www.msksemi.com
MSSR05.TCT
Semiconductor
Compiance
Features
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±15kV
Contact discharge: ±8kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 3A (8/20μs)
RoHS Compliant
Applications
USB 2.0 power and data line
Set-top box and digital TV
Digital video interface (DVI)
Notebook Computers
SIM Ports
10/100 Ethernet
SOT-143
Mechanical Characteristics
Package: SOT-143
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:3,000pcs
Reel Size:7 inch
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
Ppp
VESD
Value
300
±15
±8
Unit
W
Kv
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
www.msksemi.com
MSSR05.TCT
Semiconductor
Compiance
Electrical Characteristics(TA=25°C unless otherwise specified)
P/N
VRWM
(V)
VBR
(V)
IT
(mA)
VC
@1A
5
6
1
9.8
MSSR05.TCT
Vc
(Max)
23
(@A)
3
IR
μA
(Max)
C
(Pf)
(Typ.)
1
1.2
Characteristic Curves
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ sPulse Waveform
tr
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
60
40
td=t IPP/2
10
15
30
90%
10%
tr = 0.7~1ns
Time (ns)
30ns
60ns
t - Time ( s)
Fig3. Power Derating Curve
% of Rated Power
110
100
90
80
70
60
50
40
30
50
75
100
125
150
Ambient Temperature –TA(ºC)
www.msksemi.com
MSSR05.TCT
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
Symbol
θ
Inches
Min.
Millimeters
Nom. Max. Min. Nom. Max.
A
0.031
A1
A2
0.048
0.80
0.000
0.008 0.013
0.020
0.035
0.042
0.75
1.22
0.15
0.90
1.07
b
0.011
0.020
0.30
0.51
b1
0.029
0.037
0.76
0.94
c
0.003
0.008
0.08
0.20
D
0.110
0.114
0.120
2.80
2.90
3.04
E
0.082
0.093
0.104
2.10
2.37
2.64
E1
0.047
0.051
0.055
1.20
1.30
1.40
e
0.075
e1
L
1.92 BSC
0.008
0.015
0.020
0.20 BSC
0.024
0.40
0.50
L1
(0.021)
(0.54)
N
4
4
θ
0°
8°
0°
aaa
0.006
0.15
bbb
0.008
0.20
ccc
0.004
0.10
0.60
8°
REEL SPECIFICATION
P/N
MSSR05.TCT
PKG
SOT-143
QTY
3000
www.msksemi.com
MSSR05.TCT
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“MSSR05.TCT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.49591
- 50+1.22375
- 150+1.10711
- 500+0.96164
- 3000+0.73073
- 6000+0.69174
