fade w/o rub, severe print removal with rub No visible effect with or without rub No visible effect with or without rub No visible effect w/o rub, slight print removal with rub No visible effect with or without rub No visible effect with or without rub Slight print bleed w/o rub, complete print removal with rub Product testing, customer feedback, and history of similar products, support a customerperformance expectation of at leasttwo years from the date of receipt for this product as long as this product is stored in its original packaging in an environment below 80 degrees F (27 degrees C) and 60% RH . We are confident that our product will perform well beyond this time frame. However, it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use, in their actual applications.  Trademarks: Alconox® is a registered trademark of Alconox Co. BradyPrinter™ is a trademark of Brady Worldwide, Inc. Northwoods™ is a trademark of the Superior Chemical Corporation. Skydrol® is a registered trademark of the Monsanto Company Sunlighter™ is a trademark of the Test Lab Apparatus Company Super Agitene® is a registered trademark of Graymills Corporation ASTM: American Society for Testing and Materials (U.S.A.) All S.I. Units (metric) are mathematically derived from the U.S. Conventional Units. Note: All values shown are averages and should not be used for specification purposes.  Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414­358­6600 | Fax: 800­292­2289
M71C-785-412 价格&库存
很抱歉,暂时无法提供与“M71C-785-412”相匹配的价格&库存,您可以联系我们找货
