ASPL1117
900mA Bipolar Linear Regulator
Features
Maximum output current is 900mA
Range of operation input voltage: Max 24V
Line regulation: 0.03%/V (typ.)
Standby current: 2mA (typ.)
Load regulation: 0.2%/A (typ.)
Environment Temperature: -20℃~85℃
Application
Power Management for STB, Mother Board,
Graphic Card
LCD Monitor and LCD TV
DVD Decode Board
General Description
ADSL Modem,WLAN
Post Regulators For Switching Supplies
Typical Application
ASPL1117 is a series of low dropout three-terminal
regulators with a dropout of 1.3V at 0.9A load current.
ASPL1117 features a very low standby current 2mA
compared to 5mA of competitor.
Other than a fixed version, Vout = 1.2V, 1.5V, 1.8V,
2.5V, 3.3V and 5.0V, ASPL1117 has an adjustable version,
which can provide an output voltage from 1.25 to 5.0V with
only two external resistors.
ASPL1117 offers thermal shut down and current limit
functions, to assure the stability of chip and power system.
And it uses trimming technique to guarantee output voltage
accuracy within 2%. Other output voltage accuracy can be
customized on demand, such as 1%.ASPL1117 is available
in SOT-223 power package.
Application circuit of ASPL1117 fixed version
Typical Electrical Characteristic
Temperature(℃)
NOV 2018 Version1.1
1/9
Ascend Semicondutor Co.,Ltd
ASPL1117
Block Diagram
Pin Configuration
Absolute Maximum Rating
Parameter
Value
Max Input Voltage
24V
Max Power Dissipation(Pd)
1.0W
Max Output Current
0.9A
Recommended operating junction temperature(Tj)
-20~125℃
Max Operating Junction Temperature(Tj)
150℃
Ambient Temperature(Ta)
-20℃~85℃
Package Thermal Resistance
SOT-223
20℃/W
Storage Temperature(Ts)
-40℃~150℃
Lead Temperature & Time
260℃, 10S
Caution: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect
device reliability.
NOV 2018 Version1.1
2/9
ASPL1117
Electrical Characteristics
Symbol
Parameter
Conditions
Min.
Typ.
Max.
Unit
Vref
Reference
voltage
ASPL1117-ADJ
10mA≤Iout≤0.9A,Vin=3.25V
1.225
1.25
1.275
V
A6PL1117-1.2
0≤Iout≤0.9A , Vin=3.2V
1.176
1.2
1.224
V
ASPL1117-1.5
0≤Iout≤0.9A , Vin=3.5V
1.470
1.5
1.530
V
ASPL1117-1.8
0≤Iout≤0.9A , Vin=3.8V
1.764
1.8
1.836
V
2.45
2.5
2.55
V
3.234
3.3
3.366
V
4.9
5.0
5.1
V
ASPL1117-1.2
Iout=10mA, 2.7V≤Vin≤10V
0.03
0.2
%/V
ASPL1117-ADJ
Iout=10mA,
2.75V≤Vin≤12V
0.03
0.2
%/V
ASPL1117-1.5
Iout=10mA, 3.0V≤Vin≤12V
0.03
0.2
%/V
ASPL1117-1.8
Iout=10mA, 3.3V≤Vin≤12V
0.03
0.2
%/V
ASPL1117-2.5
Iout=10mA, 4.0V≤Vin≤12V
0.03
0.2
%/V
0.03
.2
%/V
0.03
0.2
%/V
2
8
mV
Output
voltage
Vout
ASPL1117-2.5
0≤Iout≤0.9A , Vin=4.5V
ASPL1117-3.3
0≤Iout≤0.9A , Vin=5.3V
ASPL1117-5.0
0≤Iout≤0.9A , Vin=7.0V
ΔVout
Line
Regulation
ASPL1117-3.3L
Iout=10mA, 4.8V≤Vin≤12V
ASPL1117-5.0
Iout=10mA, 6.5V≤Vin≤12V
ASPL1117-1.2
Vin =2.7V, 10mA≤Iout≤0.9A
△Vout
Load
regulation
ASPL1117-ADJ
Vin =2.75V, 10mA≤Iout≤0.9A
ASPL1117-1.5
Vin =3.0V, 10mA≤Iout≤0.9A
ASPL1117-1.8
Vin =3.3V, 10mA≤Iout≤0.9A
2
8
mV
2.5
10
mV
3
12
mV
ASPL1117-2.5
Vin =4.0V, 10mA≤Iout≤0.9A
4
16
mV
6
24
mV
9
36
mV
ASPL1117-3.3
Vin =4.8V, 10mA≤Iout≤0.9A
