TOS-3124DMG-9B4
TOS-3124DMG-9B4
    OASISTEK(李洲科技)
    插件
TOS-3124DMG-9B4 数据手册
TOS-3124DMG-9B4 Single Digit Display LED Chip Part Number TOS-3124DMG-9B4 Material Source Color AlGaInP Ultra-Green Face Color Segment Color Black White Features • (0.32”)8.00mm digit height • Common anode • I.C. compatible • Low power requirement • RoHS compliant Applications • Audio equipment • Instrument panels • Digital read out display Package Dimensions & Internal Circuit Diagram Notes: 1. All dimensions are in millimeters, tolerance: ±0.25 ; Angle: ±1° unless otherwise noted. 2. Specifications are subject to change without notice. REV.: A-2 Prepared by F.H.Wu(21458) Released Date:2015/05/20 Doc No : GD1505018 Page 1/2 Absolute Maximum Rating @ Ta=25°C Parameter Maximum Rating Unit Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width) Per Dice 80 mA Power Dissipation Per Dice 75 mW Continuous Forward Current Per Dice 20 mA Recommend Operating Current Per Dice 12 mA Reverse Voltage Per Dice 5 V Operating Temperature Range -25°C to +85°C Storage Temperature Range -30°C to +85°C Lead-Free Solder Temperature(1/16 Inch Below Seating Plane) 260°C for 3 Sec Electrical / Optical Characteristic @ Ta=25°C Parameter Symbol Luminous Intensity Per Segment Iv Dominant Wavelength Unit Test Condition 15524 ucd IF=10mA λd 570 nm IF=20mA Spectral Line Half-Width △λ 15 nm IF=20mA Forward Voltage Per Dice VF 2.3 V IF=20mA Reverse Current Per Dice IR 100 µA VR=5V Iv-m 2.0:1 Luminous Intensity Matching Rate Min. 1.8 Typ. 2.0 Max. Grade IF=20mA The DISPLAYS should be kept at 30°C or less and 60%RH or less. The DISPLAYS should be used within one year. REV.: A-2 Prepared by F.H.Wu(21458) Released Date:2015/05/20 Doc No : GD1505018 Page 2/2
TOS-3124DMG-9B4 价格&库存
很抱歉,暂时无法提供与“TOS-3124DMG-9B4”相匹配的价格&库存,您可以联系我们找货
