SS36BF
SS36BF
    YFW(佑风微)
SS36BF 数据手册
SS32BF THRU SS320BF SMBF Surface Mount Schottky Barrier Rectifier Pinning Reverse Voltage - 20 to 200 V 1.Cathode Forward Current - 3 A         1 FEATURES  Metal silicon junction, majority carrier conduction  For surface mounted applications  Low power loss, high efficiency 2.Anode   2     SMBF  High forward surge current capability Marking Code  For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications SS32BF S32B SS34BF S34B  Lead free in comply with EU RoHS 2011/65/EU directives SS36BF S36B MECHANICAL DATA  Case: SMBF  Terminals: Solderable per MIL-STD-750, Method 2026 SS38BF S38B SS310BF S310B SS312BF S312B SS315BF S315B SS320BF S320B  Approx. Weight: 57mg / 0.002oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS32BF SS34BF SS36BF SS38BF Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method) SS310BF SS312BF SS315BF SS320BF 3.0 IFSM Units A 80 70 A Maximum Instantaneous Forward Voltage at 3 A VF Maximum Instantaneous Reverse Current TA = 25°C at Rated DC Reverse Voltage TA = 100°C IR 0.5 5 0.3 3 mA Typical Junction Capacitance (1) Cj 450 400 pF Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range 0.55 0.70 0.95 0.85 V RθJA 65 °C/W Tj -55 ~ +150 °C Tstg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. SS32BF THRU SS320BF SMBF Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Average Forward Current (A) Fig.1 Forward Current Derating Curve 3.5 3.0 2.4 1.8 1.2 0.6 0.0 25 50 75 100 125 150 10 4 T J =100°C 10 3 T J =75°C 10 2 SS32BF/SS36BF T J =25°C 10 0 0 Case Temperature (°C) 60 100 80 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1.0 SS32BF/SS34BF SS36BF/SS38BF SS310BF/SS312BF SS315BF/SS320BF 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 20 SS32BF~SS36BF SS38BF~SS320BF 10 0.1 10 1 100 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 80 70 60 50 40 8.3 ms Single Half Sine Wave (JEDEC Method) 20 10 100 Number of Cycles at 60Hz www.yfwdiode.com 200 100 1.8 SS32BF-SS38BF SS310BF-SS320BF 1 500 Reverse Voltage (V) 90 30 1000 Instaneous Forward Voltage (V) Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) SS38BF-SS320BF 10 1 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 Dongguan YFW Electronics Co, Ltd. SS32BF THRU SS320BF SMBF SMBF Package Outline Plastic surface mounted package; 2 leads ∠ALL ROUND C A ∠ALL ROUND HE g g pad e E A pad D E A V M Top View A C D E HE e max 1.3 0.26 4.4 3.7 5.5 2.2 min 1.1 0.18 4.2 3.5 5.1 1.9 max 51 10 173 146 216 86 min 43 7 165 138 200 75 UNIT mm mil Bottom View g ∠ 1.0 9° 40 The recommended mounting pad size 3.0(118) 1.8(71) 2.54(100) 1.8(71) Unit:mm(mil) Summary of Packing Options Package SMBF www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 5000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
SS36BF 价格&库存
很抱歉,暂时无法提供与“SS36BF”相匹配的价格&库存,您可以联系我们找货