ASPL1117-5.0
Vin =6.5V, 10mA≤Iout≤0.9A
NOV 2018 Version1.1
3/9
ASPL1117
Vdrop
Dropout voltage
Ilimit
Current limit
Imin
Minimum
load current
Iq
IAdj
PSRR
Quiescent
Current
Adjust pin
current
Ripple
Regulation
Ichange
Iadj change
ΔV/ΔT
Temperature
coefficien
θJC
Thermal
resistance
Iout =100mA
Iout=1A
Vin-Vout=2V;Tj =25℃
1.23
1.3
0.9
1.3
1.5
V
V
A
ASPL1117-ADJ
2
10
mA
ASPL1117-1.2,Vin=10V
2
5
mA
ASPL1117-1.5,Vin=12V
2
5
mA
ASPL1117-1.8,Vin=12V
2
5
mA
ASPL1117-2.5,Vin=12V
2
5
mA
ASPL1117-3.3,Vin=12V
ASPL1117-5.0,Vin=12V
ASPL1117-ADJ
Vin=5V,10mA≤Iout≤1A
2
2
5
5
mA
mA
55
120
uA
0.8
f=100Hz, Cout=104
-65
dB
f=1KHz, Cout=104
-65
dB
f=10KHz, Cout=104
-60
dB
f=22KHz, Cout=104
-57
dB
ASPL1117-ADJ
Vin=5V,10mA≤Iout≤1A
0.2
SOT-223
10
uA
±100
ppm
℃/W
Note1: All test are conducted under ambient temperature 25°Cand within a short period of time 20ms
Note2: Load current smaller than minimum load current of ASPL1117-ADJ will lead to unstable or oscillation
output.
Detailed Description
ASPL1117 is a series of low dropout voltage, three terminal regulators. Its application circuit is very simple:
the fixed version only needs two capacitors and the adjustable version only needs two resistors and two
capacitors to work. It is composed of some modules including start-up circuit, bias circuit, bandgap, thermal
shutdown, current limit, power transistors and its driver circuit and so on.
The thermal shut down modules can assure chip and its application system working safety when the junction
temperature is larger than 140 °C.
The bandgap module provides stable reference voltage, whose temperature coefficient is compensated by
careful design considerations. The temperature coefficient is under 100 ppm/°C. And the accuracy of output
voltage is guaranteed by trimming technique.
NOV 2018 Version1.1
4/9
ASPL1117
Typical Application
ASPL1117 has an adjustable version and six fixed versions (1.2V, 1.5V, 1.8V, 2.5V, 3.3V and 5.0V)
Fixed Output Voltage Version
1) Recommend using 10uF tan capacitor as bypass capacitor (C1) for all application circuit.
2) Recommend using 10uF tan capacitor to assure circuit stability.
Adjustable Output Voltage Version
Application Circuit of ASPL1117-ADJ
The output voltage of adjustable version follows the equation: Vout=1.25×(1+R2/R1)+IAdj×R2. We can ignore
IAdj because IAdj (about 50uA) is much less than the current of R1 (about 2~10mA).
1) To meet the minimum load current (>10mA) requirement, R1 is recommended to be 125ohm or lower. As
ASPL1117-ADJ can keep itself stable at load current about 2mA, R1 is not allowed to be higher than 625ohm.
2) Using a bypass capacitor (CADJ) between the ADJ pin and ground can improve ripple rejection. This
bypass capacitor prevents ripple from being amplified as the output voltage is increased. The impedance of CADJ
should be less than R1 to prevent ripple from being amplified. As R1 is normally in the range of 100Ω~500Ω,
the value of CADJ should satisfy this equation: 1/(2π×fripple×CADJ)
