SS36F
SS36F
    YFW(佑风微)
SS36F 数据手册
SS32F THRU SS320F SMAF Surface Mount Schottky Barrier Rectifier Pinning Reverse Voltage - 20 to 200 V 1.Cathode Forward Current - 3 A 2.Anode         1 FEATURES  Metal silicon junction, majority carrier conduction  For surface mounted applications  Low power loss, high efficiency   2     SMAF  High forward surge current capability Marking Code  For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications SS32F SS32 SS34F SS34  Lead free in comply with EU RoHS 2011/65/EU directives SS36F SS36 MECHANICAL DATA  Case: SMAF  Terminals: Solderable per MIL-STD-750, Method 2026 SS38F SS38 SS310F SS310 SS312F SS312 SS315F SS315 SS320F SS320  Approx. Weight: 27mg / 0.00095oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS32F SS34F SS36F SS38F SS310F SS312F SS315F SS320F Units Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method) IFSM Maximum Instantaneous Forward Voltage at 3 A VF Maximum Instantaneous Reverse Current TA = 25°C at Rated DC Reverse Voltage TA = 100°C IR Typical Junction Capacitance(1) Cj Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range 3.0 A 80 0.55 70 0.70 0.95 0.85 0.3 3 0.5 5 250 180 A V mA pF RθJA 70 °C/W Tj -55 ~ +150 °C Tstg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. SS32F THRU SS320F SMAF Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Average Forward Current (A) Fig.1 Forward Current Derating Curve 3.5 3.0 2.4 1.8 1.2 0.6 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 10 4 SS32F/SS36F SS38F-SS320F 10 1 T J =25°C 10 0 0 40 20 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1.0 SS32F/SS34F SS34AF/SS38F SS310F/SS312F SS315F/SS320F 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1000 500 200 100 20 SS32F~SS38F SS32F~SS36F SS310F~SS320F SS38F~SS320F 10 1.8 0.1 10 1 100 Instaneous Forward Voltage (V) Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.5- Typical Transient Thermal Impedance Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) T J =75°C 10 2 Case Temperature (°C) Peak Forward Surage Current (A) T J =100°C 10 3 100 SS32F-SS38F SS310F-SS320F 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz www.yfwdiode.com 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 Dongguan YFW Electronics Co, Ltd. SS32F THRU SS320F SMAF SMAF Package Outline Plastic surface mounted package; 2 leads ∠ALL ROUND C A ∠ALL ROUND HE g g pad e E A pad D E A V M Top View A C D E e g HE max 1.1 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 43 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm mil Bottom View ∠ 7° The recommended mounting pad size 1.6 (63) 2.2 (86) 1.8 (71) 1.6 (63) mm Unit : (mil) Summary of Packing Options Package SMAF www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 10000 EIA-481-1 Tape/Reel,7”reel 3000 EIA-481-1 3/3 Dongguan YFW Electronics Co, Ltd.
SS36F 价格&库存
很抱歉,暂时无法提供与“SS36F”相匹配的价格&库存,您可以联系我们找货
